[GRASS-SVN] r57654 - sandbox/turek/scatter_plot
svn_grass at osgeo.org
Fri Sep 13 08:26:44 PDT 2013
Author: turek
Date: 2013-09-13 08:26:44 -0700 (Fri, 13 Sep 2013)
New Revision: 57654
sandbox/turek/scatter_plot/testing_patch.diff
scatter plot: integration into main gui
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff 2013-09-13 15:24:57 UTC (rev 57653)
+++ sandbox/turek/scatter_plot/testing_patch.diff 2013-09-13 15:26:44 UTC (rev 57654)
@@ -1,6 +1,50 @@
+Index: include/defs/vedit.h
+--- include/defs/vedit.h (revision 57652)
++++ include/defs/vedit.h (working copy)
+@@ -33,6 +33,8 @@
+ int Vedit_merge_lines(struct Map_info *, struct ilist *);
+ /* move.c */
++int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
++ struct ilist *, double, double, double, int, double);
+ int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
+Index: include/defs/imagery.h
+--- include/defs/imagery.h (revision 57652)
++++ include/defs/imagery.h (working copy)
+@@ -110,6 +110,26 @@
+ FILE *I_fopen_subgroup_ref_new(const char *, const char *);
+ FILE *I_fopen_subgroup_ref_old(const char *, const char *);
++/* scatt_sccats.c */
++void I_sc_init_cats(struct scCats *, int, int);
++void I_sc_free_cats(struct scCats *);
++int I_sc_add_cat(struct scCats *);
++int I_sc_insert_scatt_data(struct scCats *, struct scdScattData *, int, int);
++void I_scd_init_scatt_data(struct scdScattData *, int, int, void *);
++/* scatt.c */
++int I_compute_scatts(struct Cell_head *, struct scCats *, const char **,
++ const char **, int, struct scCats *, const char **);
++int I_create_cat_rast(struct Cell_head *, const char *);
++int I_insert_patch_to_cat_rast(const char *, struct Cell_head *, const char *);
++int I_id_scatt_to_bands(const int, const int, int *, int *);
++int I_bands_to_id_scatt(const int, const int, const int, int *);
++int I_merge_arrays(unsigned char *, unsigned char *, unsigned, unsigned, double);
++int I_apply_colormap(unsigned char *, unsigned char *, unsigned, unsigned char *, unsigned char *);
+ /* sig.c */
+ int I_init_signatures(struct Signature *, int);
+ int I_new_signature(struct Signature *);
Index: include/imagery.h
---- include/imagery.h (revision 57644)
+--- include/imagery.h (revision 57652)
+++ include/imagery.h (working copy)
@@ -135,6 +135,56 @@
@@ -59,57 +103,13 @@
#define SIGNATURE_TYPE_MIXED 1
#define GROUPFILE "CURGROUP"
-Index: include/defs/vedit.h
---- include/defs/vedit.h (revision 57644)
-+++ include/defs/vedit.h (working copy)
-@@ -33,6 +33,8 @@
- int Vedit_merge_lines(struct Map_info *, struct ilist *);
- /* move.c */
-+int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
-+ struct ilist *, double, double, double, int, double);
- int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
- struct ilist *, double, double, double, int, double);
-Index: include/defs/imagery.h
---- include/defs/imagery.h (revision 57644)
-+++ include/defs/imagery.h (working copy)
-@@ -110,6 +110,26 @@
- FILE *I_fopen_subgroup_ref_new(const char *, const char *);
- FILE *I_fopen_subgroup_ref_old(const char *, const char *);
-+/* scatt_sccats.c */
-+void I_sc_init_cats(struct scCats *, int, int);
-+void I_sc_free_cats(struct scCats *);
-+int I_sc_add_cat(struct scCats *);
-+int I_sc_insert_scatt_data(struct scCats *, struct scdScattData *, int, int);
-+void I_scd_init_scatt_data(struct scdScattData *, int, int, void *);
-+/* scatt.c */
-+int I_compute_scatts(struct Cell_head *, struct scCats *, const char **,
-+ const char **, int, struct scCats *, const char **);
-+int I_create_cat_rast(struct Cell_head *, const char *);
-+int I_insert_patch_to_cat_rast(const char *, struct Cell_head *, const char *);
-+int I_id_scatt_to_bands(const int, const int, int *, int *);
-+int I_bands_to_id_scatt(const int, const int, const int, int *);
-+int I_merge_arrays(unsigned char *, unsigned char *, unsigned, unsigned, double);
-+int I_apply_colormap(unsigned char *, unsigned char *, unsigned, unsigned char *, unsigned char *);
- /* sig.c */
- int I_init_signatures(struct Signature *, int);
- int I_new_signature(struct Signature *);
Index: gui/icons/grass/polygon.png
Cannot display: file marked as a binary type.
svn:mime-type = application/octet-stream
---- gui/icons/grass/polygon.png (revision 57644)
+--- gui/icons/grass/polygon.png (revision 57652)
+++ gui/icons/grass/polygon.png (working copy)
Property changes on: gui/icons/grass/polygon.png
@@ -118,1122 +118,6 @@
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
-Index: gui/wxpython/vdigit/wxdigit.py
---- gui/wxpython/vdigit/wxdigit.py (revision 57644)
-+++ gui/wxpython/vdigit/wxdigit.py (working copy)
-@@ -17,7 +17,7 @@
- (and NumPy would be an excellent candidate for acceleration via
- e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
--(C) 2007-2011 by the GRASS Development Team
-+(C) 2007-2011, 2013 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
-@@ -27,6 +27,8 @@
- import grass.script.core as grass
-+from grass.pydispatch.signal import Signal
- from core.gcmd import GError
- from core.debug import Debug
- from core.settings import UserSettings
-@@ -176,7 +178,21 @@
- if self.poMapInfo:
- self.InitCats()
-+ self.emit_signals = False
-+ # signals which describes features changes during digitization,
-+ # activate them using EmitSignals method
-+ #TODO signal for errors?
-+ self.featureAdded = Signal('IVDigit.featureAdded')
-+ self.areasDeleted = Signal('IVDigit.areasDeleted')
-+ self.vertexMoved = Signal('IVDigit.vertexMoved')
-+ self.vertexAdded = Signal('IVDigit.vertexAdded')
-+ self.vertexRemoved = Signal('IVDigit.vertexRemoved')
-+ self.featuresDeleted = Signal('IVDigit.featuresDeleted')
-+ self.featuresMoved = Signal('IVDigit.featuresMoved')
-+ self.lineEdited = Signal('IVDigit.lineEdited')
- def __del__(self):
- Debug.msg(1, "IVDigit.__del__()")
- Vect_destroy_line_struct(self.poPoints)
-@@ -188,7 +204,12 @@
- Vect_close(self.poBgMapInfo)
- self.poBgMapInfo = self.popoBgMapInfo = None
- del self.bgMapInfo
-+ def EmitSignals(self, emit):
-+ """!Activate/deactivate signals which describes features changes during digitization.
-+ self.emit_signals = emit
- def CloseBackgroundMap(self):
- """!Close background vector map"""
- if not self.poBgMapInfo:
-@@ -394,7 +415,6 @@
- @return tuple (number of added features, feature ids)
- layer = self._getNewFeaturesLayer()
- cat = self._getNewFeaturesCat()
-@@ -419,10 +439,14 @@
- return (-1, None)
- self.toolbar.EnableUndo()
-- return self._addFeature(vtype, points, layer, cat,
-- self._getSnapMode(), self._display.GetThreshold())
-+ ret = self._addFeature(vtype, points, layer, cat,
-+ self._getSnapMode(), self._display.GetThreshold())
-+ if ret[0] > -1 and self.emit_signals:
-+ self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
-+ return ret
- def DeleteSelectedLines(self):
- """!Delete selected features
-@@ -434,16 +458,27 @@
- # collect categories for deleting if requested
- deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
- catDict = dict()
-+ old_bboxs = []
-+ old_areas_cats = []
- if deleteRec:
- for i in self._display.selected['ids']:
- if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
- self._error.ReadLine(i)
-- cats = self.poCats.contents
-- for j in range(cats.n_cats):
-- if cats.field[j] not in catDict.keys():
-- catDict[cats.field[j]] = list()
-- catDict[cats.field[j]].append(cats.cat[j])
-+ if self.emit_signals:
-+ ret = self._getLineAreaBboxCats(i)
-+ if ret:
-+ old_bboxs += ret[0]
-+ old_areas_cats += ret[1]
-+ # catDict was not used -> put into comment
-+ #cats = self.poCats.contents
-+ #for j in range(cats.n_cats):
-+ # if cats.field[j] not in catDict.keys():
-+ # catDict[cats.field[j]] = list()
-+ # catDict[cats.field[j]].append(cats.cat[j])
- poList = self._display.GetSelectedIList()
- nlines = Vedit_delete_lines(self.poMapInfo, poList)
-@@ -456,7 +491,10 @@
- self._deleteRecords(catDict)
- self._addChangeset()
-+ self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
- return nlines
- def _deleteRecords(self, cats):
-@@ -512,22 +550,173 @@
- @return number of deleted
-+ if len(self._display.selected['ids']) < 1:
-+ return 0
- cList = poList.contents
- nareas = 0
-+ old_bboxs = []
- for i in range(cList.n_values):
- if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
- continue
-+ area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
-+ if area > 0:
-+ bbox, cats = self._getaAreaBboxCats(area)
-+ old_bboxs += bbox
-+ old_areas_cats += cats
- nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
- if nareas > 0:
-+ self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-+ return nareas
-+ def _getLineAreaBboxCats(self, ln_id):
-+ ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
-+ if ltype == GV_CENTROID:
-+ #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
-+ return self._getCentroidAreaBboxCats(ln_id)
-+ else:
-+ return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
-+ def _getCentroidAreaBboxCats(self, centroid):
-+ if not Vect_line_alive(self.poMapInfo, centroid):
-+ return None
-+ area = Vect_get_centroid_area(self.poMapInfo, centroid)
-+ if area > 0:
-+ return self._getaAreaBboxCats(area)
-+ else:
-+ return None
-+ def _getaAreaBboxCats(self, area):
-+ po_b_list = Vect_new_list()
-+ Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
-+ b_list = po_b_list.contents
-+ geoms = []
-+ areas_cats = []
-+ if b_list.n_values > 0:
-+ for i_line in range(b_list.n_values):
-+ line = b_list.value[i_line];
-+ geoms.append(self._getBbox(abs(line)))
-+ areas_cats.append(self._getLineAreasCategories(abs(line)))
-- return nareas
-+ Vect_destroy_list(po_b_list);
-+ return geoms, areas_cats
-+ def _getLineAreasCategories(self, ln_id):
-+ if not Vect_line_alive (self.poMapInfo, ln_id):
-+ return []
-+ if ltype != GV_BOUNDARY:
-+ return []
-+ cats = [None, None]
-+ left = c_int()
-+ right = c_int()
-+ if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
-+ areas = [left.value, right.value]
-+ for i, a in enumerate(areas):
-+ if a > 0:
-+ centroid = Vect_get_area_centroid(self.poMapInfo, a)
-+ if centroid <= 0:
-+ continue
-+ c = self._getCategories(centroid)
-+ if c:
-+ cats[i] = c
-+ return cats
-+ def _getCategories(self, ln_id):
-+ return none
-+ poCats = Vect_new_cats_struct()
-+ if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
-+ Vect_destroy_cats_struct(poCats)
-+ return None
-+ cCats = poCats.contents
-+ cats = {}
-+ for j in range(cCats.n_cats):
-+ if cats.has_key(cCats.field[j]):
-+ cats[cCats.field[j]].append(cCats.cat[j])
-+ else:
-+ cats[cCats.field[j]] = [cCats.cat[j]]
-+ return cats
-+ def _getBbox(self, ln_id):
-+ return None
-+ poPoints = Vect_new_line_struct()
-+ if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
-+ Vect_destroy_line_struct(poPoints)
-+ return []
-+ geom = self._convertGeom(poPoints)
-+ bbox = self._createBbox(geom)
-+ return bbox
-+ def _createBbox(self, points):
-+ bbox = {}
-+ for pt in points:
-+ if not bbox.has_key('maxy'):
-+ bbox['maxy'] = pt[1]
-+ bbox['miny'] = pt[1]
-+ bbox['maxx'] = pt[0]
-+ bbox['minx'] = pt[0]
-+ continue
-+ if bbox['maxy'] < pt[1]:
-+ elif bbox['miny'] > pt[1]:
-+ if bbox['maxx'] < pt[0]:
-+ elif bbox['minx'] > pt[0]:
-+ return bbox
-+ def _convertGeom(self, poPoints):
-+ Points = poPoints.contents
-+ pts_geom = []
-+ for j in range(Points.n_points):
-+ pts_geom.append((Points.x[j], Points.y[j]))
-+ return pts_geom
- def MoveSelectedLines(self, move):
- """!Move selected features
-@@ -536,16 +725,45 @@
- if not self._checkMap():
- return -1
-+ nsel = len(self._display.selected['ids'])
-+ if nsel < 1:
-+ return -1
- thresh = self._display.GetThreshold()
- snap = self._getSnapMode()
-+ old_bboxs = []
-+ for sel_id in self._display.selected['ids']:
-+ ret = self._getLineAreaBboxCats(sel_id)
-+ if ret:
-+ Vect_set_updated(self.poMapInfo, 1)
