[GRASS-SVN] r58028 - in grass/trunk/temporal: t.rast.neighbors t.rast.series t.remove t.vect.observe.strds
svn_grass at osgeo.org
Thu Oct 17 05:28:45 PDT 2013
Author: huhabla
Date: 2013-10-17 05:28:45 -0700 (Thu, 17 Oct 2013)
New Revision: 58028
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
Fixed map removal in t.remove
Added multiple strds observation to t.vect.observe.strds
Added flag to t.rast.series
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2013-10-17 09:46:05 UTC (rev 58027)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2013-10-17 12:28:45 UTC (rev 58028)
@@ -110,6 +110,7 @@
finish_=False, size=int(size),
method=method, overwrite=overwrite,
quiet=True)
# The module queue for parallel execution
process_queue = pymod.ParallelModuleQueue(int(nprocs))
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2013-10-17 09:46:05 UTC (rev 58027)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2013-10-17 12:28:45 UTC (rev 58028)
@@ -55,6 +55,12 @@
#% description: Do not assign the space time raster dataset start and end time to the output map
#%end
+#%flag
+#% key: n
+#% description: Propagate NULLs
+#%end
import grass.script as grass
import grass.temporal as tgis
@@ -70,6 +76,7 @@
order = options["order"]
where = options["where"]
add_time = flags["t"]
+ nulls = flags["n"]
# Make sure the temporal database exists
tgis.init()
@@ -89,7 +96,11 @@
file.close()
- ret = grass.run_command("r.series", flags="z", file=filename,
+ flag = "z"
+ if nulls:
+ flag += "n"
+ ret = grass.run_command("r.series", flags=flag, file=filename,
output=output, overwrite=grass.overwrite(),
method=method)
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2013-10-17 09:46:05 UTC (rev 58027)
+++ grass/trunk/temporal/t.remove/t.remove.py 2013-10-17 12:28:45 UTC (rev 58028)
@@ -120,7 +120,11 @@
name_list = []
for map in maps:
map.select(dbif)
- name_list.append(map.get_name())
+ # We may have multiple layer for a single map, hence we need
+ # to avoid multiple deletation of the same map,
+ # but the database entries are still present and must be removed
+ if map.get_name() not in name_list:
+ name_list.append(map.get_name())
map_statement += map.delete(dbif=dbif, execute=False)
count += 1
@@ -134,7 +138,12 @@
if map_statement:
dbif.execute_transaction(map_statement)
if name_list:
- remove(rast=name_list, run_=True)
+ if type == "strds":
+ remove(rast=name_list, run_=True)
+ if type == "stvds":
+ remove(vect=name_list, run_=True)
+ if type == "str3ds":
+ remove(rast3d=name_list, run_=True)
statement += sp.delete(dbif=dbif, execute=False)
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2013-10-17 09:46:05 UTC (rev 58027)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2013-10-17 12:28:45 UTC (rev 58028)
@@ -23,7 +23,7 @@
#%option G_OPT_V_INPUT
#%end
-#%option G_OPT_STRDS_INPUT
+#%option G_OPT_STRDS_INPUTS
#% key: strds
#%end
@@ -32,18 +32,17 @@
#%option G_OPT_V_OUTPUT
#% key: vector_output
-#% description: Name of the new created vector map that stores the sampled values
+#% description: Name of the new created vector map that stores the sampled values in different layers
#%end
#%option
-#% key: column
+#% key: columns
#% type: string
-#% description: Name of the vector column to be created and to store sampled raster values, otherwise the space time raster name is used as column name
-#% required: no
-#% multiple: no
+#% description: Names of the vector columns to be created and to store sampled raster values, one name for each STRDS
+#% required: yes
+#% multiple: yes
#%end
#%option G_OPT_DB_WHERE
#%end
@@ -57,7 +56,20 @@
+class Sample(object):
+ def __init__(self, start = None, end = None, raster_names = None):
+ self.start = start
+ self.end = end
+ if raster_names != None:
+ self.raster_names = raster_names
+ else:
+ self.raster_names = []
+ def __str__(self):
+ return "Start: %s\nEnd: %s\nNames: %s\n"%(str(self.start), str(self.end), str(self.raster_names))
def main():
# Get the options
@@ -66,7 +78,7 @@
vector_output = options["vector_output"]
strds = options["strds"]
- column = options["column"]
+ columns = options["columns"]
tempwhere = options["t_where"]
if where == "" or where == " " or where == "\n":
@@ -74,6 +86,13 @@
overwrite = grass.overwrite()
+ # Check the number of sample strds and the number of columns
