[GRASS-SVN] r57953 - grass/trunk/vector/v.voronoi
Mon Oct 7 00:09:12 PDT 2013
Author: mmetz
Date: 2013-10-07 00:09:12 -0700 (Mon, 07 Oct 2013)
New Revision: 57953
Removed:
   grass/trunk/vector/v.voronoi/dt_write.c
   grass/trunk/vector/v.voronoi/sw_output.c
   grass/trunk/vector/v.voronoi/write.h
   grass/trunk/vector/v.voronoi/main.c
   grass/trunk/vector/v.voronoi/sw_defs.h
   grass/trunk/vector/v.voronoi/sw_geometry.c
   grass/trunk/vector/v.voronoi/sw_main.c
   grass/trunk/vector/v.voronoi/sw_voronoi.c
   grass/trunk/vector/v.voronoi/vo_extend.c
   grass/trunk/vector/v.voronoi/vo_write.c
v.voronoi: remove unused functions
Deleted: grass/trunk/vector/v.voronoi/dt_write.c
--- grass/trunk/vector/v.voronoi/dt_write.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/dt_write.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -1,94 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <math.h>
-#include <float.h>
-#include <grass/gis.h>
-#include <grass/vector.h>
-#include <grass/display.h>
-#include "sw_defs.h"
-#include "defs.h"
-#include "write.h"
-int write_triple(struct Site *s1, struct Site *s2, struct Site *s3)
-    int i;
-    int node;
-    static struct line_pnts *Points = NULL;
-    static struct line_cats *Cats = NULL;
-    struct Site *sa, *sb;
-    if (!Points) {
-	Points = Vect_new_line_struct();
-	Cats = Vect_new_cats_struct();
-    if (triangulate) {
-	for (i = 0; i < 3; i++) {
-	    switch (i) {
-	    case 0:
-		sa = s1;
-		sb = s2;
-		break;
-	    case 1:
-		sa = s2;
-		sb = s3;
-		break;
-	    case 2:
-		sa = s3;
-		sb = s1;
-		break;
-	    /* Look if the line already exists */
-	    node =
-		Vect_find_node(&Out, sa->coord.x, sa->coord.y, 0.0, 0.0, 0);
-	    if (node > 0) {	/* node found */
-		int j, nlines;
-		int found = 0;
-		double x, y, z;
-		nlines = Vect_get_node_n_lines(&Out, node);
-		for (j = 0; j < nlines; j++) {
-		    int line, node2;
-		    line = Vect_get_node_line(&Out, node, j);
-		    if (line > 0)
-			Vect_get_line_nodes(&Out, line, NULL, &node2);
-		    else
-			Vect_get_line_nodes(&Out, abs(line), &node2, NULL);
-		    Vect_get_node_coor(&Out, node2, &x, &y, &z);
-		    if (x == sb->coord.x && y == sb->coord.y) {
-			found = 1;
-			break;
-		if (found)
-		    continue;	/* next segment */
-	    /* Not found, write it */
-	    Vect_reset_line(Points);
-	    if (mode3d) {
-		G_debug(3, "sa->coord.z: %f", sa->coord.z);
-		Vect_append_point(Points, sa->coord.x, sa->coord.y,
-				  sa->coord.z);
-		Vect_append_point(Points, sb->coord.x, sb->coord.y,
-				  sb->coord.z);
-	    else {
-		Vect_append_point(Points, sa->coord.x, sa->coord.y, 0.0);
-		Vect_append_point(Points, sb->coord.x, sb->coord.y, 0.0);
-	    Vect_write_line(&Out, Type, Points, Cats);
-    return 0;
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/main.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -197,12 +197,11 @@
     siteidx = 0;
     geominit();
-    triangulate = 0;
     plot = 0;
     debug = 0;