-+ n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
- nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
- poList,
- move[0], move[1], 0,
- snap, thresh)
- Vect_destroy_list(poList)
-+ if nlines > 0 and self.emit_signals:
-+ new_bboxs = []
-+ new_areas_cats = []
-+ n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
-+ for i in range(n_up_lines_old, n_up_lines):
-+ new_id = Vect_get_updated_line(self.poMapInfo, i)
-+ ret = self._getLineAreaBboxCats(new_id)
-+ if ret:
-+ new_bboxs += ret[0]
-+ new_areas_cats += ret[1]
- if nlines > 0 and self._settings['breakLines']:
- for i in range(1, nlines):
- self._breakLineAtIntersection(nlines + i, None, changeset)
-@@ -553,7 +771,13 @@
- if nlines > 0:
-+ self.featuresMoved.emit(new_bboxs = new_bboxs,
-+ old_bboxs = old_bboxs,
-+ old_areas_cats = old_areas_cats,
-+ new_areas_cats = new_areas_cats)
- return nlines
- def MoveSelectedVertex(self, point, move):
-@@ -571,12 +795,21 @@
- if len(self._display.selected['ids']) != 1:
- return -1
-+ # move only first found vertex in bbox
-+ poList = self._display.GetSelectedIList()
-+ cList = poList.contents
-+ old_bboxs = [self._getBbox(cList.value[0])]
-+ old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
- Vect_reset_line(self.poPoints)
- Vect_append_point(self.poPoints, point[0], point[1], 0.0)
-- # move only first found vertex in bbox
-- poList = self._display.GetSelectedIList()
- moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
- poList, self.poPoints,
- self._display.GetThreshold(type = 'selectThresh'),
-@@ -584,7 +817,17 @@
- move[0], move[1], 0.0,
- 1, self._getSnapMode())
-+ if moved > 0 and self.emit_signals:
-+ new_bboxs = []
-+ new_bboxs.append(self._getBbox(new_id))
-+ new_areas_cats.append(self._getLineAreasCategories(new_id))
- if moved > 0 and self._settings['breakLines']:
- self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
- None)
-@@ -592,7 +835,13 @@
- if moved > 0:
-+ self.vertexMoved.emit(new_bboxs = new_bboxs,
-+ new_areas_cats = new_areas_cats,
-+ old_bboxs = old_bboxs)
- return moved
- def AddVertex(self, coords):
-@@ -681,6 +930,10 @@
- self._error.ReadLine(line)
- return -1
-+ old_bboxs = [self._getBbox(line)]
-+ old_areas_cats = [self._getLineAreasCategories(line)]
- # build feature geometry
- for p in coords:
-@@ -696,6 +949,9 @@
- newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
- self.poPoints, self.poCats)
-+ if newline > 0 and self.emit_signals:
-+ new_geom = [self._getBbox(newline)]
-+ new_areas_cats = [self._getLineAreasCategories(newline)]
- if newline > 0 and self._settings['breakLines']:
- self._breakLineAtIntersection(newline, None)
-@@ -703,7 +959,13 @@
- if newline > 0:
-+ self.lineEdited.emit(old_bboxs = old_bboxs,
-+ new_bboxs = new_bboxs,
- return newline
- def FlipLine(self):
-@@ -1514,6 +1776,16 @@
- return 0
- Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
-@@ -1525,15 +1797,35 @@
- else:
- ret = Vedit_remove_vertex(self.poMapInfo, poList,
- self.poPoints, thresh)
-+ if ret > 0 and self.emit_signals:
-+ new_bboxs = []
- if not add and ret > 0 and self._settings['breakLines']:
- None)
- if ret > 0:
-+ if add:
-+ self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
-+ else:
-+ self.vertexRemoved.emit(old_bboxs = old_bboxs,
- return 1
- def GetLineCats(self, line):
-Index: gui/wxpython/vdigit/toolbars.py
---- gui/wxpython/vdigit/toolbars.py (revision 57644)
-+++ gui/wxpython/vdigit/toolbars.py (working copy)
-@@ -17,6 +17,7 @@
- import wx
- from grass.script import core as grass
- from gui_core.toolbars import BaseToolbar, BaseIcons
- from gui_core.dialogs import CreateNewVector
-@@ -42,6 +43,8 @@
- self.digit = None
- self._giface = giface
-+ self.editingStarted = Signal("VDigitToolbar.editingStarted")
- # currently selected map layer for editing (reference to MapLayer instance)
- self.mapLayer = None
- # list of vector layers from Layer Manager (only in the current mapset)
-@@ -860,6 +863,7 @@
- alpha = int(opacity * 255)
- self.digit.GetDisplay().UpdateSettings(alpha = alpha)
-+ self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
- return True
- def StopEditing(self):
-Index: gui/wxpython/vnet/dialogs.py
---- gui/wxpython/vnet/dialogs.py (revision 57644)
-+++ gui/wxpython/vnet/dialogs.py (working copy)
-@@ -1218,7 +1218,7 @@
- pos = (row, 1))
- row += 1
-- gridSizer.Add(item = self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
-+ gridSizer.Add(item=self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- gridSizer.AddGrowableCol(1)
- styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
-Index: gui/wxpython/vnet/toolbars.py
---- gui/wxpython/vnet/toolbars.py (revision 57644)
-+++ gui/wxpython/vnet/toolbars.py (working copy)
-@@ -19,9 +19,9 @@
- import wx
--from icon import MetaIcon
-+from icons.icon import MetaIcon
--from core.gcmd import RunCommand
-+from core.gcmd import RunCommand
- from core.utils import _
- class PointListToolbar(BaseToolbar):
-Index: gui/wxpython/Makefile
---- gui/wxpython/Makefile (revision 57644)
-+++ gui/wxpython/Makefile (working copy)
-@@ -13,7 +13,7 @@
- $(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
- gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
- mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
-- vnet/*.py web_services/*.py wxplot/*.py) \
-+ vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
- gis_set.py gis_set_error.py wxgui.py README
- DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
-@@ -21,8 +21,9 @@
- PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
- gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
-- mapswipe vdigit wxplot web_services rlisetup vnet timeline)
-+ mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
- DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
- default: $(DSTFILES)
-Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py (revision 57644)
-+++ gui/wxpython/mapdisp/toolbars.py (working copy)
-@@ -239,7 +239,8 @@
- (MapIcons["scatter"], self.parent.OnScatterplot),
- (MapIcons["histogram"], self.parent.OnHistogramPyPlot),
- (BaseIcons["histogramD"], self.parent.OnHistogram),
-- (MapIcons["vnet"], self.parent.OnVNet)))
-+ (MapIcons["vnet"], self.parent.OnVNet),
-+ (MapIcons["scatter"], self.parent.OnScatterplot2)))
- def OnDecoration(self, event):
- """!Decorations overlay menu
-Index: gui/wxpython/mapdisp/frame.py
---- gui/wxpython/mapdisp/frame.py (revision 57644)
-+++ gui/wxpython/mapdisp/frame.py (working copy)
-@@ -225,6 +225,7 @@
- self.dialogs = {}
- self.dialogs['attributes'] = None
-+ self.dialogs['scatt_plot'] = None
- self.dialogs['category'] = None
- self.dialogs['barscale'] = None
- self.dialogs['legend'] = None
-@@ -1168,6 +1169,19 @@
- """!Returns toolbar with zooming tools"""
- return self.toolbars['map']
-+ def OnScatterplot2(self, event):
-+ """!Init interactive scatterplot tools
-+ if self.dialogs['scatt_plot']:
-+ self.dialogs['scatt_plot'].Raise()
-+ return
-+ from scatt_plot.dialogs import ScattPlotMainDialog
-+ self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface)
-+ self.dialogs['scatt_plot'].CenterOnScreen()
-+ self.dialogs['scatt_plot'].Show()
- def OnVNet(self, event):
- """!Dialog for v.net* modules
-Index: gui/wxpython/iclass/dialogs.py
---- gui/wxpython/iclass/dialogs.py (revision 57644)
-+++ gui/wxpython/iclass/dialogs.py (working copy)
-@@ -333,13 +333,19 @@
- toolbar.SetCategories(catNames = catNames, catIdx = cats)
- if name in catNames:
- toolbar.choice.SetStringSelection(name)
-+ cat = toolbar.GetSelectedCategoryIdx()
- elif catNames:
- toolbar.choice.SetSelection(0)
-+ else:
-+ cat = None
- if toolbar.choice.IsEmpty():
- toolbar.EnableControls(False)
- else:
- toolbar.EnableControls(True)
-+ self.mapWindow.CategoryChanged(cat)
- # don't forget to update maps, histo, ...
- def GetSelectedIndices(self, state = wx.LIST_STATE_SELECTED):
-Index: gui/wxpython/iclass/toolbars.py
---- gui/wxpython/iclass/toolbars.py (revision 57644)
-+++ gui/wxpython/iclass/toolbars.py (working copy)
-@@ -46,9 +46,7 @@
- 'importAreas' : MetaIcon(img = 'layer-import',
- label = _('Import training areas from vector map')),
- 'addRgb' : MetaIcon(img = 'layer-rgb-add',
-- label = _('Add RGB map layer')),
-- 'scatt_plot' : MetaIcon(img = 'layer-raster-analyze',
-- label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
-+ label = _('Add RGB map layer'))
- class IClassMapToolbar(BaseToolbar):
-@@ -117,10 +115,7 @@
- ("zoomBack", icons["zoomBack"],
- self.parent.OnZoomBack),
- ("zoomToMap", icons["zoomExtent"],
-- self.parent.OnZoomToMap),
-- (None, ),
-- ("scatt_plot", iClassIcons["scatt_plot"],
-- self.parent.OnScatterplot)
-+ self.parent.OnZoomToMap)
- class IClassToolbar(BaseToolbar):
- """!IClass toolbar
-@@ -156,7 +151,7 @@
- """!Toolbar data"""
- icons = iClassIcons
- return self._getToolbarData((("selectGroup", icons['selectGroup'],
-- self.parent.OnAddBands),
-+ lambda event : self.parent.AddBands()),
- (None, ),
- ("classManager", icons['classManager'],
- self.parent.OnCategoryManager),
-Index: gui/wxpython/iclass/frame.py
---- gui/wxpython/iclass/frame.py (revision 57644)
-+++ gui/wxpython/iclass/frame.py (working copy)
-@@ -64,6 +64,8 @@
- IClassExportAreasDialog, IClassMapDialog
- from iclass.plots import PlotPanel
- class IClassMapFrame(DoubleMapFrame):
- """! wxIClass main frame
-@@ -114,6 +116,10 @@
- lambda:
- self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
- self.SetSize(size)
-+ self.groupSet = Signal("IClassMapFrame.groupSet")
-+ self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
- # Add toolbars
-@@ -177,7 +183,7 @@
- # PyPlot init
-- self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
-+ self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
- self._addPanes()
- self._mgr.Update()
-@@ -237,7 +243,7 @@
- return False
- return vectorName
- def RemoveTempVector(self):
- """!Removes temporary vector map with training areas"""
- ret = RunCommand(prog = 'g.remove',
-@@ -334,11 +340,12 @@
- self._addPaneMapWindow(name = 'preview')
- self._addPaneToolbar(name = 'iClassTrainingMapManager')
- self._addPaneMapWindow(name = 'training')
-+ self._mgr.SetDockSizeConstraint(0.5, 0.5)
- self._mgr.AddPane(self.plotPanel, wx.aui.AuiPaneInfo().
- Name("plots").Caption(_("Plots")).
- Dockable(False).Floatable(False).CloseButton(False).
-- Left().Layer(1).BestSize((400, -1)))
-+ Left().Layer(1).BestSize((300, -1)))
- def _addPaneToolbar(self, name):
- if name == 'iClassPreviewMapManager':
-@@ -477,21 +484,47 @@
- self.Render(self.GetFirstWindow())
-- def OnAddBands(self, event):
-+ def AddBands(self):
- """!Add imagery group"""
- dlg = IClassGroupDialog(self, group = self.group)
-- if dlg.ShowModal() == wx.ID_OK:
-- self.SetGroup(dlg.GetGroup())
-+ while True:
-+ if dlg.ShowModal() == wx.ID_OK:
-+ if self.SetGroup(dlg.GetGroup()):
-+ break
-+ else:
-+ break
- dlg.Destroy()
- def SetGroup(self, name):
- """!Set imagery group"""
- group = grass.find_file(name = name, element = 'group')
- if group['name']:
-+ if not self.GroupData(group['name']):
-+ GError(_("No data found in group <%s>.\n" \
-+ "Please create subgroup with same name as group and add the data there.") \
-+ % name, parent = self)
-+ return False
- self.group = group['name']
-+ self.groupSet.emit(group = group['name'])
- else:
- GError(_("Group <%s> not found") % name, parent = self)
-+ return False
-+ return True
-+ def GroupData(self, group):
-+ res = RunCommand('i.group',
-+ flags = 'g',
-+ group = group, subgroup = group,
-+ read = True).strip()
-+ bands = None
-+ if res.split('\n')[0]:
-+ bands = res.split('\n')
-+ return bands
- def OnImportAreas(self, event):
- """!Import training areas"""
- # check if we have any changes
-@@ -768,17 +801,20 @@
- Updates number of stddev, histograms, layer in preview display.
