[GRASS-SVN] r57610 - grass/trunk/vector/v.voronoi
svn_grass at osgeo.org
Fri Sep 6 11:32:45 PDT 2013
Author: mmetz
Date: 2013-09-06 11:32:45 -0700 (Fri, 06 Sep 2013)
New Revision: 57610
grass/trunk/vector/v.voronoi/main.c
grass/trunk/vector/v.voronoi/sw_defs.h
grass/trunk/vector/v.voronoi/sw_geometry.c
grass/trunk/vector/v.voronoi/sw_main.c
grass/trunk/vector/v.voronoi/sw_output.c
grass/trunk/vector/v.voronoi/vo_extend.c
grass/trunk/vector/v.voronoi/vo_write.c
v.voronoi bugfix for special cases
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/main.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -107,12 +107,14 @@
struct GModule *module;
struct line_pnts *Points;
struct line_cats *Cats;
+ struct bound_box box;
int node, nnodes;
COOR *coor;
int verbose;
int ncoor, acoor;
int line, nlines, type, ctype, area, nareas;
int err_boundaries, err_centr_out, err_centr_dupl, err_nocentr;
+ double snap_thresh;
G_gisinit(argv[0]);
@@ -407,11 +409,22 @@
/* cleaning part 2: snap */
+ /* TODO: adjust snapping treshold to ULP */
+ Vect_get_map_box(&Out, &box);
+ snap_thresh = fabs(box.W);
+ if (snap_thresh < fabs(box.E))
+ snap_thresh = fabs(box.E);
+ if (snap_thresh < fabs(box.N))
+ snap_thresh = fabs(box.N);
+ if (snap_thresh < fabs(box.S))
+ snap_thresh = fabs(box.S);
+ snap_thresh = d_ulp(snap_thresh);
if (err_nocentr || err_centr_dupl || err_centr_out) {
int nmod;
G_important_message(_("Cleaning output topology"));
- Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+ Vect_snap_lines(&Out, GV_BOUNDARY, snap_thresh, NULL);
do {
Vect_break_lines(&Out, GV_BOUNDARY, NULL);
Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
@@ -419,6 +432,11 @@
Vect_clean_small_angles_at_nodes(&Out, GV_BOUNDARY, NULL);
} while (nmod > 0);
+ G_message(_("Removing dangles..."));
+ Vect_remove_dangles(&Out, GV_BOUNDARY, -1.0, NULL);
+ G_message(_("Removing bridges..."));
+ Vect_remove_bridges(&Out, NULL, NULL, NULL);
err_boundaries = 0;
nlines = Vect_get_num_lines(&Out);
for (line = 1; line <= nlines; line++) {
Modified: grass/trunk/vector/v.voronoi/sw_defs.h
--- grass/trunk/vector/v.voronoi/sw_defs.h 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/sw_defs.h 2013-09-06 18:32:45 UTC (rev 57610)
@@ -88,6 +88,7 @@
int makevertex(struct Site *);
int deref(struct Site *);
int ref(struct Site *);
+double d_ulp(double);
/* sw_heap.c */
int PQinsert(struct Halfedge *, struct Site *, double);
Modified: grass/trunk/vector/v.voronoi/sw_geometry.c
--- grass/trunk/vector/v.voronoi/sw_geometry.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/sw_geometry.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -67,14 +67,16 @@
/* single precision ULP */
-static double d_ulp(double d)
+double d_ulp(double d)
int exp;
if (d == 0)
return GRASS_EPSILON;
+ if (d < 0)
+ d = fabs(d);
d = frexp(d, &exp);
exp -= 22;
d = ldexp(d, exp);
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/sw_main.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -126,7 +126,9 @@
if(ltype == -2)
break;
- G_percent(Vect_get_next_line_id(&In), nlines, 2);
+ if (!(ltype & GV_POINTS))
+ continue;
+ /* G_percent(Vect_get_next_line_id(&In), nlines, 2); */
if (!All) {
if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &Box))
@@ -142,6 +144,9 @@
else
