[GRASS-SVN] r57791 - in grass/branches/releasebranch_6_4/imagery: i.his.rgb i.rgb.his
svn_grass at osgeo.org
Sun Sep 22 00:33:05 PDT 2013
Author: hamish
Date: 2013-09-22 00:33:04 -0700 (Sun, 22 Sep 2013)
New Revision: 57791
grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c
grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c
grass/branches/releasebranch_6_4/imagery/i.rgb.his/r2hmain.c
grass/branches/releasebranch_6_4/imagery/i.rgb.his/rgb2his.c
add NULL support (merge r52208 from devbr6)
Modified: grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c
--- grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c 2013-09-22 07:28:09 UTC (rev 57790)
+++ grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c 2013-09-22 07:33:04 UTC (rev 57791)
@@ -91,7 +91,7 @@
/* read in a row from each cell map */
for (band = 0; band < 3; band++)
- if (G_get_map_row(fd_input[band], rowbuffer[band], i) < 0)
+ if (G_get_c_raster_row(fd_input[band], rowbuffer[band], i) < 0)
G_fatal_error(_("Unable to read raster map row %ld"), i);
/* process this row of the map */
Modified: grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c
--- grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c 2013-09-22 07:28:09 UTC (rev 57790)
+++ grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c 2013-09-22 07:33:04 UTC (rev 57791)
@@ -37,6 +37,15 @@
for (sample = 0; sample < columns; sample++) {
+ if (G_is_c_null_value(&rowbuffer[0][sample]) ||
+ G_is_c_null_value(&rowbuffer[1][sample]) ||
+ G_is_c_null_value(&rowbuffer[2][sample])) {
+ G_set_c_null_value(&rowbuffer[0][sample], 1);
+ G_set_c_null_value(&rowbuffer[1][sample], 1);
+ G_set_c_null_value(&rowbuffer[2][sample], 1);
+ continue;
red = green = blue = 0.0;
scalei = (double)rowbuffer[1][sample];
scalei /= 255.;
Modified: grass/branches/releasebranch_6_4/imagery/i.rgb.his/r2hmain.c
--- grass/branches/releasebranch_6_4/imagery/i.rgb.his/r2hmain.c 2013-09-22 07:28:09 UTC (rev 57790)
+++ grass/branches/releasebranch_6_4/imagery/i.rgb.his/r2hmain.c 2013-09-22 07:33:04 UTC (rev 57791)
@@ -89,7 +89,7 @@
G_percent(i, rows, 2);
Modified: grass/branches/releasebranch_6_4/imagery/i.rgb.his/rgb2his.c
--- grass/branches/releasebranch_6_4/imagery/i.rgb.his/rgb2his.c 2013-09-22 07:28:09 UTC (rev 57790)
+++ grass/branches/releasebranch_6_4/imagery/i.rgb.his/rgb2his.c 2013-09-22 07:33:04 UTC (rev 57791)
@@ -35,6 +35,15 @@
double hue = 0.0L; /* hue */
+ continue;
scaler = (double)rowbuffer[0][sample];
scaler /= 255.0;
scaleg = (double)rowbuffer[1][sample];