-- stat = self.stats_data.GetStatistics(currentCat)
-- nstd = stat.nstd
-- self.toolbars['iClass'].UpdateStddev(nstd)
-- self.plotPanel.UpdateCategory(currentCat)
-- self.plotPanel.OnPlotTypeSelected(None)
-+ if currentCat:
-+ stat = self.stats_data.GetStatistics(currentCat)
-+ nstd = stat.nstd
-+ self.toolbars['iClass'].UpdateStddev(nstd)
-+ self.plotPanel.UpdateCategory(currentCat)
-+ self.plotPanel.OnPlotTypeSelected(None)
-- name = stat.rasterName
-- name = self.previewMapManager.GetAlias(name)
-- if name:
-- self.previewMapManager.SelectLayer(name)
-+ name = stat.rasterName
-+ name = self.previewMapManager.GetAlias(name)
-+ if name:
-+ self.previewMapManager.SelectLayer(name)
-+ self.categoryChanged.emit(cat = currentCat)
- def DeleteAreas(self, cats):
- """!Removes all training areas of given categories
-@@ -805,12 +841,12 @@
- def UpdateRasterName(self, newName, cat):
- """!Update alias of raster map when category name is changed"""
- origName = self.stats_data.GetStatistics(cat).rasterName
-- self.previewMapManager.SetAlias(origName, newName)
-+ self.previewMapManager.SetAlias(origName, self._addSuffix(newName))
- def StddevChanged(self, cat, nstd):
- """!Standard deviation multiplier changed, rerender map, histograms"""
- stat = self.stats_data.GetStatistics(cat)
-- stat.nstd = nstd
-+ stat.SetStatistics({"nstd" : nstd})
- if not stat.IsReady():
- return
-@@ -923,7 +959,7 @@
- self.ConvertToNull(name = stats.rasterName)
- self.previewMapManager.AddLayer(name = stats.rasterName,
-- alias = stats.name, resultsLayer = True)
-+ alias = self._addSuffix(stats.name), resultsLayer = True)
- # write statistics
- I_iclass_add_signature(self.signatures, statistics)
-@@ -936,7 +972,11 @@
- self.UpdateChangeState(changes = False)
- return True
-+ def _addSuffix(self, name):
-+ suffix = _('results')
-+ return '_'.join((name, suffix))
- def OnSaveSigFile(self, event):
- """!Asks for signature file name and saves it."""
- if not self.group:
-@@ -1105,27 +1145,13 @@
- self.GetFirstWindow().SetModePointer()
- self.GetSecondWindow().SetModePointer()
-- def OnScatterplot(self, event):
-- """!Init interactive scatterplot tools
-- if self.dialogs['scatt_plot']:
-- self.dialogs['scatt_plot'].Raise()
-- return
-+ def GetMapManagers(self):
-+ """!Get map managers of wxIClass
-- try:
-- from scatt_plot.dialogs import ScattPlotMainDialog
-- except:
-- GError(parent = self, message = _("The Scatter Plot Tool is not installed."))
-- return
-+ @return trainingMapManager, previewMapManager
-+ return self.trainingMapManager, self.previewMapManager
-- self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
-- scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
-- scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
-- self.dialogs['scatt_plot'].CenterOnScreen()
-- self.dialogs['scatt_plot'].Show()
- class MapManager:
- """! Class for managing map renderer.
-@@ -1168,7 +1194,6 @@
- self.frame.Render(self.mapWindow)
- if alias is not None:
-- alias = self._addSuffix(alias)
- self.layerName[alias] = name
- name = alias
- else:
-@@ -1225,7 +1250,11 @@
- self.toolbar.choice.SetSelection(0)
-+ def Render(self):
-+ """@todo giface shoud be used instead of this method"""
-+ self.frame.Render(self.mapWindow)
- def RemoveLayer(self, name, idx):
- """!Removes layer from Map and update toolbar"""
- name = self.layerName[name]
-@@ -1281,11 +1310,7 @@
- def _changeOpacity(self, layer, opacity):
- self.map.ChangeOpacity(layer=layer, opacity=opacity)
-- def _addSuffix(self, name):
-- suffix = _('results')
-- return '_'.join((name, suffix))
- def GetAlias(self, name):
- """!Returns alias for layer"""
- name = [k for k, v in self.layerName.iteritems() if v == name]
-@@ -1296,11 +1321,11 @@
- def SetAlias(self, original, alias):
- name = self.GetAlias(original)
- if name:
-- self.layerName[self._addSuffix(alias)] = original
-+ self.layerName[alias] = original
- del self.layerName[name]
- idx = self.toolbar.choice.FindString(name)
- if idx != wx.NOT_FOUND:
-- self.toolbar.choice.SetString(idx, self._addSuffix(alias))
-+ self.toolbar.choice.SetString(idx, alias)
- def test():
- import core.render as render
-Index: gui/wxpython/iclass/plots.py
---- gui/wxpython/iclass/plots.py (revision 57644)
-+++ gui/wxpython/iclass/plots.py (working copy)
-@@ -19,6 +19,7 @@
- import wx.lib.plot as plot
- import wx.lib.scrolledpanel as scrolled
-+from core.gcmd import GError
- class PlotPanel(scrolled.ScrolledPanel):
- """!Panel for drawing multiple plots.
-@@ -28,7 +29,7 @@
- for each band and for one category. Coincidence plots show min max range
- of classes for each band.
-- def __init__(self, parent, stats_data):
-+ def __init__(self, parent, giface, stats_data):
- scrolled.ScrolledPanel.__init__(self, parent)
- self.SetupScrolling(scroll_x = False, scroll_y = True)
-@@ -38,26 +39,71 @@
- self.stats_data = stats_data
- self.currentCat = None
-+ self._giface = giface
- self.mainSizer = wx.BoxSizer(wx.VERTICAL)
- self._createControlPanel()
-+ self._createPlotPanel()
-+ self._createScatterPlotPanel()
- self.SetSizer(self.mainSizer)
- self.mainSizer.Fit(self)
- self.Layout()
-+ def _createPlotPanel(self):
-+ self.canvasPanel = wx.Panel(parent=self)
-+ self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
-+ self.canvasPanel.SetSizer(self.canvasSizer)
- def _createControlPanel(self):
- self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
- choices = [_("Histograms"),
-- _("Coincident plots")])
-+ _("Coincident plots"),
-+ _("Scatter plots")])
- self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
- self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
-+ def _createScatterPlotPanel(self):
-+ try:
-+ from scatt_plot.frame import IClassScatterPlotsPanel
-+ self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
-+ giface=self._giface,
-+ iclass_mapwin = self.parent.GetFirstWindow())
-+ self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.scatt_plot_panel.Hide()
-+ except ImportError as e:#TODO
-+ self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
-+ "Unable to import packages needed for scatter plot.\n%s" % e)
-+ GError(self.scatt_error)
-+ self.scatt_plot_panel = None
- def OnPlotTypeSelected(self, event):
- """!Plot type selected"""
-+ if self.plotSwitch.GetSelection() in [0, 1]:
-+ self.SetupScrolling(scroll_x = False, scroll_y = True)
-+ if self.scatt_plot_panel:
-+ self.canvasPanel.Show()
-+ self.Layout()
-+ elif self.plotSwitch.GetSelection() == 2:
-+ self.SetupScrolling(scroll_x = False, scroll_y = False)
-+ self.scatt_plot_panel.Show()
-+ else:
-+ self.canvasPanel.Hide()
-+ self.Layout()
- if self.currentCat is None:
- return
- if self.plotSwitch.GetSelection() == 0:
- stat = self.stats_data.GetStatistics(self.currentCat)
-@@ -66,7 +112,10 @@
- self.DrawHistograms(stat)
- else:
- self.DrawCoincidencePlots()
-+ self.Layout()
- def StddevChanged(self):
- """!Standard deviation multiplier changed, redraw histograms"""
-@@ -89,7 +138,7 @@
- panel.Destroy()
- self.canvasList = []
- def ClearPlots(self):
- """!Clears plot canvases"""
- for bandIdx in range(len(self.bandList)):
-@@ -104,15 +153,15 @@
- def CreatePlotCanvases(self):
- """!Create plot canvases according to the number of bands"""
- for band in self.bandList:
-- canvas = plot.PlotCanvas(self)
-+ canvas = plot.PlotCanvas(self.canvasPanel)
- canvas.SetMinSize((-1, 140))
- canvas.SetFontSizeTitle(10)
- canvas.SetFontSizeAxis(8)
- self.canvasList.append(canvas)
-- self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-- self.SetVirtualSize(self.GetBestVirtualSize())
-+ self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.SetVirtualSize(self.GetBestVirtualSize())
- self.Layout()
- def UpdatePlots(self, group, currentCat, stats_data):
-@@ -138,7 +187,7 @@
- def UpdateCategory(self, cat):
- self.currentCat = cat
- def DrawCoincidencePlots(self):
- """!Draw coincidence plots"""
Index: gui/wxpython/scatt_plot/core_c.py
--- gui/wxpython/scatt_plot/core_c.py (revision 0)
@@ -1446,7 +330,7 @@
--- gui/wxpython/scatt_plot/frame.py (revision 0)
+++ gui/wxpython/scatt_plot/frame.py (working copy)
-@@ -0,0 +1,636 @@
+@@ -0,0 +1,714 @@
+ at package scatt_plot.dialogs
@@ -1475,7 +359,7 @@
+from gui_core.dialogs import SetOpacityDialog
+from scatt_plot.controllers import ScattsManager
-+from scatt_plot.toolbars import MainToolbar, EditingToolbar
++from scatt_plot.toolbars import MainToolbar, EditingToolbar, CategoryToolbar
+from scatt_plot.scatt_core import idScattToidBands
+from scatt_plot.plots import ScatterPlotWidget
+from vnet.dialogs import VnetStatusbar
@@ -1485,42 +369,44 @@
+except ImportError:
+ import wx.lib.agw.aui as aui
-+class IClassScatterPlotsPanel(wx.Panel):
++class IClassIScattPanel(wx.Panel):
+ def __init__(self, parent, giface, iclass_mapwin = None,
+ id = wx.ID_ANY, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
+ #wx.SplitterWindow.__init__(self, parent = parent, id = id,
+ # style = wx.SP_LIVE_UPDATE)
-+ wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
++ wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY, **kwargs)
-+ #self.head_panel = wx.Panel(parent = self, id = wx.ID_ANY)
-+ self.scatt_mgr = ScattsManager(guiparent = self, giface = giface, iclass_mapwin = iclass_mapwin)
++ self.scatt_mgr = self._createScattMgr(guiparent=parent, giface=giface,
++ iclass_mapwin=iclass_mapwin)
+ # toobars
+ self.toolbars = {}
-+ self.toolbars['mainToolbar'] = MainToolbar(parent = self, scatt_mgr = self.scatt_mgr)
++ self.toolbars['mainToolbar'] = self._createMainToolbar()
+ self.toolbars['editingToolbar'] = EditingToolbar(parent = self, scatt_mgr = self.scatt_mgr)
+ self._createCategoryPanel(self)
-+ self.plot_panel = IClassPlotPanel(self, self.scatt_mgr)
++ self.plot_panel = ScatterPlotsPanel(self, self.scatt_mgr)
+ # statusbar
+ self.stPriors = {'high' : 5, 'info' : 1}
+ self.stBar = VnetStatusbar(parent = self, style = 0)
+ self.stBar.SetFieldsCount(number = 1)
-+ mainsizer = wx.BoxSizer(wx.VERTICAL)
-+ mainsizer.Add(item = self.toolbars['mainToolbar'], proportion = 0, flag = wx.EXPAND)
-+ mainsizer.Add(item = self.toolbars['editingToolbar'], proportion = 0, flag = wx.EXPAND)
-+ mainsizer.Add(item = self.catsPanel, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT , border = 5)
-+ mainsizer.Add(item = self.plot_panel, proportion = 1, flag = wx.EXPAND)
-+ mainsizer.Add(item = self.stBar, proportion = 0)
++ self.mainsizer = wx.BoxSizer(wx.VERTICAL)
++ self.mainsizer.Add(item = self.toolbars['mainToolbar'], proportion = 0, flag = wx.EXPAND)
++ self.mainsizer.Add(item = self.toolbars['editingToolbar'], proportion = 0, flag = wx.EXPAND)
++ self.mainsizer.Add(item = self.catsPanel, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT , border = 5)
++ self.mainsizer.Add(item = self.plot_panel, proportion = 1, flag = wx.EXPAND)
++ self.mainsizer.Add(item = self.stBar, proportion = 0)
+ self.catsPanel.Hide()
+ self.toolbars['editingToolbar'].Hide()
-+ self.SetSizer(mainsizer)
++ self.SetSizer(self.mainsizer)
+ self.scatt_mgr.cursorPlotMove.connect(self.CursorPlotMove)
+ self.scatt_mgr.renderingStarted.connect(lambda : self.stBar.AddStatusItem(text=_("Rendering..."),
@@ -1536,15 +422,22 @@
+ #self.SplitHorizontally(self.head_panel, self.plot_panel, -50)
+ self.Layout()
++ def _selCatInIScatt(self):
++ return False
++ def _createMainToolbar(self):
++ return MainToolbar(parent = self, scatt_mgr = self.scatt_mgr)
++ def _createScattMgr(self, guiparent, giface, iclass_mapwin):
++ return ScattsManager(guiparent=self, giface=giface, iclass_mapwin=iclass_mapwin)
+ def CursorPlotMove(self, x, y):
+ x = int(round(x))
+ y = int(round(y))
+ self.stBar.AddStatusItem(text="%d; %d" % (x, y),
+ key='coords',
+ priority=self.stPriors['info'])
+ def NewScatterPlot(self, scatt_id, transpose):
+ return self.plot_panel.NewScatterPlot(scatt_id, transpose)
@@ -1563,21 +456,73 @@
+ self.Layout()
+ def _createCategoryPanel(self, parent):
-+ self.catsPanel = wx.Panel(parent = parent)
-+ self.cats_list = CategoryListCtrl(parent = self.catsPanel,
-+ cats_mgr = self.scatt_mgr.GetCategoriesManager())
++ self.catsPanel = wx.Panel(parent=parent)
++ self.cats_list = CategoryListCtrl(parent=self.catsPanel,
++ cats_mgr=self.scatt_mgr.GetCategoriesManager(),
++ sel_cats_in_iscatt=self._selCatInIScatt())
+ self.catsPanel.SetMaxSize((-1, 150))
-+ box_capt = wx.StaticBox(parent = self.catsPanel, id = wx.ID_ANY,
-+ label = ' %s ' % _("Classes manager for scatter plots"))
++ box_capt = wx.StaticBox(parent=self.catsPanel, id=wx.ID_ANY,
++ label=' %s ' % _("Classes manager for scatter plots"),)
+ catsSizer = wx.StaticBoxSizer(box_capt, wx.VERTICAL)
-+ catsSizer.Add(item = self.cats_list, proportion = 1, flag = wx.EXPAND | wx.ALL)
++ self.toolbars['categoryToolbar'] = self._createCategoryToolbar(self.catsPanel)
++ catsSizer.Add(item=self.cats_list, proportion=1, flag=wx.EXPAND)
++ if self.toolbars['categoryToolbar']:
++ catsSizer.Add(item=self.toolbars['categoryToolbar'], proportion=0)
+ self.catsPanel.SetSizer(catsSizer)
++ def CleanUp(self):
++ pass
-+class IClassPlotPanel(scrolled.ScrolledPanel):
++ def _createCategoryToolbar(self, parent):
++ return None
++class IScattDialog(wx.Dialog):
++ def __init__(self, parent, giface, title=_("GRASS GIS Interactive Scatter Plot Tool"),
++ id=wx.ID_ANY, style=wx.DEFAULT_FRAME_STYLE, **kwargs):
++ wx.Dialog.__init__(self, parent, id, style=style, title = title, **kwargs)
++ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
++ self.iscatt_panel = MapDispIScattPanel(self, giface)
++ mainsizer = wx.BoxSizer(wx.VERTICAL)
++ mainsizer.Add(item=self.iscatt_panel, proportion=1, flag=wx.EXPAND)
++ self.SetSizer(mainsizer)
++ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
++ self.SetMinSize((300, 300))
++ def OnCloseWindow(self, event):
++ event.Skip()
++ #self.