sites[nsites].coord.z = 0.0;
+ sites[nsites].sitenbr = nsites;
+ sites[nsites].refcnt = 0;
if (nsites > 1) {
if (xmin > sites[nsites].coord.x)
xmin = sites[nsites].coord.x;
@@ -160,10 +165,10 @@
nsites++;
- if (nsites < 3) {
+ if (nsites < 2) {
const char *name = Vect_get_full_name(&In);
Vect_close(&In);
- G_fatal_error(_("Found %d points/centroids in <%s>, but at least 3 are needed"),
+ G_fatal_error(_("Found %d points/centroids in <%s>, but at least 2 are needed"),
nsites, name);
@@ -172,16 +177,6 @@
(struct Site *)G_realloc(sites,
(nsites) * sizeof(struct Site));
- if (xmin == Box.W)
- Box.W -= GRASS_EPSILON;
- if (xmax == Box.E)
- Box.E += GRASS_EPSILON;
- if (ymin == Box.S)
- Box.S -= GRASS_EPSILON;
- if (ymax == Box.N)
- Box.N += GRASS_EPSILON;
qsort(sites, nsites, sizeof(struct Site), scomp);
removeDuplicates();
Modified: grass/trunk/vector/v.voronoi/sw_output.c
--- grass/trunk/vector/v.voronoi/sw_output.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/sw_output.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -47,17 +47,9 @@
int out_ep(struct Edge *e)
- static struct line_pnts *Points = NULL;
- static struct line_cats *Cats = NULL;
- if (!Points) {
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- if (!triangulate & plot)
+ if ((!triangulate) & plot)
clip_line(e);
- if (!triangulate & !plot) {
+ if ((!triangulate) & !plot) {
fprintf (stdout,"e %d", e->edgenbr);
fprintf (stdout," %d ", e->ep[le] != (struct Site *)NULL ? e->ep[le]->sitenbr : -1);
@@ -85,7 +77,7 @@
int out_site(struct Site *s)
- if (!triangulate & plot & !debug)
+ if ((!triangulate) & plot & (!debug))
circle(s->coord.x, s->coord.y, cradius);
Modified: grass/trunk/vector/v.voronoi/vo_extend.c
--- grass/trunk/vector/v.voronoi/vo_extend.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/vo_extend.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -33,7 +33,7 @@
double nx, ny; /* intersection coordinates */
- if (x > w && x < e && y > s && y < n) {
+ if (x >= w && x <= e && y >= s && y <= n) {
/* vertical line? */
if (a == 0) {
*c_x = knownPointAtLeft ? e : w;
Modified: grass/trunk/vector/v.voronoi/vo_write.c
--- grass/trunk/vector/v.voronoi/vo_write.c 2013-09-06 17:42:40 UTC (rev 57609)
+++ grass/trunk/vector/v.voronoi/vo_write.c 2013-09-06 18:32:45 UTC (rev 57610)
@@ -42,23 +42,43 @@
Vect_write_line(&Out, Type, Points, Cats);
else {
- int knownPointAtLeft;
+ int knownPointAtLeft = -1;
if (e->ep[le] != NULL) {
x1 = e->ep[le]->coord.x;
y1 = e->ep[le]->coord.y;
knownPointAtLeft = 1;
- else {
+ else if (e->ep[re] != NULL) {
x1 = e->ep[re]->coord.x;
y1 = e->ep[re]->coord.y;
knownPointAtLeft = 0;
+ if (knownPointAtLeft == -1) {
+ G_warning("Dead edge!");
+ return 1;
+ x2 = (e->reg[le]->coord.x + e->reg[re]->coord.x) / 2.0;
+ y2 = (e->reg[le]->coord.y + e->reg[re]->coord.y) / 2.0;
+ knownPointAtLeft = 0;
+ if (!extend_line(Box.S, Box.N, Box.W, Box.E,
+ e->a, e->b, e->c, x2, y2, &x1, &y1,
+ knownPointAtLeft)) {
+ G_warning("Undefined edge, unable to extend line");
+ return 0;
+ G_debug(0, "x1 = %g, y1 = %g, x2 = %g, y2 = %g", x1, y1, x2, y2);
+ knownPointAtLeft = 1;
if (extend_line(Box.S, Box.N, Box.W, Box.E,
e->a, e->b, e->c, x1, y1, &x2, &y2,
- knownPointAtLeft)
/* Don't write zero length */
if (x1 == x2 && y1 == y2)
return 0;
