[GRASS-SVN] r57896 - grass/trunk/vector/v.net.visibility
svn_grass at osgeo.org
Mon Sep 30 15:05:04 PDT 2013
Author: martinl
Date: 2013-09-30 15:05:04 -0700 (Mon, 30 Sep 2013)
New Revision: 57896
grass/trunk/vector/v.net.visibility/main.c
grass/trunk/vector/v.net.visibility/v.net.visibility.html
v.net.visibility: description module cosmetics
manual cleaning
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c 2013-09-30 21:58:45 UTC (rev 57895)
+++ grass/trunk/vector/v.net.visibility/main.c 2013-09-30 22:05:04 UTC (rev 57896)
@@ -46,7 +46,7 @@
G_add_keyword(_("network"));
G_add_keyword(_("shortest path"));
G_add_keyword(_("visibility"));
- module->description = _("Visibility graph construction.");
+ module->description = _("Performs visibility graph construction.");
/* define the arguments needed */
input = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.net.visibility/v.net.visibility.html
--- grass/trunk/vector/v.net.visibility/v.net.visibility.html 2013-09-30 21:58:45 UTC (rev 57895)
+++ grass/trunk/vector/v.net.visibility/v.net.visibility.html 2013-09-30 22:05:04 UTC (rev 57896)
@@ -9,17 +9,21 @@
in the vector map. This is useful to compute the sortest path in a
vector map from any two points. To do this, first you need to compute
the visibility graph and from it compute the shortest path using
-<em>v.net.path</em> or <em>d.path</em>.
+<em><a href="v.net.path.html">v.net.path</a></em>
+or <em><a href="d.path.html">d.path</a></em>.
+<p>
<b>IMPORTANT: the algorithm doesn't work well with intersecting lines
(that includes overlapping)</b>
-<p>
-If you compute a shortest path after computing the visibility graph you
-will notice that this path might go through a vertix of a line. If this
-is not wanted you might to run the map through <em>v.buffer</em> first
-whith a small value. Example:
+<h2>NOTES</h2>
+If you compute a shortest path after computing the visibility graph
+you will notice that this path might go through a vertix of a line. If
+this is not wanted you might to run the map
+through <em><a href="v.buffer.html">v.buffer</a></em> first whith a
+small value. Example:
<div class="code"><pre>
v.buffer input=map output=bufferedmap buffer=1 type=point,line,area,boundary
</pre></div>
@@ -50,7 +54,9 @@
coordinate=25556200,6686400,25556400,6686600
</pre></div>
-<h2>EXAMPLE 1</h2>
+<h2>EXAMPLES</h2>
+<h3>Example 1</h3>
A simple example showing how to use the module
v.net.visibility input=lines output=graph
@@ -58,8 +64,8 @@
d.vect lines col=red
</pre></div>
-<h2>EXAMPLE 2</h2>
-An example on how to use <em>v.buffer</em> with the module
+<h3>Example 2</h3>
+An example on how to use <em><a href="v.buffer.html">v.buffer</a></em> with the module
v.buffer input=lines output=buffered_lines buffer=1
v.net.visibility input=buffered_lines output=graph
@@ -68,7 +74,7 @@
</pre></div>
-<h2>EXAMPLE 3</h2>
+<h3>Example 3</h3>
An example on how to use the coordinate parameter. This will compute the
visibility graph of the vector map lines with the point 2555678,6686343
@@ -77,7 +83,7 @@
</pre></div>
-<h2>EXAMPLE 4</h2>
+<h3>Example 4</h3>
An example on how to use the coordinate parameter with the vis parameter.
Here the vector map graph is computed then a new visibility graph is computed
from it with the point 2555678,6686343 extra
@@ -93,12 +99,12 @@
</pre></div>
-<h2>EXAMPLE 5</h2>
+<h3>Example 5</h3>
An example for connections of points (Spearfish):
v.net.visibility input=archsites output=graph
g.region vect=archsites
-d.mon x0
+d.mon wx0
d.vect graph
d.vect archsites col=red
</pre></div>
@@ -111,16 +117,19 @@
<h2>SEE ALSO</h2>
-<em><a href="d.path.html">d.path</a></em>,
-<em><a href="v.net.html">v.net</a></em>,
-<em><a href="v.net.alloc.html">v.net.alloc</a></em>,
-<em><a href="v.net.iso.html">v.net.iso</a></em>,
-<em><a href="v.net.salesman.html">v.net.salesman</a></em>,
-<em><a href="v.net.steiner.html">v.net.steiner</a></em>,
-<em><a href="v.to.db.html">v.to.db</a></em>
+<em>
+<a href="d.path.html">d.path</a>,
+<a href="v.net.html">v.net</a>,
+<a href="v.net.alloc.html">v.net.alloc</a>,
+<a href="v.net.iso.html">v.net.iso</a>,
+<a href="v.net.salesman.html">v.net.salesman</a>,
+<a href="v.net.steiner.html">v.net.steiner</a>,
+<a href="v.to.db.html">v.to.db</a>
+</em>
<h2>AUTHOR</h2>
Maximilian Maldacker<br>
Mentor: Wolf Bergenheim
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
