[GRASS-SVN] r57699 - grass/branches/develbranch_6/display/d.grid
svn_grass at osgeo.org
Mon Sep 16 02:37:26 PDT 2013
Author: hamish
Date: 2013-09-16 02:37:26 -0700 (Mon, 16 Sep 2013)
New Revision: 57699
grass/branches/develbranch_6/display/d.grid/description.html
grass/branches/develbranch_6/display/d.grid/local_proto.h
grass/branches/develbranch_6/display/d.grid/main.c
grass/branches/develbranch_6/display/d.grid/plot.c
grass/branches/develbranch_6/display/d.grid/plotborder.c
add direction= option to allow rendering only lines of latitude or longitude (refs#1372)
Modified: grass/branches/develbranch_6/display/d.grid/description.html
--- grass/branches/develbranch_6/display/d.grid/description.html 2013-09-16 01:13:00 UTC (rev 57698)
+++ grass/branches/develbranch_6/display/d.grid/description.html 2013-09-16 09:37:26 UTC (rev 57699)
@@ -43,13 +43,21 @@
<p>
Colors may be standard named GRASS colors (red, green, aqua, etc.) or
a numerical R:G:B triplet, where component values range from 0-255.<br>
<p>
The grid drawing may be turned off by using the <em>-n</em> flag.<br>
The border drawing may be turned off by using the <em>-b</em> flag.<br>
The coordinate text may be turned off by using the <em>-t</em> flag.<br>
+<p>
+To draw grid lines at different intervals, e.g. at high latitudes, you
+can run the module twice, once with <b>direction</b>=<i>east-west</i>
+at one interval <b>size</b>, and again with
+<b>direction</b>=<i>north-south</i> at another interval <b>size</b>.
<h2>EXAMPLES</h2>
To draw a red geographic grid with 30 minute grid spacing run
either of the following:
<PRE>
@@ -65,6 +73,7 @@
</PRE>
<br>
<h2>SEE ALSO</h2>
<em><a href="d.barscale.html">d.barscale</a></em><br>
@@ -76,7 +85,6 @@
<em><a href="d.rast.html">d.rast</a></em><br>
<h2>AUTHORS</h2>
James Westervelt, U.S. Army Construction Engineering Research Laboratory<br>
@@ -84,4 +92,5 @@
Border support: Markus Neteler<br>
Text and RGB support: Hamish Bowman<br>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/display/d.grid/local_proto.h
--- grass/branches/develbranch_6/display/d.grid/local_proto.h 2013-09-16 01:13:00 UTC (rev 57698)
+++ grass/branches/develbranch_6/display/d.grid/local_proto.h 2013-09-16 09:37:26 UTC (rev 57699)
@@ -1,9 +1,13 @@
#include <grass/gprojects.h>
+#define DIRN_BOTH 0
+#define DIRN_LAT 1
+#define DIRN_LON 2
/* plot.c */
-int plot_grid(double, double, double, int, int, int, int, int, double);
+int plot_grid(double, double, double, int, int, int, int, int, double, int);
int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int,
- int, double);
+ int, double, int);
void init_proj(struct pj_info *, struct pj_info *, int);
void get_ll_bounds(double *, double *, double *, double *, struct Cell_head,
struct pj_info, struct pj_info);
@@ -12,7 +16,7 @@
float get_heading(double, double);
/* plotborder.c */
-int plot_border(double, double, double);
+int plot_border(double, double, double, int);
#define MARK_GRID 0
#define MARK_CROSS 1
Modified: grass/branches/develbranch_6/display/d.grid/main.c
--- grass/branches/develbranch_6/display/d.grid/main.c 2013-09-16 01:13:00 UTC (rev 57698)
+++ grass/branches/develbranch_6/display/d.grid/main.c 2013-09-16 09:37:26 UTC (rev 57699)
@@ -36,9 +36,10 @@
int colort = 0;
double size = 0., gsize = 0.; /* initialize to zero */
double east, north;
- int do_text, fontsize, mark_type, line_width;
+ int do_text, fontsize, mark_type, line_width, dirn;
struct GModule *module;
- struct Option *opt1, *opt2, *opt3, *opt4, *fsize, *tcolor, *lwidth;
+ struct Option *opt1, *opt2, *opt3, *opt4, *fsize, *tcolor, *lwidth,
+ *direction;
struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84, *cross,
*fiducial, *dot;
struct pj_info info_in; /* Proj structures */
@@ -70,6 +71,16 @@
opt3->multiple = NO;
opt3->description = _("Lines of the grid pass through this coordinate");
+ direction = G_define_option();
+ direction->key = "direction";
+ direction->type = TYPE_STRING;
+ direction->required = NO;
+ direction->answer = "both";
+ direction->options = "both,east-west,north-south";
+ direction->description =
+ _("Draw only east-west lines, north-south lines, or both ");