++class MapDispIScattPanel(IClassIScattPanel):
++ id=wx.ID_ANY, style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
++ IClassIScattPanel.__init__(self, parent=parent, giface=giface,
++ id=id, style=style, **kwargs)
++ return CategoryToolbar(parent=parent,
++ scatt_mgr=self.scatt_mgr,
++ cats_list=self.cats_list)
++ return ScattsManager(guiparent = self, giface = giface)
++ return MainToolbar(parent = self, scatt_mgr = self.scatt_mgr, opt_tools=['add_group'])
++ return True
++class ScatterPlotsPanel(scrolled.ScrolledPanel):
+ def __init__(self, parent, scatt_mgr, id = wx.ID_ANY):
+ scrolled.ScrolledPanel.__init__(self, parent)
@@ -1613,6 +558,8 @@
+ self.scatt_i = 1
+ self.scatt_id_scatt_i = {}
++ self.Bind(wx.EVT_CLOSE, self.OnClose)
+ def ScatterPlotClosed(self, scatt_id):
+ scatt_i = self.scatt_id_scatt_i[scatt_id]
@@ -1658,8 +605,10 @@
+ self.Layout()
+ self.SetupScrolling()
-+ def OnCloseDialog(self, event):
++ def OnClose(self, event):
+ """!Close dialog"""
++ #TODO
++ print "closed"
+ self.scatt_mgr.CleanUp()
+ self.Destroy()
@@ -1722,12 +671,16 @@
+ listmix.ListCtrlAutoWidthMixin,
+ listmix.TextEditMixin):
-+ def __init__(self, parent, cats_mgr, id = wx.ID_ANY):
++ def __init__(self, parent, cats_mgr, sel_cats_in_iscatt, id = wx.ID_ANY):
+ wx.ListCtrl.__init__(self, parent, id,
-+ style = wx.LC_REPORT|wx.LC_VIRTUAL|wx.LC_HRULES|wx.LC_VRULES)
++ style = wx.LC_REPORT|wx.LC_VIRTUAL|wx.LC_HRULES|
++ wx.LC_VRULES|wx.LC_SINGLE_SEL)
+ self.columns = ((_('Class name'), 'name'),
+ (_('Color'), 'color'))
++ self.sel_cats_in_iscatt = sel_cats_in_iscatt
+ self.Populate(columns = self.columns)
+ self.cats_mgr = cats_mgr
@@ -1807,7 +760,16 @@
+ self.SetItemCount(len(self.cats_mgr.GetCategories()))
-+ def OnSel(self, event):
++ def OnSel(self, event):
++ if self.sel_cats_in_iscatt:
++ indexList = self.GetSelectedIndices()
++ sel_cats = []
++ cats = self.cats_mgr.GetCategories()
++ for i in indexList:
++ sel_cats.append(cats[i])
++ if sel_cats:
++ self.cats_mgr.SetSelectedCat(sel_cats[0])
+ event.Skip()
+ def GetSelectedIndices(self, state = wx.LIST_STATE_SELECTED):
@@ -3052,7 +2014,7 @@
--- gui/wxpython/scatt_plot/controllers.py (revision 0)
+++ gui/wxpython/scatt_plot/controllers.py (working copy)
-@@ -0,0 +1,815 @@
+@@ -0,0 +1,883 @@
+ at package scatt_plot.controllers
@@ -3077,20 +2039,18 @@
+import wx
+from core.gcmd import GException, GError, GMessage, RunCommand
++from core.gconsole import EVT_CMD_DONE
++from core.settings import UserSettings
++from scatt_plot.gthreading import gThread
+from scatt_plot.scatt_core import Core, idBandsToidScatt
++from scatt_plot.dialogs import AddScattPlotDialog, ExportCategoryRaster
++from iclass.dialogs import IClassGroupDialog
-+from scatt_plot.dialogs import AddScattPlotDialog, ExportCategoryRaster
-+from scatt_plot.gthreading import gThread
-+from core.gconsole import EVT_CMD_DONE
-+from core.settings import UserSettings
+import grass.script as grass
+class ScattsManager(wx.EvtHandler):
-+ def __init__(self, guiparent, giface, iclass_mapwin):
++ def __init__(self, guiparent, giface, iclass_mapwin = None):
+ #TODO remove iclass parameter
+ wx.EvtHandler.__init__(self)
@@ -3114,8 +2074,6 @@
+ self.thread = gThread(self);
+ self.plots = {}
-+ self.added_cats_rasts = []
+ self.cats_to_update = []
+ self.plot_mode = None
@@ -3131,11 +2089,11 @@
+ self.computingStarted = Signal("ScattsManager.computingStarted")
+ if iclass_mapwin:
-+ self.mapWin_conn = MapWinConnection(self, self.mapWin, self.core.CatRastUpdater())
++ self.digit_conn = IClassDigitConnection(self, self.mapWin, self.core.CatRastUpdater())
+ self.iclass_conn = IClassConnection(self, iclass_mapwin.parent, self.cats_mgr)
+ else:
-+ self.mapWin_conn = None
-+ self.iclass_conn = None
++ self.digit_conn = IMapWinDigitConnection()
++ self.iclass_conn = IMapDispConnection(scatt_mgr=self, cats_mgr=self.cats_mgr, giface=self.giface)
+ self.tasks_pids = {
+ 'add_scatt' : [],
@@ -3237,7 +2195,11 @@
+ self.cats_mgr.OnExportCatRastDone(event)
+ return
-+ def SetData(self, bands):
++ def SetData(self):
++ self.iclass_conn.SetData()
++ def SetBands(self, bands):
+ self.CleanUp()
+ self.data_set = False
@@ -3295,7 +2257,7 @@
+ dlg.Destroy()
-+ self.mapWin_conn.Update()
++ self.digit_conn.Update()
+ def _addScattPlot(self, scatt_id, transpose):
+ if self.plots.has_key(scatt_id):
@@ -3304,7 +2266,9 @@
+ self.tasks_pids['add_scatt'].append(self.thread.GetId())
-+ self.thread.Run(callable = self.core.AddScattPlot, scatt_id = scatt_id, userdata = {'transpose' : transpose})
++ self.thread.Run(callable = self.core.AddScattPlot,
++ scatt_id = scatt_id,
++ userdata = {'transpose' : transpose})
+ def RenderScattPlts(self, scatt_ids = None):
+ if len(self.tasks_pids['render']) > 1:
@@ -3455,52 +2419,12 @@
+ cat_id = event.ret
+ self.RenderScattPlts()
-+ cat_id = event.kwds["cat_id"]
-+ train_mgr, preview_mgr = self.iclass_conn.iclass_frame.GetMapManagers()
-+ if not cat_id in self.added_cats_rasts:
-+ cat_rast = self.core.GetCatRast(cat_id)
-+ cat_name = self.cats_mgr.GetCategoryAttrs(cat_id)['name']
-+ self.UpdateCategoryRaster(cat_id, ['color'], render = False)
-+ train_mgr.AddLayer(cat_rast, alias = cat_name)
-+ self.added_cats_rasts.append(cat_id)
-+ else: #TODO settings
-+ train_mgr.Render()
++ self.iclass_conn.RenderCatRast(cat_id)
-+ def UpdateCategoryRaster(self, cat_id, attrs, render = True):
-+ if not grass.find_file(cat_rast, element = 'cell', mapset = '.')['file']:
-+ return
-+ cats_attrs = self.cats_mgr.GetCategoryAttrs(cat_id)
-+ if "color" in attrs:
-+ ret, err_msg = RunCommand('r.colors',
-+ map=cat_rast,
-+ rules="-",
-+ stdin="1 %s" % cats_attrs["color"],
-+ getErrorMsg=True)
-+ if ret != 0:
-+ GError("r.colors failed\n%s" % err_msg)
-+ if render:
-+ if "name" in attrs:
-+ train_mgr.SetAlias(original=cat_rast, alias=cats_attrs['name'])
-+ cats_attrs["name"]
+ def DigitDataChanged(self, vectMap, digit):
-+ if self.mapWin_conn:
-+ self.mapWin_conn.DigitDataChanged(vectMap, digit)
++ if self.digit_conn:
++ self.digit_conn.DigitDataChanged(vectMap, digit)
+ return 1
+ else:
+ return 0
@@ -3533,14 +2457,7 @@
+ del self.cats_ids[:]
+ self.sel_cat_id = None
-+ def InitCoreCats(self):
-+ if self.scatt_mgr.data_set:
-+ for cat_id in self.cats_ids:
-+ self._addCategory(cat_id)
-+ self.scatt_mgr.mapWin_conn.Update()
+ def ChangePosition(self, cat_id, new_pos):
+ if new_pos >= len(self.cats_ids):
+ return False
@@ -3580,7 +2497,7 @@
+ # return -1;
+ self.cats[cat_id] = {
-+ 'name' : _('Category %s' % cat_id ),
++ 'name' : _('Class %s' % cat_id ),
+ 'color' : "0:0:0",
+ 'opacity' : 1.0,
+ 'show' : True,
@@ -3619,7 +2536,7 @@
+ self.scatt_mgr.RenderScattPlts()
+ if update_cat_rast:
-+ self.scatt_mgr.UpdateCategoryRaster(cat_id, update_cat_rast)
++ self.scatt_mgr.iclass_conn.UpdateCategoryRaster(cat_id, update_cat_rast)
+ self.setCategoryAttrs.emit(cat_id = cat_id, attrs_dict = attrs_dict)
@@ -3688,7 +2605,11 @@
+ (event.userdata['name'], event.kwds['rast_name'], err))
-+class MapWinConnection:
++class IMapWinDigitConnection:
++ def Update(self):
++ pass
++class IClassDigitConnection:
+ def __init__(self, scatt_mgr, mapWin, scatt_rast_updater):
+ self.mapWin = mapWin
+ self.vectMap = None
@@ -3701,15 +2622,6 @@
+ #TODO
+ self.mapWin.parent.toolbars["vdigit"].editingStarted.connect(self.DigitDataChanged)
-+ #def ChangeMap(self, vectMap, layers_cats):
-+ # self.vectMap = vectMap
-+ # self.layers_cats = layers_cats
-+ #ret, region, msg = RunCommand("v.to.rast",
-+ # flags = "gp",
-+ # getErrorMsg = True,
-+ # read = True)
+ def Update(self):
+ self.thread.Run(callable=self.scatt_rast_updater.SynchWithMap)
@@ -3746,7 +2658,6 @@
+ new_areas_cats = [])
+ def EditedFeature(self, new_bboxs, new_areas_cats, old_bboxs, old_areas_cats):
+ if not self.scatt_mgr.data_set:
+ return
@@ -3770,13 +2681,91 @@
+ self._connectSignals()
++class IMapDispConnection:
++ def __init__(self, scatt_mgr, cats_mgr, giface):
++ self.scatt_mgr = scatt_mgr
++ self.cats_mgr = cats_mgr
++ self.set_group = None
++ self.giface = giface
++ self.added_cats_rasts = {}
++ dlg = IClassGroupDialog(self.scatt_mgr.guiparent, group=self.set_group)
++ bands = []
++ while True:
++ if dlg.ShowModal() == wx.ID_OK:
++ bands = dlg.GetGroupBandsErr(parent=self.scatt_mgr.guiparent)
++ if bands:
++ name = dlg.GetGroup()
++ group = grass.find_file(name = name, element = 'group')
++ self.set_group = group['name']
++ break
++ else:
++ break
++ dlg.Destroy()
++ if bands:
++ self.scatt_mgr.SetBands(bands)
++ def EmptyCategories(self):
++ pass
++ def SyncCats(self, cats_ids = None):
++ pass
++ def UpdateCategoryRaster(self, cat_id, attrs, render = True):
++ cat_rast = self.scatt_mgr.core.GetCatRast(cat_id)
++ if not grass.find_file(cat_rast, element = 'cell', mapset = '.')['file']:
++ return
++ cats_attrs = self.cats_mgr.GetCategoryAttrs(cat_id)
++ if "color" in attrs:
++ ret, err_msg = RunCommand('r.colors',
++ map=cat_rast,
++ rules="-",
++ stdin="1 %s" % cats_attrs["color"],
++ getErrorMsg=True)
