[GRASS-SVN] r58065 - grass/trunk/raster/r.topidx
svn_grass at osgeo.org
Sat Oct 19 17:52:00 PDT 2013
Author: hcho
Date: 2013-10-19 17:52:00 -0700 (Sat, 19 Oct 2013)
New Revision: 58065
grass/trunk/raster/r.topidx/file_io.c
grass/trunk/raster/r.topidx/global.h
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.topidx/topidx.c
parameter descriptions updated; routine names changed
Modified: grass/trunk/raster/r.topidx/file_io.c
--- grass/trunk/raster/r.topidx/file_io.c 2013-10-20 00:46:47 UTC (rev 58064)
+++ grass/trunk/raster/r.topidx/file_io.c 2013-10-20 00:52:00 UTC (rev 58065)
@@ -4,7 +4,7 @@
#include <grass/glocale.h>
#include "global.h"
-void getcells(void)
+void read_cells(void)
int fd, i, j;
RASTER_MAP_TYPE data_type;
@@ -13,10 +13,10 @@
struct Cell_head inhead;
char buf_wrns[32], buf_wrew[32], buf_mrns[32], buf_mrew[32];
- fd = Rast_open_old(iname, "");
+ fd = Rast_open_old(input, "");
data_type = Rast_get_map_type(fd);
- Rast_get_cellhd(iname, "", &inhead);
+ Rast_get_cellhd(input, "", &inhead);
if (data_type == CELL_TYPE)
ccell = (CELL *) G_malloc(sizeof(CELL) * window.cols);
@@ -77,13 +77,12 @@
Rast_close(fd);
-void putcells(void)
+void write_cells(void)
int fd, i;
struct History history;
- fd = Rast_open_new(oname, DCELL_TYPE);
+ fd = Rast_open_new(output, DCELL_TYPE);
G_message(_("Writing topographic index map..."));
@@ -94,7 +93,7 @@
G_percent(i, window.rows, 2);
Rast_close(fd);
- Rast_short_history(oname, "raster", &history);
- Rast_set_history(&history, HIST_DATSRC_1, iname);
- Rast_write_history(oname, &history);
+ Rast_short_history(output, "raster", &history);
+ Rast_set_history(&history, HIST_DATSRC_1, input);
+ Rast_write_history(output, &history);
Modified: grass/trunk/raster/r.topidx/global.h
--- grass/trunk/raster/r.topidx/global.h 2013-10-20 00:46:47 UTC (rev 58064)
+++ grass/trunk/raster/r.topidx/global.h 2013-10-20 00:52:00 UTC (rev 58065)
@@ -15,12 +15,13 @@
#define GLOBAL extern
#endif
-GLOBAL char *iname, *oname;
+GLOBAL char *input, *output;
GLOBAL struct Cell_head window;
GLOBAL DCELL **cell;
GLOBAL DCELL **atb, **a;
-void getcells(void);
-void putcells(void);
+void read_cells(void);
+void write_cells(void);
+void calculate_statistics(void);
void initialize(void);
-void atanb(void);
+void calculate_atanb(void);
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c 2013-10-20 00:46:47 UTC (rev 58064)
+++ grass/trunk/raster/r.topidx/main.c 2013-10-20 00:52:00 UTC (rev 58065)
@@ -10,7 +10,7 @@
* PURPOSE: Creates topographic index map from elevation map.
* Based on GRIDATB.FOR.
- * COPYRIGHT: (C) 2000-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2013 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -41,10 +41,12 @@
module->description =
_("Creates topographic index map from elevation raster map.");
- params.input = G_define_standard_option(G_OPT_R_INPUT);
+ params.input = G_define_standard_option(G_OPT_R_ELEV);
+ params.input->key = "input";
params.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ params.output->description = _("Name for output topographic index map");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -53,15 +55,15 @@
G_fatal_error(_("Lat/Long location is not supported by %s. Please reproject map first."),
G_program_name());
- iname = params.input->answer;
- oname = params.output->answer;
+ input = params.input->answer;
+ output = params.output->answer;
G_get_window(&window);
- getcells();
+ read_cells();
initialize();
- atanb();
- putcells();
+ calculate_atanb();
+ write_cells();
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.topidx/topidx.c
--- grass/trunk/raster/r.topidx/topidx.c 2013-10-20 00:46:47 UTC (rev 58064)
+++ grass/trunk/raster/r.topidx/topidx.c 2013-10-20 00:52:00 UTC (rev 58065)
@@ -25,8 +25,7 @@
-void atanb(void)
int i, j, k, snatb;
int iter, ncells, nroute, nslp;