+ strds_names = strds.split(",")
+ column_names = columns.split(",")
+ if len(strds_names) != len(column_names):
+ grass.fatal(_("The number of columns must be equal to the number of space time raster datasets"))
tgis.init()
# We need a database interface
@@ -82,28 +101,71 @@
mapset = grass.gisenv()["MAPSET"]
- strds_sp = tgis.open_old_space_time_dataset(strds, "strds", dbif)
+ out_sp = tgis.check_new_space_time_dataset(output, "stvds", dbif, overwrite)
+ samples = []
- title = _("Observaion of space time raster dataset <%s>") % (strds_sp.get_id())
- description= _("Observation of space time raster dataset <%s>"
- " with vector map <%s>") % (strds_sp.get_id(),
- input)
+ first_strds = tgis.open_old_space_time_dataset(strds_names[0], "strds", dbif)
- out_sp = tgis.check_new_space_time_dataset(output, "stvds", dbif,
- overwrite)
+ # Single space time raster dataset
+ if len(strds_names) == 1:
+ rows = first_strds.get_registered_maps(
+ "name,mapset,start_time,end_time", tempwhere, "start_time", dbif)
- # Select the raster maps
- rows = strds_sp.get_registered_maps(
- "name,mapset,start_time,end_time", tempwhere, "start_time", dbif)
+ if not rows:
+ dbif.close()
+ grass.fatal(_("Space time raster dataset <%s> is empty") %
+ out_sp.get_id())
- if not rows:
- dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is empty") %
- out_sp.get_id())
+ for row in rows:
+ start = row["start_time"]
+ end = row["end_time"]
+ raster_maps = [row["name"] + "@" + row["mapset"],]
- num_rows = len(rows)
+ s = Sample(start, end, raster_maps)
+ samples.append(s)
+ else:
+ # Multiple space time raster datasets
+ for name in strds_names[1:]:
+ dataset = tgis.open_old_space_time_dataset(name, "strds", dbif)
+ if dataset.get_temporal_type() != first_strds.get_temporal_type():
+ grass.fatal(_("Temporal type of space time raster datasets must be equal\n"
+ "<%(a)s> of type %(type_a)s do not match <%(b)s> of type %(type_b)s"%\
+ {"a":first_strds.get_id(),
+ "type_a":first_strds.get_temporal_type(),
+ "b":dataset.get_id(),
+ "type_b":dataset.get_temporal_type()}))
+ mapmatrizes = tgis.sample_stds_by_stds_topology("strds", "strds", strds_names,
+ strds_names[0], False, None,
+ "equal", False, False)
+ for i in xrange(len(mapmatrizes[0])):
+ isvalid = True
+ mapname_list = []
+ for mapmatrix in mapmatrizes:
+ entry = mapmatrix[i]
+ if entry["samples"]:
+ sample = entry["samples"][0]
+ name = sample.get_id()
+ if name is None:
+ isvalid = False
+ break
+ else:
+ mapname_list.append(name)
+ if isvalid:
+ entry = mapmatrizes[0][i]
+ map = entry["granule"]
+ start, end = map.get_temporal_extent_as_tuple()
+ s = Sample(start, end, mapname_list)
+ samples.append(s)
+ num_samples = len(samples)
# Get the layer and database connections of the input vector
vector_db = grass.vector.vector_db(input)
@@ -114,7 +176,7 @@
else:
layers = ""
first = True
- for layer in range(num_rows):
+ for layer in range(num_samples):
layer += 1
# Skip existing layer
if vector_db and layer in vector_db and \
@@ -136,11 +198,15 @@
grass.fatal(_("Unable to create new layers for vector map <%s>")
% (vectmap))
+ title = _("Observaion of space time raster dataset(s) <%s>") % (strds)
+ description= _("Observation of space time raster dataset(s) <%s>"
+ " with vector map <%s>") % (strds, input)
# Create the output space time vector dataset
out_sp = tgis.open_new_space_time_dataset(output, "stvds",
- strds_sp.get_temporal_type(),
+ first_strds.get_temporal_type(),
title, description,
- strds_sp.get_semantic_type(),
+ first_strds.get_semantic_type(),
dbif, overwrite)
dummy = out_sp.get_new_map_instance(None)
@@ -148,64 +214,72 @@
# Sample the space time raster dataset with the vector
# map at specific layer with v.what.rast
count = 1
- for row in rows:
- start = row["start_time"]
- end = row["end_time"]
- rastmap = row["name"] + "@" + row["mapset"]
+ for sample in samples:
+ raster_names = sample.raster_names
- if column:
- col_name = column
- else:
- # Create a new column with name of the
- # sampled space time raster dataset
- col_name = row["name"]
+ if len(raster_names) != len(column_names):
+ grass.fatal(_("The number of raster maps in a granule must "
+ "be equal to the number of column names"))
- coltype = "DOUBLE PRECISION"
- # Get raster map type
