[GRASS-SVN] r57704 - grass/trunk/imagery/i.group
svn_grass at osgeo.org
Mon Sep 16 06:52:24 PDT 2013
Author: turek
Date: 2013-09-16 06:52:24 -0700 (Mon, 16 Sep 2013)
New Revision: 57704
grass/trunk/imagery/i.group/main.c
i.group: adding s flag for printing out the subgroup files
Modified: grass/trunk/imagery/i.group/main.c
--- grass/trunk/imagery/i.group/main.c 2013-09-16 13:47:51 UTC (rev 57703)
+++ grass/trunk/imagery/i.group/main.c 2013-09-16 13:52:24 UTC (rev 57704)
@@ -11,7 +11,7 @@
* Hamish Bowman <hamish_b yahoo.com>
* PURPOSE: collect raster map layers into an imagery group by assigning
* them to user-named subgroups or other groups
- * COPYRIGHT: (C) 2001-2007, 2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2007, 2011, 2013 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -35,15 +35,15 @@
static int remove_subgroup_files(char group[INAME_LEN],
char subgroup[INAME_LEN], char **rasters,
int k);
+static void print_subgroups(char *group, int simple);
int main(int argc, char *argv[])
char group[GNAME_MAX], mapset[GMAPSET_MAX];
int m, k = 0;
struct Option *grp, *rast, *sgrp;
- struct Flag *r, *l, *simple_flag;
+ struct Flag *r, *l, *s, *simple_flag;
struct GModule *module;
G_gisinit(argv[0]);
@@ -71,26 +71,32 @@
r = G_define_flag();
r->key = 'r';
- r->description = _("Remove selected files from specified group or subgroup");
+ r->description =
+ _("Remove selected files from specified group or subgroup");
r->guisection = _("Maps");
l = G_define_flag();
l->key = 'l';
l->description = _("List files from specified (sub)group");
l->guisection = _("Print");
+ s = G_define_flag();
+ s->key = 's';
+ s->description = _("List subgroups from specified group");
+ s->guisection = _("Print");
simple_flag = G_define_flag();
simple_flag->key = 'g';
- simple_flag->description =
- _("List files from specified (sub)group (shell script style)");
+ simple_flag->description = _("Print in shell script style");
simple_flag->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* simple list implies list */
- if (simple_flag->answer && !l->answer)
+ /* backward comaptibility -> simple list implied l flag list, if there was only l flag
+ (with s flag added it is not clear, simple_flag is linked to both) */
+ if ((simple_flag->answer && !s->answer) && !l->answer)
l->answer = TRUE;
/* Determine number of files to include */
@@ -101,7 +107,7 @@
k++;
- if (k < 1 && !l->answer) /* remove if input is requirement */
+ if (k < 1 && !(l->answer || s->answer)) /* remove if input is requirement */
G_fatal_error(_("No input raster map(s) specified"));
/* check if current mapset: (imagery libs are very lacking in this dept)
@@ -120,7 +126,8 @@
/* Remove files from Group */
if (I_find_group(group) == 0) {
- G_fatal_error(_("Specified group does not exist in current mapset"));
+ G_fatal_error(_
+ ("Specified group does not exist in current mapset"));
if (sgrp->answer) {
@@ -135,31 +142,38 @@
else {
- if (l->answer) {
+ if (l->answer || s->answer) {
/* List raster maps in group */
struct Ref ref;
+ G_fatal_error(_
if (sgrp->answer) {
/* list subgroup files */
I_get_subgroup_ref(group, sgrp->answer, &ref);
if (simple_flag->answer) {
- G_message(_("Subgroup <%s> of group <%s> references the following raster maps:"),
+ G_message(_
+ ("Subgroup <%s> of group <%s> references the following raster maps:"),
sgrp->answer, group);
I_list_subgroup_simple(&ref, stdout);
else
I_list_subgroup(group, sgrp->answer, &ref, stdout);
+ else if (s->answer) {
+ print_subgroups(group, simple_flag->answer);
else {
/* list group files */
I_get_group_ref(group, &ref);
- G_message(_("Group <%s> references the following raster maps:"), group);
+ G_message(_
+ ("Group <%s> references the following raster maps:"),
+ group);
I_list_group_simple(&ref, stdout);
else
@@ -169,7 +183,8 @@
else {
/* Create or update Group REF */
- G_verbose_message(_("Group <%s> does not yet exist. Creating..."),
+ G_verbose_message(_
+ ("Group <%s> does not yet exist. Creating..."),
group);
if (sgrp->answer) {
@@ -188,11 +203,10 @@
return EXIT_SUCCESS;
static int add_or_update_group(char group[INAME_LEN], char **rasters, int k)
int m, n, skip;
@@ -252,7 +266,8 @@
/* Go through existing files to check for duplicates */
for (n = 0; n < ref.nfiles; n++) {
if (strcmp(rasters[m], ref.file[n].name) == 0) {
- G_message(_("Raster map <%s> exists in subgroup. Skipping..."),
+ G_message(_
+ ("Raster map <%s> exists in subgroup. Skipping..."),
G_fully_qualified_name(rasters[m], mapset));
skip = 1;
continue;
@@ -382,3 +397,46 @@
return 0;
+ int subgs_num, i;
+ int len, tot_len;
+ int max;
+ char **subgs;
+ subgs = I_list_subgroups(group, &subgs_num);
+ if (simple)
+ for (i = 0; i < subgs_num; i++)
+ fprintf(stdout, "%s\n", subgs[i]);
+ else {
+ if (subgs_num <= 0) {
+ fprintf(stdout, _("Group <%s> does not contain any subgroup.\n"),
+ group);
+ return;
+ max = 0;
+ for (i = 0; i < subgs_num; i++) {
+ len = strlen(subgs[i]) + 4;
+ if (len > max)
+ max = len;
+ fprintf(stdout,
+ _("group <%s> references the following subgroups\n"), group);
+ fprintf(stdout, "-------------\n");
+ tot_len = 0;
+ tot_len += max;
+ if (tot_len > 78) {
+ fprintf(stdout, "\n");
+ tot_len = max;
+ fprintf(stdout, "%-*s", max, subgs[i]);
+ if (tot_len)
+ G_free(subgs);
+ return;
