[GRASS-SVN] r57846 - in grass/trunk: include include/defs lib/imagery
Thu Sep 26 13:32:19 PDT 2013
Author: turek
Date: 2013-09-26 13:32:19 -0700 (Thu, 26 Sep 2013)
New Revision: 57846
Added:
   grass/trunk/lib/imagery/iscatt_core.c
   grass/trunk/lib/imagery/iscatt_structs.c
   grass/trunk/include/defs/imagery.h
   grass/trunk/include/imagery.h
wx.iscatt: c backend
Modified: grass/trunk/include/defs/imagery.h
--- grass/trunk/include/defs/imagery.h	2013-09-26 18:39:38 UTC (rev 57845)
+++ grass/trunk/include/defs/imagery.h	2013-09-26 20:32:19 UTC (rev 57846)
@@ -111,6 +111,28 @@
 FILE *I_fopen_subgroup_ref_new(const char *, const char *);
 FILE *I_fopen_subgroup_ref_old(const char *, const char *);
+/* iscatt_structs.c */
+void I_sc_init_cats(struct scCats *, int, int);
+void I_sc_free_cats(struct scCats *);
+int I_sc_add_cat(struct scCats *);
+int I_sc_insert_scatt_data(struct scCats *, struct scdScattData *, int, int);
+void I_scd_init_scatt_data(struct scdScattData *, int, int, void *);
+/* iscatt_core.c */
+int I_compute_scatts(struct Cell_head *, struct scCats *, const char **,
+	                 const char **, int, struct scCats *, const char **);
+int I_create_cat_rast(struct Cell_head *, const char *);
+int I_insert_patch_to_cat_rast(const char *, struct Cell_head *,  const char *);
+int I_id_scatt_to_bands(const int, const int, int *, int *);
+int I_bands_to_id_scatt(const int, const int, const int, int *);
+int I_merge_arrays(unsigned char *, unsigned char *, unsigned, unsigned, double);
+int I_apply_colormap(unsigned char *, unsigned char *, unsigned,  unsigned char *, unsigned char *);
+int I_rasterize(double *, int, unsigned char, struct Cell_head *, unsigned char *);
 /* sig.c */
 int I_init_signatures(struct Signature *, int);
 int I_new_signature(struct Signature *);
Modified: grass/trunk/include/imagery.h
--- grass/trunk/include/imagery.h	2013-09-26 18:39:38 UTC (rev 57845)
+++ grass/trunk/include/imagery.h	2013-09-26 20:32:19 UTC (rev 57846)
@@ -135,6 +135,63 @@
 } IClass_statistics;
+/* wx.iscatt backend */
+#define SC_SCATT_DATA          0
+#define SC_SCATT_CONDITIONS    1
+/*! Holds list of all catagories.
+    It can contain selected areas for scatter plots (SC_SCATT_CONDITIONS type)
+    or computed scatter plots (SC_SCATT_DATA type).
+struct scCats
+    int type;        /*!< SC_SCATT_DATA -> computed scatter plots, SC_SCATT_CONDITIONS ->
+                          set conditions for scatter plots to be computed */
+    int n_cats;      /*!< number of alocated categories */
+    int n_bands;     /*!< number of analyzed bands */
+    int n_scatts;    /*!< number of possible scattter plots, which can be created from bands */
+    int   n_a_cats;  /*!< number of used/active categories */
+    int * cats_ids;  /*!< (cat_idx->cat_id) array index is internal idx (position in cats_arr)
+                          and id is saved in it's position*/
+    int * cats_idxs; /*!< (cat_id->cat_idx) array index is id and internal idx is saved
+                           in it's position*/
+    struct scScatts ** cats_arr; /*!< array of pointers to struct scScatts */
+/*! Holds list of all scatter plots, which belongs to category.
+struct scScatts
+    int n_a_scatts;     /*!< number of used/active scatter plots*/
+    int * scatts_bands; /*!< array of bands, which represents the scatter plots,
+                             every scatter plot has assigned two bads
+                             (size of the array is n_a_scatts * 2 -> idx*2)*/
+    int * scatt_idxs;   /*!< (scatt_id->scatt_idx) internal idx of the scatter plot
+                             (position in scatts_arr)*/
+    struct scdScattData ** scatts_arr; /*!< array of pointers to scdScattData */
+/*! Holds scatter plot data.
+struct scdScattData
+    int n_vals; /*!< Number of values in scatter plot
+                     (length of b_conds_arr or scatt_vals_arr arrays). */
+    unsigned char  * b_conds_arr; /*!< array of selected areas
+                                      (used for SC_SCATT_CONDITIONS type) otherwise NULL */
+    unsigned int  * scatt_vals_arr; /*!< array of computed areas
+                                        (used for SC_SCATT_DATA type) otherwise NULL */
 #define SIGNATURE_TYPE_MIXED 1
 #define GROUPFILE "CURGROUP"
Added: grass/trunk/lib/imagery/iscatt_core.c
--- grass/trunk/lib/imagery/iscatt_core.c	                        (rev 0)
+++ grass/trunk/lib/imagery/iscatt_core.c	2013-09-26 20:32:19 UTC (rev 57846)
@@ -0,0 +1,1005 @@
+   \file lib/imagery/iscatt_core.c
+   \brief Imagery library - wx.iscatt (wx Interactive Scatter Plot Tool) backend.
