[GRASS-SVN] r58084 - in grass/trunk: lib/python/temporal temporal/t.register
Mon Oct 21 05:06:10 PDT 2013
Author: huhabla
Date: 2013-10-21 05:06:10 -0700 (Mon, 21 Oct 2013)
New Revision: 58084
Added:
   grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/temporal/t.register/t.register.html
Added (r|r3|v).timestamp read support in t.register.
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-10-21 10:42:46 UTC (rev 58083)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-10-21 12:06:10 UTC (rev 58084)
@@ -119,10 +119,10 @@
            in the grass file system based spatial database and
            set the internal time stamp that should be insert/updated
            in the temporal database.
            @param ts The timetsamp to be set, is of type libgis.TimeStamp()
         if not self.has_grass_timestamp():
             return False
@@ -130,22 +130,22 @@
         dt2 = libgis.DateTime()
         count = ctypes.c_int()
-        libgis.G_get_timestamps(ctypes.byref(ts),
-                                ctypes.byref(dt1),
-                                ctypes.byref(dt2),
+        libgis.G_get_timestamps(ctypes.byref(ts),
+                                ctypes.byref(dt1),
+                                ctypes.byref(dt2),
                                 ctypes.byref(count))
         if dt1.mode == libdate.DATETIME_ABSOLUTE:
             pdt1 = None
             pdt2 = None
-            if count >= 1:
-                pdt1 = datetime(int(dt1.year), int(dt1.month), int(dt1.day),
-                                int(dt1.hour), int(dt1.minute),
+            if count.value >= 1:
+                pdt1 = datetime(int(dt1.year), int(dt1.month), int(dt1.day),
+                                int(dt1.hour), int(dt1.minute),
                                 int(dt1.second))
-            if count == 2:
-                pdt2 = datetime(int(dt2.year), int(dt2.month), int(dt2.day),
-                                int(dt2.hour), int(dt2.minute),
+            if count.value == 2:
+                pdt2 = datetime(int(dt2.year), int(dt2.month), int(dt2.day),
+                                int(dt2.hour), int(dt2.minute),
                                 int(dt2.second))
             # ATTENTION: We ignore the time zone
@@ -188,7 +188,7 @@
                 elif dt2.seconds > 0:
                     end = dt2.seconds
             self.set_relative_time(start, end, unit)
         return True
     @abstractmethod
@@ -433,7 +433,7 @@
            @param end_time a datetime object specifying the end time of the
                            map, None in case or time instance
            @param timezone Thee timezone of the map (not used)
            @return True for success and False otherwise
         if start_time and not isinstance(start_time, datetime):
@@ -508,13 +508,13 @@
            @param dbif The database interface to be used
         if self.get_mapset() != get_current_mapset():
             core.fatal(_("Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
                          " The mapset of the dataset does not match the current mapset")%\
                          {"ds":self.get_id(), "type":self.get_type()})
         if self.set_absolute_time(start_time, end_time, timezone):
             dbif, connected = init_dbif(dbif)
             self.absolute_time.update_all(dbif)
@@ -522,7 +522,7 @@
             if connected:
                 dbif.close()
             self.write_timestamp_to_grass()
     def set_relative_time(self, start_time, end_time, unit):
@@ -611,7 +611,7 @@
             if connected:
                 dbif.close()
     def set_temporal_extent(self, extent):
@@ -909,7 +909,7 @@
             core.fatal(_("Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database."
         statement = ""
@@ -976,12 +976,12 @@
         #    core.verbose(_("Unregister %(type)s map <%(map)s> "
         #                   "from space time datasets"
         #                 % {'type':self.get_type(), 'map':self.get_map_id()}))
             core.fatal(_("Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database."