++ if ret != 0:
++ GError("r.colors failed\n%s" % err_msg)
++ if render:
++ self.giface.updateMap.emit()
++ if "name" in attrs:
++ #TODO hack
++ self.giface.GetLayerList()._tree.SetItemText(self.added_cats_rasts[cat_id],
++ cats_attrs['name'])
++ cats_attrs["name"]
++ def RenderCatRast(self, cat_id):
++ if not cat_id in self.added_cats_rasts.iterkeys():
++ cat_name = self.cats_mgr.GetCategoryAttrs(cat_id)['name']
++ self.UpdateCategoryRaster(cat_id, ['color'], render = False)
++ cmd = ['d.rast', 'map=%s' % cat_rast]
++ #HACK
++ layer = self.giface.GetLayerList()._tree.AddLayer(ltype="raster",
++ lname=cat_name,
++ lcmd=cmd,
++ lchecked=True)
++ self.added_cats_rasts[cat_id] = layer
++ else: #TODO settings
+class IClassConnection:
+ def __init__(self, scatt_mgr, iclass_frame, cats_mgr):
+ self.iclass_frame = iclass_frame
+ self.stats_data = self.iclass_frame.stats_data
+ self.scatt_mgr= scatt_mgr
++ self.added_cats_rasts = []
+ self.stats_data.statisticsAdded.connect(self.AddCategory)
+ self.stats_data.statisticsDeleted.connect(self.DeleteCategory)
@@ -3793,6 +2782,46 @@
+ self.SyncCats()
++ return
++ train_mgr, preview_mgr = self.iclass_frame.GetMapManagers()
++ map=cat_rast,
++ rules="-",
++ if ret != 0:
++ if render:
++ train_mgr.Render()
++ train_mgr.SetAlias(original=cat_rast, alias=cats_attrs['name'])
++ if not cat_id in self.added_cats_rasts:
++ train_mgr.AddLayer(cat_rast, alias = cat_name)
++ self.added_cats_rasts.append(cat_id)
+ self.iclass_frame.AddBands()
@@ -3865,9 +2894,10 @@
+ flags = 'g',
-+ self.scatt_mgr.SetData(bands)
\ No newline at end of file
Index: gui/wxpython/scatt_plot/gthreading.py
@@ -4438,7 +3468,7 @@
--- gui/wxpython/scatt_plot/toolbars.py (revision 0)
+++ gui/wxpython/scatt_plot/toolbars.py (working copy)
-@@ -0,0 +1,224 @@
+@@ -0,0 +1,264 @@
+ at package scatt_plot.toolbars
@@ -4466,9 +3496,10 @@
+class MainToolbar(BaseToolbar):
+ """!Main toolbar
-+ def __init__(self, parent, scatt_mgr):
++ def __init__(self, parent, scatt_mgr, opt_tools=None):
+ BaseToolbar.__init__(self, parent)
++ self.opt_tools = opt_tools
+ self.InitToolbar(self._toolbarData())
@@ -4479,6 +3510,8 @@
+ def _toolbarData(self):
+ icons = {
++ 'selectGroup' : MetaIcon(img = 'layer-group-add',
++ label = _('Select imagery group')),
+ 'settings' : BaseIcons['settings'].SetLabel( _('Settings')),
+ 'help' : MetaIcon(img = 'help',
+ label = _('Show manual')),
@@ -4495,34 +3528,40 @@
+ 'cats_mgr' : MetaIcon(img = 'table-manager',
+ label = _('Show/hide class manager'))
++ tools = [
++ ('add_scatt', icons["add_scatt_pl"],
++ lambda event : self.scatt_mgr.AddScattPlot()),
++ (None, ),
++ ("cats_mgr", icons['cats_mgr'],
++ lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
++ (None, ),
++ ("pan", icons["pan"],
++ lambda event: self.SetPloltsMode(event, 'pan'),
++ wx.ITEM_CHECK),
++ ("zoom", icons["zoomIn"],
++ lambda event: self.SetPloltsMode(event, 'zoom'),
++ wx.ITEM_CHECK),
++ ("zoom_extend", icons["zoomExtent"],
++ lambda event: self.SetPloltsMode(event, 'zoom_extend'),
++ wx.ITEM_CHECK),
++ (None, ),
++ ('sel_pol_mode', icons['selCatPol'],
++ self.ActivateSelectionPolygonMode,
++ wx.ITEM_CHECK),
++ (None, ),
++ ('settings', icons["settings"],
++ self.OnSettings)
++ #('help', icons["help"],
++ # self.OnHelp),
-+ return self._getToolbarData((
-+ ('add_scatt', icons["add_scatt_pl"],
-+ lambda event : self.scatt_mgr.AddScattPlot()),
-+ (None, ),
-+ ("cats_mgr", icons['cats_mgr'],
-+ lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
-+ (None, ),
-+ ("pan", icons["pan"],
-+ lambda event: self.SetPloltsMode(event, 'pan'),
-+ wx.ITEM_CHECK),
-+ ("zoom", icons["zoomIn"],
-+ lambda event: self.SetPloltsMode(event, 'zoom'),
-+ wx.ITEM_CHECK),
-+ ("zoom_extend", icons["zoomExtent"],
-+ lambda event: self.SetPloltsMode(event, 'zoom_extend'),
-+ wx.ITEM_CHECK),
-+ (None, ),
-+ ('sel_pol_mode', icons['selCatPol'],
-+ self.ActivateSelectionPolygonMode,
-+ wx.ITEM_CHECK),
-+ (None, ),
-+ ('settings', icons["settings"],
-+ self.OnSettings)
-+ #('help', icons["help"],
-+ # self.OnHelp),
++ if self.opt_tools and "add_group" in self.opt_tools:
++ tools.insert(0, ("selectGroup", icons['selectGroup'],
++ lambda event : self.scatt_mgr.SetData()))
++ return self._getToolbarData(tools)
+ def GetToolId(self, toolName): #TODO can be useful in base
+ return vars(self)[toolName]
@@ -4662,7 +3701,39 @@
+ self.ToggleTool(i_tool_id, False)
-+ return vars(self)[toolName]
++ return vars(self)[toolName]
++class CategoryToolbar(BaseToolbar):
++ """!Main toolbar
++ def __init__(self, parent, scatt_mgr, cats_list):
++ BaseToolbar.__init__(self, parent)
++ self.cats_mgr = self.scatt_mgr.GetCategoriesManager()
++ self.cats_list = cats_list
++ self.InitToolbar(self._toolbarData())
++ # realize the toolbar
++ self.Realize()
++ def _toolbarData(self):
++ """!Toolbar data
++ self.icons = {
++ 'add_class' : MetaIcon(img = 'layer-add',
++ label = _('Add class.')),
++ 'remove_class' : MetaIcon(img = 'layer-remove',
++ label = _('Remove selected class.'))
++ return self._getToolbarData((
++ ("add_class", self.icons["add_class"],
++ lambda event: self.cats_mgr.AddCategory()),
++ ("remove_class", self.icons['remove_class'],
++ lambda event: self.cats_list.DeleteCategory()),
+\ No newline at end of file
Index: gui/wxpython/scatt_plot/scatt_core.py
--- gui/wxpython/scatt_plot/scatt_core.py (revision 0)
@@ -5381,9 +4452,9 @@
+ for tmp in self.cats_rasts_conds.itervalues():
+ grass.try_remove(tmp)
+ for tmp in self.cats_rasts.itervalues():
-+ print RunCommand("g.remove",
-+ rast=tmp,
++ RunCommand("g.remove",
++ rast=tmp,
+ self.cats_rasts = {}
+ self.cats_rasts_conds = {}
@@ -5463,9 +4534,1196 @@
+ return scatt_id
+Index: gui/wxpython/vnet/dialogs.py
+--- gui/wxpython/vnet/dialogs.py (revision 57652)
++++ gui/wxpython/vnet/dialogs.py (working copy)
+@@ -1218,7 +1218,7 @@
+ pos = (row, 1))
+ row += 1
+- gridSizer.Add(item = self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
++ gridSizer.Add(item=self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+ gridSizer.AddGrowableCol(1)
+ styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+Index: gui/wxpython/vnet/toolbars.py
+--- gui/wxpython/vnet/toolbars.py (revision 57652)
++++ gui/wxpython/vnet/toolbars.py (working copy)
+@@ -19,9 +19,9 @@
+ import wx
+-from icon import MetaIcon
++from icons.icon import MetaIcon
+ from gui_core.toolbars import BaseToolbar, BaseIcons
+-from core.gcmd import RunCommand
++from core.gcmd import RunCommand
+ from core.utils import _
+ class PointListToolbar(BaseToolbar):
+Index: gui/wxpython/Makefile
+--- gui/wxpython/Makefile (revision 57652)
++++ gui/wxpython/Makefile (working copy)
+@@ -13,7 +13,7 @@
+ $(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
+ gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
+ mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
+- vnet/*.py web_services/*.py wxplot/*.py) \
++ vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
+ gis_set.py gis_set_error.py wxgui.py README
+ DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
+@@ -21,8 +21,9 @@
+ PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
+ gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
+- mapswipe vdigit wxplot web_services rlisetup vnet timeline)
++ mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
+ DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
+ default: $(DSTFILES)
+Index: gui/wxpython/vdigit/wxdigit.py
+--- gui/wxpython/vdigit/wxdigit.py (revision 57652)
++++ gui/wxpython/vdigit/wxdigit.py (working copy)
+@@ -17,7 +17,7 @@
+ (and NumPy would be an excellent candidate for acceleration via
+ e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
+-(C) 2007-2011 by the GRASS Development Team
++(C) 2007-2011, 2013 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+@@ -27,6 +27,8 @@
+ import grass.script.core as grass
++from grass.pydispatch.signal import Signal
+ from core.gcmd import GError
+ from core.debug import Debug
+ from core.settings import UserSettings
+@@ -176,7 +178,21 @@
+ if self.poMapInfo:
+ self.InitCats()
++ self.emit_signals = False
++ # signals which describes features changes during digitization,
++ # activate them using EmitSignals method
++ #TODO signal for errors?
++ self.featureAdded = Signal('IVDigit.featureAdded')
++ self.areasDeleted = Signal('IVDigit.areasDeleted')
++ self.vertexMoved = Signal('IVDigit.vertexMoved')
++ self.vertexAdded = Signal('IVDigit.vertexAdded')
++ self.vertexRemoved = Signal('IVDigit.vertexRemoved')
++ self.featuresDeleted = Signal('IVDigit.featuresDeleted')
++ self.featuresMoved = Signal('IVDigit.featuresMoved')
++ self.lineEdited = Signal('IVDigit.lineEdited')
+ def __del__(self):
+ Debug.msg(1, "IVDigit.__del__()")
+ Vect_destroy_line_struct(self.poPoints)
+@@ -188,7 +204,12 @@
+ Vect_close(self.poBgMapInfo)
+ self.poBgMapInfo = self.popoBgMapInfo = None
+ del self.bgMapInfo
++ def EmitSignals(self, emit):
++ """!Activate/deactivate signals which describes features changes during digitization.