+   Copyright (C) 2013 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   \author Stepan Turek <stepan.turek at seznam.cz> (GSoC 2013, Mentor: Martin Landa)
+#include <stdio.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/raster.h>
+#include <grass/imagery.h>
+#include <grass/glocale.h>
+#include "iclass_local_proto.h"
+struct rast_row
+    CELL *row;
+    char *null_row;
+    struct Range rast_range;	/*Range of whole raster. */
+   \brief Create pgm header.
+   Scatter plot internally generates pgm files.
+   These pgms have header in format created by this function.
+   \param region region to be pgm header generated for
+   \param [out] header header of pgm file
+static int get_cat_rast_header(struct Cell_head *region, char *header)
+    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
+   \brief Create category raster conditions file.
+   The file is used for holding selected areas from mapwindow.
+   The reason why the standard GRASS raster is not used is that for every
+   modification (new area is selected) we would need to create whole new raster.
+   Instead of this scatter plot only modifies affected region in
+   the internal pgm file.
+   \param cat_rast_region region to be file generated for
+   \param[out] cat_rast path where the pgm raster file will be generated
+int I_create_cat_rast(struct Cell_head *cat_rast_region, const char *cat_rast)
+    FILE *f_cat_rast;
+    char cat_rast_header[1024];	//TODO magic number
+    int i_row, i_col;
+    int head_nchars;
+    unsigned char *row_data;
+    f_cat_rast = fopen(cat_rast, "wb");
+    if (!f_cat_rast) {
+	G_warning("Unable to create category raster condition file <%s>.",
+		  cat_rast);
+	return -1;
+    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
+    fwrite(cat_rast_header, sizeof(char), head_nchars / sizeof(char),
+	   f_cat_rast);
+    if (ferror(f_cat_rast)) {
+	fclose(f_cat_rast);
+	G_warning(_
+		  ("Unable to write header into category raster condition file <%s>."),
+		  cat_rast);
+	return -1;
+    row_data =
+	(unsigned char *)G_malloc(cat_rast_region->cols *
+				  sizeof(unsigned char));
+    for (i_col = 0; i_col < cat_rast_region->cols; i_col++)
+	row_data[i_col] = 0 & 255;
+    for (i_row = 0; i_row < cat_rast_region->rows; i_row++) {
+	fwrite(row_data, sizeof(unsigned char),
+	       (cat_rast_region->cols) / sizeof(unsigned char), f_cat_rast);
+	    G_warning(_
+		      ("Unable to write into category raster condition file <%s>."),
+		      cat_rast);
+	    return -1;
+    return 0;
+   \brief Find intersection region of two regions.
+   \param A pointer to intersected region
+   \param B pointer to intersected region
+   \param [out] intersec pointer to intersection region of regions A B
+   			   (relevant params of the region are: south, north, east, west)
+   \return  0 if interection exists
+   \return -1 if regions does not intersect
+static int regions_intersecion(struct Cell_head *A, struct Cell_head *B,
+			       struct Cell_head *intersec)
+    if (B->north < A->south)
+	return -1;
+    else if (B->north > A->north)
+	intersec->north = A->north;
+    else
+	intersec->north = B->north;
+    if (B->south > A->north)
+	return -1;
+    else if (B->south < A->south)
+	intersec->south = A->south;
+    else
+	intersec->south = B->south;
+    if (B->east < A->west)
+	return -1;
+    else if (B->east > A->east)
+	intersec->east = A->east;
+    else
+	intersec->east = B->east;
+    if (B->west > A->east)
+	return -1;
+    else if (B->west < A->west)
+	intersec->west = A->west;
+    else
+	intersec->west = B->west;
+    if (intersec->north == intersec->south)
+	return -1;
+    if (intersec->east == intersec->west)
+	return -1;
+    return 0;
+   \brief Get rows and cols numbers, which defines intersection of the regions.
+   \param B pointer to intersected region (A and B must have same resolution)
+   \param [out] A_bounds rows and cols numbers of A stored in
+                south, north, east, west, which defines intersection of A and B
+   \param [out] B_bounds rows and cols numbers of B stored in
+   \return -1 if regions do not intersect
+   \return -2 resolution of regions is not same
+static int get_rows_and_cols_bounds(struct Cell_head *A, struct Cell_head *B,
+				    struct Cell_head *A_bounds,
+				    struct Cell_head *B_bounds)
+    float ns_res, ew_res;
+    struct Cell_head intersec;
+    /* TODO is it right check? */
+    if (abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
+	G_warning(
+		"'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f",
+		A->ns_res, B->ns_res);
+	return -2;
+    if (abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
+	G_warning(
+		"'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f",
+		A->ew_res, B->ew_res);
+	return -2;
+    ns_res = A->ns_res;
+    ew_res = A->ew_res;
+    if (regions_intersecion(A, B, &intersec) == -1)
+	return -1;
+    A_bounds->north =
+	ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
+    A_bounds->south =
+	ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
+    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
+    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
+    B_bounds->north =
+	ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
+    B_bounds->south =
+	ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
+    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
+    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
+    return 0;
+   \brief Insert raster map patch into pgm file.
