[GRASS-SVN] r57599 - in grass/trunk/lib/vector/rtree: . test_suite
Thu Sep 5 07:16:49 PDT 2013
Author: huhabla
Date: 2013-09-05 07:16:48 -0700 (Thu, 05 Sep 2013)
New Revision: 57599
Added:
   grass/trunk/lib/vector/rtree/test_suite/
   grass/trunk/lib/vector/rtree/test_suite/Makefile
   grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html
   grass/trunk/lib/vector/rtree/test_suite/test.rtree.lib.html
   grass/trunk/lib/vector/rtree/test_suite/test_basics.c
   grass/trunk/lib/vector/rtree/test_suite/test_main.c
   grass/trunk/lib/vector/rtree/test_suite/test_rtree_lib.h
New rtree testsuite
Added: grass/trunk/lib/vector/rtree/test_suite/Makefile
--- grass/trunk/lib/vector/rtree/test_suite/Makefile	                        (rev 0)
+++ grass/trunk/lib/vector/rtree/test_suite/Makefile	2013-09-05 14:16:48 UTC (rev 57599)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ../../../..
+PGM=test.rtree.lib
+LIBES = $(VECTORLIB) $(GISLIB) $(RTREELIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP) $(RTREEDEP)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+EXTRA_INC = $(VECT_INC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html
--- grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html	                        (rev 0)
+++ grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html	2013-09-05 14:16:48 UTC (rev 57599)
@@ -0,0 +1,3 @@
+Take a look at the module command line help for more information.
Added: grass/trunk/lib/vector/rtree/test_suite/test.rtree.lib.html
Added: grass/trunk/lib/vector/rtree/test_suite/test_basics.c
--- grass/trunk/lib/vector/rtree/test_suite/test_basics.c	                        (rev 0)
+++ grass/trunk/lib/vector/rtree/test_suite/test_basics.c	2013-09-05 14:16:48 UTC (rev 57599)
@@ -0,0 +1,205 @@
+ * MODULE:       Grass PDE Numerical Library
+ * AUTHOR(S):    Soeren Gebbert, Berlin (GER) Dec 2006
+ * 		soerengebbert <at> gmx <dot> de
+ * PURPOSE:      Unit tests for les solving
+ * COPYRIGHT:    (C) 2000 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/glocale.h>
+#include <grass/gis.h>
+#include <grass/rtree.h>
+#include <grass/vector.h>
+#include "test_rtree_lib.h"
+/* prototypes */
+static int test_basics_1d(void);
+static int test_basics_2d(void);
+static int test_basics_3d(void);
+static int test_basics_4d(void);
+/* Performe the solver unit tests ****************************************** */
+int unit_test_basics(void)
+	int sum = 0;
+	G_message(_("\n++ Running basic unit tests ++"));
+        sum += test_basics_1d();
+        sum += test_basics_2d();
+        sum += test_basics_3d();
+        sum += test_basics_4d();
+	if (sum > 0)
+            G_warning(_("\n-- Basic rtree unit tests failure --"));
+	else
+            G_message(_("\n-- Basic rtree unit tests finished successfully --"));
+	return sum;
+int test_basics_1d(void)
+    int sum = 0, num, i;
+    struct RTree* tree = RTreeCreateTree(-1, 0, 1);
+    struct ilist *list = G_new_ilist();
+    for(i = 0; i < 10; i++) {
+        struct RTree_Rect* rect1 = RTreeAllocRect(tree);
+        RTreeSetRect1D(rect1, tree,(i - 2), (i + 2));
+        RTreeInsertRect(rect1, i + 1, tree);
+        struct RTree_Rect* rect2 = RTreeAllocRect(tree);
+        RTreeSetRect1D(rect2, tree, 2.0, 7.0);
+        num = RTreeSearch2(tree, rect2, list);
+        printf("Found %i neighbors\n", num);
+        if(num != i + 1)
+            sum++;
+        RTreeFreeRect(rect1);
+        RTreeFreeRect(rect2);
+    RTreeDestroyTree(tree);
+    G_free_ilist(list);
+    return sum;
+int test_basics_2d(void)
+    struct RTree* tree = RTreeCreateTree(-1, 0, 2);
+        RTreeSetRect2D(rect1, tree,(i - 2), (i + 2), (i - 2), (i + 2));
+        RTreeSetRect2D(rect2, tree, 2.0, 7.0, 2.0, 7.0);
+        if(num != i + 1)
+            sum++;
+    return sum;
