[GRASS-SVN] r58020 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Oct 16 16:30:12 PDT 2013
Author: huhabla
Date: 2013-10-16 16:30:12 -0700 (Wed, 16 Oct 2013)
New Revision: 58020
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/open.py
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/sampling.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/stds_import.py
grass/trunk/lib/python/temporal/univar_statistics.py
Implemented a check for the correct mapset when datasets are modified.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -378,6 +378,11 @@
@return The SQL insert statement in case execute=False, or an empty string otherwise
+ if self.get_mapset() != get_current_mapset():
+ core.fatal(_("Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database."
+ " The mapset of the dataset does not match the current mapset")%\
+ {"ds":self.get_id(), "type":self.get_type()})
dbif, connected = init_dbif(dbif)
# Build the INSERT SQL statement
@@ -408,6 +413,12 @@
@return The SQL update statement in case execute=False, or an empty string otherwise
+ core.fatal(_("Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
# Build the UPDATE SQL statement
@@ -440,6 +451,11 @@
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -410,7 +410,13 @@
map, None in case or time instance
@param timezone Thee timezone of the map (not used)
@param dbif The database interface to be used
self.set_absolute_time(start_time, end_time, timezone)
@@ -439,7 +445,6 @@
@return True for success and False otherwise
if not self.check_relative_time_unit(unit):
if self.get_layer() is not None:
core.error(_("Unsupported relative time unit type for %(type)s"
@@ -497,6 +502,11 @@
@param unit The relative time unit
if self.set_relative_time(start_time, end_time, unit):
@@ -799,7 +809,11 @@
@return The SQL statements if execute=False, else an empty string,
None in case of a failure
+ core.fatal(_("Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database."
statement = ""
@@ -814,7 +828,7 @@
# Remove the strds register table
if self.get_stds_register() is not None:
- statement += "DROP TABLE " + self.get_stds_register() + ";\n"
+ statement += "DROP TABLE IF EXISTS " + self.get_stds_register() + ";\n"
# Commented because of performance issue calling g.message thousend times
#core.verbose(_("Delete %s dataset <%s> from temporal database")
@@ -866,7 +880,12 @@
# core.verbose(_("Unregister %(type)s map <%(map)s> "
# "from space time datasets"
# % {'type':self.get_type(), 'map':self.get_map_id()}))
+ core.fatal(_("Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database."
statement = ""
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -1467,7 +1467,7 @@
if maps is None:
return None
if not check_granularity_string(gran, maps[-1].get_temporal_type()):
core.error(_("Wrong granularity format: %s" % (gran)))
return None
@@ -1496,6 +1496,11 @@
granularity
+ core.fatal(_("Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database."
+ ({"ds":self.get_id()}, {"type":self.get_type()}))
if not check_granularity_string(gran, self.get_temporal_type()):
return False
@@ -1657,6 +1662,12 @@
+ core.fatal(_("Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database."
maps = self.get_registered_maps_as_objects(dbif=dbif)
@@ -1751,7 +1762,12 @@
@param ident The new identifier "name at mapset"
+ core.fatal(_("Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database."
# SELECT all needed information from the database
@@ -1816,6 +1832,11 @@
# (self.get_new_map_instance(ident=None).get_type(),
# self.get_id()))
statement = ""
@@ -1835,7 +1856,7 @@
map=map, dbif=dbif, execute=False)
# Safe the DROP table statement
- statement += "DROP TABLE " + self.get_map_register() + ";\n"
+ statement += "DROP TABLE IF EXISTS " + self.get_map_register() + ";\n"
# Remove the primary key, the foreign keys will be removed by trigger
statement += self.base.get_delete_statement()
@@ -1868,6 +1889,12 @@
@return True if success, False otherwise
+ core.fatal(_("Unable to register map in dataset <%(ds)s> of type %(type)s."
if map.is_in_db(dbif) == False:
@@ -2033,6 +2060,9 @@
if stds_register_table is None:
# Create table name
stds_register_table = self.create_map_register_name()
+ # Assure that the table and index do not exist
+ dbif.execute_transaction("DROP INDEX IF EXISTS %s; DROP TABLE IF EXISTS %s;"%(stds_register_table + "_index", stds_register_table))
# Read the SQL template
sql = open(os.path.join(sql_path,
"stds_map_register_table_template.sql"),
@@ -2121,6 +2151,11 @@
string, None in case of a failure
+ core.fatal(_("Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database."
statement = ""
@@ -2221,6 +2256,12 @@
core.verbose(_("Update metadata, spatial and temporal extent from "
"all registered maps of <%s>") % (self.get_id()))
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/core.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -50,6 +50,9 @@
except:
pass
+# Uncomment this to raise and exception in case of a fatal error
+# core.set_raise_on_error(True)
# Global variable that defines the backend
# of the temporal GIS
# It can either be "sqlite" or "pg"
@@ -65,8 +68,32 @@
# temporal database SQL layout
tgis_db_version=1
+# We need to access the current mapset quite often in the framework, so we make
+# global variable that will be initiated when init() is called
+current_mapset=None
+def get_current_mapset():
+ """!Return the current mapset
+ This is the fastest way to receive the current mapset.
+ The current mapset is set by init() and stored in a global variable.
+ This function provides access to this global variable.
+ global current_mapset
+ return current_mapset
+def _set_current_mapset():
+ """!This functions set the global current mapset variable to the current mapset
+ by calling g.gisenv.