++ self.emit_signals = emit
+ def CloseBackgroundMap(self):
+ """!Close background vector map"""
+ if not self.poBgMapInfo:
+@@ -394,7 +415,6 @@
+ @return tuple (number of added features, feature ids)
+ layer = self._getNewFeaturesLayer()
+ cat = self._getNewFeaturesCat()
+@@ -419,10 +439,14 @@
+ return (-1, None)
+ self.toolbar.EnableUndo()
+- return self._addFeature(vtype, points, layer, cat,
+- self._getSnapMode(), self._display.GetThreshold())
++ ret = self._addFeature(vtype, points, layer, cat,
++ self._getSnapMode(), self._display.GetThreshold())
++ if ret[0] > -1 and self.emit_signals:
++ self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
++ return ret
+ def DeleteSelectedLines(self):
+ """!Delete selected features
+@@ -434,16 +458,27 @@
+ # collect categories for deleting if requested
+ deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
+ catDict = dict()
++ old_bboxs = []
++ old_areas_cats = []
+ if deleteRec:
+ for i in self._display.selected['ids']:
+ if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
+ self._error.ReadLine(i)
+- cats = self.poCats.contents
+- for j in range(cats.n_cats):
+- if cats.field[j] not in catDict.keys():
+- catDict[cats.field[j]] = list()
+- catDict[cats.field[j]].append(cats.cat[j])
++ if self.emit_signals:
++ ret = self._getLineAreaBboxCats(i)
++ if ret:
++ old_bboxs += ret[0]
++ old_areas_cats += ret[1]
++ # catDict was not used -> put into comment
++ #cats = self.poCats.contents
++ #for j in range(cats.n_cats):
++ # if cats.field[j] not in catDict.keys():
++ # catDict[cats.field[j]] = list()
++ # catDict[cats.field[j]].append(cats.cat[j])
+ nlines = Vedit_delete_lines(self.poMapInfo, poList)
+@@ -456,7 +491,10 @@
+ self._deleteRecords(catDict)
+ self._addChangeset()
++ self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
+ return nlines
+ def _deleteRecords(self, cats):
+@@ -512,22 +550,173 @@
+ @return number of deleted
++ if len(self._display.selected['ids']) < 1:
++ return 0
+ nareas = 0
++ old_bboxs = []
+ for i in range(cList.n_values):
+ if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
+ continue
++ area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
++ if area > 0:
++ bbox, cats = self._getaAreaBboxCats(area)
++ old_bboxs += bbox
++ old_areas_cats += cats
+ nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
+ if nareas > 0:
++ self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
++ return nareas
++ def _getLineAreaBboxCats(self, ln_id):
++ ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
++ if ltype == GV_CENTROID:
++ #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
++ return self._getCentroidAreaBboxCats(ln_id)
++ else:
++ return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
++ def _getCentroidAreaBboxCats(self, centroid):
++ if not Vect_line_alive(self.poMapInfo, centroid):
++ return None
++ area = Vect_get_centroid_area(self.poMapInfo, centroid)
++ if area > 0:
++ return self._getaAreaBboxCats(area)
++ else:
++ return None
++ def _getaAreaBboxCats(self, area):
++ po_b_list = Vect_new_list()
++ Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
++ b_list = po_b_list.contents
++ geoms = []
++ areas_cats = []
++ if b_list.n_values > 0:
++ for i_line in range(b_list.n_values):
++ line = b_list.value[i_line];
++ geoms.append(self._getBbox(abs(line)))
++ areas_cats.append(self._getLineAreasCategories(abs(line)))
+- return nareas
++ Vect_destroy_list(po_b_list);
++ return geoms, areas_cats
++ def _getLineAreasCategories(self, ln_id):
++ if not Vect_line_alive (self.poMapInfo, ln_id):
++ return []
++ if ltype != GV_BOUNDARY:
++ return []
++ cats = [None, None]
++ left = c_int()
++ right = c_int()
++ if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
++ areas = [left.value, right.value]
++ for i, a in enumerate(areas):
++ if a > 0:
++ centroid = Vect_get_area_centroid(self.poMapInfo, a)
++ if centroid <= 0:
++ continue
++ c = self._getCategories(centroid)
++ if c:
++ cats[i] = c
++ return cats
++ def _getCategories(self, ln_id):
++ return none
++ poCats = Vect_new_cats_struct()
++ if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
++ Vect_destroy_cats_struct(poCats)
++ return None
++ cCats = poCats.contents
++ cats = {}
++ for j in range(cCats.n_cats):
++ if cats.has_key(cCats.field[j]):
++ cats[cCats.field[j]].append(cCats.cat[j])
++ else:
++ cats[cCats.field[j]] = [cCats.cat[j]]
++ return cats
++ def _getBbox(self, ln_id):
++ return None
++ poPoints = Vect_new_line_struct()
++ if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
++ Vect_destroy_line_struct(poPoints)
++ return []
++ geom = self._convertGeom(poPoints)
++ bbox = self._createBbox(geom)
++ return bbox
++ def _createBbox(self, points):
++ bbox = {}
++ for pt in points:
++ if not bbox.has_key('maxy'):
++ bbox['maxy'] = pt[1]
++ bbox['miny'] = pt[1]
++ bbox['maxx'] = pt[0]
++ bbox['minx'] = pt[0]
++ continue
++ if bbox['maxy'] < pt[1]:
++ elif bbox['miny'] > pt[1]:
++ if bbox['maxx'] < pt[0]:
++ elif bbox['minx'] > pt[0]:
++ return bbox
++ def _convertGeom(self, poPoints):
++ Points = poPoints.contents
++ pts_geom = []
++ for j in range(Points.n_points):
++ pts_geom.append((Points.x[j], Points.y[j]))
++ return pts_geom
+ def MoveSelectedLines(self, move):
+ """!Move selected features
+@@ -536,16 +725,45 @@
+ if not self._checkMap():
+ return -1
++ nsel = len(self._display.selected['ids'])
++ if nsel < 1:
++ return -1
+ thresh = self._display.GetThreshold()
+ snap = self._getSnapMode()
++ old_bboxs = []
++ for sel_id in self._display.selected['ids']:
++ ret = self._getLineAreaBboxCats(sel_id)
++ if ret:
++ Vect_set_updated(self.poMapInfo, 1)
++ n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
+ nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+ poList,
+ move[0], move[1], 0,
+ snap, thresh)
+ Vect_destroy_list(poList)
++ if nlines > 0 and self.emit_signals:
++ new_bboxs = []
++ new_areas_cats = []
++ n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
++ for i in range(n_up_lines_old, n_up_lines):
++ new_id = Vect_get_updated_line(self.poMapInfo, i)
++ ret = self._getLineAreaBboxCats(new_id)
++ if ret:
++ new_bboxs += ret[0]
++ new_areas_cats += ret[1]
+ if nlines > 0 and self._settings['breakLines']:
+ for i in range(1, nlines):
+ self._breakLineAtIntersection(nlines + i, None, changeset)
+@@ -553,7 +771,13 @@
+ if nlines > 0:
++ self.featuresMoved.emit(new_bboxs = new_bboxs,
++ old_bboxs = old_bboxs,
++ old_areas_cats = old_areas_cats,
++ new_areas_cats = new_areas_cats)
+ return nlines
+ def MoveSelectedVertex(self, point, move):
+@@ -571,12 +795,21 @@
+ if len(self._display.selected['ids']) != 1:
+ return -1
++ # move only first found vertex in bbox
++ poList = self._display.GetSelectedIList()
++ cList = poList.contents
++ old_bboxs = [self._getBbox(cList.value[0])]
++ old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
+ Vect_reset_line(self.poPoints)
+ Vect_append_point(self.poPoints, point[0], point[1], 0.0)
+- # move only first found vertex in bbox
+- poList = self._display.GetSelectedIList()
+ moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+ poList, self.poPoints,
+ self._display.GetThreshold(type = 'selectThresh'),
+@@ -584,7 +817,17 @@
+ move[0], move[1], 0.0,
+ 1, self._getSnapMode())
++ if moved > 0 and self.emit_signals:
++ new_bboxs = []
++ new_bboxs.append(self._getBbox(new_id))
++ new_areas_cats.append(self._getLineAreasCategories(new_id))
+ if moved > 0 and self._settings['breakLines']:
+ self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
+ None)
+@@ -592,7 +835,13 @@
+ if moved > 0:
++ self.vertexMoved.emit(new_bboxs = new_bboxs,
++ new_areas_cats = new_areas_cats,
++ old_bboxs = old_bboxs)
+ return moved
+ def AddVertex(self, coords):
+@@ -681,6 +930,10 @@
+ self._error.ReadLine(line)
+ return -1
++ old_bboxs = [self._getBbox(line)]
++ old_areas_cats = [self._getLineAreasCategories(line)]
+ # build feature geometry
+ for p in coords:
+@@ -696,6 +949,9 @@
+ newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
+ self.poPoints, self.poCats)
++ if newline > 0 and self.emit_signals:
++ new_geom = [self._getBbox(newline)]
++ new_areas_cats = [self._getLineAreasCategories(newline)]
+ if newline > 0 and self._settings['breakLines']:
+ self._breakLineAtIntersection(newline, None)
+@@ -703,7 +959,13 @@
+ if newline > 0:
++ self.lineEdited.emit(old_bboxs = old_bboxs,
++ new_bboxs = new_bboxs,
+ return newline
+ def FlipLine(self):
+@@ -1514,6 +1776,16 @@
+ return 0
+ Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
+@@ -1525,15 +1797,35 @@
+ else:
+ ret = Vedit_remove_vertex(self.poMapInfo, poList,
+ self.poPoints, thresh)
++ if ret > 0 and self.emit_signals:
++ new_bboxs = []
+ if not add and ret > 0 and self._settings['breakLines']:
+ None)
+ if ret > 0:
++ if add:
++ self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
++ else:
++ self.vertexRemoved.emit(old_bboxs = old_bboxs,
+ return 1
+ def GetLineCats(self, line):
+Index: gui/wxpython/vdigit/toolbars.py
+--- gui/wxpython/vdigit/toolbars.py (revision 57652)
++++ gui/wxpython/vdigit/toolbars.py (working copy)
+@@ -17,6 +17,7 @@
+ import wx
+ from grass.script import core as grass
+ from gui_core.dialogs import CreateNewVector
+@@ -42,6 +43,8 @@
+ self.digit = None
++ self.editingStarted = Signal("VDigitToolbar.editingStarted")
+ # currently selected map layer for editing (reference to MapLayer instance)
+ self.mapLayer = None
+ # list of vector layers from Layer Manager (only in the current mapset)
+@@ -860,6 +863,7 @@
+ alpha = int(opacity * 255)
+ self.digit.GetDisplay().UpdateSettings(alpha = alpha)
++ self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
+ return True
+ def StopEditing(self):
+Index: gui/wxpython/mapdisp/toolbars.py
+--- gui/wxpython/mapdisp/toolbars.py (revision 57652)
++++ gui/wxpython/mapdisp/toolbars.py (working copy)
+@@ -49,6 +49,8 @@
+ label = _('Create histogram of raster map')),
+ 'vnet' : MetaIcon(img = 'vector-tools',
+ label = _('Vector network analysis tool')),
++ 'interact_scatter' : MetaIcon(img = 'layer-raster-profile',
++ label = _("Interactive scatter plot tool")),
+ NvizIcons = {
+@@ -239,7 +241,9 @@
+ (MapIcons["scatter"], self.parent.OnScatterplot),
+ (MapIcons["histogram"], self.parent.OnHistogramPyPlot),
+ (BaseIcons["histogramD"], self.parent.OnHistogram),
+- (MapIcons["vnet"], self.parent.OnVNet)))
++ (MapIcons["vnet"], self.parent.OnVNet),
++ (MapIcons["interact_scatter"],
++ self.parent.OnIScatt)))
+ def OnDecoration(self, event):
+ """!Decorations overlay menu
+Index: gui/wxpython/mapdisp/frame.py
+--- gui/wxpython/mapdisp/frame.py (revision 57652)
++++ gui/wxpython/mapdisp/frame.py (working copy)
+@@ -225,6 +225,7 @@
+ self.dialogs = {}
+ self.dialogs['attributes'] = None
++ self.dialogs['scatt_plot'] = None
+ self.dialogs['category'] = None
+ self.dialogs['barscale'] = None
+ self.dialogs['legend'] = None
+@@ -1168,6 +1169,19 @@
+ """!Returns toolbar with zooming tools"""
+ return self.toolbars['map']
++ def OnIScatt(self, event):
++ """!Init interactive scatterplot tools
++ if self.dialogs['scatt_plot']:
++ self.dialogs['scatt_plot'].Raise()
++ return
++ from scatt_plot.frame import IScattDialog
++ self.dialogs['scatt_plot'] = IScattDialog(parent=self, giface=self._giface)
++ self.dialogs['scatt_plot'].CenterOnScreen()
++ self.dialogs['scatt_plot'].Show()
+ def OnVNet(self, event):
+ """!Dialog for v.net* modules
+Index: gui/wxpython/iclass/dialogs.py
+--- gui/wxpython/iclass/dialogs.py (revision 57652)
++++ gui/wxpython/iclass/dialogs.py (working copy)
+@@ -25,14 +25,14 @@
+ import wx.lib.mixins.listctrl as listmix
+ import wx.lib.scrolledpanel as scrolled
+-from core import globalvar
++from core import globalvar
+-from core.settings import UserSettings
+-from core.gcmd import GMessage
+-from gui_core.dialogs import SimpleDialog, GroupDialog
+-from gui_core import gselect
+-from gui_core.widgets import SimpleValidator
+-from iclass.statistics import Statistics, BandStatistics
++from core.gcmd import GMessage, GError, RunCommand
++from gui_core.dialogs import SimpleDialog, GroupDialog
++from gui_core import gselect
++from gui_core.widgets import SimpleValidator
++from iclass.statistics import Statistics, BandStatistics
+ import grass.script as grass
+@@ -88,7 +88,52 @@
+ if gr in dlg.GetExistGroups():
+ self.element.SetValue(gr)
+ dlg.Destroy()
++ def AddBands(self):
++ """!Add imagery group"""
++ dlg = IClassGroupDialog(self, group = self.group)
++ while True:
++ if self.SetGroup(dlg.GetGroup()):
++ break
++ else:
++ break
++ dlg.Destroy()
++ def GetGroupBandsErr(self, parent):
++ """!Get list of raster bands which are in the soubgroup of group with both having same name.
++ If the group does not exists or it does not contain any bands in subgoup with same name,
++ error dialog is shown.
++ name = self.GetGroup()
++ group = grass.find_file(name=name, element='group')
++ bands = []
++ if group['name']:
++ bands = self.GetGroupBands(group['name'])
++ if not bands:
++ GError(_("No data found in group <%s>.\n" \
++ "Please create subgroup with same name as group and add the data there.") \
++ % name, parent=parent)
++ else:
++ GError(_("Group <%s> not found") % name, parent=parent)
++ return bands
++ def GetGroupBands(self, group):
++ """!Get list of raster bands which are in the soubgroup of group with both having same name."""
++ res = RunCommand('i.group',
++ flags='g',
++ group=group, subgroup=group,
++ read = True).strip()
++ bands = None
++ if res.split('\n')[0]:
++ bands = res.split('\n')
++ return bands
+ class IClassMapDialog(SimpleDialog):
+ """!Dialog for adding raster/vector map"""
+ def __init__(self, parent, title, element):
+@@ -333,13 +378,19 @@
+ toolbar.SetCategories(catNames = catNames, catIdx = cats)
+ if name in catNames:
+ toolbar.choice.SetStringSelection(name)
++ cat = toolbar.GetSelectedCategoryIdx()
+ elif catNames:
+ toolbar.choice.SetSelection(0)
++ else:
++ cat = None
+ if toolbar.choice.IsEmpty():
+ toolbar.EnableControls(False)
+ else:
+ toolbar.EnableControls(True)
++ self.mapWindow.CategoryChanged(cat)
+ # don't forget to update maps, histo, ...
