[GRASS-SVN] r57934 - grass/branches/releasebranch_6_4/imagery/i.landsat.toar
svn_grass at osgeo.org
Fri Oct 4 03:37:11 PDT 2013
Author: neteler
Date: 2013-10-04 03:37:11 -0700 (Fri, 04 Oct 2013)
New Revision: 57934
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
i.landsat.toar: standard code indentation
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-10-04 10:35:03 UTC (rev 57933)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-10-04 10:37:11 UTC (rev 57934)
@@ -58,10 +58,10 @@
struct FPRange range;
double min, max;
- /* It initializes GIS environment */
+ /* initialize GIS environment */
G_gisinit(argv[0]);
- /* It initializes module */
+ /* initialize module */
module = G_define_module();
module->description =
_("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI");
@@ -106,7 +106,7 @@
"tm4;Landsat_4 TM;"
"tm5;Landsat_5 TM;"
"tm7;Landsat_7 ETM+;"
- "oli8;Landsat_8 OLI/TIRS");
+ "oli8;Landsat_8 OLI/TIRS");
sensor->required = NO; /* perhaps YES for clarity */
sensor->guisection = _("Metadata");
@@ -232,7 +232,7 @@
rayleigh = atof(atmo->answer);
- * Data from metadata file
+ * Data from metadata file
lsat.flag = NOMETADATAFILE; /* Unnecessary because G_zero filled, but for sanity */
if (met != NULL) {
@@ -306,10 +306,10 @@
if (metho->answer[3] == '2') method = (metho->answer[4] == '\0') ? DOS2 : DOS2b;
- else if (metho->answer[3] == '1') method = DOS1;
- else if (metho->answer[3] == '3') method = DOS3;
- else if (metho->answer[3] == '4') method = DOS4;
- else method = UNCORRECTED;
+ else if (metho->answer[3] == '1') method = DOS1;
+ else if (metho->answer[3] == '3') method = DOS3;
+ else if (metho->answer[3] == '4') method = DOS4;
+ else method = UNCORRECTED;
for (i = 0; i < lsat.bands; i++) {
@@ -402,8 +402,8 @@
* unnecessary or necessary with more checking as acquisition date,...
- * if (strlen(lsat.creation) == 0)
- * G_fatal_error(_("Unknown production date (defined by '%s')"), pdate->key);
+ * if (strlen(lsat.creation) == 0)
+ * G_fatal_error(_("Unknown production date (defined by '%s')"), pdate->key);
if (G_verbose() > G_verbose_std()) {
@@ -524,9 +524,9 @@
qcal = (double)((DCELL *) inrast)[col];
break;
default:
- ptr = NULL;
- qcal = -1.;
- break;
+ ptr = NULL;
+ qcal = -1.;
+ break;
if (G_is_null_value(ptr, in_data_type) ||
qcal < lsat.band[i].qcalmin) {
@@ -568,10 +568,10 @@
- * needed?
+ * needed?
* if (out_type != CELL_TYPE)
* G_quantize_fp_map_range(band_out, G_mapset(), 0., 360., 0,
- * 360);
+ * 360);
/* set grey255 colortable */
