[GRASS-SVN] r58087 - in grass/trunk/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Mon Oct 21 19:21:13 PDT 2013
Author: annakrat
Date: 2013-10-21 19:21:13 -0700 (Mon, 21 Oct 2013)
New Revision: 58087
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: change notification for setting comp region from selected map (do not switch tab); add docstring
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2013-10-22 02:12:20 UTC (rev 58086)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2013-10-22 02:21:13 UTC (rev 58087)
@@ -305,8 +305,10 @@
def WriteLog(self, text, style=None, wrap=None,
notification=Notification.HIGHLIGHT):
"""!Generic method for writing log message in
- given style
+ given style.
+ Emits contentChanged signal.
@param line text line
@param style text style (see GStc)
@param stdout write to stdout or stderr
@@ -421,7 +423,9 @@
self.cmdOutput.Unbind(stc.EVT_STC_PAINTED)
def OnCmdOutput(self, event):
- """!Print command output
+ """!Prints command output.
message = event.text
type = event.type
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-22 02:12:20 UTC (rev 58086)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2013-10-22 02:21:13 UTC (rev 58087)
@@ -48,6 +48,7 @@
from web_services.dialogs import SaveWMSLayerDialog
from gui_core.widgets import GenericValidator
from lmgr.giface import LayerManagerGrassInterfaceForMapDisplay
+from core.giface import Notification
TREE_ITEM_HEIGHT = 25
@@ -642,7 +643,7 @@
'zoom=%s' % mapLayer.GetName()]
# print output to command log area
- self._giface.RunCmd(cmd)
+ self._giface.RunCmd(cmd, notification=Notification.HIGHLIGHT)
# re-render map display
self._giface.GetMapWindow().UpdateMap(render=True)
@@ -680,7 +681,8 @@
cmd.append('-p')
if mltype == '3d-raster':
cmd.append('-3')
- self._giface.RunCmd(cmd, compReg = False)
+ self._giface.RunCmd(cmd, compReg = False,
+ notification=Notification.HIGHLIGHT)
