[GRASS-SVN] r57798 - grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel
Sun Sep 22 01:44:56 PDT 2013
Author: hamish
Date: 2013-09-22 01:44:55 -0700 (Sun, 22 Sep 2013)
New Revision: 57798
   grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel
sync with devbr6 (big speedup, many improvements)
Modified: grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel	2013-09-22 08:26:32 UTC (rev 57797)
+++ grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel	2013-09-22 08:44:55 UTC (rev 57798)
@@ -26,7 +26,7 @@
 # REQUIREMENTS:
 #      -  gpsbabel from:
 #	     http://gpsbabel.sourceforge.net
-#      -  unix tools: grep, cat, tac, cut, paste, awk/nawk/gawk, sed
+#      -  unix tools: grep, cat, cut, paste, awk/nawk/gawk, sed
 #      -  cs2cs from PROJ.4    http://proj.maptools.org/
 #      - report supported formats:
@@ -109,10 +109,11 @@
 LC_NUMERIC=C
 export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
+### setup enviro vars ###
+MAPSET=`g.gisenv get=MAPSET`
+LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
+GISDBASE=`g.gisenv get=GISDBASE`
+LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
 PROG=`basename "$0"`
 #### check for gpsbabel
@@ -135,6 +136,13 @@
     exit 1
 fi
+if [ `ogr2ogr --formats | grep -cw GPX` -eq 1 ] ; then
+    g.message -v "OGR is GPX capable."
+    OGR_GPX=1
+else
+    OGR_GPX=0
+fi
 #### set temporary files
 TEMPFILE="`g.tempfile pid=$$`"
 if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
@@ -216,7 +224,15 @@
 else
     IN_PROJ="+proj=longlat +datum=WGS84"
 fi
-OUT_PROJ="`g.proj -jf`"
+OUT_PROJ=`g.proj -j | (
+    OUT_PROJ=
+    while read line ; do
+	OUT_PROJ="$OUT_PROJ '$line'"
+    done
+    echo "$OUT_PROJ"
 PROJ_TYPE=`g.region -p | grep 'projection' | cut -f2 -d" "`
 if [ $PROJ_TYPE -eq 0 ] && [ $KEEP_WGS84 -ne 1 ] ; then
@@ -241,7 +257,6 @@
     if [ $WPT -eq 1 ] ; then
 	g.message "Loading Waypoints from <$GIS_OPT_INPUT>..."
 	TYPE="-w"
-	EXITCODE=$?
     elif [ $RTE -eq 1 ] ; then
 	g.message "Loading Routes as points from <$GIS_OPT_INPUT>..."
 	TYPE="-r"
@@ -264,11 +279,9 @@
 	g.message "Loading Routes from <$GIS_OPT_INPUT>..."
 	TYPE="-r"
-	EXITCODE=$?
     elif [ $TRK -eq 1 ] ; then
 	g.message "Loading Tracks from <$GIS_OPT_INPUT>..."
 	TYPE="-t"
-	EXITCODE=$?
     fi
     gpsbabel $TYPE -i $GIS_OPT_FORMAT -f "$GPSdevice" $PROGVERBOSE \
 	-o gpx -F "$TEMPFILE".gpx
@@ -310,8 +323,12 @@
 	cp "${TEMPFILE}.base" "${TEMPFILE}.P_base"
     else
 	g.message "Attempting waypoint projection transform with cs2cs"
-	cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
+	eval cs2cs -f %.9f `echo $IN_PROJ` +to `echo $OUT_PROJ` \
+	  < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
 	EXITCODE=$?
 	# check if transform REALLY worked (e.g. when the grid file is not found)
 	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_base"`"
 	if [ "$BAD_PTS" -gt 0 ] ; then
@@ -365,57 +382,73 @@
     #### prepare line components
+	if [ "$OGR_GPX" -eq 1 ] ; then
+	    # http://www.gdal.org/ogr/drv_gpx.html
+	    # make it really easy ; but need to reproject from WGS84/LL.
+	    #   use '-c location=', then v.proj it in, then rm -rf the temp locn?