     G_message(_("Processing Voronoi triangulation..."));
-    voronoi(triangulate, nextone);
+    voronoi(nextone);
     /* Close free ends by current region */
     verbose = G_verbose();
Modified: grass/trunk/vector/v.voronoi/sw_defs.h
--- grass/trunk/vector/v.voronoi/sw_defs.h	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/sw_defs.h	2013-10-07 07:09:12 UTC (rev 57953)
@@ -46,7 +46,7 @@
     struct Halfedge *PQnext;
-extern int triangulate, sorted, plot, debug, mode3d;
+extern int sorted, plot, debug, mode3d;
 extern struct Site *sites;
 extern int nsites;
 extern int siteidx;
@@ -111,18 +111,13 @@
 int makefree(struct Freenode *, struct Freelist *);
 char *myalloc(unsigned);
-/* sw_output.c */
-int openpl(void);
-int line(int, int, int, int);
-int circle(int, int, int);
-int range(int, int, int, int);
-int out_bisector(struct Edge *);
-int out_ep(struct Edge *);
-int out_vertex(struct Site *);
-int out_site(struct Site *);
-int out_triple(struct Site *, struct Site *, struct Site *);
-int plotinit(void);
-int clip_line(struct Edge *);
 /* sw_voronoi.c */
-int voronoi(int, struct Site *(*)(void));
+int voronoi(struct Site *(*)(void));
+/* vo_extend.c */
+int extend_line(double, double, double, double, double, double, double,
+		double, double, double *, double *, int);
+/* vo_write.c */
+int write_ep(struct Edge *);
Modified: grass/trunk/vector/v.voronoi/sw_geometry.c
--- grass/trunk/vector/v.voronoi/sw_geometry.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/sw_geometry.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -61,7 +61,6 @@
     newedge->edgenbr = nedges;
-    out_bisector(newedge);
     nedges++;
     return (newedge);
@@ -196,7 +195,7 @@
     ref(s);
     if (e->ep[re - lr] == (struct Site *)NULL)
 	return -1;
-    out_ep(e);
+    write_ep(e);
     deref(e->reg[le]);
     deref(e->reg[re]);
     makefree((struct Freenode *)e, &efl);
@@ -217,7 +216,6 @@
     v->sitenbr = -1;
     nvertices++;
-    out_vertex(v);
     return 0;
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/sw_main.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -8,7 +8,7 @@
 #include "defs.h"
-int triangulate, sorted, plot, debug, mode3d;
+int sorted, plot, debug, mode3d;
 struct Site *sites;
 int nsites;
 int siteidx;
Deleted: grass/trunk/vector/v.voronoi/sw_output.c
--- grass/trunk/vector/v.voronoi/sw_output.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/sw_output.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -1,213 +0,0 @@
-#include <stdio.h>
-#include <math.h>
-#include <float.h>
-#include "write.h"
-int openpl(void)
-    return 0;
-int line(int a, int b, int c, int d)
-    return 0;
-int circle(int a, int b, int c)
-    return 0;
-int range(int a, int b, int c, int d)
-    return 0;
-double pxmin, pxmax, pymin, pymax, cradius;
-int out_bisector(struct Edge *e)
-    if (triangulate & plot & !debug) {
-	line(e->reg[0]->coord.x, e->reg[0]->coord.y, e->reg[1]->coord.x,
-	     e->reg[1]->coord.y);