+   \see I_create_cat_rast
+   Warning: calls Rast_set_window
+   \param patch_rast name of raster map
+   \param cat_rast_region region of category raster file
+   \param cat_rast path to category raster file
+   \return  0 on success
+   \return -1 on failure
+int I_insert_patch_to_cat_rast(const char *patch_rast,
+			       struct Cell_head *cat_rast_region,
+			       const char *cat_rast)
+    FILE *f_cat_rast;
+    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
+    int i_row, i_col, ncols, nrows, patch_col;
+    int head_nchars, ret;
+    int fd_patch_rast, init_shift, step_shift;
+    unsigned char *patch_data;
+    char *null_chunk_row;
+    const char *mapset;
+    f_cat_rast = fopen(cat_rast, "rb+");
+	G_warning(_("Unable to open category raster condtions file <%s>."),
+		  cat_rast);
+	return -1;
+    if ((mapset = G_find_raster((char *)patch_rast, "")) == NULL) {
+	G_warning(_("Unable to find patch raster <%s>."), patch_rast);
+	return -1;
+    Rast_get_cellhd(patch_rast, mapset, &patch_region);
+    Rast_set_window(&patch_region);
+    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
+	return -1;
+    ret =
+	get_rows_and_cols_bounds(cat_rast_region, &patch_region,
+				 &cat_rast_bounds, &patch_bounds);
+    if (ret == -2) {
+	G_warning(_
+		  ("Resolutions of patch <%s> and patched file <%s> are not same."),
+		  patch_rast, cat_rast);
+	Rast_close(fd_patch_rast);
+	return -1;
+    else if (ret == -1) {
+	return 0;
+    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
+    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
+    patch_data = (unsigned char *)G_malloc(ncols * sizeof(unsigned char));
+    init_shift =
+	head_nchars + cat_rast_region->cols * cat_rast_bounds.north +
+	cat_rast_bounds.west;
+    if (fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
+	G_warning(_
+		  ("Corrupted  category raster conditions file <%s> (fseek failed)"),
+		  cat_rast);
+	return -1;
+    step_shift = cat_rast_region->cols - ncols;
+    null_chunk_row = Rast_allocate_null_buf();
+    for (i_row = 0; i_row < nrows; i_row++) {
+	Rast_get_null_value_row(fd_patch_rast, null_chunk_row,
+				i_row + patch_bounds.north);
+	for (i_col = 0; i_col < ncols; i_col++) {
+	    patch_col = patch_bounds.west + i_col;
+	    if (null_chunk_row[patch_col] != 1)
+		patch_data[i_col] = 1 & 255;
+	    else {
+		patch_data[i_col] = 0 & 255;
+	fwrite(patch_data, sizeof(unsigned char),
+	       (ncols) / sizeof(unsigned char), f_cat_rast);
+	    G_warning(_
+		      ("Unable to write into category raster conditions file <%s>"),
+		      cat_rast);
+	    G_free(null_chunk_row);
+	    return -1;
+	if (fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
+	    G_warning(_
+		      cat_rast);
+	    return -1;
+    return 0;
+   \brief Updates scatter plots data in category by pixels which meets category conditions.
+   \param bands_rows data represents data describig one row from raster band
+   \param belongs_pix array which defines which pixels belongs to category
+          (1 value) and which not (0 value)
+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA,
+   		which are modified according to values in belongs_pix
+   		(represents scatter plot category)
+static inline void update_cat_scatt_plts(struct rast_row *bands_rows,
+					 unsigned short *belongs_pix,
+					 struct scScatts *scatts)
+    int i_scatt, array_idx, i_chunk_rows_pix, max_arr_idx;
+    CELL *b_1_row;
+    CELL *b_2_row;
+    char *b_1_null_row, *b_2_null_row;
+    struct rast_row b_1_rast_row, b_2_rast_row;
+    struct Range b_1_range, b_2_range;
+    int b_1_range_size;
+    int row_size = Rast_window_cols();
+    int *scatts_bands = scatts->scatts_bands;
+    for (i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++) {
+	b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
+	b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
+	b_1_row = b_1_rast_row.row;
+	b_2_row = b_2_rast_row.row;
+	b_1_null_row = b_1_rast_row.null_row;
+	b_2_null_row = b_2_rast_row.null_row;
+	b_1_range = b_1_rast_row.rast_range;
+	b_2_range = b_2_rast_row.rast_range;
+	b_1_range_size = b_1_range.max - b_1_range.min + 1;
+	max_arr_idx =
+	    (b_1_range.max - b_1_range.min + 1) * (b_2_range.max -
+						   b_2_range.min + 1);
+	for (i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size;
+	     i_chunk_rows_pix++) {
+	    /* pixel does not belongs to scatter plot or has null value in one of the bands */
+	    if (!belongs_pix[i_chunk_rows_pix] ||
+		b_1_null_row[i_chunk_rows_pix] == 1 ||
+		b_2_null_row[i_chunk_rows_pix] == 1)
+		continue;
+	    /* index in scatter plot array */
+	    array_idx =
+		b_1_row[i_chunk_rows_pix] - b_1_range.min +
+		(b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
+	    if (array_idx < 0 || array_idx >= max_arr_idx) {
+		G_warning
+		    ("Inconsistent data. Value computed for scatter plot is out of initialized range.");
+		continue;
+	    /* increment scatter plot value */
+	    ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
+   \brief Computes scatter plots data from bands_rows.
