[GRASS-SVN] r58119 - in grass/branches/develbranch_6/lib: gis pngdriver
Tue Oct 29 06:34:07 PDT 2013
Author: martinl
Date: 2013-10-29 06:34:06 -0700 (Tue, 29 Oct 2013)
New Revision: 58119
   grass/branches/develbranch_6/lib/gis/gdal.c
   grass/branches/develbranch_6/lib/pngdriver/read_png.c
   grass/branches/develbranch_6/lib/pngdriver/write_png.c
#2095 (GRASS changes for OSGeo4W 64bit)
      patch provided by jef
Modified: grass/branches/develbranch_6/lib/gis/gdal.c
--- grass/branches/develbranch_6/lib/gis/gdal.c	2013-10-29 01:33:59 UTC (rev 58118)
+++ grass/branches/develbranch_6/lib/gis/gdal.c	2013-10-29 13:34:06 UTC (rev 58119)
@@ -91,6 +91,7 @@
 	"libgdal1.7.0.so",
 # endif
 # ifdef _WIN32
+	"gdal110.dll",
 	"gdal19.dll",
 	"gdal18.dll",
 	"gdal17.dll",
@@ -120,7 +121,7 @@
     load_library();
-# ifdef _WIN32
+# if defined(_WIN32) && !defined(_WIN64)
     pGDALAllRegister   = get_symbol("_GDALAllRegister at 0");
     pGDALOpen          = get_symbol("_GDALOpen at 8");
     pGDALClose         = get_symbol("_GDALClose at 4");
Modified: grass/branches/develbranch_6/lib/pngdriver/read_png.c
--- grass/branches/develbranch_6/lib/pngdriver/read_png.c	2013-10-29 01:33:59 UTC (rev 58118)
+++ grass/branches/develbranch_6/lib/pngdriver/read_png.c	2013-10-29 13:34:06 UTC (rev 58119)
@@ -6,6 +6,28 @@
 #include <grass/gis.h>
 #include "pngdriver.h"
+static void read_data(png_structp png_ptr, png_bytep data, png_size_t length)
+  png_size_t check;
+  FILE *fp;
+  if (png_ptr == NULL )
+    return;
+  fp = (FILE *) png_get_io_ptr(png_ptr);
+  if ( fp == NULL )
+    return;
+  /* fread() returns 0 on error, so it is OK to store this in a png_size_t
+   * instead of an int, which is what fread() actually returns.
+  check = fread(data, 1, length, fp);
+  if (check != length)
+    G_fatal_error("PNG: Read Error");
 void read_png(void)
     static jmp_buf jbuf;
@@ -34,7 +56,7 @@
     if (!input)
 	G_fatal_error("PNG: couldn't open output file %s", file_name);
-    png_init_io(png_ptr, input);
+    png_set_read_fn(png_ptr, input, read_data);
     png_read_info(png_ptr, info_ptr);
Modified: grass/branches/develbranch_6/lib/pngdriver/write_png.c
--- grass/branches/develbranch_6/lib/pngdriver/write_png.c	2013-10-29 01:33:59 UTC (rev 58118)
+++ grass/branches/develbranch_6/lib/pngdriver/write_png.c	2013-10-29 13:34:06 UTC (rev 58119)
@@ -1,4 +1,3 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <png.h>
@@ -6,6 +5,39 @@
+static void write_data(png_structp png_ptr, png_bytep data, png_size_t length)
+    png_size_t check;
+    FILE *fp;
+	return;
+    if ( fp == NULL )
+        return;
+    check = fwrite(data, 1, length, fp);
+	G_fatal_error("PNG: Write Error");
+static void output_flush(png_structp png_ptr)
+    FILE *fp;
+	return;
+    if ( fp == NULL )
+	return;
+    fflush( fp );
 void write_png(void)
@@ -34,7 +66,7 @@
     if (!output)
-    png_init_io(png_ptr, output);
+    png_set_write_fn(png_ptr, output, write_data, output_flush);
     png_set_IHDR(png_ptr, info_ptr,
 		 width, height, 8,