+Index: gui/wxpython/iclass/toolbars.py
+--- gui/wxpython/iclass/toolbars.py (revision 57652)
++++ gui/wxpython/iclass/toolbars.py (working copy)
+@@ -46,9 +46,7 @@
+ 'importAreas' : MetaIcon(img = 'layer-import',
+ label = _('Import training areas from vector map')),
+ 'addRgb' : MetaIcon(img = 'layer-rgb-add',
+- label = _('Add RGB map layer')),
+- 'scatt_plot' : MetaIcon(img = 'layer-raster-analyze',
+- label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
++ label = _('Add RGB map layer'))
+ class IClassMapToolbar(BaseToolbar):
+@@ -117,10 +115,7 @@
+ ("zoomBack", icons["zoomBack"],
+ self.parent.OnZoomBack),
+ ("zoomToMap", icons["zoomExtent"],
+- self.parent.OnZoomToMap),
+- (None, ),
+- ("scatt_plot", iClassIcons["scatt_plot"],
+- self.parent.OnScatterplot)
++ self.parent.OnZoomToMap)
+ class IClassToolbar(BaseToolbar):
+ """!IClass toolbar
+@@ -156,7 +151,7 @@
+ """!Toolbar data"""
+ icons = iClassIcons
+ return self._getToolbarData((("selectGroup", icons['selectGroup'],
+- self.parent.OnAddBands),
++ lambda event : self.parent.AddBands()),
+ (None, ),
+ ("classManager", icons['classManager'],
+ self.parent.OnCategoryManager),
+Index: gui/wxpython/iclass/frame.py
+--- gui/wxpython/iclass/frame.py (revision 57652)
++++ gui/wxpython/iclass/frame.py (working copy)
+@@ -64,6 +64,8 @@
+ IClassExportAreasDialog, IClassMapDialog
+ from iclass.plots import PlotPanel
+ class IClassMapFrame(DoubleMapFrame):
+ """! wxIClass main frame
+@@ -114,6 +116,10 @@
+ lambda:
+ self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
+ self.SetSize(size)
++ self.groupSet = Signal("IClassMapFrame.groupSet")
++ self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
+ # Add toolbars
+@@ -177,7 +183,7 @@
+ # PyPlot init
+- self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
++ self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
+ self._addPanes()
+ self._mgr.Update()
+@@ -237,7 +243,7 @@
+ return False
+ return vectorName
+ def RemoveTempVector(self):
+ """!Removes temporary vector map with training areas"""
+ ret = RunCommand(prog = 'g.remove',
+@@ -334,11 +340,12 @@
+ self._addPaneMapWindow(name = 'preview')
+ self._addPaneToolbar(name = 'iClassTrainingMapManager')
+ self._addPaneMapWindow(name = 'training')
++ self._mgr.SetDockSizeConstraint(0.5, 0.5)
+ self._mgr.AddPane(self.plotPanel, wx.aui.AuiPaneInfo().
+ Name("plots").Caption(_("Plots")).
+ Dockable(False).Floatable(False).CloseButton(False).
+- Left().Layer(1).BestSize((400, -1)))
++ Left().Layer(1).BestSize((300, -1)))
+ def _addPaneToolbar(self, name):
+ if name == 'iClassPreviewMapManager':
+@@ -477,21 +484,24 @@
+ self.Render(self.GetFirstWindow())
+- def OnAddBands(self, event):
+- dlg = IClassGroupDialog(self, group = self.group)
+- if dlg.ShowModal() == wx.ID_OK:
+- self.SetGroup(dlg.GetGroup())
++ dlg = IClassGroupDialog(self, group=self.group)
++ while True:
++ if dlg.GetGroupBandsErr(parent=self):
++ self.group = group['name']
++ self.groupSet.emit(group=self.group)
++ break
++ else:
++ break
+ dlg.Destroy()
+- def SetGroup(self, name):
+- """!Set imagery group"""
+- group = grass.find_file(name = name, element = 'group')
+- if group['name']:
+- self.group = group['name']
+- else:
+- GError(_("Group <%s> not found") % name, parent = self)
+ def OnImportAreas(self, event):
+ """!Import training areas"""
+ # check if we have any changes
+@@ -768,17 +778,20 @@
+ Updates number of stddev, histograms, layer in preview display.
+- stat = self.stats_data.GetStatistics(currentCat)
+- nstd = stat.nstd
+- self.toolbars['iClass'].UpdateStddev(nstd)
+- self.plotPanel.UpdateCategory(currentCat)
+- self.plotPanel.OnPlotTypeSelected(None)
++ if currentCat:
++ stat = self.stats_data.GetStatistics(currentCat)
++ nstd = stat.nstd
++ self.toolbars['iClass'].UpdateStddev(nstd)
++ self.plotPanel.UpdateCategory(currentCat)
++ self.plotPanel.OnPlotTypeSelected(None)
+- name = stat.rasterName
+- name = self.previewMapManager.GetAlias(name)
+- if name:
+- self.previewMapManager.SelectLayer(name)
++ name = stat.rasterName
++ name = self.previewMapManager.GetAlias(name)
++ if name:
++ self.previewMapManager.SelectLayer(name)
++ self.categoryChanged.emit(cat = currentCat)
+ def DeleteAreas(self, cats):
+ """!Removes all training areas of given categories
+@@ -805,12 +818,12 @@
+ def UpdateRasterName(self, newName, cat):
+ """!Update alias of raster map when category name is changed"""
+ origName = self.stats_data.GetStatistics(cat).rasterName
+- self.previewMapManager.SetAlias(origName, newName)
++ self.previewMapManager.SetAlias(origName, self._addSuffix(newName))
+ def StddevChanged(self, cat, nstd):
+ """!Standard deviation multiplier changed, rerender map, histograms"""
+ stat = self.stats_data.GetStatistics(cat)
+- stat.nstd = nstd
++ stat.SetStatistics({"nstd" : nstd})
+ if not stat.IsReady():
+ return
+@@ -923,7 +936,7 @@
+ self.ConvertToNull(name = stats.rasterName)
+ self.previewMapManager.AddLayer(name = stats.rasterName,
+- alias = stats.name, resultsLayer = True)
++ alias = self._addSuffix(stats.name), resultsLayer = True)
+ # write statistics
+ I_iclass_add_signature(self.signatures, statistics)
+@@ -936,7 +949,11 @@
+ self.UpdateChangeState(changes = False)
+ return True
++ def _addSuffix(self, name):
++ suffix = _('results')
++ return '_'.join((name, suffix))
+ def OnSaveSigFile(self, event):
+ """!Asks for signature file name and saves it."""
+ if not self.group:
+@@ -1105,27 +1122,13 @@
+ self.GetFirstWindow().SetModePointer()
+ self.GetSecondWindow().SetModePointer()
+- def OnScatterplot(self, event):
+- """!Init interactive scatterplot tools
+- if self.dialogs['scatt_plot']:
+- self.dialogs['scatt_plot'].Raise()
+- return
++ def GetMapManagers(self):
++ """!Get map managers of wxIClass
+- try:
+- from scatt_plot.dialogs import ScattPlotMainDialog
+- except:
+- GError(parent = self, message = _("The Scatter Plot Tool is not installed."))
+- return
++ @return trainingMapManager, previewMapManager
++ return self.trainingMapManager, self.previewMapManager
+- self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
+- scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
+- scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
+- self.dialogs['scatt_plot'].CenterOnScreen()
+- self.dialogs['scatt_plot'].Show()
+ class MapManager:
+ """! Class for managing map renderer.
+@@ -1168,7 +1171,6 @@
+ if alias is not None:
+- alias = self._addSuffix(alias)
+ self.layerName[alias] = name
+ name = alias
+ else:
+@@ -1225,7 +1227,11 @@
+ self.toolbar.choice.SetSelection(0)
++ def Render(self):
++ """@todo giface shoud be used instead of this method"""
++ self.frame.Render(self.mapWindow)
+ def RemoveLayer(self, name, idx):
+ """!Removes layer from Map and update toolbar"""
+ name = self.layerName[name]
+@@ -1281,11 +1287,7 @@
+ def _changeOpacity(self, layer, opacity):
+ self.map.ChangeOpacity(layer=layer, opacity=opacity)
+- def _addSuffix(self, name):
+- suffix = _('results')
+- return '_'.join((name, suffix))
+ def GetAlias(self, name):
+ """!Returns alias for layer"""
+ name = [k for k, v in self.layerName.iteritems() if v == name]
+@@ -1296,11 +1298,11 @@
+ def SetAlias(self, original, alias):
+ name = self.GetAlias(original)
+ if name:
+- self.layerName[self._addSuffix(alias)] = original
++ self.layerName[alias] = original
+ del self.layerName[name]
+ idx = self.toolbar.choice.FindString(name)
+ if idx != wx.NOT_FOUND:
+- self.toolbar.choice.SetString(idx, self._addSuffix(alias))
++ self.toolbar.choice.SetString(idx, alias)
+ def test():
+ import core.render as render
+Index: gui/wxpython/iclass/plots.py
+--- gui/wxpython/iclass/plots.py (revision 57652)
++++ gui/wxpython/iclass/plots.py (working copy)
+@@ -19,6 +19,7 @@
+ import wx.lib.plot as plot
++from core.gcmd import GError
+ class PlotPanel(scrolled.ScrolledPanel):
+ """!Panel for drawing multiple plots.
+@@ -28,7 +29,7 @@
+ for each band and for one category. Coincidence plots show min max range
+ of classes for each band.
+- def __init__(self, parent, stats_data):
++ def __init__(self, parent, giface, stats_data):
+@@ -38,26 +39,71 @@
+ self.stats_data = stats_data
+ self.currentCat = None
++ self._giface = giface
+ self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+ self._createControlPanel()
++ self._createPlotPanel()
++ self._createScatterPlotPanel()
+ self.SetSizer(self.mainSizer)
+ self.mainSizer.Fit(self)
+ self.Layout()
++ def _createPlotPanel(self):
++ self.canvasPanel = wx.Panel(parent=self)
++ self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
++ self.canvasPanel.SetSizer(self.canvasSizer)
+ def _createControlPanel(self):
+ self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
+ choices = [_("Histograms"),
+- _("Coincident plots")])
++ _("Coincident plots"),
++ _("Scatter plots")])
+ self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
+ self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++ def _createScatterPlotPanel(self):
++ try:
++ from scatt_plot.frame import IClassIScattPanel
++ self.scatt_plot_panel = IClassIScattPanel(parent=self,
++ giface=self._giface,
++ iclass_mapwin = self.parent.GetFirstWindow())
++ self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.scatt_plot_panel.Hide()
++ except ImportError as e:#TODO
++ self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
++ "Unable to import packages needed for scatter plot.\n%s" % e)
++ GError(self.scatt_error)
++ self.scatt_plot_panel = None
+ def OnPlotTypeSelected(self, event):
+ """!Plot type selected"""
++ if self.plotSwitch.GetSelection() in [0, 1]:
++ self.SetupScrolling(scroll_x = False, scroll_y = True)
++ if self.scatt_plot_panel:
++ self.canvasPanel.Show()
++ self.Layout()
++ elif self.plotSwitch.GetSelection() == 2:
++ self.SetupScrolling(scroll_x = False, scroll_y = False)
++ self.scatt_plot_panel.Show()
++ else:
++ self.canvasPanel.Hide()
++ self.Layout()
+ if self.currentCat is None:
+ return
+ if self.plotSwitch.GetSelection() == 0:
+ stat = self.stats_data.GetStatistics(self.currentCat)
+@@ -66,7 +112,10 @@
+ self.DrawHistograms(stat)
+ else:
+ self.DrawCoincidencePlots()
++ self.Layout()
+ def StddevChanged(self):
+ """!Standard deviation multiplier changed, redraw histograms"""
+@@ -89,7 +138,7 @@
+ panel.Destroy()
+ self.canvasList = []
+ def ClearPlots(self):
+ """!Clears plot canvases"""
+ for bandIdx in range(len(self.bandList)):
+@@ -104,15 +153,15 @@
+ def CreatePlotCanvases(self):
+ """!Create plot canvases according to the number of bands"""
+ for band in self.bandList:
+- canvas = plot.PlotCanvas(self)
++ canvas = plot.PlotCanvas(self.canvasPanel)
+ canvas.SetMinSize((-1, 140))
+ canvas.SetFontSizeTitle(10)
+ canvas.SetFontSizeAxis(8)
+ self.canvasList.append(canvas)
+- self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
+- self.SetVirtualSize(self.GetBestVirtualSize())
++ self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.SetVirtualSize(self.GetBestVirtualSize())
+ self.Layout()
+ def UpdatePlots(self, group, currentCat, stats_data):
+@@ -138,7 +187,7 @@
+ def UpdateCategory(self, cat):
+ self.currentCat = cat
+ def DrawCoincidencePlots(self):
+ """!Draw coincidence plots"""
Index: lib/vector/Vlib/open.c
---- lib/vector/Vlib/open.c (revision 57644)
+--- lib/vector/Vlib/open.c (revision 57652)
+++ lib/vector/Vlib/open.c (working copy)
@@ -240,7 +240,9 @@
@@ -5478,6 +5736,416 @@
/* temporary map: reduce to current mapset if search path
* was set */
if (strcmp(Map->mapset, "") == 0)
+Index: lib/imagery/scatt_sccats.c
+--- lib/imagery/scatt_sccats.c (revision 0)
++++ lib/imagery/scatt_sccats.c (working copy)
+@@ -0,0 +1,405 @@
++ \file lib/imagery/scatt_cat_rast.c
++ \brief Imagery library - functions for manipulation with scatter plot structs.
++ Copyright (C) 2013 by the GRASS Development Team
++ This program is free software under the GNU General Public License
++ (>=v2). Read the file COPYING that comes with GRASS for details.