+   \param region analysis region
+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS,
+   			       where are selected areas (condtitions) stored
+   \param f_cats_rasts_conds file which stores selected areas (conditions) from
+                            mapwindow see I_create_cat_rast and I_insert_patch_to_cat_rast
+   \param bands_rows data arrays of raster rows from analyzed raster bands
+         (all data in bands_rows and belongs_pix arrays represents same region (row))
+   \param[out] scatts pointer to scScatts struct of type SC_SCATT_DATA,
+               where are computed scatter plots stored
+   \param[out] fd_cats_rasts array of opened raster maps,
+                which every represents all selected pixels for category
+static inline int compute_scatts_from_chunk_row(struct Cell_head *region,
+						struct scCats *scatt_conds,
+						FILE ** f_cats_rasts_conds,
+						struct rast_row *bands_rows,
+						struct scCats *scatts,
+						int *fd_cats_rasts)
+    int i_rows_pix, i_cat, i_scatt, n_pixs;
+    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
+    CELL *cat_rast_row;
+    struct scScatts *scatts_conds;
+    struct scScatts *scatts_scatt_plts;
+    int *scatts_bands;
+    CELL *b_1_row;
+    CELL *b_2_row;
+    unsigned char *i_scatt_conds;
+    unsigned short *belongs_pix =
+	(unsigned short *)G_malloc(row_size * sizeof(unsigned short));
+    unsigned char *rast_pixs =
+	(unsigned char *)G_malloc(row_size * sizeof(unsigned char));
+    cat_rast_row = Rast_allocate_c_buf();
+    for (i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++) {
+	scatts_conds = scatt_conds->cats_arr[i_cat];
+	cat_id = scatt_conds->cats_ids[i_cat];
+	scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
+	if (scatt_plts_cat_idx < 0)
+	    continue;
+	scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
+	G_zero(belongs_pix, row_size * sizeof(unsigned short));
+	/* if category has no conditions defined, scatter plots without
+	   any constraint are computed (default scatter plots) */
+	if (!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
+	    for (i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts;
+		 i_scatt++) {
+		/* all pixels belongs */
+		for (i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
+		    belongs_pix[i_rows_pix] = 1;
+	/* compute belonging pixels for defined conditions */
+	else {
+	    scatts_bands = scatts_conds->scatts_bands;
+        /* check conditions from category raster condtitions file
+           (see I_create_cat_rast) */
+	    if (f_cats_rasts_conds[i_cat]) {
+		n_pixs =
+		    fread(rast_pixs, sizeof(unsigned char),
+			  (row_size) / sizeof(unsigned char),
+			  f_cats_rasts_conds[i_cat]);
+		if (ferror(f_cats_rasts_conds[i_cat])) {
+		    G_free(rast_pixs);
+		    G_free(belongs_pix);
+		    G_warning(_
+			      ("Unable to read from category raster condtition file."));
+		    return -1;
+		if (n_pixs != n_pixs) {
+		    G_warning(_
+			      ("Invalid size of category raster conditions file."));
+		    return -1;
+		for (i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++) {
+            if (rast_pixs[i_rows_pix] != (0 & 255))
+	    /* check condtions defined in scatter plots */
+	    for (i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++) {
+		max_arr_idx =
+		i_scatt_conds =
+		    scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
+		    /* pixels already belongs to category from category raster conditions
+		       file or contains null value in one of the bands */
+		    if (belongs_pix[i_rows_pix] ||
+			b_1_null_row[i_rows_pix] == 1 ||
+			b_2_null_row[i_rows_pix] == 1)
+			continue;
+		    array_idx =
+			b_1_row[i_rows_pix] - b_1_range.min +
+			(b_2_row[i_rows_pix] -
+			 b_2_range.min) * b_1_range_size;
+			G_warning
+                _("Data inconsistent. "
+                  "Value computed for scatter plot is out of initialized range.");
+			continue;
+            /* pixels meets condtion defined in scatter plot ->
+               belongs to scatter plot category */
+		    if (i_scatt_conds[array_idx])
+	/* update category raster with belonging pixels */
+	if (fd_cats_rasts[i_cat] >= 0) {
+	    Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
+		if (belongs_pix[i_rows_pix])
+		    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
+	    Rast_put_c_row(fd_cats_rasts[i_cat], cat_rast_row);
+	/* update scatter plots with belonging pixels */
+	update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
+    G_free(cat_rast_row);
+    return 0;
+   \brief Get list of bands needed to be opened for analysis from scCats struct.