+ direction->guisection = _("Disable");
lwidth = G_define_option();
lwidth->key = "width";
lwidth->type = TYPE_DOUBLE;
@@ -177,6 +188,15 @@
if (dot->answer)
mark_type = MARK_DOT;
+ if (G_strcasecmp(direction->answer, "both") == 0)
+ dirn = DIRN_BOTH;
+ else if (G_strcasecmp(direction->answer, "east-west") == 0)
+ dirn = DIRN_LAT;
+ else if (G_strcasecmp(direction->answer, "north-south") == 0)
+ dirn = DIRN_LON;
+ else
+ G_fatal_error("Invalid direction: %s", direction->answer);
/* get grid size */
if (geogrid->answer) {
if (!G_scan_resolution(opt2->answer, &gsize, PROJECTION_LL) ||
@@ -222,12 +242,12 @@
/* initialzie proj stuff */
init_proj(&info_in, &info_out, wgs84->answer);
plot_geogrid(gsize, info_in, info_out, do_text, colorg, colort,
- fontsize, mark_type, line_width);
+ fontsize, mark_type, line_width, dirn);
else {
/* Do the grid plotting */
plot_grid(size, east, north, do_text, colorg, colort, fontsize,
- mark_type, line_width);
+ mark_type, line_width, dirn);
@@ -237,7 +257,7 @@
D_raster_use_color(colorb);
/* Do the border plotting */
- plot_border(size, east, north);
+ plot_border(size, east, north, dirn);
D_add_to_list(G_recreate_command());
Modified: grass/branches/develbranch_6/display/d.grid/plot.c
--- grass/branches/develbranch_6/display/d.grid/plot.c 2013-09-16 01:13:00 UTC (rev 57698)
+++ grass/branches/develbranch_6/display/d.grid/plot.c 2013-09-16 09:37:26 UTC (rev 57699)
@@ -12,7 +12,7 @@
int plot_grid(double grid_size, double east, double north, int do_text,
int gcolor, int tcolor, int fontsize, int mark_type,
- double line_width)
+ double line_width, int direction)
double x, y, y0;
double e1, e2;
@@ -38,38 +38,39 @@
else
x = east - ceil((east - window.west) / grid_size) * grid_size;
- while (x <= window.east) {
+ if (direction != DIRN_LAT) {
+ while (x <= window.east) {
- if (mark_type == MARK_GRID) {
- D_raster_use_color(gcolor);
- if (line_width)
- D_line_width(line_width);
- G_plot_line(x, window.north, x, window.south);
- D_line_width(0); /* reset so text doesn't use it */
+ if (mark_type == MARK_GRID) {
+ D_raster_use_color(gcolor);
+ if (line_width)
+ D_line_width(line_width);
+ G_plot_line(x, window.north, x, window.south);
+ D_line_width(0); /* reset so text doesn't use it */
- if (do_text) {
- D_raster_use_color(tcolor);
- G_format_easting(x, text, G_projection());
- R_text_rotation(270.0);
- R_text_size(fontsize, fontsize);
+ if (do_text) {
+ D_raster_use_color(tcolor);
+ G_format_easting(x, text, G_projection());
+ R_text_rotation(270.0);
+ R_text_size(fontsize, fontsize);
- /* Positioning -
- x: 4 pixels to the right of the grid line, + 0.5 rounding factor.
- y: End of text is 7 pixels up from bottom of screen, +.5 rounding.
- fontsize*.81 = actual text width FOR DEFAULT FONT (NOT FreeType)
- R_move_abs((int)(D_u_to_d_col(x) + 4 + .5),
- (int)(D_get_d_south() -
- (strlen(text) * fontsize * 0.81) - 7 + 0.5));
+ /* Positioning -
+ x: 4 pixels to the right of the grid line, + 0.5 rounding factor.
+ y: End of text is 7 pixels up from bottom of screen, +.5 rounding.
+ fontsize*.81 = actual text width FOR DEFAULT FONT (NOT FreeType)
+ R_move_abs((int)(D_u_to_d_col(x) + 4 + .5),
+ (int)(D_get_d_south() -
+ (strlen(text) * fontsize * 0.81) - 7 + 0.5));
- R_text(text);
+ R_text(text);
+ x += grid_size;
- x += grid_size;
+ R_text_rotation(0.0); /* reset */
- R_text_rotation(0.0); /* reset */
/* Draw horizontal grids
* For latlon, must draw in shorter sections
@@ -84,34 +85,36 @@
else
y = north - ceil((north - window.south) / grid_size) * grid_size;
- while (y <= window.north) {
- if (line_width)
- G_plot_line(window.east, y, e1, y);
- G_plot_line(e1, y, e2, y);
- G_plot_line(e2, y, window.west, y);
+ if (direction != DIRN_LON) {
+ while (y <= window.north) {
+ if (line_width)
+ G_plot_line(window.east, y, e1, y);
+ G_plot_line(e1, y, e2, y);
+ G_plot_line(e2, y, window.west, y);
- if (do_text) {
- G_format_northing(y, text, G_projection());
+ if (do_text) {
+ G_format_northing(y, text, G_projection());
- /* Positioning -
- x: End of text is 7 pixels left from right edge of screen, +.5 rounding.