+ current_mapset = core.gisenv()["MAPSET"]
def get_tgis_version():
"""!Get the verion number of the temporal framework
@return The version number of the temporal framework as string
@@ -178,6 +205,9 @@
# We need to set the correct database backend from the environment variables
global tgis_backend
+ # Set the global variable current_mapset for fast mapset access
+ _set_current_mapset()
core.run_command("t.connect", flags="c")
kv = core.parse_command("t.connect", flags="pg")
@@ -541,6 +571,37 @@
return statement
+ def check_table(self, table_name):
+ """!Check if a table exists in the temporal database
+ @param table_name The name of the table to be checked for existance
+ @return True if the table exists, False otherwise
+ table_exists = False
+ connected = False
+ if not self.connected:
+ self.connect()
+ connected = True
+ # Check if the database already exists
+ if self.dbmi.__name__ == "sqlite3":
+ self.cursor.execute("SELECT name FROM sqlite_master WHERE type='table' AND name='%s';"%table_name)
+ name = self.cursor.fetchone()
+ if name and name[0] == table_name:
+ table_exists = True
+ else:
+ # Check for raster_base table
+ self.cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
+ "WHERE table_name=%s)", ('%s'%table_name,))
+ if self.cursor.fetchone()[0]:
+ if connected:
+ self.close()
+ return table_exists
def execute_transaction(self, statement):
"""!Execute a transactional SQL statement
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/extract.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -52,7 +52,7 @@
if expression and not base:
core.fatal(_("You need to specify the base name of new created maps"))
- mapset = core.gisenv()["MAPSET"]
+ mapset = get_current_mapset()
dbif = SQLDatabaseInterfaceConnection()
dbif.connect()
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -79,7 +79,7 @@
dbif.connect()
input_name_list = inputs.split(",")
Modified: grass/trunk/lib/python/temporal/open.py
--- grass/trunk/lib/python/temporal/open.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/open.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -42,7 +42,7 @@
@param dbif The optional database interface to be used
# Check if the dataset name contains the mapset as well
if name.find("@") < 0:
@@ -93,7 +93,7 @@
#Get the current mapset to create the id of the space time dataset
id = name + "@" + mapset
@@ -175,16 +175,13 @@
-def check_new_map_dataset(name, layer=None, mapset=None,
- type="raster", overwrite=False, dbif=None):
+def check_new_map_dataset(name, layer=None, type="raster",
+ overwrite=False, dbif=None):
"""!Check if a new map dataset of a specific type can be created in
@param name The name of the new map dataset
@param layer The layer of the new map dataset
- @param mapset The current mapset the new map dataset is created in,
- this argument is optional, if not provided g.gisenv
- will be called to reveive the current mapset
@param type The type of the new map dataset (raster, vector, raster3d)
@param dbif The temporal database interface to be used
@param overwrite Flag to allow overwriting
@@ -193,8 +190,7 @@
This function will raise a ScriptError in case of an error.
- if not mapset:
map_id = AbstractMapDataset.build_id(name, mapset, layer)
@@ -215,7 +211,7 @@
-def open_new_map_dataset(name, layer=None, mapset=None, type="raster",
+def open_new_map_dataset(name, layer=None, type="raster",
temporal_extent=None, overwrite=False,
dbif=None):
"""!Create a new map dataset object of a specific type that can be
@@ -223,9 +219,6 @@
@@ -235,12 +228,10 @@
- if not mapset:
- new_map = check_new_map_dataset(name, layer, mapset, "raster",
- overwrite, dbif)
+ new_map = check_new_map_dataset(name, layer, "raster", overwrite, dbif)
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/register.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -83,7 +83,7 @@
'f': "file"})
# We may need the mapset
dbif, connected = init_dbif(None)
# The name of the space time dataset is optional
Modified: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/sampling.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -56,7 +56,7 @@
@return The map matrix or None if nothing found
# Make a method list
method = method.split(",")
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -52,7 +52,7 @@
>>> grass.run_command("r.mapcalc", overwrite=True,
... expression="strds_map_test_case = 1")
0
- >>> mapset = grass.gisenv()["MAPSET"]
+ >>> mapset = get_current_mapset()
>>> name = "strds_map_test_case"
>>> identifier = "%s@%s" % (name, mapset)
>>> rmap = RasterDataset(identifier)
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/stds_import.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -269,7 +269,7 @@
fs = "|"
maplist = []
list_file = open(list_file_name, "r")
new_list_file = open(new_list_file_name, "w")
@@ -284,7 +284,7 @@
# The filename is actually the base name of the map
# that must be extended by the file suffix
- filename = line_list[0].strip()
+ filename = line_list[0].strip().split(":")[0]
if base:
mapname = "%s_%i"%(base, line_count)
mapid= "%s@%s"%(mapname, mapset)
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2013-10-16 19:10:48 UTC (rev 58019)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2013-10-16 23:30:12 UTC (rev 58020)
@@ -46,7 +46,7 @@
dbif.connect()
- sp = open_old_space_time_dataset(input, "strds", dbif)
+ sp = open_old_space_time_dataset(input, type, dbif)
rows = sp.get_registered_maps(
"id,start_time,end_time", where, "start_time", dbif)
@@ -123,7 +123,7 @@
dbif.connect()
if input.find("@") >= 0:
id = input