+static void get_needed_bands(struct scCats *cats, int *b_needed_bands)
+    /* results in b_needed_bands - array of bools - if item has value 1,
+       band (defined by item index) is needed to be opened */
+    int i_cat, i_scatt;
+    for (i_cat = 0; i_cat < cats->n_a_cats; i_cat++) {
+	for (i_scatt = 0; i_scatt < cats->cats_arr[i_cat]->n_a_scatts;
+	     i_scatt++) {
+	    G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
+	    b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] =
+		1;
+			   scatts_bands[i_scatt * 2 + 1]] = 1;
+    return;
+   \brief Helper function for clean up.
+static void free_compute_scatts_data(int *fd_bands,
+				     int n_a_bands, int *bands_ids,
+				     int *fd_cats_rasts,
+				     FILE ** f_cats_rasts_conds, int n_a_cats)
+    int i, band_id;
+    for (i = 0; i < n_a_bands; i++) {
+	band_id = bands_ids[i];
+	if (band_id >= 0) {
+	    Rast_close(fd_bands[i]);
+	    G_free(bands_rows[band_id].row);
+	    G_free(bands_rows[band_id].null_row);
+    if (f_cats_rasts_conds)
+	for (i = 0; i < n_a_cats; i++)
+	    if (f_cats_rasts_conds[i])
+		fclose(f_cats_rasts_conds[i]);
+    if (fd_cats_rasts)
+	    if (fd_cats_rasts[i] >= 0)
+		Rast_close(fd_cats_rasts[i]);
+   \brief Compute scatter plots data.
+   If category has not defined category raster condition file and no scatter plot
+   exists with condition, default/full scatter plot is computed.
+   \param region analysis region, beaware that all input data must be prepared for this region
+   	  (bands (their ranges), cats_rasts_conds rasters...)
+   \param region function calls Rast_set_window for this region
+          where are stored selected areas (conditions) in scatter plots
+   \param cats_rasts_conds paths to category raster conditions files representing
+    	  selected areas from mapwindow (conditions) in rasters for every category
+   \param cats_rasts_conds index in array represents corresponding category id
+   \param cats_rasts_conds for manupulation with category raster conditions file
+                see also I_id_scatt_to_bands and I_insert_patch_to_cat_rast
+   \param bands names of analyzed bands, order of bands is defined by their id
+   \param n_bands number of bands
+   \param[out] cats_rasts array of raster maps names for every category
+               where will be stored all selected pixels
+int I_compute_scatts(struct Cell_head *region, struct scCats *scatt_conds,
+		     const char **cats_rasts_conds, const char **bands,
+		     int n_bands, struct scCats *scatts,
+		     const char **cats_rasts)
+    char header[1024];
+    int fd_cats_rasts[scatt_conds->n_a_cats];
+    FILE *f_cats_rasts_conds[scatt_conds->n_a_cats];
+    struct rast_row bands_rows[n_bands];
+    RASTER_MAP_TYPE data_type;
+    int nrows, i_band, n_a_bands, band_id;
+    int i_row, head_nchars, i_cat, id_cat;
+    int fd_bands[n_bands];
+    int bands_ids[n_bands];
+    int b_needed_bands[n_bands];
+    Rast_set_window(region);
+    for (i_band = 0; i_band < n_bands; i_band++)
+	fd_bands[i_band] = -1;
+	bands_ids[i_band] = -1;
+    if (n_bands != scatts->n_bands || n_bands != scatt_conds->n_bands)
+	return -1;
+    G_zero(b_needed_bands, (size_t) n_bands * sizeof(int));
+    get_needed_bands(scatt_conds, &b_needed_bands[0]);
+    get_needed_bands(scatts, &b_needed_bands[0]);
+    n_a_bands = 0;
+    /* open band rasters, which are needed for computation */
+    for (band_id = 0; band_id < n_bands; band_id++) {
+	if (b_needed_bands[band_id]) {
+	    G_debug(3, "Opening raster no. %d with name: %s", band_id,
+		    bands[band_id]);
+	    if ((mapset = G_find_raster2(bands[band_id], "")) == NULL) {
+		free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
+					 bands_ids, NULL, NULL,
+					 scatt_conds->n_a_cats);
+		G_warning(_("Unbale to read find raster <%s>"),
+			  bands[band_id]);
+		return -1;
+	    if ((fd_bands[n_a_bands] =
+		 Rast_open_old(bands[band_id], mapset)) < 0) {
+		G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
+		return -1;
+	    data_type = Rast_get_map_type(fd_bands[n_a_bands]);
+	    if (data_type != CELL_TYPE) {
+		G_warning(_("Raster <%s> type is not <%s>"), bands[band_id],
