[GRASS-SVN] r57679 - grass/branches/releasebranch_6_4/general/g.setproj
svn_grass at osgeo.org
Fri Sep 13 22:28:55 PDT 2013
Author: hamish
Date: 2013-09-13 22:28:55 -0700 (Fri, 13 Sep 2013)
New Revision: 57679
grass/branches/releasebranch_6_4/general/g.setproj/main.c
options to read and reset the location's one line description (merge from devbr6 r56961, wish #2018)
Modified: grass/branches/releasebranch_6_4/general/g.setproj/main.c
--- grass/branches/releasebranch_6_4/general/g.setproj/main.c 2013-09-14 05:17:25 UTC (rev 57678)
+++ grass/branches/releasebranch_6_4/general/g.setproj/main.c 2013-09-14 05:28:55 UTC (rev 57679)
@@ -57,21 +57,24 @@
int stat;
char cmnd2[500];
char proj_out[20], proj_name[50], set_name[20];
- char path[1024], buffa[1024], buffb[1024], answer[200], answer1[200];
+ char path[GPATH_MAX], buffa[1024], buffb[1024], answer[200], answer1[200];
char answer2[200], buff[1024];
char tmp_buff[20], *buf;
struct Key_Value *old_proj_keys, *out_proj_keys, *in_unit_keys;
double aa, e2;
double f;
- FILE *FPROJ;
+ FILE *FPROJ, *fp;
int exist = 0;
char spheroid[100];
int j, k, sph_check;
struct Cell_head cellhd;
char datum[100], dat_ellps[100], dat_params[100];
struct proj_parm *proj_parms;
+ struct Option *set_myname;
+ struct Flag *print_myname;
G_gisinit(argv[0]);
module = G_define_module();
@@ -79,15 +82,45 @@
module->description =
_("Interactively reset the location's projection settings.");
+ set_myname = G_define_option();
+ set_myname->key = "description";
+ set_myname->key_desc = "\"phrase\"";
+ set_myname->type = TYPE_STRING;
+ set_myname->required = NO;
+ set_myname->description =
+ _("Reset the location's one line description with this text, then exit");
+ print_myname = G_define_flag();
+ print_myname->key = 'n';
+ print_myname->description =
+ _("Print the location's one line description and exit");
if (argc > 1 && G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (print_myname->answer) {
+ fprintf(stdout, "%s\n", G_myname());
+ exit(EXIT_SUCCESS);
if (strcmp(G_mapset(), "PERMANENT") != 0)
G_fatal_error(_("You must be in the PERMANENT mapset to run g.setproj"));
+ if (set_myname->answer) {
+ fp = G_fopen_new(".", "MYNAME");
+ if (strlen(set_myname->answer) > RECORD_LEN-1)
+ G_warning(_("Text shortened to first %d characters"), RECORD_LEN-1);
+ strncpy(buffa, set_myname->answer, RECORD_LEN-1);
+ buffa[RECORD_LEN-1] = '\0';
+ G_squeeze(buffa);
+ fputs(buffa, fp);
+ fclose(fp);
- * no longer necessary, table is a static struct
+ * no longer necessary, table is a static struct
* init_unit_table();
sprintf(set_name, "PERMANENT");
@@ -246,7 +279,7 @@
else {
-/***************** GET spheroid **************************/
+ /***************** GET spheroid **************************/
if (Out_proj != PROJECTION_SP) { /* some projections have
* fixed spheroids */
@@ -318,7 +351,7 @@
radius =
prompt_num_double(_("Enter radius for the sphere in meters"),
RADIUS_DEF, 1);
- } /* end ask radius */
+ } /* end ask radius */
@@ -486,7 +519,7 @@
G_set_key_value(desc->key, tmp_buff, out_proj_keys);
- } /* for OPTIONS */
+ } /* for OPTIONS */
/* create the PROJ_INFO & PROJ_UNITS files, if required */
