[GRASS-SVN] r57630 - grass/trunk/vector/v.voronoi
Tue Sep 10 13:29:47 PDT 2013
Author: mmetz
Date: 2013-09-10 13:29:47 -0700 (Tue, 10 Sep 2013)
New Revision: 57630
   grass/trunk/vector/v.voronoi/main.c
   grass/trunk/vector/v.voronoi/sw_geometry.c
   grass/trunk/vector/v.voronoi/sw_voronoi.c
   grass/trunk/vector/v.voronoi/vo_write.c
v.voronoi: change option segf to smoothness, clean up code
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c	2013-09-10 14:13:53 UTC (rev 57629)
+++ grass/trunk/vector/v.voronoi/main.c	2013-09-10 20:29:47 UTC (rev 57630)
@@ -102,7 +102,7 @@
 	struct Flag *line, *table, *area;
     } flag;
     struct {
-	struct Option *in, *out, *field, *segf;
+	struct Option *in, *out, *field, *smooth;
     } opt;
     struct GModule *module;
     struct line_pnts *Points;
@@ -132,12 +132,12 @@
     opt.out = G_define_standard_option(G_OPT_V_OUTPUT);
-    opt.segf = G_define_option();
-    opt.segf->type = TYPE_DOUBLE;
-    opt.segf->key = "segment";
-    opt.segf->answer = "0.25";
-    opt.segf->label = _("Factor to control boundary interpolation");
-    opt.segf->description = _("Applies to input areas only. Smaller values produce smoother output but can cause numerical instability.");
+    opt.smooth = G_define_option();
+    opt.smooth->type = TYPE_DOUBLE;
+    opt.smooth->key = "smoothness";
+    opt.smooth->answer = "0.25";
+    opt.smooth->label = _("Factor for output smoothness");
+    opt.smooth->description = _("Applies to input areas only. Smaller values produce smoother output but can cause numerical instability.");
     flag.area = G_define_flag();
     flag.area->key = 'a';
@@ -160,10 +160,10 @@
 	Type = GV_BOUNDARY;
     in_area = flag.area->answer;
-    segf = atof(opt.segf->answer);
+    segf = atof(opt.smooth->answer);
     if (segf < GRASS_EPSILON) {
 	segf = 0.25;
-	G_warning(_("Option '%s' is too small, set to %g"), opt.segf->key, segf);
+	G_warning(_("Option '%s' is too small, set to %g"), opt.smooth->key, segf);
     Points = Vect_new_line_struct();
@@ -387,6 +387,7 @@
     Vect_close(&In);
     /* cleaning part 1: count errors */
+    G_message(_("Searching for topology errors..."));
     G_set_verbose(0);
     Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
     G_set_verbose(verbose);
Modified: grass/trunk/vector/v.voronoi/sw_geometry.c
--- grass/trunk/vector/v.voronoi/sw_geometry.c	2013-09-10 14:13:53 UTC (rev 57629)
+++ grass/trunk/vector/v.voronoi/sw_geometry.c	2013-09-10 20:29:47 UTC (rev 57630)
@@ -215,7 +215,7 @@
 int makevertex(struct Site *v)
-    v->sitenbr = nvertices;
+    v->sitenbr = -1;
     nvertices++;
     out_vertex(v);
     return 0;
Modified: grass/trunk/vector/v.voronoi/sw_voronoi.c
--- grass/trunk/vector/v.voronoi/sw_voronoi.c	2013-09-10 14:13:53 UTC (rev 57629)
+++ grass/trunk/vector/v.voronoi/sw_voronoi.c	2013-09-10 20:29:47 UTC (rev 57630)
@@ -102,6 +102,8 @@
 	e = lbnd->ELedge;
 	out_ep(e);
+    /* TODO: free memory */
     return 0;
Modified: grass/trunk/vector/v.voronoi/vo_write.c
--- grass/trunk/vector/v.voronoi/vo_write.c	2013-09-10 14:13:53 UTC (rev 57629)
+++ grass/trunk/vector/v.voronoi/vo_write.c	2013-09-10 20:29:47 UTC (rev 57630)
@@ -59,11 +59,6 @@
 	    if (knownPointAtLeft == -1) {
-		G_warning("Dead edge!");
-		return 1;
 		x2 = (e->reg[le]->coord.x + e->reg[re]->coord.x) / 2.0;
 		y2 = (e->reg[le]->coord.y + e->reg[re]->coord.y) / 2.0;
 		knownPointAtLeft = 0;
@@ -75,7 +70,6 @@
 		    return 0;
-		G_debug(0, "x1 = %g, y1 = %g, x2 = %g, y2 = %g", x1, y1, x2, y2);
 		knownPointAtLeft = 1;
 	    if (extend_line(Box.S, Box.N, Box.W, Box.E,