+			  "CELL");
+		return -1;
+	    bands_rows[band_id].row = Rast_allocate_c_buf();
+	    bands_rows[band_id].null_row = Rast_allocate_null_buf();
+	    if (Rast_read_range
+		(bands[band_id], mapset,
+		 &bands_rows[band_id].rast_range) != 1) {
+		G_warning(_("Unable to read range of raster <%s>"),
+			  bands[band_id]);
+		return -1;
+	    bands_ids[n_a_bands] = band_id;
+	    ++n_a_bands;
+    /* open category rasters condition files and category rasters */
+    for (i_cat = 0; i_cat < scatts->n_a_cats; i_cat++) {
+	id_cat = scatts->cats_ids[i_cat];
+	if (cats_rasts[id_cat]) {
+	    fd_cats_rasts[i_cat] =
+		Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
+	else
+	    fd_cats_rasts[i_cat] = -1;
+	if (cats_rasts_conds[id_cat]) {
+	    f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
+	    if (!f_cats_rasts_conds[i_cat]) {
+					 bands_ids, fd_cats_rasts,
+					 f_cats_rasts_conds,
+		G_warning(_
+			  ("Unable to open category raster condtition file <%s>"),
+			  bands[band_id]);
+		return -1;
+	else
+	    f_cats_rasts_conds[i_cat] = NULL;
+    head_nchars = get_cat_rast_header(region, header);
+	    if (fseek(f_cats_rasts_conds[i_cat], head_nchars, SEEK_SET) != 0) {
+		G_warning(_
+			  ("Corrupted category raster conditions file (fseek failed)"));
+		return -1;
+    nrows = Rast_window_rows();
+    /* analyze bands by rows */
+	for (i_band = 0; i_band < n_a_bands; i_band++) {
+	    band_id = bands_ids[i_band];
+	    Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
+	    Rast_get_null_value_row(fd_bands[i_band],
+				    bands_rows[band_id].null_row, i_row);
+	if (compute_scatts_from_chunk_row
+	    (region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts,
+	     fd_cats_rasts) == -1) {
+	    return -1;
+    free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
+			     			 fd_cats_rasts, f_cats_rasts_conds,
+    return 0;
+   \brief Merge arrays according to opacity.
+   Every pixel in array must be represented by 4 values (RGBA).
+   Implementd for speeding up of scatter plots rendering.
+   \param merged_arr array which will be overlayd with overlay_arr
+   \param overlay_arr array to be merged_arr overlayed with
+   \param rows number of rows for the both arrays
+   \param cols number of columns for the both arrays
+   \param alpha transparency (0-1) of the overlay array for merging
+   \return  0
+int I_merge_arrays(unsigned char *merged_arr, unsigned char *overlay_arr,
+		   unsigned rows, unsigned cols, double alpha)
+    unsigned int i_row, i_col, i_b;
+    unsigned int row_idx, col_idx, idx;
+    unsigned int c_a_i, c_a;
+    for (i_row = 0; i_row < rows; i_row++) {
+	row_idx = i_row * cols;
+	for (i_col = 0; i_col < cols; i_col++) {
+	    col_idx = 4 * (row_idx + i_col);
+	    idx = col_idx + 3;
+	    c_a = overlay_arr[idx] * alpha;
+	    c_a_i = 255 - c_a;
+	    merged_arr[idx] =
+		(c_a_i * (int)merged_arr[idx] + c_a * 255) / 255;
+	    for (i_b = 0; i_b < 3; i_b++) {
+		idx = col_idx + i_b;
+		merged_arr[idx] =
+		     c_a * (int)overlay_arr[idx]) / 255;
+    return 0;
+   \brief Apply colromap to the raster.
+   \param vals array of values for applying the colormap
+   \param vals_mask maks of vals array
+   \param nvals number of items of vals_mask and vals array
+   \param colmap colour map to be applied
+   \param[out] col_vals output raster with applied color map (length is 4 * nvals (RGBA))
+   \return 0
+int I_apply_colormap(unsigned char *vals, unsigned char *vals_mask,
+		     unsigned nvals, unsigned char *colmap,
+		     unsigned char *col_vals)
+    unsigned int i_val;
+    int v, i, i_cm;
+    for (i_val = 0; i_val < nvals; i_val++) {
+	i_cm = 4 * i_val;
+	v = vals[i_val];
+	if (vals_mask && vals_mask[i_val])
+	    for (i = 0; i < 4; i++)
+		col_vals[i_cm + i] = colmap[258 * 4 + i];
+	else if (v > 255)
+		col_vals[i_cm + i] = colmap[257 * 4 + i];
+	else if (v < 0)
+		col_vals[i_cm + i] = colmap[256 * 4 + i];
+	else
+	    for (i = 0; i < 4; i++) {
+		col_vals[i_cm + i] = colmap[v * 4 + i];
+    return 0;
+   \brief Wrapper for using of iclass perimeter rasterization by scatter plot.
