[GRASS-SVN] r57578 - grass/branches/releasebranch_6_4/scripts/v.rast.stats
svn_grass at osgeo.org
Sun Sep 1 00:07:15 PDT 2013
Author: hamish
Date: 2013-09-01 00:07:15 -0700 (Sun, 01 Sep 2013)
New Revision: 57578
grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
minor linewrap, quoting (merge from devbr6 r57560)
Modified: grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
--- grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2013-09-01 07:05:45 UTC (rev 57577)
+++ grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2013-09-01 07:07:15 UTC (rev 57578)
@@ -146,7 +146,7 @@
# check the input vector map
eval `v.info -t map="$VECTORFULL" layer="$GIS_OPT_LAYER"`
-if [ $areas -eq 0 ] ; then
+if [ "$areas" -eq 0 ] ; then
g.message -e "No areas found in vector map"
exit 1
fi
@@ -195,7 +195,7 @@
r.category "${VECTOR}_$TMPNAME" fs=';' --quiet | cut -d';' -f1 > "$TEMPFILE.cats"
# echo "List of categories found: $CATSLIST"
NUMBER=`cat "$TEMPFILE.cats" | wc -l | awk '{print $1}'`
-if [ $NUMBER -lt 1 ] ; then
+if [ "$NUMBER" -lt 1 ] ; then
g.message -e "No categories found in raster map"
cleanup
exit 1
@@ -212,7 +212,7 @@
DBFDRIVER=0
fi
-if [ $DBFDRIVER -eq 1 ] ; then
+if [ "$DBFDRIVER" -eq 1 ] ; then
# `wc -c` reports number of chars + 1 for the newline
if [ `echo "$COLPREFIX" | wc -c` -gt 10 ] ; then
g.message -e "Cannot create unique names for columns. \
@@ -260,7 +260,7 @@
unset COLNAMES
for i in $BASECOLS $EXTRACOLS ; do
# check if column already present
- if [ $DBFDRIVER -eq 1 ] ; then
+ if [ "$DBFDRIVER" -eq 1 ] ; then
CURRCOLUMN="`echo "${COLPREFIX}_$i" | cut -b1-10`"
else
CURRCOLUMN="${COLPREFIX}_$i"
@@ -310,7 +310,8 @@
do
col=`echo "$ADDCOLS" | cut -d',' -f$n`
- echo "ALTER TABLE $TABLE ADD COLUMN $col" | db.execute database="${DB_DATABASE}" driver="${DB_SQLDRIVER}"
+ echo "ALTER TABLE $TABLE ADD COLUMN $col" | \
+ db.execute database="$DB_DATABASE" driver="$DB_SQLDRIVER"
if [ $? -eq 1 ] ; then
g.message -e "Cannot continue (problem adding column)."
exit 1
@@ -329,14 +330,14 @@
unset $BASECOLS $EXTRACOLS
if [ $GIS_FLAG_E -eq 1 ] ; then
r.univar -t -e map="$RASTER" \
- zones="${VECTOR}_$TMPNAME" percentile="$GIS_OPT_PERCENTILE" | \
- cut -f1,3,5-8,10-13,15-18 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
+ zones="${VECTOR}_$TMPNAME" percentile="$GIS_OPT_PERCENTILE" | \
+ cut -f1,3,5-8,10-13,15-18 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
else
r.univar -t map="$RASTER" zones="${VECTOR}_$TMPNAME" | \
- cut -f1,3,5-8,10-13 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
+ cut -f1,3,5-8,10-13 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
fi
-if [ $GIS_FLAG_E -eq 1 ] && [ $DBFDRIVER -eq 1 ] ; then
+if [ $GIS_FLAG_E -eq 1 ] && [ "$DBFDRIVER" -eq 1 ] ; then
eval "$PERCCOL=\$percentile_$GIS_OPT_PERCENTILE"
fi
@@ -360,13 +361,22 @@
# create SQL file for extended and normal statistics
g.message -v "Creating SQL file ..."
- sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f , '${col10}' = %.2f , '${col11}' = %.2f , '${col12}' = %2f , '${col13}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$1}' > "$SQLTMP"
+ sed -e '1d' "$STATSTMP" | awk -F "|" \
+ '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.15g , \
+ '${col3}' = %.15g , '${col4}' = %.15g , '${col5}' = %.15g , '${col6}' = %.15g , \
+ '${col7}' = %.15g , '${col8}' = %.15g , '${col9}' = %.15g , '${col10}' = %.15g , \
+ '${col11}' = %.15g , '${col12}' = %2f , '${col13}' = %.15g \
+ WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$1}' > "$SQLTMP"
else
- sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
+ '${col7}' = %.15g , '${col8}' = %.15g , '${col9}' = %.15g \
+ WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
fi
g.message message="Updating the database ..."
-db.execute input="$SQLTMP" database="${DB_DATABASE}" driver="$DB_SQLDRIVER"
+db.execute input="$SQLTMP" database="$DB_DATABASE" driver="$DB_SQLDRIVER"
EXITCODE=$?
cleanup
