[GRASS-SVN] r58000 - grass/trunk/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Tue Oct 15 02:52:01 PDT 2013
Author: zarch
Date: 2013-10-15 02:52:01 -0700 (Tue, 15 Oct 2013)
New Revision: 58000
grass/trunk/lib/python/pygrass/modules/grid/grid.py
grass/trunk/lib/python/pygrass/modules/grid/patch.py
Improve isolations between mapsets when copy data, remove temporary GISRC, add support for groups and vectors as input, copy them to the temporary mapset if needed
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-10-14 17:43:45 UTC (rev 57999)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-10-15 09:52:01 UTC (rev 58000)
@@ -17,7 +17,7 @@
from grass.pygrass.functions import get_mapset_raster
from split import split_region_tiles
-from patch import patch_map
+from patch import rpatch_map
def select(parms, ptype):
@@ -62,13 +62,44 @@
return Mapset(mapset.name, location, gisdbase)
-def copy_raster(rasters, src, dst, region=None, gisrc_dst=None):
- """Copy raster from one mapset to another, crop the raster to the region.
+def copy_groups(groups, src, dst, gisrc_dst=None, region=None):
+ """Copy groupd from one mapset to another, crop the raster to the region.
+ env = os.environ.copy()
# set region
if region:
region.set_current()
+ # instantiate modules
+ get_grp = Module('i.group', flags='lg', stdout_=sub.PIPE, run_=False)
+ set_grp = Module('i.group')
+ get_grp.run_ = True
+ # get and set GISRC
+ gisrc_src = env['GISRC']
+ gisrc_dst = gisrc_dst if gisrc_dst else write_gisrc(dst.gisdbase,
+ dst.location,
+ dst.name)
+ for grp in groups:
+ # change gisdbase to src
+ env['GISRC'] = gisrc_src
+ get_grp(group=grp, env_=env)
+ rasts = get_grp.outputs.stdout.split()
+ # change gisdbase to dst
+ env['GISRC'] = gisrc_dst
+ set_grp(group=grp, input=rasts, env_=env)
+ return gisrc_src, gisrc_dst
+def copy_rasters(rasters, src, dst, gisrc_dst=None, region=None):
+ """Copy rasters from one mapset to another, crop the raster to the region.
+ # set region
+ if region:
+ region.set_current()
nam = "copy%d__%s" % (id(dst), '%s')
expr = "%s=%s"
@@ -79,7 +110,7 @@
rm = Module('g.remove')
# get and set GISRC
- gisrc_src = os.environ['GISRC']
dst.location,
dst.name)
@@ -87,21 +118,55 @@
pdst = dst.path()
for rast in rasters:
- os.environ['GISRC'] = gisrc_src
- src.current()
name = nam % rast
- mpclc(expression=expr % (name, rast), overwrite=True)
+ mpclc(expression=expr % (name, rast), overwrite=True, env_=env)
file_dst = "%s.pack" % os.path.join(pdst, name)
- rpck(input=name, output=file_dst, overwrite=True)
- rm(rast=name)
+ rpck(input=name, output=file_dst, overwrite=True, env_=env)
+ rm(rast=name, env_=env)
- os.environ['GISRC'] = gisrc_dst
- dst.current()
- rupck(input=file_dst, output=rast, overwrite=True)
+ rupck(input=file_dst, output=rast, overwrite=True, env_=env)
os.remove(file_dst)
+def copy_vectors(vectors, src, dst, gisrc_dst=None, region=None):
+ """Copy vectors from one mapset to another, crop the raster to the region.
+ # set region
+ if region:
+ nam = "copy%d__%s" % (id(dst), '%s')
+ vpck = Module('v.pack')
+ vupck = Module('v.unpack')
+ rm = Module('g.remove')
+ dst.location,
+ dst.name)
+ pdst = dst.path()
+ for vect in vectors:
+ name = nam % vect
+ file_dst = "%s.pack" % os.path.join(pdst, name)
+ vpck(input=name, output=file_dst, overwrite=True, env_=env)
+ rm(vect=name, env_=env)
+ vupck(input=file_dst, output=vect, overwrite=True, env_=env)
+ os.remove(file_dst)
def get_cmd(cmdd):
"""Transforma a cmd dictionary to a list of parameters"""
cmd = [cmdd['name'], ]
@@ -123,7 +188,7 @@
def cmd_exe(args):
"""Create a mapset, and execute a cmd inside."""
- bbox, mapnames, msetname, cmd = args
+ bbox, mapnames, msetname, cmd, groups = args
mset = Mapset()
try:
make_mapset(msetname)
@@ -147,8 +212,12 @@
lcmd = ['g.region', ]
lcmd.extend(["%s=%s" % (k, v) for k, v in bbox.iteritems()])
sub.Popen(lcmd, env=env).wait()
+ if groups:
+ src, dst = copy_groups(groups, mset, ms, env['GISRC'])
# run the grass command
sub.Popen(get_cmd(cmd), env=env).wait()
+ # remove temp GISRC
+ os.remove(env['GISRC'])
class GridModule(object):
@@ -165,7 +234,7 @@
Height of the tile, in pixel.
overlap: integer
Overlap between tiles, in pixel.