- rasterinfo = raster.raster_info(rastmap)
- if rasterinfo["datatype"] == "CELL":
- coltype = "INT"
+ # Create the columns creation string
+ columns_string = ""
+ for name, column in zip(raster_names, column_names):
+ # The column is by default double precision
+ coltype = "DOUBLE PRECISION"
+ # Get raster map type
+ raster_map = tgis.RasterDataset(name)
+ raster_map.load()
+ if raster_map.metadata.get_datatype() == "CELL":
+ coltype = "INT"
+ tmp_string = "%s %s,"%(column, coltype)
+ columns_string += tmp_string
+ # Remove last comma
+ columns_string = columns_string[0:len(columns_string) - 1]
# Try to add a column
if vector_db and count in vector_db and vector_db[count]["table"]:
ret = grass.run_command("v.db.addcolumn", map=vectmap,
- layer=count,
- column="%s %s" % (col_name, coltype),
+ layer=count, column=columns_string,
overwrite=overwrite)
if ret != 0:
dbif.close()
grass.fatal(_("Unable to add column %s to vector map <%s> "
- "with layer %i") % (col_name, vectmap, count))
+ "with layer %i") % (columns_string, vectmap, count))
else:
# Try to add a new table
grass.message("Add table to layer %i" % (count))
ret = grass.run_command("v.db.addtable", map=vectmap, layer=count,
- columns="%s %s" % (col_name, coltype),
- overwrite=overwrite)
+ columns=columns_string, overwrite=overwrite)
if ret != 0:
dbif.close()
grass.fatal(_("Unable to add table to vector map "
"<%s> with layer %i") % (vectmap, count))
- # Call v.what.rast
- ret = grass.run_command("v.what.rast", map=vectmap,
- layer=count, raster=rastmap,
- column=col_name, where=where)
- if ret != 0:
- dbif.close()
- grass.fatal(_("Unable to run v.what.rast for vector map <%s> "
- "with layer %i and raster map <%s>") % \
- (vectmap, count, rastmap))
+ # Call v.what.rast for each raster map
+ ret = grass.run_command("v.what.rast", map=vectmap,
+ layer=count, raster=name,
+ column=column, where=where)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to run v.what.rast for vector map <%s> "
+ "with layer %i and raster map <%s>") % \
+ (vectmap, count, str(raster_names)))
vect = out_sp.get_new_map_instance(dummy.build_id(vectmap,
mapset, str(count)))
vect.load()
+ start = sample.start
+ end = sample.end
if out_sp.is_time_absolute():
vect.set_absolute_time(start, end)
else:
vect.set_relative_time(
- start, end, strds_sp.get_relative_time_unit())
+ start, end, first_strds.get_relative_time_unit())
if vect.is_in_db(dbif):
vect.update_all(dbif)
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2013-10-17 09:46:05 UTC (rev 58027)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2013-10-17 12:28:45 UTC (rev 58028)
@@ -14,12 +14,20 @@
r.mapcalc expr="prec_5 = 500.0"
r.mapcalc expr="prec_6 = 600.0"
+r.mapcalc expr="prec_7 = 400"
+r.mapcalc expr="prec_8 = 500.0"
+r.mapcalc expr="prec_9 = 600.0"
v.random output=prec n=5 seed=1
v.random -z output=test_1 column=test n=5 seed=1
t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+t.create type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.register -i input=precip_abs2 maps=prec_7,prec_8,prec_9 start="2001-05-01 00:00:00" increment="1 months"
# The @test
t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column="test_val"
v.info prec_observer
@@ -27,19 +35,15 @@
t.vect.list input=prec_observer
t.vect.db.select input=prec_observer
-t.vect.observe.strds input=test_1 strds=precip_abs1 output=test_1_observer vector=test_1_observer
+t.vect.observe.strds columns=test1,test2,test3 input=test_1 \
+ strds=precip_abs1,precip_abs1,precip_abs2 output=test_1_observer \
+ vector=test_1_observer
v.info test_1_observer
t.info type=stvds input=test_1_observer
t.vect.list input=test_1_observer
-t.vect.db.select input=test_1_observer
+t.vect.db.select input=test_1_observer columns=cat,test1,test2,test3
# @postprocess
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1
-t.remove type=stvds input=prec_observer,test_1_observer
-t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
-t.unregister type=vect maps=test_1_observer:1,test_1_observer:2,test_1_observer:3,test_1_observer:4,test_1_observer:5,test_1_observer:6
-g.remove vect=prec_observer,test_1_observer
-g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove -rf type=strds input=precip_abs1,precip_abs2
+t.remove -rf type=stvds input=prec_observer,test_1_observer