+	    #? GPX_USE_EXTENSIONS=YES
+	    #? export GPX_USE_EXTENSIONS
+	    #v.in.ogr dsn="$TEMPFILE.gpx" out=$map_name
+	    echo
+	fi
 	# this part is quite difficult using gpx... I'll explain all I've done
 	# if someone has any suggest please mail!!!!
 	# list of bytes where routes finish
-	cat "$TEMPFILE.gpx" | grep -n "</rte>" > "$TEMPFILE.bytes"
-	# number of routes
-	cat "$TEMPFILE.bytes" | grep -c "</rte>" > "$TEMPFILE.var"
-	ROUTE_NUMBER=0
-	read ROUTE_NUMBER < "$TEMPFILE.var" # route number to process
+	grep -n '</rte>' "$TEMPFILE.gpx" > "$TEMPFILE.bytes"
+	# number of routes to process
+	ROUTE_NUMBER=`grep -c '</rte>' "$TEMPFILE.bytes"`
 	READ_BYTES=0 # offset of bytes already read
 	cp "$TEMPFILE.gpx" "$TEMPFILE.gpx2" # file to be "eaten" by head commands in while
 	ROUTE_ID=0 # route identifier
 	while [ "$ROUTE_NUMBER" -gt 0 ] ; do
-	    head -n 1 "$TEMPFILE.bytes" | cut -f 1 -d ':'> "$TEMPFILE.var"
-	    END_BYTE=0
-	    read END_BYTE < "$TEMPFILE.var" # this route ends at END_BYTE in $TEMPFILE.gpx file
+	    # this route ends at END_BYTE in $TEMPFILE.gpx file
+	    END_BYTE=`head -n 1 "$TEMPFILE.bytes" | cut -f 1 -d ':'`
-	    TO_READ=0
-	    TO_READ="`expr $END_BYTE - $READ_BYTES`"    # bytes to read from $TEMPFILE.gpx2 file
-	    READ_BYTES="`expr $READ_BYTES + $TO_READ`"  # update readed bytes
+	    TO_READ=`expr $END_BYTE - $READ_BYTES`    # bytes to read from $TEMPFILE.gpx2 file
+	    READ_BYTES=`expr $READ_BYTES + $TO_READ`  # update readed bytes
 	    # list of points in route
-	    head -n $TO_READ "$TEMPFILE.gpx2" | grep "<rtept" > "$TEMPFILE.points"
-	    POINTS=0 # number of points in route
-	    cat "$TEMPFILE.points" | grep -c "<rtept" > "$TEMPFILE.var"
-	    read POINTS < "$TEMPFILE.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep '<rtept' > "$TEMPFILE.points"
+	    # number of points in route
+	    POINTS=`grep -c '<rtept' "$TEMPFILE.points"`
 	    echo "L $POINTS 1" >> "$TEMPFILE.base"
 	    # read lat lon data
-	    cat "$TEMPFILE.points" | cut -f2 -d'<' | cut -f2,3 -d ' ' | cut -f2,4 -d '"' | tr '"' '\t' > "$TEMPFILE.latlon"
-	    cat "$TEMPFILE.latlon" | tr ',' '.' | awk '{printf(" %s %s\n", $2, $1) }' >> "$TEMPFILE.base"
+	    cut -f2 -d'<' "$TEMPFILE.points" | cut -f2,3 -d ' ' | \
+	       cut -f2,4 -d '"' | tr '"' '\t' > "$TEMPFILE.latlon"
+	    tr ',' '.' < "$TEMPFILE.latlon" | \
+	       awk '{printf(" %s %s\n", $2, $1) }' >> "$TEMPFILE.base"
 	    # create attribute line
-	    head -n $TO_READ "$TEMPFILE.gpx2" | grep -n "<rtept" | head -n 1 | cut -f1 -d ':' > "$TEMPFILE.var"
-	    OFFSET=0
-	    read OFFSET < "$TEMPFILE.var"
+	    OFFSET=`head -n $TO_READ "$TEMPFILE.gpx2" | grep -n '<rtept' | \
+	       head -n 1 | cut -f1 -d ':'`
 	    head -n $OFFSET "$TEMPFILE.gpx2" > "$TEMPFILE.rte_attr"
 	    # read needed attributes
 	    ROUTE_ID="`expr $ROUTE_ID + 1`"
-	    cat "$TEMPFILE.rte_attr"| grep "<number" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
-	    NUMBER=0
-	    read NUMBER < "$TEMPFILE.var" # read the route number
-	    cat "$TEMPFILE.rte_attr"| grep "<name" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
-	    R_NAME=""
-	    read R_NAME < "$TEMPFILE.var" # read the route name
+	    # read the route number
+	    NUMBER=`grep '<number' "$TEMPFILE.rte_attr" | tail -n 1 | cut -f2 -d'<' | \
+	      cut -f2 -d'>'`
+	    # read the route name
+	    R_NAME=`grep '<name' "$TEMPFILE.rte_attr" | tail -n 1 | cut -f2 -d'<' | \
+	       cut -f2 -d'>'`
 	    OFFSET="`expr $TO_READ - $OFFSET`"
-	    head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | grep "<name" | head -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
-	    START_PNT=""
-	    read START_PNT < "$TEMPFILE.var" # read the name of start point
+	    # read the name of start point
+	    START_PNT=`head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | grep '<name' | \
