[GRASS-SVN] r57841 - grass/trunk/raster/r.water.outlet
svn_grass at osgeo.org
Wed Sep 25 22:40:12 PDT 2013
Author: hcho
Date: 2013-09-25 22:40:12 -0700 (Wed, 25 Sep 2013)
New Revision: 57841
grass/trunk/raster/r.water.outlet/main.c
grass/trunk/raster/r.water.outlet/r.water.outlet.html
grass/trunk/raster/r.water.outlet/r_water_outlet.png
grass/trunk/raster/r.water.outlet/ramseg.h
Added recommended parentheses to make gcc happy.
Updated the example coordinates and screenshot in the manual using nc_spm_08_grass7.tar.gz.
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2013-09-25 17:56:09 UTC (rev 57840)
+++ grass/trunk/raster/r.water.outlet/main.c 2013-09-26 05:40:12 UTC (rev 57841)
@@ -54,7 +54,7 @@
double N, E;
int row, col, basin_fd, drain_fd;
CELL *cell_buf;
- char drain_name[GNAME_MAX], E_f, ba_f, N_f, errr;
+ char drain_name[GNAME_MAX];
struct GModule *module;
struct {
struct Option *input, *output, *coords;
@@ -98,7 +98,6 @@
G_get_set_window(&window);
- ba_f = N_f = E_f = errr = 0;
nrows = Rast_window_rows();
ncols = Rast_window_cols();
Modified: grass/trunk/raster/r.water.outlet/r.water.outlet.html
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html 2013-09-25 17:56:09 UTC (rev 57840)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html 2013-09-26 05:40:12 UTC (rev 57841)
@@ -36,7 +36,7 @@
# the watershed outlet position should be placed on a stream (from
# accumulation map):
r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K basin=basin_5K
-r.water.outlet input=draindir_5K output=basin_A30 coord=638741.43125,220269.7
+r.water.outlet input=draindir_5K output=basin_A30 coord=638740.423248,220271.519225
d.mon wx0
d.rast map=accum_5K
Modified: grass/trunk/raster/r.water.outlet/r_water_outlet.png
(Binary files differ)
Modified: grass/trunk/raster/r.water.outlet/ramseg.h
--- grass/trunk/raster/r.water.outlet/ramseg.h 2013-09-25 17:56:09 UTC (rev 57840)
+++ grass/trunk/raster/r.water.outlet/ramseg.h 2013-09-26 05:40:12 UTC (rev 57841)
@@ -4,5 +4,5 @@
#define SEGLENLESS 15 /* 2 ^ ramsegbits - 1 */
#define SEG_INDEX(s,r,c) (int) \
- ((((r) >> RAMSEGBITS) * (s) + (((c) >> RAMSEGBITS)) << DOUBLEBITS) \
+ (((((r) >> RAMSEGBITS) * (s) + ((c) >> RAMSEGBITS)) << DOUBLEBITS) \
+ (((r) & SEGLENLESS) << RAMSEGBITS) + ((c) & SEGLENLESS))