- nthreads: number of threads
+ processes: number of threads
Default value is equal to the number of processor available.
split: boolean
If True use r.tile to split all the inputs.
@@ -204,13 +273,17 @@
self.n_mset = None
self.gisrc_src = self.gisrc_dst = None
self.log = log
- if move:
- self.n_mset = copy_mapset(self.mset, move)
+ self.move = move
+ if self.move:
+ self.n_mset = copy_mapset(self.mset, self.move)
rasters = select(self.module.inputs, 'raster')
- self.gisrc_src, self.gisrc_dst = copy_raster(rasters,
- self.mset,
- self.n_mset,
- region=self.region)
+ self.gisrc_src, self.gisrc_dst = copy_rasters(rasters,
+ self.mset,
+ self.n_mset,
+ region=self.region)
+ vectors = select(self.module.inputs, 'vector')
+ copy_vectors(vectors, self.mset, self.n_mset,
+ gisrc_dst=self.gisrc_dst, region=self.region)
self.bboxes = split_region_tiles(region=region,
width=width, height=height,
@@ -221,9 +294,10 @@
self.split()
self.debug = debug
- def clean_location(self):
+ def clean_location(self, location=None):
"""Remove all created mapsets."""
- mapsets = Location().mapsets(self.msetstr.split('_')[0] + '_*')
+ location = location if location else Location()
+ mapsets = location.mapsets(self.msetstr.split('_')[0] + '_*')
for mset in mapsets:
Mapset(mset).delete()
@@ -245,6 +319,7 @@
works = []
reg = Region()
cmd = self.module.get_dict()
+ groups = [g for g in select(self.module.inputs, 'group')]
for row, box_row in enumerate(self.bboxes):
for col, box in enumerate(box_row):
inms = None
@@ -262,7 +337,7 @@
works.append((bbox, inms,
self.msetstr % (self.start_row + row,
self.start_col + col),
- cmd))
+ cmd, groups))
return works
def define_mapset_inputs(self):
@@ -288,15 +363,17 @@
if not result.successful():
raise RuntimeError
+ self.mset.current()
if patch:
self.patch()
if self.n_mset is not None:
- # move the outputs to the original mapset
- outputs = [self.out_prefix + o
- for o in select(self.module.outputs, 'raster')]
- copy_raster(outputs, self.n_mset, self.mset, self.region,
- self.gisrc_src)
+ # move the raster outputs to the original mapset
+ routputs = [self.out_prefix + o
+ for o in select(self.module.outputs, 'raster')]
+ copy_rasters(routputs, self.n_mset, self.mset,
+ self.gisrc_src, self.region)
if self.log:
# record in the temp directory
@@ -314,21 +391,29 @@
fp.close()
if clean:
self.clean_location()
self.rm_tiles()
+ if self.n_mset:
+ gisdbase, location = os.path.split(self.move)
+ self.clean_location(Location(location, gisdbase))
+ # rm temporary gis_rc
+ os.remove(self.gisrc_dst)
+ self.gisrc_dst = None
+ sht.rmtree(os.path.join(self.move, 'PERMANENT'))
+ sht.rmtree(os.path.join(self.move, self.mset.name))
def patch(self):
"""Patch the final results."""
# patch all the outputs
+ bboxes = split_region_tiles(width=self.width, height=self.height)
for otmap in self.module.outputs:
otm = self.module.outputs[otmap]
if otm.typedesc == 'raster' and otm.value:
- patch_map(otm.value,
- self.mset.name, self.msetstr,
- split_region_tiles(width=self.width,
- height=self.height),
- self.module.flags.overwrite,
- self.start_row, self.start_col, self.out_prefix)
+ rpatch_map(otm.value,
+ self.mset.name, self.msetstr, bboxes,
+ self.module.flags.overwrite,
+ self.start_row, self.start_col, self.out_prefix)
def rm_tiles(self):
"""Remove all the tiles."""
Modified: grass/trunk/lib/python/pygrass/modules/grid/patch.py
--- grass/trunk/lib/python/pygrass/modules/grid/patch.py 2013-10-14 17:43:45 UTC (rev 57999)
+++ grass/trunk/lib/python/pygrass/modules/grid/patch.py 2013-10-15 09:52:01 UTC (rev 58000)
@@ -22,7 +22,7 @@
return ss_list
-def patch_row(rast, rasts, bboxes):
+def rpatch_row(rast, rasts, bboxes):
"""Patch a row of bound boxes."""
sei = get_start_end_index(bboxes)
# instantiate two buffer
@@ -37,8 +37,8 @@
rast.put_row(rbuff)
-def patch_map(raster, mapset, mset_str, bbox_list, overwrite=False,
- start_row=0, start_col=0, prefix=''):
+def rpatch_map(raster, mapset, mset_str, bbox_list, overwrite=False,
+ start_row=0, start_col=0, prefix=''):
"""Patch raster using a bounding box list to trim the raster."""
# Instantiate the RasterRow input objects
rast = RasterRow(prefix + raster, mapset)
@@ -55,10 +55,9 @@
start_col + col)))
rrasts[-1].open('r')
rasts.append(rrasts)
- patch_row(rast, rrasts, rbbox)
+ rpatch_row(rast, rrasts, rbbox)
for rrast in rasts:
for rast_ in rrast:
rast_.close()
rast.close()
