[GRASS-SVN] r57867 - grass/branches/releasebranch_6_4/imagery/i.landsat.toar
svn_grass at osgeo.org
Mon Sep 30 07:37:54 PDT 2013
Author: neteler
Date: 2013-09-30 07:37:54 -0700 (Mon, 30 Sep 2013)
New Revision: 57867
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
i.landsat.toar: fix compiler warnings (author: E. Jorge Tizado)
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c 2013-09-30 02:12:02 UTC (rev 57866)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c 2013-09-30 14:37:54 UTC (rev 57867)
@@ -17,7 +17,7 @@
#define TM5_MET_SIZE 28700 /* .met file size 28686 bytes */
-inline void chrncpy(char *dest, char src[], int n)
+static void chrncpy(char *dest, char src[], int n)
int i;
@@ -31,7 +31,7 @@
while (*str) {
if (*str == '/')
*str = '-';
- *str++;
+ str++;
@@ -46,9 +46,9 @@
if (ptr != NULL) {
while (*ptr++ != '=') ;
while (*ptr <= ' ')
- *ptr++;
+ ptr++;
if (*ptr == '\"')
- *ptr++;
+ ptr++;
while (i < MAX_STR && *ptr != '\"' && *ptr >= ' ')
value[i++] = *ptr++;
@@ -64,9 +64,9 @@
if (ptr != NULL) {
while (*ptr <= ' ')
- *ptr++;
+ ptr++;
if (*ptr == '\"')
- *ptr++;
+ ptr++;
while (i < MAX_STR && *ptr != '\"' && *ptr > ' ')
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-09-30 02:12:02 UTC (rev 57866)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-09-30 14:37:54 UTC (rev 57867)
@@ -335,6 +335,8 @@
G_set_window(&cellhd);
in_data_type = G_raster_map_type(band_in, mapset);
+ if (in_data_type < 0)
+ G_fatal_error(_("Unable to read data type of raster map <%s>"), band_in);
inrast = G_allocate_raster_buf(in_data_type);
nrows = G_window_rows();
@@ -357,6 +359,10 @@
ptr = (void *)((DCELL *) inrast + col);
q = (int)*((DCELL *) ptr);
break;
+ default:
+ ptr = NULL;
+ q = -1.;
+ break;
if (!G_is_null_value(ptr, in_data_type) &&
q >= lsat.band[i].qcalmin &&
@@ -470,6 +476,8 @@
if ((infd = G_open_cell_old(band_in, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), band_in);
if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
G_fatal_error(_("Unable to read header of raster map <%s>"),
band_in);
@@ -515,6 +523,10 @@
qcal = (double)((DCELL *) inrast)[col];
break;
+ default:
+ ptr = NULL;
+ qcal = -1.;
+ break;
if (G_is_null_value(ptr, in_data_type) ||
qcal < lsat.band[i].qcalmin) {
