[GRASS-SVN] r58089 - in grass/trunk/gui/wxpython: core gui_core lmgr
svn_grass at osgeo.org
Mon Oct 21 19:53:30 PDT 2013
Author: annakrat
Date: 2013-10-21 19:53:29 -0700 (Mon, 21 Oct 2013)
New Revision: 58089
grass/trunk/gui/wxpython/core/gconsole.py
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/lmgr/giface.py
wxGUI/gconsole: rename write methods parameter
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2013-10-22 02:42:36 UTC (rev 58088)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2013-10-22 02:53:29 UTC (rev 58089)
@@ -396,29 +396,29 @@
"""!Generic method for writing log message in
given style
- @param line text line
+ @param text text line
@param notification form of notification
self.writeLog.emit(text=text, wrap=wrap,
notification=notification)
- def WriteCmdLog(self, line, pid=None, notification=Notification.MAKE_VISIBLE):
+ def WriteCmdLog(self, text, pid=None, notification=Notification.MAKE_VISIBLE):
"""!Write message in selected style
- @param line message to be printed
+ @param text message to be printed
@param pid process pid or None
- self.writeCmdLog.emit(line=line, pid=pid,
+ self.writeCmdLog.emit(text=text, pid=pid,
- def WriteWarning(self, line):
+ def WriteWarning(self, text):
"""!Write message in warning style"""
- self.writeWarning.emit(line=line)
+ self.writeWarning.emit(text=text)
- def WriteError(self, line):
+ def WriteError(self, text):
"""!Write message in error style"""
- self.writeError.emit(line=line)
+ self.writeError.emit(text=text)
def RunCmd(self, command, compReg=True, skipInterface=False,
onDone=None, onPrepare=None, userData=None, notification=Notification.MAKE_VISIBLE):
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2013-10-22 02:42:36 UTC (rev 58088)
+++ grass/trunk/gui/wxpython/core/giface.py 2013-10-22 02:53:29 UTC (rev 58089)
@@ -123,17 +123,17 @@
raise NotImplementedError()
"""!Writes message related to start or end of the command.
"""!Writes warning message for the user.
"""!Writes error message for the user."""
@@ -236,16 +236,16 @@
notification=Notification.HIGHLIGHT):
self._write(grass.message, text)
if pid:
- line = '(' + str(pid) + ') ' + line
- self._write(grass.message, line)
+ text = '(' + str(pid) + ') ' + text
+ self._write(grass.message, text)
- self._write(grass.warning, line)
+ self._write(grass.warning, text)
- self._write(grass.error, line)
+ self._write(grass.error, text)
def _write(self, function, text):
orig = os.getenv("GRASS_MESSAGE_FORMAT")
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2013-10-22 02:42:36 UTC (rev 58088)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2013-10-22 02:53:29 UTC (rev 58089)
@@ -334,24 +334,24 @@
self.contentChanged.emit(notification=notification)
@param switchPage True to switch page
if pid:
- self.WriteLog(line, style = self.cmdOutput.StyleCommand, notification=notification)
+ self.WriteLog(text, style=self.cmdOutput.StyleCommand, notification=notification)
- self.WriteLog(line, style = self.cmdOutput.StyleWarning, notification=Notification.MAKE_VISIBLE)
+ self.WriteLog(text, style=self.cmdOutput.StyleWarning, notification=Notification.MAKE_VISIBLE)
- self.WriteLog(line, style = self.cmdOutput.StyleError, notification=Notification.MAKE_VISIBLE)
+ self.WriteLog(text, style=self.cmdOutput.StyleError, notification=Notification.MAKE_VISIBLE)
def OnOutputClear(self, event):
"""!Clear content of output window"""
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2013-10-22 02:42:36 UTC (rev 58088)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2013-10-22 02:53:29 UTC (rev 58089)
@@ -153,14 +153,14 @@
self.lmgr._gconsole.WriteLog(text=text, wrap=wrap,
- self.lmgr._gconsole.WriteCmdLog(line=line, pid=pid, notification=notification)
+ self.lmgr._gconsole.WriteCmdLog(text=text, pid=pid, notification=notification)
- self.lmgr._gconsole.WriteWarning(line = line)
+ self.lmgr._gconsole.WriteWarning(text=text)
- self.lmgr._gconsole.WriteError(line = line)
+ self.lmgr._gconsole.WriteError(text=text)
def GetLayerTree(self):
return self.lmgr.GetLayerTree()