-       if(!triangulate & !plot &!debug) {
-       fprintf (stdout,"l %.*g %.*g %.*g \n", DBL_DIG, e->a, DBL_DIG, e->b, DBL_DIG, e->c);
-       if(debug) {
-       fprintf (stdout,"line(%d) %gx+%gy=%g, bisecting %d %d\n", e->edgenbr,
-       e->a, e->b, e->c, e->reg[le]->sitenbr, e->reg[re]->sitenbr);
-    return 0;
-int out_ep(struct Edge *e)
-    if ((!triangulate) & plot)
-	clip_line(e);
-    if ((!triangulate) & !plot) {
-	   fprintf (stdout,"e %d", e->edgenbr);
-	   fprintf (stdout," %d ", e->ep[le] != (struct Site *)NULL ? e->ep[le]->sitenbr : -1);
-	   fprintf (stdout,"%d\n", e->ep[re] != (struct Site *)NULL ? e->ep[re]->sitenbr : -1);
-	write_ep(e);
-    return 0;
-int out_vertex(struct Site *v)
-       fprintf (stdout,"v %.*g %.*g\n", DBL_DIG, v->coord.x, DBL_DIG, v->coord.y);
-       if(debug)
-       fprintf (stdout,"vertex(%d) at %f %f\n", v->sitenbr, v->coord.x, v->coord.y);
-    return 0;
-int out_site(struct Site *s)
-    if ((!triangulate) & plot & (!debug))
-	circle(s->coord.x, s->coord.y, cradius);
-       if(!triangulate & !plot & !debug)
-       fprintf (stdout,"s %f %f\n", s->coord.x, s->coord.y);
-       if(debug)
-       fprintf (stdout,"site (%d) at %f %f\n", s->sitenbr, s->coord.x, s->coord.y);
-    return 0;
-int out_triple(struct Site *s1, struct Site *s2, struct Site *s3)
-    if (triangulate & !plot & !debug) {
-	/* fprintf (stdout,"%d %d %d\n", s1->sitenbr, s2->sitenbr, s3->sitenbr); */
-	write_triple(s1, s2, s3);
-       if(debug)
-       fprintf (stdout,"circle through left=%d right=%d bottom=%d\n",
-       s1->sitenbr, s2->sitenbr, s3->sitenbr);
-    return 0;
-int plotinit(void)
-    double dx, dy, d;
-    dy = ymax - ymin;
-    dx = xmax - xmin;
-    d = (dx > dy ? dx : dy) * 1.1;
-    pxmin = xmin - (d - dx) / 2.0;
-    pxmax = xmax + (d - dx) / 2.0;
-    pymin = ymin - (d - dy) / 2.0;
-    pymax = ymax + (d - dy) / 2.0;
-    cradius = (pxmax - pxmin) / 350.0;
-    openpl();
-    range(pxmin, pymin, pxmax, pymax);
-    return 0;
-int clip_line(struct Edge *e)
-    struct Site *s1, *s2;
-    double x1, x2, y1, y2;
-    if (e->a == 1.0 && e->b >= 0.0) {
-	s1 = e->ep[1];
-	s2 = e->ep[0];
-    else {
-	s1 = e->ep[0];
-	s2 = e->ep[1];
-    if (e->a == 1.0) {
-	y1 = pymin;
-	if (s1 != (struct Site *)NULL && s1->coord.y > pymin)
-	    y1 = s1->coord.y;
-	if (y1 > pymax)
-	    return -1;
-	x1 = e->c - e->b * y1;
-	y2 = pymax;
-	if (s2 != (struct Site *)NULL && s2->coord.y < pymax)
-	    y2 = s2->coord.y;
-	if (y2 < pymin)
-	    return (0);
-	x2 = e->c - e->b * y2;
-	if (((x1 > pxmax) & (x2 > pxmax)) | ((x1 < pxmin) & (x2 < pxmin)))
-	    return -1;
-	if (x1 > pxmax) {
-	    x1 = pxmax;
-	    y1 = (e->c - x1) / e->b;
-	if (x1 < pxmin) {
-	    x1 = pxmin;
-	if (x2 > pxmax) {
-	    x2 = pxmax;
-	    y2 = (e->c - x2) / e->b;
-	if (x2 < pxmin) {
-	    x2 = pxmin;
-    else {
-	x1 = pxmin;
-	if (s1 != (struct Site *)NULL && s1->coord.x > pxmin)
-	    x1 = s1->coord.x;
-	if (x1 > pxmax)
-	    return (0);