++ \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++ \brief Compute band ids from scatter plot id.
++ Scatter plot id describes which bands defines the scatter plot.
++ Let say we have 3 bands, their ids are 0, 1 and 2.
++ Scatter plot with id 0 consists of band 1 (b_1_id) 0 and band 2 (b_2_id) 1.
++ All scatter plots:
++ scatt_id b_1_id b_2_id
++ 0 0 1
++ 1 0 2
++ 2 1 2
++ \param scatt_id scatter plot id
++ \param n_bands number of bands
++ \param [out] b_1_id id of band1
++ \param[out] b_2_id id of band2
++ \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++ int n_b1 = n_bands - 1;
++ * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++ * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++ return 0;
++ \brief Compute scatter plot id from band ids.
++ See also I_id_scatt_to_bands().
++ \param b_1_id id of band1
++ \param b_1_id id of band2
++ \param [out] scatt_id scatter plot id
++ \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++ * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++ return 0;
++ \brief Initialize structure for storing scatter plots data.
++ \param cats pointer to scCats struct
++ \param type SC_SCATT_DATA - stores scatter plots
++ \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
++ int i_cat;
++ cats->type = type;
++ cats->n_cats = 100;
++ cats->n_a_cats = 0;
++ cats->n_bands = n_bands;
++ cats->n_scatts = (n_bands - 1) * n_bands / 2;
++ cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++ memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++ cats->cats_ids = (int *) G_malloc(cats->n_cats * sizeof(int));
++ cats->cats_idxs =(int *) G_malloc(cats->n_cats * sizeof(int));
++ for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++ cats->cats_idxs[i_cat] = -1;
++ return;
++ \brief Free data of struct scCats, the structure itself remains alocated.
++ \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++ int i_cat;
++ for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
++ if(cats->cats_arr[i_cat])
++ G_free(cats->cats_arr[i_cat]->scatt_idxs);
++ G_free(cats->cats_arr[i_cat]->scatts_bands);
++ G_free(cats->cats_arr[i_cat]->scatts_arr);
++ G_free(cats->cats_arr[i_cat]);
++ G_free(cats->cats_ids);
++ G_free(cats->cats_idxs);
++ G_free(cats->cats_arr);
++ cats->n_cats = 0;
++ cats->n_bands = 0;
++ cats->n_scatts = 0;
++ cats->type = -1;
++ return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++ a_cats_ids = cats->cats_ids;
++ * n_a_cats = cats->n_a_cats;
++#endif
++ \brief Add category.
++ Category represents group of scatter plots.
++ \return assigned category id (starts with 0)
++ \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++ int i_scatt, i_cat_id, cat_id;
++ int n_a_cats = cats->n_a_cats;
++ if(cats->n_a_cats >= cats->n_cats)
++ return -1;
++ for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++ if(cats->cats_idxs[i_cat_id] < 0) {
++ cat_id = i_cat_id;
++ break;
++ cats->cats_ids[n_a_cats] = cat_id;
++ cats->cats_idxs[cat_id] = n_a_cats;
++ cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++ cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++ memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++ cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++ cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++ cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++ for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++ cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++ ++cats->n_a_cats;
++ return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
++ int cat_idx, i_cat;
++ if(cat_id < 0 || cat_id >= cats->n_cats)
++ return -1;
++ cat_idx = cats->cats_idxs[cat_id];
++ if(cat_idx < 0)
++ return -1;
++ G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++ G_free(cats->cats_arr[cat_idx]->scatts_bands);
++ G_free(cats->cats_arr[cat_idx]->scatts_arr);
++ G_free(cats->cats_arr[cat_idx]);
++ for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++ cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++ cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++ cats->cats_idxs[cat_id] = -1;
++ --cats->n_a_cats;
++ return 0;
++#endif
++ \brief Insert scatter plot data .
++ Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
++ \param cat_id id number of category.
++ \param scatt_id id number of scatter plot.
++ \return 0 on success
++ \return -1 on failure
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++ int band_1, band_2, cat_idx, n_a_scatts;
++ struct scScatts * scatts;
++ return -1;
++ if(cat_idx < 0)
++ return -1;
++ if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++ return -1;
++ scatts = cats->cats_arr[cat_idx];
++ if(scatts->scatt_idxs[scatt_id] >= 0)
++ return -1;
++ if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++ return -1;
++ if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++ return -1;
++ n_a_scatts = scatts->n_a_scatts;
++ scatts->scatt_idxs[scatt_id] = n_a_scatts;
++ I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++ scatts->scatts_bands[n_a_scatts * 2] = band_1;
++ scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++ scatts->scatts_arr[n_a_scatts] = scatt_data;
++ ++scatts->n_a_scatts;
++ return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++ int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++ if(cat_id < 0 && cat_id >= cats->n_cats)
++ return -1;
++ if(cat_idx < 0)
++ return -1;
++ if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++ return -1;
++ if(scatts->scatt_idxs[scatt_id] < 0)
++ return -1;
++ scatt_data = scatts->scatts_arr[scatt_idx];
++ for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++ scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++ scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++ scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++ scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++ scatts->scatt_idxs[scatt_id] = -1;
++ scatt_data = scatts->scatts_arr[scatt_id];
++ scatts->n_a_scatts--;
++ return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++ int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++ int cat_idx, scatt_idx, ret;
++ if(cat_idx < 0)
++ return -1;
++ if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++ return -1;
++ scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++ I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++ return 0;
++#endif
++ \brief Insert scatter plot data.
++ \param scatt_data pointer to existing struct scdScattData
++ \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++ \param n_vals number of data values
++ \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++ scatt_data->n_vals = n_vals;
++ if(type == SC_SCATT_DATA)
++ if(data)
++ scatt_data->scatt_vals_arr = (unsigned int *) data;
++ else {
++ scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++ memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++ scatt_data->b_conds_arr = NULL;
++ else if(type == SC_SCATT_CONDITIONS)
++ if(data)
++ scatt_data->b_conds_arr = (unsigned char *) data;
++ else {
++ scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++ memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++ scatt_data->scatt_vals_arr = NULL;
++ return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++ Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++ Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++ return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++ if(!scatt_data->b_conds_arr)
++ return scatt_data->b_conds_arr;
++ else if(!scatt_data->scatt_vals_arr)
++ return scatt_data->scatt_vals_arr;
++ return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++ if(val_idx < 0 && val_idx > scatt_data->n_vals)
++ return -1;
++ if(scatt_data->b_conds_arr)
++ scatt_data->b_conds_arr[val_idx] = val;
++ else if(scatt_data->scatt_vals_arr)
++ scatt_data->scatt_vals_arr[val_idx] = val;
++ else
++ return -1;
++ return 0;
++#endif
Index: lib/imagery/scatt.c
--- lib/imagery/scatt.c (revision 0)
@@ -6282,413 +6950,3 @@
+ return 0;
-Index: lib/imagery/scatt_sccats.c
---- lib/imagery/scatt_sccats.c (revision 0)
-+++ lib/imagery/scatt_sccats.c (working copy)
-@@ -0,0 +1,405 @@
-+ \file lib/imagery/scatt_cat_rast.c
-+ \brief Imagery library - functions for manipulation with scatter plot structs.
-+ Copyright (C) 2013 by the GRASS Development Team
-+ This program is free software under the GNU General Public License
-+ (>=v2). Read the file COPYING that comes with GRASS for details.
-+ \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+ \brief Compute band ids from scatter plot id.
-+ Scatter plot id describes which bands defines the scatter plot.
-+ Let say we have 3 bands, their ids are 0, 1 and 2.
-+ Scatter plot with id 0 consists of band 1 (b_1_id) 0 and band 2 (b_2_id) 1.
-+ All scatter plots:
-+ scatt_id b_1_id b_2_id
-+ 0 0 1
-+ 1 0 2
-+ 2 1 2
-+ \param scatt_id scatter plot id
-+ \param n_bands number of bands
-+ \param [out] b_1_id id of band1
-+ \param[out] b_2_id id of band2
-+ \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+ int n_b1 = n_bands - 1;
-+ * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
-+ * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
-+ return 0;
-+ \brief Compute scatter plot id from band ids.
-+ See also I_id_scatt_to_bands().
-+ \param b_1_id id of band1
-+ \param b_1_id id of band2
-+ \param [out] scatt_id scatter plot id
-+ \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
-+ * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
-+ return 0;
-+ \brief Initialize structure for storing scatter plots data.
-+ \param cats pointer to scCats struct
-+ \param type SC_SCATT_DATA - stores scatter plots
-+ \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+ int i_cat;
-+ cats->type = type;
-+ cats->n_cats = 100;
-+ cats->n_a_cats = 0;
-+ cats->n_bands = n_bands;
-+ cats->n_scatts = (n_bands - 1) * n_bands / 2;
-+ cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+ memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
-+ cats->cats_ids = (int *) G_malloc(cats->n_cats * sizeof(int));
-+ cats->cats_idxs =(int *) G_malloc(cats->n_cats * sizeof(int));
-+ for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+ cats->cats_idxs[i_cat] = -1;
-+ return;
-+ \brief Free data of struct scCats, the structure itself remains alocated.
-+ \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+ int i_cat;
-+ for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
-+ if(cats->cats_arr[i_cat])
-+ G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+ G_free(cats->cats_arr[i_cat]->scatts_bands);
-+ G_free(cats->cats_arr[i_cat]->scatts_arr);
-+ G_free(cats->cats_arr[i_cat]);
-+ G_free(cats->cats_ids);
-+ G_free(cats->cats_idxs);
-+ G_free(cats->cats_arr);
-+ cats->n_cats = 0;
-+ cats->n_bands = 0;
-+ cats->n_scatts = 0;
-+ cats->type = -1;
-+ return;
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+ a_cats_ids = cats->cats_ids;
-+ * n_a_cats = cats->n_a_cats;
-+#endif
-+ \brief Add category.
-+ Category represents group of scatter plots.
-+ \return assigned category id (starts with 0)
-+ \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+ int i_scatt, i_cat_id, cat_id;
-+ int n_a_cats = cats->n_a_cats;
-+ if(cats->n_a_cats >= cats->n_cats)
-+ return -1;
-+ for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+ if(cats->cats_idxs[i_cat_id] < 0) {
-+ cat_id = i_cat_id;
-+ break;
-+ cats->cats_ids[n_a_cats] = cat_id;
-+ cats->cats_idxs[cat_id] = n_a_cats;
-+ cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+ cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+ memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+ cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+ cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+ cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+ for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+ cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+ ++cats->n_a_cats;
-+ return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+ int cat_idx, i_cat;
-+ if(cat_id < 0 || cat_id >= cats->n_cats)
-+ return -1;
-+ cat_idx = cats->cats_idxs[cat_id];
-+ if(cat_idx < 0)
-+ return -1;
-+ G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+ G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+ G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+ G_free(cats->cats_arr[cat_idx]);
-+ for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+ cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+ cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+ cats->cats_idxs[cat_id] = -1;
-+ --cats->n_a_cats;
-+ return 0;
-+#endif
-+ \brief Insert scatter plot data .
-+ Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+ \param cat_id id number of category.
-+ \param scatt_id id number of scatter plot.
-+ \return 0 on success
-+ \return -1 on failure
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+ int band_1, band_2, cat_idx, n_a_scatts;
-+ struct scScatts * scatts;
-+ return -1;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+ return -1;
-+ scatts = cats->cats_arr[cat_idx];
-+ if(scatts->scatt_idxs[scatt_id] >= 0)
-+ return -1;
-+ if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+ return -1;
-+ if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+ return -1;
-+ n_a_scatts = scatts->n_a_scatts;
-+ scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+ I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+ scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+ scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+ scatts->scatts_arr[n_a_scatts] = scatt_data;
-+ ++scatts->n_a_scatts;
-+ return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+ int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+ if(cat_id < 0 && cat_id >= cats->n_cats)
-+ return -1;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+ return -1;
-+ if(scatts->scatt_idxs[scatt_id] < 0)
-+ return -1;
-+ scatt_data = scatts->scatts_arr[scatt_idx];
-+ for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+ scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+ scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+ scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+ scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+ scatts->scatt_idxs[scatt_id] = -1;
-+ scatt_data = scatts->scatts_arr[scatt_id];
-+ scatts->n_a_scatts--;
-+ return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+ int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+ int cat_idx, scatt_idx, ret;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+ return -1;
-+ scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+ I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+ return 0;
-+#endif
-+ \brief Insert scatter plot data.
-+ \param scatt_data pointer to existing struct scdScattData
-+ \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+ \param n_vals number of data values
-+ \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+ scatt_data->n_vals = n_vals;
-+ if(type == SC_SCATT_DATA)
-+ if(data)
-+ scatt_data->scatt_vals_arr = (unsigned int *) data;
-+ else {
-+ scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+ memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+ scatt_data->b_conds_arr = NULL;
-+ else if(type == SC_SCATT_CONDITIONS)
-+ if(data)
-+ scatt_data->b_conds_arr = (unsigned char *) data;
-+ else {
-+ scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+ memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+ scatt_data->scatt_vals_arr = NULL;
-+ return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+ Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+ Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+ return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+ if(!scatt_data->b_conds_arr)
-+ return scatt_data->b_conds_arr;
-+ else if(!scatt_data->scatt_vals_arr)
-+ return scatt_data->scatt_vals_arr;
-+ return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+ if(val_idx < 0 && val_idx > scatt_data->n_vals)
-+ return -1;
-+ if(scatt_data->b_conds_arr)
-+ scatt_data->b_conds_arr[val_idx] = val;
-+ else if(scatt_data->scatt_vals_arr)
-+ scatt_data->scatt_vals_arr[val_idx] = val;
-+ else
-+ return -1;
-+ return 0;
-+#endif