+int test_basics_3d(void)
+    struct RTree* tree = RTreeCreateTree(-1, 0, 3);
+        RTreeSetRect3D(rect1, tree,(i - 2), (i + 2), (i - 2), (i + 2),
+                       (i - 2), (i + 2));
+        RTreeSetRect3D(rect2, tree, 2.0, 7.0, 2.0,
+                       7.0, 2.0, 7.0);
+        if(num != i + 1)
+            sum++;
+    return sum;
+int test_basics_4d(void)
+    struct RTree* tree = RTreeCreateTree(-1, 0, 4);
+        RTreeSetRect4D(rect1, tree,(i - 2), (i + 2), (i - 2), (i + 2),
+                       (i - 2), (i + 2), (i - 2), (i + 2));
+        RTreeSetRect4D(rect2, tree, 2.0, 7.0, 2.0,
+                       7.0, 2.0, 7.0, 2.0, 7.0);
+        if(num != i + 1)
+            sum++;
+    return sum;
Added: grass/trunk/lib/vector/rtree/test_suite/test_main.c
--- grass/trunk/lib/vector/rtree/test_suite/test_main.c	                        (rev 0)
+++ grass/trunk/lib/vector/rtree/test_suite/test_main.c	2013-09-05 14:16:48 UTC (rev 57599)
@@ -0,0 +1,93 @@
+ * MODULE:       test.gpde.lib
+ * AUTHOR(S):    Original author
+ *               Soeren Gebbert soerengebbert <at> gmx <dot> de
+ * 		05 Sep 2007 Berlin
+ * PURPOSE:      Unit and integration tests for the gmath library
+ * COPYRIGHT:    (C) 2007 by the GRASS Development Team
+ *   	    	for details.
+/*- Parameters and global variables -----------------------------------------*/
+typedef struct {
+    struct Option *unit, *integration, *solverbenchmark, *blasbenchmark, *rows;
+    struct Flag *full, *testunit, *testint;
+} paramType;
+paramType param; /*Parameters */
+/*- prototypes --------------------------------------------------------------*/
+static void set_params(void); /*Fill the paramType structure */
+/* Set up the arguments we are expecting ********************************** */
+void set_params(void) {
+    param.unit = G_define_option();
+    param.unit->key = "unit";
+    param.unit->type = TYPE_STRING;
+    param.unit->required = YES;
+    param.unit->options = "basics";
+    param.unit->description = _("Choose the unit tests to run");
+    param.testunit = G_define_flag();
+    param.testunit->key = 'u';
+    param.testunit->description = _("Run all unit tests");
+int main(int argc, char *argv[]) {
+    struct GModule *module;
+    int returnstat = 0, i;
+    /* Initialize GRASS */
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->description
+            = _("Performs benchmarks, unit and integration tests for the gmath library");
+    /* Get parameters from user */
+    set_params();
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    /*unit tests */
+    i = 0;
+    if (param.unit->answers) {
+        while (param.unit->answers[i]) {
+            if (strcmp(param.unit->answers[i], "basics") == 0)
+                returnstat += unit_test_basics();
+            i++;
+    if (returnstat != 0)
+        G_warning("Errors detected while testing the gmath lib");
+    else
+        G_message("\n-- gmath lib tests finished successfully --");
+    return (returnstat);
Added: grass/trunk/lib/vector/rtree/test_suite/test_rtree_lib.h
--- grass/trunk/lib/vector/rtree/test_suite/test_rtree_lib.h	                        (rev 0)
+++ grass/trunk/lib/vector/rtree/test_suite/test_rtree_lib.h	2013-09-05 14:16:48 UTC (rev 57599)
@@ -0,0 +1,24 @@
+* MODULE:       Grass gmath Library
+* AUTHOR(S):    Soeren Gebbert, Berlin (GER) Oct 2007
+* 		soerengebbert <at> gmx <dot> de
+* PURPOSE:	Unit and Integration tests
+* COPYRIGHT:    (C) 2000 by the GRASS Development Team
+*               This program is free software under the GNU General Public
+*               License (>=v2). Read the file COPYING that comes with GRASS
+*               for details.
+#ifndef _TEST_GMATH_LIB_H_
+#define _TEST_GMATH_LIB_H_
+/* Basic functionality tests */
+extern int unit_test_basics(void);
+#endif
