[GRASS-SVN] r58042 - in grass/trunk/temporal: t.rast.export t.rast.import
Fri Oct 18 04:39:47 PDT 2013
Author: huhabla
Date: 2013-10-18 04:39:47 -0700 (Fri, 18 Oct 2013)
New Revision: 58042
   grass/trunk/temporal/t.rast.export/t.rast.export.py
   grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
Integrated AAIGrid format for export and import of space time raster datasets.
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.py
--- grass/trunk/temporal/t.rast.export/t.rast.export.py	2013-10-18 11:39:34 UTC (rev 58041)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.py	2013-10-18 11:39:47 UTC (rev 58042)
@@ -47,10 +47,10 @@
 #%option
 #% key: format
 #% type: string
-#% description: The export format of a single raster map. Supported are GeoTIFF via r.out.gdal and the GRASS package format of r.pack.
+#% description: The export format of a single raster map. Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack.
 #% required: no
 #% multiple: no
-#% options: GTiff,pack
+#% options: GTiff,AAIGrid,pack
 #% answer: GTiff
 #%end
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh	2013-10-18 11:39:34 UTC (rev 58041)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh	2013-10-18 11:39:47 UTC (rev 58042)
@@ -36,7 +36,7 @@
 # The first @test
 t.register -i type=rast input=precip_abs1 file="${n1}"
-t.rast.export input=precip_abs1 output=strds_export.tar.bz2 compression=bzip2 format=GTiff workdir=test
+t.rast.export input=precip_abs1 output=strds_export.tar.bz2 compression=bzip2 format=AAIGrid workdir=test
 t.rast.export input=precip_abs1 output=strds_export.tar.gz compression=gzip format=GTiff workdir=test
 t.rast.export input=precip_abs1 output=strds_export.tar compression=no format=GTiff workdir=test
 t.rast.export input=precip_abs1 output=strds_export_pack.tar compression=no format=pack workdir=test
