[GRASS-SVN] r57651 - grass/trunk/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Fri Sep 13 03:11:25 PDT 2013
Author: zarch
Date: 2013-09-13 03:11:25 -0700 (Fri, 13 Sep 2013)
New Revision: 57651
grass/trunk/lib/python/pygrass/modules/grid/grid.py
Copy data back to original mapset and log
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-09-13 09:58:14 UTC (rev 57650)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-09-13 10:11:25 UTC (rev 57651)
@@ -62,7 +62,7 @@
return Mapset(mapset.name, location, gisdbase)
-def copy_raster(rasters, src, dst, region=None):
+def copy_raster(rasters, src, dst, region=None, gisrc_dst=None):
"""Copy raster from one mapset to another, crop the raster to the region.
# set region
@@ -80,7 +80,9 @@
# get and set GISRC
gisrc_src = os.environ['GISRC']
- gisrc_dst = write_gisrc(dst.gisdbase, dst.location, dst.name)
+ gisrc_dst = gisrc_dst if gisrc_dst else write_gisrc(dst.gisdbase,
+ dst.location,
+ dst.name)
pdst = dst.path()
for rast in rasters:
@@ -185,7 +187,7 @@
>>> grd.run()
def __init__(self, cmd, width=None, height=None, overlap=0, processes=None,
- split=False, debug=False, region=None, move=None,
+ split=False, debug=False, region=None, move=None, log=False,
start_row=0, start_col=0, out_prefix='',
*args, **kargs):
kargs['run_'] = False
@@ -201,6 +203,7 @@
self.out_prefix = out_prefix
self.n_mset = None
self.gisrc_src = self.gisrc_dst = None
+ self.log = log
if move:
self.n_mset = copy_mapset(self.mset, move)
rasters = select(self.module.inputs, 'raster')
@@ -288,6 +291,28 @@
if patch:
self.patch()
+ if self.n_mset is not None:
+ # move the outputs to the original mapset
+ outputs = [self.out_prefix + o
+ for o in select(self.module.outputs, 'raster')]
+ copy_raster(outputs, self.n_mset, self.mset, self.region,
+ self.gisrc_src)
+ if self.log:
+ # record in the temp directory
+ from grass.lib.gis import G_tempfile
+ tmp, dummy = os.path.split(G_tempfile())
+ tmpdir = os.path.join(tmp, self.module.name)
+ for k in self.module.outputs:
+ par = self.module.outputs[k]
+ if par.typedesc == 'raster' and par.value:
+ dirpath = os.path.join(tmpdir, par.name)
+ if not os.path.isdir(dirpath):
+ os.makedirs(dirpath)
+ fp = open(os.path.join(dirpath,
+ self.out_prefix + par.value), 'w+')
+ fp.close()
if clean:
self.clean_location()
self.rm_tiles()
@@ -298,12 +323,12 @@
for otmap in self.module.outputs:
otm = self.module.outputs[otmap]
if otm.typedesc == 'raster' and otm.value:
- patch_map(self.out_prefix + otm.value,
+ patch_map(otm.value,
self.mset.name, self.msetstr,
split_region_tiles(width=self.width,
height=self.height),
self.module.flags.overwrite,
- self.start_row, self.start_col)
+ self.start_row, self.start_col, self.out_prefix)
def rm_tiles(self):
"""Remove all the tiles."""