+   \param polygon array of polygon coordinates [x, y, x, y...]
+   \param pol_n_pts number of points in the polygon array
+   \param val value to be assigned to cells, which belong to plygon
+   \param rast_region region of raster
+   \param[out] rast raster to be pologyn rasterized in
+   \return 1 on failure
+int I_rasterize(double *polygon, int pol_n_pts, unsigned char val,
+		struct Cell_head *rast_region, unsigned char *rast)
+    int i;
+    int x0, x1, y;
+    int row, row_idx, i_col;
+    IClass_perimeter perimeter;
+    struct line_pnts *pol;
+    pol = Vect_new_line_struct();
+    for (i = 0; i < pol_n_pts; i++) {
+	Vect_append_point(pol, polygon[i * 2], polygon[i * 2 + 1], 0.0);
+    Rast_set_window(rast_region);
+    make_perimeter(pol, &perimeter, rast_region);
+    for (i = 1; i < perimeter.npoints; i += 2) {
+	y = perimeter.points[i].y;
+	if (y != perimeter.points[i - 1].y) {
+	    G_warning(_
+		      ("prepare_signature: scan line %d has odd number of points."),
+		      (i + 1) / 2);
+	    return 1;
+	x0 = perimeter.points[i - 1].x;
+	x1 = perimeter.points[i].x;
+	if (x0 > x1) {
+	    G_warning(_("signature: perimeter points out of order."));
+	    return 1;
+	row = (rast_region->rows - y);
+	if (row < 0 || row >= rast_region->rows) {
+	    continue;
+	row_idx = rast_region->cols * row;
+	for (i_col = x0; i_col <= x1; i_col++) {
+	    if (i_col < 0 || i_col >= rast_region->cols) {
+		continue;
+	    rast[row_idx + i_col] = val;
+    Vect_destroy_line_struct(pol);
+    G_free(perimeter.points);
+    return 0;
Property changes on: grass/trunk/lib/imagery/iscatt_core.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass/trunk/lib/imagery/iscatt_structs.c
--- grass/trunk/lib/imagery/iscatt_structs.c	                        (rev 0)
+++ grass/trunk/lib/imagery/iscatt_structs.c	2013-09-26 20:32:19 UTC (rev 57846)
@@ -0,0 +1,290 @@
+   \file lib/imagery/iscatt_structs.c
+   \brief Imagery library - functions for manipulation with structures used
+          by wx.iscatt (wx Interactive Scatter Plot Tool)
+#include <math.h>
+   \brief Compute band ids from scatter plot id.
+   Scatter plot id describes which bands defines the scatter plot.
+   Let say we have 3 bands, their ids are 0, 1 and 2.
+   Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
+   All scatter plots:
+   scatt_id b_1_id b_2_id
+   0        0      1
+   1        0      2
+   2        1      2
+   \param scatt_id scatter plot id
+   \param[out] b_1_id id of band1
+   \param[out] b_2_id id of band2
+   \return 0
+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int *b_1_id,
+			int *b_2_id)
+    int n_b1 = n_bands - 1;
+    *b_1_id =
+	(int)((2 * n_b1 + 1 -
+	       sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id)))
+	      / 2);
+    *b_2_id =
+	scatt_id - ((*b_1_id) * (2 * n_b1 + 1) - (*b_1_id) * (*b_1_id)) / 2 +
+	(*b_1_id) + 1;
+    return 0;
+   \brief Compute scatter plot id from band ids.
+   See also I_id_scatt_to_bands
+   \param b_1_id id of band1
+   \param b_1_id id of band2
+   \param[out] scatt_id scatter plot id
+   \return 0
+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands,
+			int *scatt_id)
+    *scatt_id =
+	(b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
+    return 0;
+   \brief Initialize structure for storing scatter plots data.
+   \param cats pointer to scCats struct
+   \param type SC_SCATT_DATA - stores scatter plots
+   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
+void I_sc_init_cats(struct scCats *cats, int n_bands, int type)
+    int i_cat;
+    cats->type = type;
+    cats->n_cats = 100;
+    cats->n_a_cats = 0;
+    cats->n_bands = n_bands;
+    cats->n_scatts = (n_bands - 1) * n_bands / 2;
+    cats->cats_arr =
+	(struct scScatts **)G_malloc(cats->n_cats *
+				     sizeof(struct scScatts *));
+    G_zero(cats->cats_arr, cats->n_cats * sizeof(struct scScatts *));
+    cats->cats_ids = (int *)G_malloc(cats->n_cats * sizeof(int));
+    cats->cats_idxs = (int *)G_malloc(cats->n_cats * sizeof(int));
+    for (i_cat = 0; i_cat < cats->n_cats; i_cat++)
+	cats->cats_idxs[i_cat] = -1;
+    return;
+   \brief Free data of struct scCats, the structure itself remains alocated.