- y: 4 pixels above each grid line, +.5 rounding.
- R_move_abs((int)
- (D_get_d_east() - (strlen(text) * fontsize * 0.81) -
- 7 + 0.5), (int)(D_u_to_d_row(y) - 4 + .5));
+ /* Positioning -
+ x: End of text is 7 pixels left from right edge of screen, +.5 rounding.
+ y: 4 pixels above each grid line, +.5 rounding.
+ R_move_abs((int)
+ (D_get_d_east() - (strlen(text) * fontsize * 0.81) -
+ 7 + 0.5), (int)(D_u_to_d_row(y) - 4 + .5));
- R_text(text);
+ R_text(text);
+ y += grid_size;
- y += grid_size;
/* draw marks not grid lines */
@@ -148,7 +151,7 @@
int plot_geogrid(double size, struct pj_info info_in, struct pj_info info_out,
int do_text, int gcolor, int tcolor, int fontsize,
- int mark_type, double line_width)
+ int mark_type, double line_width, int direction)
double g;
double e1, e2, n1, n2;
@@ -189,7 +192,7 @@
e1 = east;
for (j = 0; g >= south; j++, g -= size) {
start_coord = -9999.;
- if (g == north || g == south)
+ if (g == north || g == south || direction == DIRN_LON)
continue;
/* Set grid color */
@@ -244,7 +247,7 @@
for (j = 0; g > west; j++, g -= size) {
extra_y_off = 0.0;
- if (g == east || g == west)
+ if (g == east || g == west || direction == DIRN_LAT)
continue;
Modified: grass/branches/develbranch_6/display/d.grid/plotborder.c
--- grass/branches/develbranch_6/display/d.grid/plotborder.c 2013-09-16 01:13:00 UTC (rev 57698)
+++ grass/branches/develbranch_6/display/d.grid/plotborder.c 2013-09-16 09:37:26 UTC (rev 57699)
@@ -1,8 +1,9 @@
#include <math.h>
#include <grass/gis.h>
#include <grass/display.h>
+#include "local_proto.h"
-int plot_border(double grid_size, double east, double north)
+int plot_border(double grid_size, double east, double north, int direction)
double x, y;
struct Cell_head window;
@@ -41,39 +42,41 @@
else
- loop = 0;
- for (i = 0; i <= grid_size; i = i + steps) {
- if (loop == 0) {
- G_plot_line(x + i,
- window.south + (window.north -
- window.south) / longmark, x + i,
- window.south);
- G_plot_line(x + i, window.north, x + i,
- window.north - (window.north -
- window.south) / longmark);
+ loop = 0;
+ for (i = 0; i <= grid_size; i = i + steps) {
+ if (loop == 0) {
+ G_plot_line(x + i,
+ window.south + (window.north -
+ window.south) / longmark, x + i,
+ window.south);
+ G_plot_line(x + i, window.north, x + i,
+ window.north - (window.north -
+ window.south) / longmark);
+ if (loop == 5) {
+ window.south) / middlemark, x + i,
+ window.south);
+ window.south) / middlemark);
+ else {
+ window.south) / shortmark, x + i,
+ window.south);
+ window.south) / shortmark);
+ loop++;
- if (loop == 5) {
- window.south) / middlemark, x + i,
- window.south);
- window.south) / middlemark);
- else {
- window.south) / shortmark, x + i,
- window.south);
- window.south) / shortmark);
- loop++;
+ x += grid_size;
- x += grid_size;
/* Draw horizontal border marks */
@@ -83,36 +86,38 @@
else
- loop = 0;
- if (loop == 0) {
- G_plot_line(window.west, y + i,
- window.west + (window.east -
- window.west) / longmark, y + i);
- G_plot_line(window.east -
- (window.east - window.west) / longmark, y + i,
- window.east, y + i);
+ loop = 0;
+ if (loop == 0) {
+ G_plot_line(window.west, y + i,
+ window.west + (window.east -
+ window.west) / longmark, y + i);
+ G_plot_line(window.east -
+ (window.east - window.west) / longmark, y + i,
+ window.east, y + i);
+ if (loop == 5) {
+ window.west) / middlemark, y + i);
+ (window.east - window.west) / middlemark, y + i,
+ else {
+ window.west) / shortmark, y + i);
+ (window.east - window.west) / shortmark, y + i,
+ loop++;
- if (loop == 5) {
- window.west) / middlemark, y + i);
- (window.east - window.west) / middlemark, y + i,
- else {
- window.west) / shortmark, y + i);
- (window.east - window.west) / shortmark, y + i,
- loop++;
+ y += grid_size;
- y += grid_size;
return 0;
