[GRASS-SVN] r57929 - in grass/trunk/gui/wxpython: core lmgr
svn_grass at osgeo.org
Thu Oct 3 16:01:29 PDT 2013
Author: martinl
Date: 2013-10-03 16:01:29 -0700 (Thu, 03 Oct 2013)
New Revision: 57929
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI: store current working directory (if set up) in the workspace file
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2013-10-03 22:17:13 UTC (rev 57928)
+++ grass/trunk/gui/wxpython/core/workspace.py 2013-10-03 23:01:29 UTC (rev 57929)
@@ -36,9 +36,9 @@
# layer manager properties
- self.layerManager = {}
- self.layerManager['pos'] = None # window position
- self.layerManager['size'] = None # window size
+ self.layerManager = { 'pos' : None, # window position
+ 'size' : None, # window size
+ 'cwd' : None } # current working directory
# list of mapdisplays
@@ -100,6 +100,10 @@
self.layerManager['size'] = (posVal[2], posVal[3])
except:
pass
+ # current working directory
+ cwdPath = self.__getNodeText(node_lm, 'cwd')
+ if cwdPath:
+ self.layerManager['cwd'] = cwdPath
# displays
@@ -582,7 +586,11 @@
windowSize[0],
windowSize[1]
+ self.indent += 4
+ cwdPath = self.lmgr.GetCwdPath()
+ if cwdPath:
+ file.write('%s<cwd>%s</cwd>\n' % (' ' * self.indent, cwdPath))
+ self.indent -= 4
file.write('%s</layer_manager>\n' % (' ' * self.indent))
# list of displays
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2013-10-03 22:17:13 UTC (rev 57928)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2013-10-03 23:01:29 UTC (rev 57929)
@@ -94,6 +94,7 @@
self.currentPageNum = None # currently selected page number for layer tree notebook
self.workspaceFile = workspace # workspace file
self.workspaceChanged = False # track changes in workspace
+ self.cwdPath = None # current working directory
wx.Frame.__init__(self, parent = parent, id = id, size = size,
style = style, **kwargs)
@@ -939,12 +940,13 @@
dlg = wx.DirDialog(parent = self, message = _("Choose a working directory"),
defaultPath = os.getcwd(), style = wx.DD_CHANGE_DIR)
- cwd_path = ''
if dlg.ShowModal() == wx.ID_OK:
- cwd_path = dlg.GetPath()
+ self.cwdPath = dlg.GetPath() # is saved in the workspace
- # save path to somewhere ?
+ def GetCwdPath(self):
+ """!Get current working directory or None"""
+ return self.cwdPath
def OnNewVector(self, event):
"""!Create new vector map layer"""
dlg = CreateNewVector(self, giface=self._giface,
@@ -1132,6 +1134,10 @@
self.SetPosition(gxwXml.layerManager['pos'])
if gxwXml.layerManager['size']:
self.SetSize(gxwXml.layerManager['size'])
+ if gxwXml.layerManager['cwd']:
+ self.cwdPath = gxwXml.layerManager['cwd']
+ if os.path.isdir(self.cwdPath):
+ os.chdir(self.cwdPath)
# start map displays first (list of layers can be empty)
