[GRASS-SVN] r57860 - grass/trunk/vector/v.db.connect
svn_grass at osgeo.org
Sat Sep 28 14:22:13 PDT 2013
Author: mmetz
Date: 2013-09-28 14:22:13 -0700 (Sat, 28 Sep 2013)
New Revision: 57860
grass/trunk/vector/v.db.connect/main.c
v.db.connect: topo is not needed
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2013-09-28 17:17:12 UTC (rev 57859)
+++ grass/trunk/vector/v.db.connect/main.c 2013-09-28 21:22:13 UTC (rev 57860)
@@ -145,8 +145,8 @@
if (print->answer && shell_print->answer)
G_fatal_error(_("Please choose only one print style"));
+ Vect_set_open_level(1); /* no topology needed */
if (print->answer || shell_print->answer || columns->answer) {
- Vect_set_open_level(1); /* no topology needed */
Vect_open_old2(&Map, inopt->answer, "", field_opt->answer);
else {