         statement = ""
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2013-10-21 10:42:46 UTC (rev 58083)
+++ grass/trunk/lib/python/temporal/register.py	2013-10-21 12:06:10 UTC (rev 58084)
@@ -177,27 +177,26 @@
         # Put the map into the database
         if not map.is_in_db(dbif):
-            is_in_db = False
             # Break in case no valid time is provided
-            if start == "" or start is None:
+            if (start == "" or start is None) and not map.has_grass_timestamp():
                 dbif.close()
                 if map.get_layer():
                     core.fatal(_("Unable to register %(t)s map <%(id)s> with "
-                                 "layer %(l)s. The map has no valid time and "
+                                 "layer %(l)s. The map has timestamp and "
                                  "the start time is not set.") % {
                                  't': map.get_type(), 'id': map.get_map_id(),
                                  'l': map.get_layer()})
                 else:
                     core.fatal(_("Unable to register %(t)s map <%(id)s>. The"
-                                 " map has no valid time and the start time "
+                                 " map has no timestamp and the start time "
                                  "is not set.") % {'t': map.get_type(),
                                                    'id': map.get_map_id()})
+            if start != "" and start != None:
+                if unit:
+                    map.set_time_to_relative()
+                else:
+                    map.set_time_to_absolute()
-            if unit:
-                map.set_time_to_relative()
-            else:
-                map.set_time_to_absolute()
         else:
             is_in_db = True
             # Check the overwrite flag
@@ -247,6 +246,11 @@
         # Load the data from the grass file database
         map.load()
+        # Try to read an existing time stamp from the grass spatial database
+        # in case this map wasn't already registered in the temporal database
+        if not is_in_db:
+            map.read_timestamp_from_grass()
         # Set the valid time
         if start:
             # In case the time is in the input file we ignore the increment
Modified: grass/trunk/temporal/t.register/t.register.html
--- grass/trunk/temporal/t.register/t.register.html	2013-10-21 10:42:46 UTC (rev 58083)
+++ grass/trunk/temporal/t.register/t.register.html	2013-10-21 12:06:10 UTC (rev 58084)
@@ -1,25 +1,34 @@
 <h2>DESCRIPTION</h2>
-The module <em>t.register</em> is designed to register raster, 3D raster and
+The module <em>t.register</em> is designed to register raster, 3D raster and
 vector maps in the temporal database and in specific space time datasets.
 This module must be used to assign time stamps to raster, 3D raster and vector maps.
 The existing timestamp modules <a href="r.timestamp.html">r.timestamp</a>,
-<a href="r3.timestamp.html">r3.timestamp</a> and <a href="v.timestamp.html">v.timestamp</a>
-should not be used, since they do not register the maps in the temporal database of GRASS.
+<a href="r3.timestamp.html">r3.timestamp</a> and <a href="v.timestamp.html">v.timestamp</a>
+do not register the maps in the temporal database of GRASS. However, timestamps that have been
+created with these modules can be read and used by <em>t.register</em>. This works only for
+maps that are not already registered in the temporal database.
 <p>
-This module supports absolute and relative time. Maps can be registered by command line argument
+This module supports absolute and relative time. Maps can be registered by command line argument
 (a list of comma separated map names) or using an input file.
 The start time, the end time and a temporal increment can be provided by command line
 or in the input file.
 End time and increment are mutual exclusive.
-The user can register single maps or a list of maps at once. Maps can be registered in several
-space time datasets using the same time stamp.
+The user can register single maps or a list of maps at once. Maps can be registered in several
+space time datasets using the same timestamp.
 <p>
 Start time and end time with absolute time must be provided using the format <b>yyyy-mm-dd HH:MM:SS +HHMM</b>.
 It is supported to specify only the date <b>yyyy-mm-dd</b>.
 In case of relative time the temporal unit (years, months, days, hours, minutes or seconds) must be provided.
 The relative start time, end time and the increment are integers.
