[GRASS-SVN] r57750 - grass/trunk/scripts/db.univar
svn_grass at osgeo.org
Thu Sep 19 01:25:09 PDT 2013
Author: mmetz
Date: 2013-09-19 01:25:09 -0700 (Thu, 19 Sep 2013)
New Revision: 57750
grass/trunk/scripts/db.univar/db.univar.py
db.univar: fix precision
Modified: grass/trunk/scripts/db.univar/db.univar.py
--- grass/trunk/scripts/db.univar/db.univar.py 2013-09-19 07:27:11 UTC (rev 57749)
+++ grass/trunk/scripts/db.univar/db.univar.py 2013-09-19 08:25:09 UTC (rev 57750)
@@ -155,16 +155,16 @@
if not shellstyle:
print ""
print "Number of values: %d" % N
- print "Minimum: %g" % minv
- print "Maximum: %g" % maxv
- print "Range: %g" % (maxv - minv)
+ print "Minimum: %.15g" % minv
+ print "Maximum: %.15g" % maxv
+ print "Range: %.15g" % (maxv - minv)
print "-----"
- print "Mean: %g" % (sum/N)
- print "Arithmetic mean of absolute values: %g" % (sum3/N)
- print "Variance: %g" % ((sum2 - sum*sum/N)/N)
- print "Standard deviation: %g" % (math.sqrt((sum2 - sum*sum/N)/N))
- print "Coefficient of variation: %g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
- print "Sum: %g" % sum
+ print "Mean: %.15g" % (sum/N)
+ print "Arithmetic mean of absolute values: %.15g" % (sum3/N)
+ print "Variance: %.15g" % ((sum2 - sum*sum/N)/N)
+ print "Standard deviation: %.15g" % (math.sqrt((sum2 - sum*sum/N)/N))
+ print "Coefficient of variation: %.15g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "Sum: %.15g" % sum
print "-----"
else:
print "n=%d" % N
@@ -226,29 +226,29 @@
q50 = (q50a + q50b) / 2
if not shellstyle:
- print "1st Quartile: %g" % q25
- print "Median (%s N): %g" % (eostr, q50)
- print "3rd Quartile: %g" % q75
+ print "1st Quartile: %.15g" % q25
+ print "Median (%s N): %.15g" % (eostr, q50)
+ print "3rd Quartile: %.15g" % q75
for i in range(len(perc)):
if perc[i] == int(perc[i]): # integer
if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
- print "%dst Percentile: %g" % (int(perc[i]), pval[i])
+ print "%dst Percentile: %.15g" % (int(perc[i]), pval[i])
elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
- print "%dnd Percentile: %g" % (int(perc[i]), pval[i])
+ print "%dnd Percentile: %.15g" % (int(perc[i]), pval[i])
elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
- print "%drd Percentile: %g" % (int(perc[i]), pval[i])
+ print "%drd Percentile: %.15g" % (int(perc[i]), pval[i])
else:
- print "%dth Percentile: %g" % (int(perc[i]), pval[i])
+ print "%dth Percentile: %.15g" % (int(perc[i]), pval[i])
else:
- print "%.15g Percentile: %g" % (perc[i], pval[i])
+ print "%.15g Percentile: %.15g" % (perc[i], pval[i])
else:
- print "first_quartile=%g" % q25
- print "median=%g" % q50
- print "third_quartile=%g" % q75
+ print "first_quartile=%.15g" % q25
+ print "median=%.15g" % q50
+ print "third_quartile=%.15g" % q75
percstr = "%.15g" % perc[i]
percstr = percstr.replace('.','_')
- print "percentile_%s=%g" % (percstr, pval[i])
+ print "percentile_%s=%.15g" % (percstr, pval[i])
if __name__ == "__main__":
options, flags = grass.parser()