+	       head -n 1 | cut -f2 -d'<' | cut -f2 -d'>'`
 	    # check that numberic values don't try and pass an empty string
 ### variable names don't line up with column names ?!
 	    if [ -z "$ROUTE_ID" ] ; then
@@ -435,12 +468,8 @@
 	    tail -n $ROUTE_NUMBER "$TEMPFILE.bytes" > "$TEMPFILE.bytes2"
 	    mv "$TEMPFILE.bytes2" "$TEMPFILE.bytes"
 	    head -n $TO_READ "$TEMPFILE.gpx2" > "$TEMPFILE.points"
-	    B_GPX=0
-	    wc -c < "$TEMPFILE.gpx2" > "$TEMPFILE.var"
-	    read B_GPX < "$TEMPFILE.var"
-	    B_PNT=0
-	    wc -c < "$TEMPFILE.points" > "$TEMPFILE.var"
-	    read B_PNT < "$TEMPFILE.var"
+	    B_GPX=`wc -c < "$TEMPFILE.gpx2"`
+	    B_PNT=`wc -c < "$TEMPFILE.points"`
 	    TO_READ="`expr $B_GPX - $B_PNT`"
 	    tail -c $TO_READ "$TEMPFILE.gpx2" > "$TEMPFILE.points"
 	    mv "$TEMPFILE.points" "$TEMPFILE.gpx2"
@@ -450,62 +479,59 @@
 	ATTR_COLS='cat int, route_id int, name varchar(40), start_wpt varchar(40)'
     fi
+	# list of bytes where tracks finish
+	grep -n '</trkseg>' "$TEMPFILE.gpx" > "$TEMPFILE.bytes"
-	# list of bytes where tracks finish
-	cat "$TEMPFILE.gpx" | grep -n "</trkseg>" > "$TEMPFILE.bytes"
 	# number of tracks
-	cat "$TEMPFILE.bytes" | grep -c "</trkseg>" > "$TEMPFILE.var"
-	TRACK_NUMBER=0
-	read TRACK_NUMBER < "$TEMPFILE.var" # route number to process
+	TRACK_NUMBER=`grep -c '</trkseg>' "$TEMPFILE.bytes"`
 	TRACK_ID=0 # track identifier
 	while [ "$TRACK_NUMBER" -gt 0 ] ; do
-	    END_BYTE=0
+	    # this track ends at END_BYTE in the $TEMPFILE.gpx file
+	    END_BYTE=`head -n 1 "$TEMPFILE.bytes" | cut -f1 -d':'`
 	    TO_READ=0
-	    head -n $TO_READ "$TEMPFILE.gpx2" | grep "<trkpt" > "$TEMPFILE.points"
-	    POINTS=0 # number of points in track
-	    cat "$TEMPFILE.points" | grep -c "<trkpt" > "$TEMPFILE.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep '<trkpt' > "$TEMPFILE.points"
+	    # number of points in track
+	    POINTS=`grep -c '<trkpt' "$TEMPFILE.points"`
 	    # read lat lon data
-	    head -n $TO_READ "$TEMPFILE.gpx2" | grep -n "<trk" | head -n 1 | cut -f1 -d ':' > "$TEMPFILE.var"
-	    OFFSET=0
-	    S_LAT=""
-	    head -n 1 "$TEMPFILE.latlon" | cut -f1 > "$TEMPFILE.var"
-	    read S_LAT < "$TEMPFILE.var"
-	    S_LON=""
-	    head -n 1 "$TEMPFILE.latlon" | cut -f2 > "$TEMPFILE.var"
-	    read S_LON < "$TEMPFILE.var"
-	    E_LAT=""
-	    tail -n 1 "$TEMPFILE.latlon" | cut -f1 > "$TEMPFILE.var"
-	    read E_LAT < "$TEMPFILE.var"
-	    E_LON=""
-	    tail -n 1 "$TEMPFILE.latlon" | cut -f2 > "$TEMPFILE.var"
-	    read E_LON < "$TEMPFILE.var"
+	    OFFSET=`head -n $TO_READ "$TEMPFILE.gpx2" | grep -n '<trk' | \
+	    S_LAT=`head -n 1 "$TEMPFILE.latlon" | cut -f1`
+	    S_LON=`head -n 1 "$TEMPFILE.latlon" | cut -f2`
+	    E_LAT=`tail -n 1 "$TEMPFILE.latlon" | cut -f1`
