[GRASS-SVN] r58047 - grass/trunk/include/Make
Fri Oct 18 10:56:33 PDT 2013
Author: wenzeslaus
Date: 2013-10-18 10:56:33 -0700 (Fri, 18 Oct 2013)
New Revision: 58047
   grass/trunk/include/Make/Doxyfile_arch_html.in
   grass/trunk/include/Make/Doxyfile_arch_latex.in
dox: exclude various test files and dirs and local_proto.h files
Modified: grass/trunk/include/Make/Doxyfile_arch_html.in
--- grass/trunk/include/Make/Doxyfile_arch_html.in	2013-10-18 15:14:39 UTC (rev 58046)
+++ grass/trunk/include/Make/Doxyfile_arch_html.in	2013-10-18 17:56:33 UTC (rev 58047)
@@ -745,7 +745,17 @@
 # against the file with absolute path, so to exclude all test directories
 # for example use the pattern */test/*
-EXCLUDE_PATTERNS       =
+EXCLUDE_PATTERNS       = */test/* \
+                         */tests/* \
+                         */unit_test/* \
+                         */unit_tests/* \
+                         */unit_test* \
+                         */unit_tests* \
+                         */test_suite/* \
+                         */testsuite/* \
+                         */test_* \
+                         */test.* \
+                         */*local_proto.h
 # The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
 # (namespaces, classes, functions, etc.) that should be excluded from the
Modified: grass/trunk/include/Make/Doxyfile_arch_latex.in
--- grass/trunk/include/Make/Doxyfile_arch_latex.in	2013-10-18 15:14:39 UTC (rev 58046)
+++ grass/trunk/include/Make/Doxyfile_arch_latex.in	2013-10-18 17:56:33 UTC (rev 58047)
-EXCLUDE_PATTERNS       =
+                         */tests/* \
+                         */unit_test/* \
+                         */unit_tests/* \
+                         */unit_test* \
+                         */unit_tests* \
+                         */test_suite/* \
+                         */testsuite/* \
+                         */test_* \
+                         */test.* \
+                         */*local_proto.h