-	y1 = e->c - e->a * x1;
-	x2 = pxmax;
-	if (s2 != (struct Site *)NULL && s2->coord.x < pxmax)
-	    x2 = s2->coord.x;
-	if (x2 < pxmin)
-	    return (0);
-	y2 = e->c - e->a * x2;
-	if (((y1 > pymax) & (y2 > pymax)) | ((y1 < pymin) & (y2 < pymin)))
-	    return 0;
-	if (y1 > pymax) {
-	    y1 = pymax;
-	    x1 = (e->c - y1) / e->a;
-	if (y1 < pymin) {
-	    y1 = pymin;
-	if (y2 > pymax) {
-	    y2 = pymax;
-	    x2 = (e->c - y2) / e->a;
-	if (y2 < pymin) {
-	    y2 = pymin;
-    line(x1, y1, x2, y2);
-    return 0;
Modified: grass/trunk/vector/v.voronoi/sw_voronoi.c
--- grass/trunk/vector/v.voronoi/sw_voronoi.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/sw_voronoi.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -6,7 +6,7 @@
    Performance suffers if they are wrong; better to make nsites,
    deltax, and deltay too big than too small.  (?) */
-int voronoi(int triangulate, struct Site *(*nextsite) (void))
+int voronoi(struct Site *(*nextsite) (void))
     struct Site *newsite, *bot, *top, *temp, *p;
     struct Site *v;
@@ -17,7 +17,6 @@
     PQinitialize();
     bottomsite = (*nextsite) ();
-    out_site(bottomsite);
     ELinitialize();
     newsite = (*nextsite) ();
@@ -30,7 +29,6 @@
 	    (newsite->coord.y == newintstar.y &&
 	    newsite->coord.x < newintstar.x))) {	/* new site is smallest */
-	    out_site(newsite);
 	    lbnd = ELleftbnd(&(newsite->coord));
 	    rbnd = ELright(lbnd);
 	    bot = rightreg(lbnd);
@@ -65,7 +63,6 @@
 	    rrbnd = ELright(rbnd);
 	    bot = leftreg(lbnd);
 	    top = rightreg(rbnd);
-	    out_triple(bot, top, rightreg(lbnd));
 	    v = lbnd->vertex;
 	    makevertex(v);
@@ -100,7 +97,7 @@
     for (lbnd = ELright(ELleftend); lbnd != ELrightend; lbnd = ELright(lbnd)) {
 	e = lbnd->ELedge;
-	out_ep(e);
+	write_ep(e);
     /* TODO: free memory */
Modified: grass/trunk/vector/v.voronoi/vo_extend.c
--- grass/trunk/vector/v.voronoi/vo_extend.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/vo_extend.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -3,7 +3,6 @@
 #include "defs.h"
-#include "write.h"
 /*-extend_line()  finds coordinates along the boundary of a window
  *                  that also lie on a specified line (ax+by=c). The
@@ -34,14 +33,14 @@
     double nx, ny;		/* intersection coordinates */
     if (x >= w && x <= e && y >= s && y <= n) {
-	/* vertical line? */
+	/* horizontal line? */
 	if (a == 0) {
 	    *c_x = knownPointAtLeft ? e : w;
 	    *c_y =  y;
 	    return 1;
-	/* horizontal line? */
+	/* vertical line? */
 	if (b == 0) {
 	    *c_x = x;
 	    *c_y = knownPointAtLeft ? s : n;
Modified: grass/trunk/vector/v.voronoi/vo_write.c
--- grass/trunk/vector/v.voronoi/vo_write.c	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/vo_write.c	2013-10-07 07:09:12 UTC (rev 57953)
@@ -6,34 +6,72 @@
 #include "defs.h"
-#include "write.h"
 int write_ep(struct Edge *e)
+    double x1, y1, x2, y2;
     if (!Points) {
-    if (!triangulate) {
-	double x1, y1, x2, y2;
