[GRASS-SVN] r57899 - grass/trunk/gui/wxpython/animation
Mon Sep 30 20:31:44 PDT 2013
Author: annakrat
Date: 2013-09-30 20:31:44 -0700 (Mon, 30 Sep 2013)
New Revision: 57899
   grass/trunk/gui/wxpython/animation/mapwindow.py
wxGUI/animation: add warning when rendering fails
Modified: grass/trunk/gui/wxpython/animation/mapwindow.py
--- grass/trunk/gui/wxpython/animation/mapwindow.py	2013-09-30 22:47:24 UTC (rev 57898)
+++ grass/trunk/gui/wxpython/animation/mapwindow.py	2013-10-01 03:31:44 UTC (rev 57899)
@@ -285,7 +285,7 @@
         """!Sets size when size of related window changes."""
         self.imageWidth, self.imageHeight = width, height
-    def _createNoDataBitmap(self, width, height):
+    def _createNoDataBitmap(self, width, height, text="No data"):
         """!Creates 'no data' bitmap.
         Used when requested bitmap is not available (loading data was not successful) or
@@ -295,7 +295,7 @@
         dc = wx.MemoryDC()
         dc.SelectObject(bitmap)
         dc.Clear()
-        text = _("No data")
+        text = _(text)
         dc.SetFont(wx.Font(pointSize = 40, family = wx.FONTFAMILY_SCRIPT,
                            style = wx.FONTSTYLE_NORMAL, weight = wx.FONTWEIGHT_BOLD))
         tw, th = dc.GetTextExtent(text)
@@ -424,7 +424,8 @@
                     # Unfortunately the png files must be read here,
                     # since the swig wx objects can not be serialized by the Queue object :(
                     if filename == None:
-                        self.bitmapPool[name_list[i]] = wx.EmptyBitmap(imageWidth, imageHeight)
+                        self.bitmapPool[name_list[i]] = self._createNoDataBitmap(imageWidth, imageHeight,
+        text="Failed to render")
                     else:
                         self.bitmapPool[name_list[i]] = wx.BitmapFromImage(wx.Image(filename))
                         os.remove(filename)
@@ -535,6 +536,7 @@
         return
     if returncode != 0:
+        grass.warning("Rendering failed:\n" + messages)
         fileQueue.put(None)
         os.remove(filename)
         return
