[GRASS-SVN] r58018 - in grass/trunk/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Wed Oct 16 11:57:51 PDT 2013
Author: martinl
Date: 2013-10-16 11:57:51 -0700 (Wed, 16 Oct 2013)
New Revision: 58018
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: add 'make a copy' item to the map layer contextual menu
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-10-16 16:35:31 UTC (rev 58017)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-10-16 18:57:51 UTC (rev 58018)
@@ -2512,9 +2512,9 @@
It differs from wx.TextEntryDialog because it allows adding validator.
def __init__(self, parent, message, caption='',
- defaultValue='', pos=wx.DefaultPosition, validator=wx.DefaultValidator,
- style=wx.OK | wx.CANCEL):
- wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=caption, pos=pos)
+ defaultValue='', validator=wx.DefaultValidator,
+ style=wx.OK | wx.CANCEL, **kwargs):
+ wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=caption, **kwargs)
vbox = wx.BoxSizer(wx.VERTICAL)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-16 16:35:31 UTC (rev 58017)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-16 18:57:51 UTC (rev 58018)
@@ -32,7 +32,7 @@
from grass.script import vector as gvector
from core import globalvar
-from gui_core.dialogs import SqlQueryFrame, SetOpacityDialog
+from gui_core.dialogs import SqlQueryFrame, SetOpacityDialog, TextEntryDialog
from gui_core.forms import GUI
from mapdisp.frame import MapFrame
from core.render import Map
@@ -42,13 +42,13 @@
from core.debug import Debug
from core.settings import UserSettings, GetDisplayVectSettings
from vdigit.main import haveVDigit
-from core.gcmd import GWarning, GError
+from core.gcmd import GWarning, GError, RunCommand
from gui_core.toolbars import BaseIcons
from icons.icon import MetaIcon
from web_services.dialogs import SaveWMSLayerDialog
+from gui_core.widgets import GenericValidator
from lmgr.giface import LayerManagerGrassInterfaceForMapDisplay
TREE_ITEM_HEIGHT = 25
LMIcons = {
@@ -404,9 +404,12 @@
for key in ('remove', 'rename', 'opacity', 'nviz', 'zoom',
'region', 'export', 'attr', 'edit0', 'edit1', 'save_ws',
'bgmap', 'topo', 'meta', 'null', 'zoom1', 'region1',
- 'color', 'hist', 'univar', 'prof', 'properties', 'sql'):
+ 'color', 'hist', 'univar', 'prof', 'properties', 'sql', 'copy'):
self.popupID[key] = wx.NewId()
+ # get current mapset
+ currentMapset = grass.gisenv()['MAPSET']
self.popupMenu = wx.Menu()
numSelected = len(self.GetSelections())
@@ -463,6 +466,11 @@
'input=%s' % mapLayer.GetName()]),
id = self.popupID['export'])
+ lmapset = self.GetLayerInfo(self.layer_selected, key = 'maplayer').GetMapset()
+ if lmapset != currentMapset:
+ self.popupMenu.Append(self.popupID['copy'], text = _("Make a copy in the current mapset"))
+ self.Bind(wx.EVT_MENU, self.OnCopyMap, id = self.popupID['copy'])
self.popupMenu.AppendSeparator()
self.popupMenu.Append(self.popupID['color'], _("Set color table"))
@@ -506,7 +514,7 @@
self.popupMenu.Append(self.popupID['sql'], text = _("SQL Spatial Query"))
self.Bind(wx.EVT_MENU, self.OnSqlQuery, id = self.popupID['sql'])
- if layer.GetMapset() != grass.gisenv()['MAPSET']:
+ if layer.GetMapset() != currentMapset:
# only vector map in current mapset can be edited
self.popupMenu.Enable (self.popupID['edit0'], False)
self.popupMenu.Enable (self.popupID['edit1'], False)
@@ -543,6 +551,11 @@
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
@@ -703,6 +716,73 @@
GUI(parent = self, centreOnParent = False).ParseCommand(['v.colors',
'map=%s' % name])
+ def _mapNameValidationFailed(self, ctrl):
+ message = _("Name <%(name)s> is not a valid name for GRASS map. "
+ "Please use only ASCII characters excluding %(chars)s "
+ "and space.") % {'name': ctrl.GetValue(), 'chars': '/"\'@,=*~'}
+ GError(parent=self, message=message, caption=_("Invalid name"))
+ def OnCopyMap(self, event):
+ """!Copy selected map into current mapset"""
+ layer = self.GetSelectedLayer()
+ ltype = self.GetLayerInfo(layer, key='type')
+ lnameSrc = self.GetLayerInfo(layer, key = 'maplayer').GetName()
+ if ltype == 'raster':
+ key = 'rast'
+ label = _('Raster map')
+ elif ltype == 'vector':
+ key = 'vect'
+ label = _('Vector map')
+ elif ltype == '3d-raster':
+ key = 'rast3d'
+ label = _('3D raster map')
+ else:
+ GError(_("Unsupported map type <%s>") % ltype, parent = self)
+ return
+ # TODO: replace by New[Raster|Vector]Dialog
+ dlg = TextEntryDialog(parent = self,
+ message = _('Enter name for the new %s in the current mapset:') % label.lower(),
+ caption = _('Make a copy of %s <%s>') % (label.lower(), lnameSrc),
+ defaultValue = lnameSrc.split('@')[0],
+ validator = GenericValidator(grass.legal_name, self._mapNameValidationFailed),
+ size = (700, -1))
+ if dlg.ShowModal() == wx.ID_OK:
+ lnameDst = dlg.GetValue()
+ dlg.Destroy()
+ else:
+ dlg.Destroy()
+ return
+ # check if map already exists
+ if lnameDst in grass.list_grouped(key)[currentMapset]:
+ dlgOw = wx.MessageDialog(parent = self, message = _("%s <%s> already exists "
+ "in the current mapset. "
+ "Do you want to overwrite it?") % (label, lnameDst),
+ caption = _("Overwrite?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlgOw.ShowModal() != wx.ID_YES:
+ return
+ kwargs = {key : '%s,%s' % (lnameSrc, lnameDst)}
+ if 0 != RunCommand('g.copy', overwrite = True, **kwargs):
+ GError(_("Unable to make copy of <%s>") % lnameSrc,
+ parent=self)
+ return
+ if '@' in lnameDst:
+ mapsetDst = lnameDst.split('@')[1]
+ if mapsetDst != currentMapset:
+ GError(_("Unable to make copy of <%s>. Mapset <%s> is not current mapset.") % \
+ (lnameSrc, mapsetDst))
+ return
+ lnameDst += '@' + currentMapset
+ # add copied map to the layer tree
+ self.AddLayer(ltype, lname = lnameDst, lcmd = ['d.%s' % key, 'map=%s' % lnameDst])
def OnHistogram(self, event):
"""!Plot histogram for given raster map layer
