[GRASS-SVN] r57844 - grass/branches/releasebranch_6_4/lib/gis
svn_grass at osgeo.org
Thu Sep 26 03:30:53 PDT 2013
Author: mmetz
Date: 2013-09-26 03:30:53 -0700 (Thu, 26 Sep 2013)
New Revision: 57844
grass/branches/releasebranch_6_4/lib/gis/plot.c
libgis: backport fix FPE error tolerance for plotting
Modified: grass/branches/releasebranch_6_4/lib/gis/plot.c
--- grass/branches/releasebranch_6_4/lib/gis/plot.c 2013-09-26 10:27:51 UTC (rev 57843)
+++ grass/branches/releasebranch_6_4/lib/gis/plot.c 2013-09-26 10:30:53 UTC (rev 57844)
@@ -485,16 +485,20 @@
/* check if perimeter has odd number of points */
- if (np % 2)
+ if (np % 2) {
+ G_debug(1, "Weird internal error: perimeter has odd number of points");
return OUT_OF_SYNC;
/* sort the edge points by col(x) and then by row(y) */
qsort(P, np, sizeof(POINT), &edge_order);
/* plot */
for (i = 1; i < np; i += 2) {
- if (P[i].y != P[i - 1].y)
+ if (P[i].y != P[i - 1].y) {
+ G_debug(1, "Weird internal error: edge leaves row");
return OUT_OF_SYNC;
row_fill(P[i].y, P[i - 1].x + shift1, P[i].x + shift1);
if (window.proj == PROJECTION_LL) { /* now do wrap-around, part 2 */
@@ -622,8 +626,10 @@
} /* for() */
- if (np % 2)
+ if (np % 2) {
return OUT_OF_SYNC;
@@ -631,8 +637,10 @@
/* plot */
for (j = 0; j < rings; j++) {
return OUT_OF_SYNC;
row_fill(P[i].y, P[i - 1].x + shift1[j], P[i].x + shift1[j]);
@@ -661,17 +669,26 @@
static int edge(double x0, double y0, double x1, double y1)
register double m;
- double dy, x;
+ double x, d;
int ystart, ystop;
+ int exp;
+ /* tolerance to avoid FPE */
+ d = GRASS_EPSILON;
+ if (y0 != y1) {
+ if (fabs(y0) > fabs(y1))
+ d = fabs(y0);
+ else
+ d = fabs(y1);
- /* tolerance to avoid FPE */
- dy = y0 - y1;
- if (fabs(dy) < 1e-10)
+ d = frexp(d, &exp);
+ exp -= 53;
+ d = ldexp(d, exp);
+ if (fabs(y0 - y1) < d)
return 1;
- m = (x0 - x1) / dy;
if (y0 < y1) {
ystart = iceil(y0);
ystop = ifloor(y1);
@@ -687,6 +704,7 @@
if (ystart > ystop)
return 1; /* does not cross center line of row */
+ m = (x0 - x1) / (y0 - y1);
x = m * (ystart - y0) + x0;
while (ystart <= ystop) {
if (!edge_point(x, ystart++))
