[GRASS-SVN] r57919 - in grass/trunk/gui/wxpython: core gui_core lmgr
svn_grass at osgeo.org
Thu Oct 3 03:56:28 PDT 2013
Author: martinl
Date: 2013-10-03 03:56:28 -0700 (Thu, 03 Oct 2013)
New Revision: 57919
grass/trunk/gui/wxpython/core/gconsole.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: update map for [r|r3].colors modules
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2013-10-03 08:25:39 UTC (rev 57918)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2013-10-03 10:56:28 UTC (rev 57919)
@@ -604,7 +604,8 @@
def OnCmdDone(self, event):
"""!Command done (or aborted)
- Sends signal mapCreated if map is recognized in output parameters.
+ Sends signal mapCreated if map is recognized in output
+ parameters or for specific modules (as r.colors).
# Process results here
try:
@@ -654,10 +655,13 @@
task = None
return
+ name = task.get_name()
for p in task.get_options()['params']:
prompt = p.get('prompt', '')
if prompt in ('raster', 'vector', '3d-raster') and \
- p.get('age', 'old') == 'new' and \
+ (p.get('age', 'old') == 'new' or
+ # TODO: do it better (?)
+ name in ('r.colors', 'r3.colors', 'v.colors')) and \
p.get('value', None):
name = p.get('value')
if '@' not in name:
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-10-03 08:25:39 UTC (rev 57918)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-10-03 10:56:28 UTC (rev 57919)
@@ -648,10 +648,16 @@
wx.FutureCall(2000, self.Close)
def OnMapCreated(self, name, ltype):
+ """!Map created or changed
+ @param name map name
+ @param ltype layer type (prompt value)
if hasattr(self, "addbox") and self.addbox.IsChecked():
add = True
else:
add = False
if self._giface:
self._giface.mapCreated.emit(name=name, ltype=ltype, add=add)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2013-10-03 08:25:39 UTC (rev 57918)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2013-10-03 10:56:28 UTC (rev 57919)
@@ -1750,11 +1750,17 @@
def OnMapCreated(self, name, ltype, add=None):
"""!Decides wheter the map should be added to layer tree."""
if add is None:
+ # add new map into layer if globally enabled
if UserSettings.Get(group = 'cmd',
key = 'addNewLayer', subkey = 'enabled'):
self.AddOrUpdateMap(name, ltype)
elif add:
+ # add new map into layer tree
+ else:
+ # update the map
+ display = self.GetMapDisplay()
+ display.GetWindow().UpdateMap(render = True)
def AddOrUpdateMap(self, mapName, ltype):
"""!Add map layer or update"""
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-03 08:25:39 UTC (rev 57918)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-03 10:56:28 UTC (rev 57919)
@@ -678,8 +678,8 @@
command = 'r3.colors'
else:
command = 'r.colors'
- GUI(parent = self).ParseCommand([command,
- 'map=%s' % name])
+ GUI(parent = self, giface = self._giface).ParseCommand([command,
+ 'map=%s' % name])
def OnVectorColorTable(self, event):
"""!Set color table for vector map"""
