[GRASS-SVN] r58051 - grass/trunk/vector/v.segment
svn_grass at osgeo.org
Sat Oct 19 02:27:46 PDT 2013
Author: neteler
Date: 2013-10-19 02:27:46 -0700 (Sat, 19 Oct 2013)
New Revision: 58051
Added:
grass/trunk/vector/v.segment/v_segment_spaced_percent_points.jpg
grass/trunk/vector/v.segment/v_segment_spaced_points.jpg
grass/trunk/vector/v.segment/v_segment_spaced_right_points.jpg
grass/trunk/vector/v.segment/v_segment_subline.jpg
grass/trunk/vector/v.segment/v.segment.html
v.segment: examples added (NC location)
Modified: grass/trunk/vector/v.segment/v.segment.html
--- grass/trunk/vector/v.segment/v.segment.html 2013-10-19 09:27:13 UTC (rev 58050)
+++ grass/trunk/vector/v.segment/v.segment.html 2013-10-19 09:27:46 UTC (rev 58051)
@@ -47,20 +47,24 @@
<h2>EXAMPLES</h2>
-Spearfish location:
+The examples may be used in the North Carolina sample location.
+<p>
+Example: Extract line segment from 400m to 5000m from beginning
+of line 1:
<div class="code"><pre>
# extract lines from railroad map:
-v.extract railroads out=myrr list=1
+v.extract railroads out=myrr cats=1
# join segments into polyline and reassign category numbers
v.build.polylines myrr out=myrr_pol
v.category myrr_pol out=myrailroads option=add
# zoom to an area of interest
-g.region n=4928200 s=4921100 w=605600 e=613200
+g.region vector=myrailroads -p
# show line, category, direction (to find the beginning)
+d.mon wx0
d.vect myrailroads disp=shape,cat,dir lsize=12
# extract line segment from 400m to 5000m from beginning of line 1
@@ -72,12 +76,17 @@
# set node at 5000m from beginning of line 1
echo "P 1 1 5000" | v.segment myrailroads out=myrailroads_segp
d.vect myrailroads_segp icon=basic/circle color=red fcolor=red size=5
+</pre></div>
+<center>
+<img src="v_segment_subline.jpg"><br>
+Extract line segment from 400m to 5000m from beginning
+of line 1
+</center>
-# get points from a text file
-cat mypoints.txt | v.segment myrailroads out=myrailroads_mypoints
-# create parallel 1km long line segments along first 8km of track,
-# offset 500m to the left of the tracks.
+<p>
+Example: Create parallel 1km long line segments along first 8km of
+track, offset 500m to the left of the tracks.
+<div class="code"><pre>
v.segment myrailroads out=myrailroads_segl_side << EOF
L 1 1 1000 2000 -500
L 2 1 3000 4000 -500
@@ -87,26 +96,49 @@
d.erase
d.vect myrailroads disp=shape,dir
d.vect -c myrailroads_segl_side width=2
+</pre></div>
-# A series of points, spaced every 2km along the tracks
+<p>
+Example: A series of points, spaced every 2km along the tracks
v.segment myrailroads out=myrailroads_pt2km << EOF
P 1 1 1000
P 2 1 3000
P 3 1 5000
P 4 1 7000
EOF
+d.erase
+d.vect myrailroads disp=shape,dir
d.vect myrailroads_pt2km icon=basic/circle color=blue fcolor=blue size=5
+</pre></div>
+<center>
+<img src="v_segment_spaced_points.jpg"><br>
+A series of points, spaced every 2km along the tracks
+</center>
-# A series of points, spaced every 2km along the tracks, offset 500m to the right
+<p>
+Example: A series of points, spaced every 2km along the tracks, offset 500m to the right
v.segment myrailroads out=myrailroads_pt2kmO500m << EOF
P 1 1 1000 500
P 2 1 3000 500
P 3 1 5000 500
P 4 1 7000 500
EOF
+d.erase
d.vect myrailroads_pt2kmO500m icon=basic/circle color=aqua fcolor=aqua size=5
+</pre></div>
+<center>
+<img src="v_segment_spaced_right_points.jpg"><br>
+A series of points, spaced every 2km along the tracks, offset 500m to the right
+</center>
-# A series of points, spaced every 10% of the line's length along the tracks from the end of the line up to the middle point, offset 500m to the right
+<p>
+Example: A series of points, spaced every 10% of the line's length along the
+tracks from the end of the line up to the middle point, offset 500m to the right
v.segment myrailroads out=myrailroads_pt10pctO500m << EOF
P 1 1 -0% 500
P 1 1 -10% 500
@@ -115,10 +147,16 @@
P 4 1 -40% 500
P 4 1 -50% 500
EOF
+d.erase
d.vect myrailroads_pt10pctO500m icon=basic/circle color=red fcolor=black size=5
</pre></div>
+<center>
+<img src="v_segment_spaced_percent_points.jpg"><br>
+A series of points, spaced every 10% of the line's length along the
+</center>
<h2>BUGS</h2>
There is a problem with side-offset parallel line generation for inside corners.
<!-- in Vect_line_parallel(), v.parallel is also affected -->
Added: grass/trunk/vector/v.segment/v_segment_spaced_percent_points.jpg
(Binary files differ)
Property changes on: grass/trunk/vector/v.segment/v_segment_spaced_percent_points.jpg
___________________________________________________________________
Added: svn:mime-type
+ image/jpeg
Added: grass/trunk/vector/v.segment/v_segment_spaced_points.jpg
Property changes on: grass/trunk/vector/v.segment/v_segment_spaced_points.jpg
+ image/jpeg
Added: grass/trunk/vector/v.segment/v_segment_spaced_right_points.jpg
Property changes on: grass/trunk/vector/v.segment/v_segment_spaced_right_points.jpg
+ image/jpeg
Added: grass/trunk/vector/v.segment/v_segment_subline.jpg
Property changes on: grass/trunk/vector/v.segment/v_segment_subline.jpg
+ image/jpeg
