[GRASS-SVN] r57993 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Mon Oct 14 02:05:51 PDT 2013
Author: martinl
Date: 2013-10-14 02:05:51 -0700 (Mon, 14 Oct 2013)
New Revision: 57993
grass/trunk/gui/wxpython/gui_core/widgets.py
wxGUI: fix on search module widget (zero-length string to reset)
sort commands in the choice widget (modeler)
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2013-10-14 08:45:26 UTC (rev 57992)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2013-10-14 09:05:51 UTC (rev 57993)
@@ -860,9 +860,13 @@
"""!Search module by keywords or description"""
value = self._search.GetValue()
if len(value) <= 2:
- self.showNotification.emit(message=_("Searching, please type more characters."))
- return
- commands = self._searchModule(keys=self._searchKeys, value=value)
+ if len(value) == 0: # reset
+ commands = self._searchModule(keys=['command'], value='')
+ else:
+ self.showNotification.emit(message=_("Searching, please type more characters."))
+ return
+ else:
+ commands = self._searchModule(keys=self._searchKeys, value=value)
if self._showChoice:
self._searchChoice.SetItems(commands)
if commands:
@@ -877,16 +881,24 @@
event.Skip()
def _searchModule(self, keys, value):
+ """!Search modules by keys
+ @param keys list of keys
+ @param value patter to match
nodes = set()
for key in keys:
nodes.update(self._model.SearchNodes(key=key, value=value))
nodes = list(nodes)
nodes.sort(key=lambda node: self._model.GetIndexOfNode(node))
self._results = nodes
self._resultIndex = -1
- return [node.data['command'] for node in nodes if node.data['command']]
+ commands = [node.data['command'] for node in nodes if node.data['command']]
+ commands.sort() # return sorted list of commands (TODO: sort in better way)
+ return commands
def OnSelectModule(self, event):
"""!Module selected from choice, update command prompt"""
cmd = self._searchChoice.GetStringSelection()
