[GRASS-SVN] r57961 - grass/trunk/temporal/t.vect.observe.strds
svn_grass at osgeo.org
Wed Oct 9 00:40:06 PDT 2013
Author: huhabla
Date: 2013-10-09 00:40:05 -0700 (Wed, 09 Oct 2013)
New Revision: 57961
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
Cosmetics
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2013-10-09 06:52:41 UTC (rev 57960)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2013-10-09 07:40:05 UTC (rev 57961)
@@ -2,7 +2,7 @@
# -*- coding: utf-8 -*-
-# MODULE: t.vect.oberve.rast
+# MODULE: t.vect.observe.strds
# AUTHOR(S): Soeren Gebbert
# PURPOSE: Observe specific locations in a space time raster dataset over a period of time using vector points
@@ -99,7 +99,7 @@
if not rows:
dbif.close()
- grass.fatal(_("Space time vector dataset <%s> is empty") %
+ grass.fatal(_("Space time raster dataset <%s> is empty") %
out_sp.get_id())
num_rows = len(rows)
@@ -126,7 +126,6 @@
else:
layers += ",%i" % (layer)
- # Use the name of the space time vector dataset as new vector name
vectmap = vector_output
# We create a new vector map using the categories of the original map
