[GRASS-SVN] r57914 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Wed Oct 2 08:27:45 PDT 2013
Author: annakrat
Date: 2013-10-02 08:27:45 -0700 (Wed, 02 Oct 2013)
New Revision: 57914
grass/trunk/lib/python/script/vector.py
pythonlib: v.db.select wrapper: do not add key column when we don't want it
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py 2013-10-02 10:12:45 UTC (rev 57913)
+++ grass/trunk/lib/python/script/vector.py 2013-10-02 15:27:45 UTC (rev 57914)
@@ -239,9 +239,11 @@
{ 'layer' : layer, 'map' : map })
return { 'columns' : [], 'values' : {} }
+ include_key = True
if 'columns' in kwargs:
if key not in kwargs['columns'].split(','):
# add key column if missing
+ include_key = False
debug("Adding key column to the output")
kwargs['columns'] += ',' + key
@@ -260,11 +262,18 @@
if not columns:
columns = line.split('|')
key_index = columns.index(key)
+ # discard key column
+ if not include_key:
+ columns = columns[:-1]
continue
value = line.split('|')
key_value = int(value[key_index])
- values[key_value] = line.split('|')
+ values[key_value] = value[:-1]
+ else:
return { 'columns' : columns,
'values' : values }