+	    E_LON=`tail -n 1 "$TEMPFILE.latlon" | cut -f2`
-	    head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | grep "<time" > "$TEMPFILE.time"
-	    S_TIME=""
-	    head -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TEMPFILE.var"
-	    read S_TIME < "$TEMPFILE.var"
-	    E_TIME=""
-	    tail -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TEMPFILE.var"
-	    read E_TIME < "$TEMPFILE.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | \
+	       grep '<time' > "$TEMPFILE.time"
+	    S_TIME=`head -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<'`
+	    E_TIME=`tail -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<'`
 	    TRACK_ID="`expr $TRACK_ID + 1`"
@@ -530,7 +556,8 @@
 		g.message -w "Track $TRACK_NUMBER:  ending lon was empty. Bug?"
 	    fi
-	    echo "$TRACK_ID|$S_TIME|$S_LAT|$S_LON|$E_TIME|$E_LAT|$E_LON" >> "$TEMPFILE.track_atts"
+	    echo "$TRACK_ID|$S_TIME|$S_LAT|$S_LON|$E_TIME|$E_LAT|$E_LON" \
+	       >> "$TEMPFILE.track_atts"
 	    TRACK_NUMBER="`expr $TRACK_NUMBER - 1`"
@@ -538,15 +565,9 @@
 	    tail -n $TRACK_NUMBER "$TEMPFILE.bytes" > "$TEMPFILE.bytes2"
-	    B_GPX=0
-	    B_PNT=0
 	done
@@ -566,10 +587,14 @@
 	    $1!="L" { printf(" %s %s\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
     else
-	cs2cs -tL -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
+	eval cs2cs -tL -f %.9f `echo $IN_PROJ` +to `echo $OUT_PROJ` \
+	   < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
 	EXITCODE=$?
-	 # check if transform REALLY worked (e.g. grid file not found)
-	 BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
+	# check if transform REALLY worked (e.g. grid file not found)
+	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
 	    g.message message=""
 	    g.message -w "$BAD_PTS vertices failed reprojection."
@@ -647,19 +672,21 @@
 	    # =>  echo "INSERT INTO $NAME VALUES (2, 1, 'AB', 'B')" | db.execute
 	    cat "$ATTR_FILE" | \
-	      awk -F'|' '{
-		printf("echo \"INSERT INTO $NAME VALUES (%d, %d, ^%s^, ^%s^)\" | db.execute\n", $1, $2, $3, $4) }' \
-		    | tr '^' \' > "$ATTR_FILE"_exe
+	      awk -F'|' -v DBNAME="$NAME" '{
+		printf("INSERT INTO %s VALUES (%d, %d, ^%s^, ^%s^);\n",
+			DBNAME, $1, $2, $3, $4) }' \
+		    | tr '^' \' > "$ATTR_FILE".sql
 	fi
 	    # =>  echo "INSERT INTO $NAME VALUES ()" | db.execute
-	      awk -F'|' '{
-		printf("echo \"INSERT INTO $NAME VALUES (%d, ^%s^, %s, %s, ^%s^, %s, %s)\" | db.execute\n", $1, $2, $3, $4, $5, $6, $7) }' \
+		printf("INSERT INTO %s VALUES (%d, ^%s^, %s, %s, ^%s^, %s, %s);\n",
+			DBNAME, $1, $2, $3, $4, $5, $6, $7) }' \
 	fi
-	. "$ATTR_FILE"_exe
+	db.execute input="$ATTR_FILE".sql
 ### </hack>
 	g.message "Connecting attribute table to vector file..."
