[GRASS-SVN] r57818 - grass/trunk/lib/python/pygrass/raster
    svn_grass at osgeo.org
    Mon Sep 23 07:07:38 PDT 2013
Author: zarch
Date: 2013-09-23 07:07:38 -0700 (Mon, 23 Sep 2013)
New Revision: 57818
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
Add the with statement also when opening a raster class in write mode
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2013-09-23 14:06:11 UTC (rev 57817)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2013-09-23 14:07:38 UTC (rev 57818)
@@ -12,11 +12,9 @@
 from grass.script import fatal, warning
 from grass.script import core as grasscore
-#from grass.script import core
-#import grass.lib as grasslib
 import grass.lib.gis as libgis
 import grass.lib.raster as libraster
-import grass.lib.segment as libseg
 import grass.lib.rowio as librowio
@@ -142,7 +140,7 @@
         libraster.Rast_put_row(self._fd, row.p, self._gtype)
-    def open(self, mode='r', mtype='CELL', overwrite=False):
+    def open(self, mode=None, mtype=None, overwrite=None):
         """Open the raster if exist or created a new one.
         Parameters
@@ -165,9 +163,9 @@
             * self._gtype
             * self._rows and self._cols
-        self.mode = mode
-        self.mtype = mtype
-        self.overwrite = overwrite
+        self.mode = mode if mode else self.mode
+        self.mtype = mtype if mtype else self.mtype
+        self.overwrite = overwrite if overwrite is not None else self.overwrite
         # check if exist and instantiate all the private attributes
         if self.exist():
@@ -206,7 +204,7 @@
         self.rowio = RowIO()
         super(RasterRowIO, self).__init__(name, *args, **kargs)
+    def open(self, mode=None, mtype=None, overwrite=False):
         super(RasterRowIO, self).open(mode, mtype, overwrite)
         self.rowio.open(self._fd, self._rows, self._cols, self.mtype)
@@ -259,7 +257,7 @@
         return self._mode
     def _set_mode(self, mode):
-        if mode.lower() not in ('r', 'w', 'rw'):
+        if mode and mode.lower() not in ('r', 'w', 'rw'):
             str_err = _("Mode type: {0} not supported ('r', 'w','rw')")
             raise ValueError(str_err.format(mode))
         self._mode = mode
@@ -364,7 +362,7 @@
         self.segment.val.value = val
         self.segment.put(row, col)
-    def open(self, mode='r', mtype='DCELL', overwrite=False):
         """Open the map, if the map already exist: determine the map type
         and copy the map to the segment files;
         else, open a new segment map.
@@ -384,14 +382,14 @@
         self._rows = libraster.Rast_window_rows()
         self._cols = libraster.Rast_window_cols()
-        self.mode = mode
         if self.exist():
             self.info = Info(self.name, self.mapset)
             if ((self.mode == "w" or self.mode == "rw") and
-                self.overwrite is False):
+                    self.overwrite is False):
                 str_err = _("Raster map <{0}> already exists. Use overwrite.")
                 fatal(str_err.format(self))
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2013-09-23 14:06:11 UTC (rev 57817)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2013-09-23 14:07:38 UTC (rev 57818)
@@ -168,7 +168,8 @@
     * Implements color, history and category handling
     * Renaming, deletion, ...
-    def __init__(self, name, mapset=""):
+    def __init__(self, name, mapset="",
+                 mode='r', mtype='FCELL', overwrite=False):
         """The constructor need at least the name of the map
         *optional* field is the `mapset`. ::
@@ -199,13 +200,13 @@
         self.hist = History()
         if self.exist():
+        self.mode = mode
     def __enter__(self):
-        if self.exist():
-            self.open('r')
-            return self
-        else:
-            raise ValueError("Raster not found.")
+        self.open()
+        return self
     def __exit__(self, exc_type, exc_value, traceback):
         self.close()