+<h2>Note</h2>
+The timestamps of registred maps will be stored in the temporal
+database and in the metadata of the grass maps in the spatial database. This assures
+that timestamps can always be accessed with <em>(r|r3|v).timestamp</em> and the temporal
+modules. Timestamps should only be modified with <em>t.register</em> because
+the <em>(r|r3|v).timestamp</em> modules have no access to the temporal database.
 <p>
@@ -56,23 +65,58 @@
 <h2>EXAMPLE</h2>
 In this example we create 6 raster maps that will be registered in a single space time
-raster dataset named <em>precip_abs</em> using a monthly temporal granularity. The -i flag generates interval time.
+raster dataset named <em>precip_abs</em> using a monthly temporal granularity.
+The -i flag generates interval time. The generated timestamps will be
+inspected using <em>r.timestamp</em> and t.rast.list.
+We will register an additional map with
+a timetsamp that was set with <em>r.timestamp</em>.
 <div class="code"><pre>
-r.mapcalc --o expr="prec_1 = 100"
-r.mapcalc --o expr="prec_2 = 200"
-r.mapcalc --o expr="prec_3 = 300"
-r.mapcalc --o expr="prec_4 = 400"
-r.mapcalc --o expr="prec_5 = 500"
-r.mapcalc --o expr="prec_6 = 600"
+r.mapcalc expr="prec_1 = 100"
+r.mapcalc expr="prec_2 = 200"
+r.mapcalc expr="prec_3 = 300"
+r.mapcalc expr="prec_4 = 400"
+r.mapcalc expr="prec_5 = 500"
+r.mapcalc expr="prec_6 = 600"
-t.create --o type=strds temporaltype=absolute \
-    output=precip_abs title="Eexample" \
+t.create type=strds temporaltype=absolute \
+    output=precip_abs title="Example" \
     descr="Example"
 t.register -i type=rast input=precip_abs \
     maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
     start="2001-01-01" increment="1 months"
+r.timestamp prec_1
+1 Jan 2001 00:00:00 / 1 Feb 2001 00:00:00
+r.timestamp prec_2
+1 Feb 2001 00:00:00 / 1 Mar 2001 00:00:00
+t.rast.list input=precip_abs
+prec_1	test2	2001-01-01 00:00:00	2001-02-01 00:00:00
+prec_2	test2	2001-02-01 00:00:00	2001-03-01 00:00:00
+prec_3	test2	2001-03-01 00:00:00	2001-04-01 00:00:00
+prec_4	test2	2001-04-01 00:00:00	2001-05-01 00:00:00
+prec_5	test2	2001-05-01 00:00:00	2001-06-01 00:00:00
+prec_6	test2	2001-06-01 00:00:00	2001-07-01 00:00:00
+r.mapcalc expr="prec_7 = 700"
+r.timestamp map=prec_7 date="1 jul 2001 / 1 aug 2001"
+t.register type=rast input=precip_abs maps=prec_7
+prec_7	test2	2001-07-01 00:00:00	2001-08-01 00:00:00
 </pre></div>
Added: grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh	                        (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh	2013-10-21 12:06:10 UTC (rev 58084)
@@ -0,0 +1,37 @@
+#!/bin/sh
+# This is a test to register and unregister raster maps in
+# space time raster datasets.
+# The raster maps will be registered in different space time raster
+# datasets.
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create several space time raster datasets
+# with absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.timestamp map=prec_1 date="1 jan 1995 / 23 sep 1995"
+r.timestamp map=prec_2 date="14 jul 1996 / 15 jul 1996"
+r.timestamp map=prec_3 date="1 mar 1998"
+r.timestamp map=prec_4 date="17 mar 1950 / 28 apr 1960"
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register --o -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4
+t.info type=strds input=precip_abs1
+t.info -g type=strds input=precip_abs1
+r.info map=prec_1
+t.rast.list input=precip_abs1
+t.topology input=precip_abs1
+# Test the warning message
+t.remove -rf type=strds input=precip_abs1
Property changes on: grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh
___________________________________________________________________
Added: svn:executable
