[GRASS-SVN] r57690 - grass/trunk/gui/wxpython/nviz
svn_grass at osgeo.org
Sat Sep 14 20:20:32 PDT 2013
Author: annakrat
Date: 2013-09-14 20:20:31 -0700 (Sat, 14 Sep 2013)
New Revision: 57690
grass/trunk/gui/wxpython/nviz/tools.py
wxNviz: fix string formatting and update formatting method
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py 2013-09-15 03:04:00 UTC (rev 57689)
+++ grass/trunk/gui/wxpython/nviz/tools.py 2013-09-15 03:20:31 UTC (rev 57690)
@@ -3949,19 +3949,19 @@
level = isosurfData['topo']['value'] = round(self._get3dRange(name = layer.name)[0], 2)
if sel < 0 or sel >= list.GetCount() - 1:
- item = list.Append(item = "%s %s" % (_("Level"), str(level)))
+ item = list.Append(item=_("Level {level}").format(level=level))
else:
- list.Insert(item = "%s %s" % (_("Level"), str(level)),
- pos = sel+1) # append
+ list.Insert(item=_("Level {level}").format(level=level),
+ pos=sel+1) # append
item = sel + 1
else:
sliceData = self.mapWindow.nvizDefault.SetSliceDefaultProp()
axis = ("X", "Y", "Z")[sliceData['position']['axis']]
- item = list.Append(item = "%s %s" % (_("Slice parallel to"), axis))
+ item = list.Append(item=_("Slice parallel to {axis}").format(axis=axis))
else:
- list.Insert(item = "%s" % (_("Slice parallel to"), axis),
+ list.Insert(item=_("Slice parallel to {axis}").format(axis=axis),
item = sel + 1
list.Check(item)
