[GRASS-SVN] r57946 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sun Oct 6 05:09:31 PDT 2013
Author: neteler
Date: 2013-10-06 05:09:31 -0700 (Sun, 06 Oct 2013)
New Revision: 57946
grass/trunk/raster/r.in.lidar/local_proto.h
grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: -p Print LAS file info and exit added from v.in.lidar
Modified: grass/trunk/raster/r.in.lidar/local_proto.h
--- grass/trunk/raster/r.in.lidar/local_proto.h 2013-10-06 10:21:30 UTC (rev 57945)
+++ grass/trunk/raster/r.in.lidar/local_proto.h 2013-10-06 12:09:31 UTC (rev 57946)
@@ -41,6 +41,7 @@
#define METHOD_TRIMMEAN 13
/* main.c */
+void print_lasinfo(LASHeaderH, LASSRSH);
int scan_bounds(LASReaderH, int, int, double, struct Cell_head *);
/* support.c */
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2013-10-06 10:21:30 UTC (rev 57945)
+++ grass/trunk/raster/r.in.lidar/main.c 2013-10-06 12:09:31 UTC (rev 57946)
@@ -91,8 +91,6 @@
int main(int argc, char *argv[])
int out_fd;
@@ -142,8 +140,9 @@
struct Option *input_opt, *output_opt, *percent_opt, *type_opt;
struct Option *method_opt, *zrange_opt, *zscale_opt;
struct Option *trim_opt, *pth_opt, *res_opt;
- struct Flag *scan_flag, *shell_style, *over_flag, *extents_flag;
+ struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag;
+ /* LAS */
LASReaderH LAS_reader;
LASHeaderH LAS_header;
LASSRSH LAS_srs;
@@ -162,11 +161,11 @@
G_add_keyword(_("import"));
G_add_keyword(_("LIDAR"));
module->description =
- _("Create a raster map from LAS LiDAR points using univariate statistics.");
+ _("Creates a raster map from LAS LiDAR points using univariate statistics.");
input_opt = G_define_standard_option(G_OPT_F_INPUT);
- input_opt->description =
- _("LiDAR LAS input file");
+ input_opt->label = _("LAS input file");
+ input_opt->description = _("LiDAR input files in LAS format (*.las or *.laz)");
output_opt = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -236,6 +235,12 @@
res_opt->description =
_("Output raster resolution");
+ print_flag = G_define_flag();
+ print_flag->key = 'p';
+ print_flag->description =
+ _("Print LAS file info and exit");
+ print_flag->suppress_required = YES;
extents_flag = G_define_flag();
extents_flag->key = 'e';
extents_flag->description =
@@ -283,6 +288,18 @@
LAS_srs = LASHeader_GetSRS(LAS_header);
+ /* Print LAS header */
+ if (print_flag->answer) {
+ /* print... */
+ print_lasinfo(LAS_header, LAS_srs);
+ LASSRS_Destroy(LAS_srs);
+ LASHeader_Destroy(LAS_header);
+ LASReader_Destroy(LAS_reader);
+ exit(EXIT_SUCCESS);
/* Fetch input map projection in GRASS form. */
proj_info = NULL;
proj_units = NULL;
@@ -1130,8 +1147,75 @@
+void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs)
+ char *las_srs_proj4 = LASSRS_GetProj4(LAS_srs);
+ int las_point_format = LASHeader_GetDataFormatId(LAS_header);
+ fprintf(stdout, "\nUsing LAS Library Version '%s'\n\n",
+ LAS_GetFullVersion());
+ fprintf(stdout, "LAS File Version: %d.%d\n",
+ LASHeader_GetVersionMajor(LAS_header),
+ LASHeader_GetVersionMinor(LAS_header));
+ fprintf(stdout, "System ID: '%s'\n",
+ LASHeader_GetSystemId(LAS_header));
+ fprintf(stdout, "Generating Software: '%s'\n",
+ LASHeader_GetSoftwareId(LAS_header));
+ fprintf(stdout, "File Creation Day/Year: %d/%d\n",
+ LASHeader_GetCreationDOY(LAS_header),
+ LASHeader_GetCreationYear(LAS_header));
+ fprintf(stdout, "Point Data Format: %d\n",
+ las_point_format);
+ fprintf(stdout, "Number of Point Records: %d\n",
+ LASHeader_GetPointRecordsCount(LAS_header));
+ fprintf(stdout, "Number of Points by Return: %d %d %d %d %d\n",
+ LASHeader_GetPointRecordsByReturnCount(LAS_header, 0),
+ LASHeader_GetPointRecordsByReturnCount(LAS_header, 1),
+ LASHeader_GetPointRecordsByReturnCount(LAS_header, 2),
+ LASHeader_GetPointRecordsByReturnCount(LAS_header, 3),
+ LASHeader_GetPointRecordsByReturnCount(LAS_header, 4));
+ fprintf(stdout, "Scale Factor X Y Z: %g %g %g\n",
+ LASHeader_GetScaleX(LAS_header),
+ LASHeader_GetScaleY(LAS_header),
+ LASHeader_GetScaleZ(LAS_header));
+ fprintf(stdout, "Offset X Y Z: %g %g %g\n",
+ LASHeader_GetOffsetX(LAS_header),
+ LASHeader_GetOffsetY(LAS_header),
+ LASHeader_GetOffsetZ(LAS_header));
+ fprintf(stdout, "Min X Y Z: %g %g %g\n",
+ LASHeader_GetMinX(LAS_header),
+ LASHeader_GetMinY(LAS_header),
+ LASHeader_GetMinZ(LAS_header));
+ fprintf(stdout, "Max X Y Z: %g %g %g\n",
+ LASHeader_GetMaxX(LAS_header),
+ LASHeader_GetMaxY(LAS_header),
+ LASHeader_GetMaxZ(LAS_header));
+ if (las_srs_proj4 && strlen(las_srs_proj4) > 0) {
+ fprintf(stdout, "Spatial Reference:\n");
+ fprintf(stdout, "%s\n", las_srs_proj4);
+ else {
+ fprintf(stdout, "Spatial Reference: None\n");
+ fprintf(stdout, "\nData Fields:\n");
+ fprintf(stdout, " 'X'\n 'Y'\n 'Z'\n 'Intensity'\n 'Return Number'\n");
+ fprintf(stdout, " 'Number of Returns'\n 'Scan Direction'\n");
+ fprintf(stdout, " 'Flighline Edge'\n 'Classification'\n 'Scan Angle Rank'\n");
+ fprintf(stdout, " 'User Data'\n 'Point Source ID'\n");
+ if (las_point_format == 1 || las_point_format == 3 || las_point_format == 4 || las_point_format == 5) {
+ fprintf(stdout, " 'GPS Time'\n");
+ if (las_point_format == 2 || las_point_format == 3 || las_point_format == 5) {
+ fprintf(stdout, " 'Red'\n 'Green'\n 'Blue'\n");
+ fprintf(stdout, "\n");
+ fflush(stdout);
+ return;
int scan_bounds(LASReaderH LAS_reader, int shell_style, int extents,
double zscale, struct Cell_head *region)
