[GRASS-SVN] r57800 - grass/branches/releasebranch_6_4/scripts/v.in.garmin
svn_grass at osgeo.org
Sun Sep 22 01:52:19 PDT 2013
Author: hamish
Date: 2013-09-22 01:52:18 -0700 (Sun, 22 Sep 2013)
New Revision: 57800
grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin
improved support for spaces in path names (specifically the cs2cs NTv2 grid file), merge from devbr6
Modified: grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin
--- grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin 2013-09-22 08:48:19 UTC (rev 57799)
+++ grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin 2013-09-22 08:52:18 UTC (rev 57800)
@@ -256,7 +256,15 @@
#### set up projection info
IN_PROJ="+proj=longlat +datum=WGS84"
-OUT_PROJ="`g.proj -jf`"
+OUT_PROJ=`g.proj -j | (
+ OUT_PROJ=
+ while read line ; do
+ OUT_PROJ="$OUT_PROJ '$line'"
+ done
+ echo "$OUT_PROJ"
PROJ_TYPE=`g.region -p | grep 'projection' | cut -f2 -d" "`
if [ $PROJ_TYPE -eq 0 ] && [ $KEEP_WGS84 -ne 1 ] ; then
g.message -e "Cannot project to a XY location."
@@ -463,7 +471,8 @@
cp "${TEMPFILE}.base" "${TEMPFILE}.P_base"
else
g.message "Attempting waypoint projection transform with cs2cs..."
- cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
+ eval cs2cs -f %.7f $IN_PROJ +to `echo $OUT_PROJ` \
+ < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
EXITCODE=$?
# check if transform REALLY worked (e.g. grid file not found)
BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_base"`"
@@ -671,7 +680,8 @@
$1!="L" { printf(" %.7f %.7f\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
else
- cs2cs -tL -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
+ eval cs2cs -tL -f %.7f $IN_PROJ +to `echo $OUT_PROJ` \
+ < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
EXITCODE=$?
BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