-	if (in_area && e->reg[le]->sitenbr == e->reg[re]->sitenbr)
+    if (in_area && e->reg[le]->sitenbr == e->reg[re]->sitenbr)
+	return 0;
+    if (e->ep[le] != NULL && e->ep[re] != NULL) {	/* both end defined */
+	x1 = e->ep[le]->coord.x;
+	y1 = e->ep[le]->coord.y;
+	x2 = e->ep[re]->coord.x;
+	y2 = e->ep[re]->coord.y;
+	if (!Vect_point_in_box(x1, y1, 0.0, &Box) ||
+	    !Vect_point_in_box(x2, y2, 0.0, &Box)) {
+	    Vect_box_clip(&x1, &y1, &x2, &y2, &Box);
+	/* Don't write zero length */
+	if (x1 == x2 && y1 == y2)
 	    return 0;
-	if (e->ep[le] != NULL && e->ep[re] != NULL) {	/* both end defined */
+	Vect_reset_line(Points);
+	Vect_append_point(Points, x1, y1, 0.0);
+	Vect_append_point(Points, x2, y2, 0.0);
+	Vect_write_line(&Out, Type, Points, Cats);
+    else {
+	int knownPointAtLeft = -1;
+	if (e->ep[le] != NULL) {
-	    x2 = e->ep[re]->coord.x;
-	    y2 = e->ep[re]->coord.y;
+	    knownPointAtLeft = 1;
+	else if (e->ep[re] != NULL) {
+	    x1 = e->ep[re]->coord.x;
+	    y1 = e->ep[re]->coord.y;
+	    knownPointAtLeft = 0;
-	    if (!Vect_point_in_box(x1, y1, 0.0, &Box) ||
-		!Vect_point_in_box(x2, y2, 0.0, &Box)) {
-		Vect_box_clip(&x1, &y1, &x2, &y2, &Box);
+	if (knownPointAtLeft == -1) {
+	    x2 = (e->reg[le]->coord.x + e->reg[re]->coord.x) / 2.0;
+	    y2 = (e->reg[le]->coord.y + e->reg[re]->coord.y) / 2.0;
+	    if (!extend_line(Box.S, Box.N, Box.W, Box.E,
+			     e->a, e->b, e->c, x2, y2, &x1, &y1,
+			     knownPointAtLeft)) {
+		G_warning("Undefined edge, unable to extend line");
+		return 0;
+	if (extend_line(Box.S, Box.N, Box.W, Box.E,
+			e->a, e->b, e->c, x1, y1, &x2, &y2,
@@ -44,48 +82,6 @@
-	else {
-	    int knownPointAtLeft = -1;
-	    if (e->ep[le] != NULL) {
-		x1 = e->ep[le]->coord.x;
-		y1 = e->ep[le]->coord.y;
-		knownPointAtLeft = 1;
-	    else if (e->ep[re] != NULL) {
-		x1 = e->ep[re]->coord.x;
-		y1 = e->ep[re]->coord.y;
-		knownPointAtLeft = 0;
-	    if (knownPointAtLeft == -1) {
-		x2 = (e->reg[le]->coord.x + e->reg[re]->coord.x) / 2.0;
-		y2 = (e->reg[le]->coord.y + e->reg[re]->coord.y) / 2.0;
-		if (!extend_line(Box.S, Box.N, Box.W, Box.E,
-				 e->a, e->b, e->c, x2, y2, &x1, &y1,
-				 knownPointAtLeft)) {
-		    G_warning("Undefined edge, unable to extend line");
-		    return 0;
-	    if (extend_line(Box.S, Box.N, Box.W, Box.E,
-			    e->a, e->b, e->c, x1, y1, &x2, &y2,
-		/* Don't write zero length */
-		if (x1 == x2 && y1 == y2)
-		    return 0;
-		Vect_append_point(Points, x1, y1, 0.0);
-		Vect_append_point(Points, x2, y2, 0.0);
     return 0;
Deleted: grass/trunk/vector/v.voronoi/write.h
--- grass/trunk/vector/v.voronoi/write.h	2013-10-07 06:27:42 UTC (rev 57952)
+++ grass/trunk/vector/v.voronoi/write.h	2013-10-07 07:09:12 UTC (rev 57953)
@@ -1,7 +0,0 @@
-/* vo_extend.c */
-int extend_line(double, double, double, double, double, double, double,
-		double, double, double *, double *, int);
-int write_ep(struct Edge *);
-int write_triple(struct Site *, struct Site *, struct Site *);
