[GRASS-SVN] r57671 - grass/branches/releasebranch_6_4/raster/r.null
svn_grass at osgeo.org
Fri Sep 13 20:10:50 PDT 2013
Author: hamish
Date: 2013-09-13 20:10:50 -0700 (Fri, 13 Sep 2013)
New Revision: 57671
grass/branches/releasebranch_6_4/raster/r.null/null.c
int to boolean macros for readability (sync with devbr6, partial merge of r50234)
Modified: grass/branches/releasebranch_6_4/raster/r.null/null.c
--- grass/branches/releasebranch_6_4/raster/r.null/null.c 2013-09-14 03:07:25 UTC (rev 57670)
+++ grass/branches/releasebranch_6_4/raster/r.null/null.c 2013-09-14 03:10:50 UTC (rev 57671)
@@ -33,7 +33,7 @@
int row, col, null_fd;
unsigned char *null_bits;
RASTER_MAP_TYPE map_type;
- int change_null = 0, create, remove, only_int, only_fp, only_null;
+ int change_null = FALSE, create, remove, only_int, only_fp, only_null;
int is_reclass;
struct GModule *module;
@@ -131,7 +131,7 @@
if (parms.null->answer) {
if (sscanf(parms.null->answer, "%lf", &new_null) == 1)
- change_null = 1;
+ change_null = TRUE;
else
G_fatal_error(_("%s is illegal entry for null"),
parms.null->answer);
@@ -177,8 +177,7 @@
for (row = 0; row < cellhd.rows; row++) {
G_percent(row, cellhd.rows, 1);
- if (G__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) <
- 0)
+ if (G__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) < 0)
G_fatal_error(_("Error writing null row %d"), row);
