[GRASS-SVN] r57702 - grass/trunk/display/d.barscale
svn_grass at osgeo.org
Mon Sep 16 06:24:55 PDT 2013
Author: martinl
Date: 2013-09-16 06:24:55 -0700 (Mon, 16 Sep 2013)
New Revision: 57702
grass/trunk/display/d.barscale/d.barscale.html
grass/trunk/display/d.barscale/main.c
d.barscale: more guisection + i18n
use standardized key for bgcolor
manual cosmetics
Modified: grass/trunk/display/d.barscale/d.barscale.html
--- grass/trunk/display/d.barscale/d.barscale.html 2013-09-16 12:54:54 UTC (rev 57701)
+++ grass/trunk/display/d.barscale/d.barscale.html 2013-09-16 13:24:55 UTC (rev 57702)
@@ -1,32 +1,36 @@
<h2>DESCRIPTION</h2>
-<em>d.barscale</em> displays a barscale on the graphics monitor
-at the given screen coordinates. If no coordinates are given it
-will draw the barscale in the bottom left of the display.
-It can draw the scale or north arrow in a number of styles.
+<em>d.barscale</em> displays a barscale on the graphics monitor at the
+given screen coordinates. If no coordinates are given it will draw the
+barscale in the bottom left of the display. It can draw the scale or
+north arrow in a number of styles (see
+the <a href="http://grasswiki.osgeo.org/wiki/Cartography#Display_monitors">wiki
+page</a> for details).
+<p>
+If <b>-n</b> flag is given, <em>d.barscale</em> draws north arrow
+instead of the barscale. Style of north arrow can be controlled
+by <b>north_arrow</b> paramater.
<h2>NOTE</h2>
<em>d.barscale</em> will not work in Lat/Lon locations as the horizontal
-scale distance changes with latitude. Try <em>d.grid</em> instead.
+scale distance changes with latitude. Try <em><a href="d.grid.html">d.grid</a></em> instead.
<h2>SEE ALSO</h2>
<em>
-<a href="d.graph.html">d.graph</a><br>
-<a href="d.grid.html">d.grid</a><br>
-<a href="d.legend.html">d.legend</a><br>
-<a href="g.region.html">g.region</a><br>
+<a href="d.graph.html">d.graph</a>,
+<a href="d.grid.html">d.grid</a>,
+<a href="d.legend.html">d.legend</a>,
+<a href="g.region.html">g.region</a>
</em>
<h2>AUTHOR</h2>
-unknown, but from USACE/CERL.<br>
+unknown, but from USA/CERL.<br>
Major rewrite for GRASS 7 by Hamish Bowman
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/display/d.barscale/main.c
--- grass/trunk/display/d.barscale/main.c 2013-09-16 12:54:54 UTC (rev 57701)
+++ grass/trunk/display/d.barscale/main.c 2013-09-16 13:24:55 UTC (rev 57702)
@@ -62,11 +62,12 @@
northarrow = G_define_flag();
northarrow->key = 'n';
northarrow->description = _("Draw a north arrow only");
+ northarrow->guisection = _("Style");
no_text = G_define_flag();
no_text->key = 't';
no_text->description = _("Draw the scale bar without text");
- no_text->guisection = "Text";
+ no_text->guisection = _("Text");
barstyle = G_define_option();
barstyle->key = "style";
@@ -74,6 +75,7 @@
barstyle->options =
"classic,line,solid,hollow,full_checker,part_checker,mixed_checker,tail_checker,up_ticks,down_ticks,both_ticks,arrow_ends";
barstyle->answer = "classic";
+ barstyle->guisection = _("Style");
coords = G_define_option();
coords->key = "at";
@@ -87,21 +89,19 @@
coords->description = _("(0,0) is lower-left of display frame");
fg_color_opt = G_define_standard_option(G_OPT_C_FG);
- fg_color_opt->key = "color";
fg_color_opt->label = _("Bar scale, text, and north arrow color");
- fg_color_opt->guisection = "Colors";
+ fg_color_opt->guisection = _("Colors");
bg_color_opt = G_define_standard_option(G_OPT_C_BG);
- bg_color_opt->key = "background_color";
bg_color_opt->label = _("Background color (drawn behind the bar)");
- bg_color_opt->guisection = "Colors";
+ bg_color_opt->guisection = _("Colors");
text_placement = G_define_option();
text_placement->key = "text_position";
text_placement->description = _("Text position");
text_placement->options = "under,over,left,right";
text_placement->answer = "right";
- text_placement->guisection = "Text";
+ text_placement->guisection = _("Text");
fsize = G_define_option();
fsize->key = "fontsize";
@@ -110,16 +110,15 @@
fsize->answer = "12";
fsize->options = "1-360";
fsize->description = _("Font size");
- fsize->guisection = "Text";
+ fsize->guisection = _("Text");
n_arrow = G_define_option();
n_arrow->key = "north_arrow";
- n_arrow->description = _("Only used when drawing a north arrow with the -n flag");
- n_arrow->label = _("North arrow style");
+ n_arrow->description = _("North arrow style (used only with the -n flag)");
n_arrow->options = "1a,1b,2,3,4,5,6,7a,7b,8a,8b,9";
n_arrow->answer = "1a";
+ n_arrow->guisection = _("Style");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