+   \param cats pointer to existing scCats struct
+void I_sc_free_cats(struct scCats *cats)
+    int i_cat;
+	if (cats->cats_arr[i_cat]) {
+	    G_free(cats->cats_arr[i_cat]->scatt_idxs);
+	    G_free(cats->cats_arr[i_cat]->scatts_bands);
+	    G_free(cats->cats_arr[i_cat]->scatts_arr);
+	    G_free(cats->cats_arr[i_cat]);
+    G_free(cats->cats_ids);
+    G_free(cats->cats_idxs);
+    G_free(cats->cats_arr);
+    cats->n_cats = 0;
+    cats->n_bands = 0;
+    cats->n_scatts = 0;
+    cats->type = -1;
+    return;
+   \brief Add category.
+   Category represents group of scatter plots.
+   \return assigned category id (starts with 0)
+   \return -1 if maximum nuber of categories was reached
+int I_sc_add_cat(struct scCats *cats)
+    int i_scatt, i_cat_id, cat_id;
+    int n_a_cats = cats->n_a_cats;
+    if (cats->n_a_cats >= cats->n_cats)
+	return -1;
+    for (i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
+	if (cats->cats_idxs[i_cat_id] < 0) {
+	    cat_id = i_cat_id;
+	    break;
+    cats->cats_ids[n_a_cats] = cat_id;
+    cats->cats_idxs[cat_id] = n_a_cats;
+    cats->cats_arr[n_a_cats] =
+	(struct scScatts *)G_malloc(sizeof(struct scScatts));
+    cats->cats_arr[n_a_cats]->scatts_arr =
+	(struct scdScattData **)G_malloc(cats->n_scatts *
+					 sizeof(struct scdScattData *));
+    G_zero((cats->cats_arr[n_a_cats]->scatts_arr),
+	   cats->n_scatts * sizeof(struct scdScattData *));
+    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
+    cats->cats_arr[n_a_cats]->scatts_bands =
+	(int *)G_malloc(cats->n_scatts * 2 * sizeof(int));
+    cats->cats_arr[n_a_cats]->scatt_idxs =
+	(int *)G_malloc(cats->n_scatts * sizeof(int));
+    for (i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
+	cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
+    ++cats->n_a_cats;
+    return cat_id;
+   \brief Insert scatter plot data .
+   Inserted scatt_data struct must have same type as
+   cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
+   \param scarr_data pointer to scdScattData struct
+   \param cat_id id number of category
+   \param scatt_id id number of scatter plot
+int I_sc_insert_scatt_data(struct scCats *cats,
+			   struct scdScattData *scatt_data, int cat_id,
+			   int scatt_id)
+    int band_1, band_2, cat_idx, n_a_scatts;
+    struct scScatts *scatts;
+    if (cat_id < 0 || cat_id >= cats->n_cats)
+	return -1;
+    cat_idx = cats->cats_idxs[cat_id];
+    if (cat_idx < 0)
+	return -1;
+    if (scatt_id < 0 && scatt_id >= cats->n_scatts)
+	return -1;
+    scatts = cats->cats_arr[cat_idx];
+    if (scatts->scatt_idxs[scatt_id] >= 0)
+	return -1;
+    if (!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
+	return -1;
+    if (!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
+	return -1;
+    n_a_scatts = scatts->n_a_scatts;
+    scatts->scatt_idxs[scatt_id] = n_a_scatts;
+    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
+    scatts->scatts_bands[n_a_scatts * 2] = band_1;
+    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
+    scatts->scatts_arr[n_a_scatts] = scatt_data;
+    ++scatts->n_a_scatts;
+    return 0;
+   \brief Insert scatter plot data.
+   \param scatt_data pointer to existing struct scdScattData
+   \param type SC_SCATT_DATA for scatter plots or
+               SC_SCATT_CONDITIONS for selected areas in scatter plot
+   \param n_vals number of data values
+   \param data array of values (unsigned char for SC_SCATT_CONDITIONS,
+          unsigned int for SC_SCATT_DATA)
+void I_scd_init_scatt_data(struct scdScattData *scatt_data, int type,
+			   int n_vals, void *data)
+    scatt_data->n_vals = n_vals;
+    if (type == SC_SCATT_DATA) {
+	if (data)
+	    scatt_data->scatt_vals_arr = (unsigned int *)data;
+	else {
+		(unsigned int *)G_malloc(n_vals * sizeof(unsigned int));
+        G_zero(scatt_data->scatt_vals_arr,
+		   n_vals * sizeof(unsigned int));
+	scatt_data->b_conds_arr = NULL;
+    else if (type == SC_SCATT_CONDITIONS) {
+	if (data)
+	    scatt_data->b_conds_arr = (unsigned char *)data;
+	else {
+		(unsigned char *)G_malloc(n_vals * sizeof(unsigned char));
+        G_zero(scatt_data->b_conds_arr,
+		   n_vals * sizeof(unsigned char));
+	scatt_data->scatt_vals_arr = NULL;
+    return;
Property changes on: grass/trunk/lib/imagery/iscatt_structs.c
   + text/x-csrc
   + native
