[GRASS-SVN] r59538 - grass/trunk/gui/wxpython/animation
svn_grass at osgeo.org
Tue Apr 1 00:59:24 PDT 2014
Author: lucadelu
Date: 2014-04-01 00:59:23 -0700 (Tue, 01 Apr 2014)
New Revision: 59538
grass/trunk/gui/wxpython/animation/dialogs.py
grass/trunk/gui/wxpython/animation/frame.py
grass/trunk/gui/wxpython/animation/g.gui.animation.py
grass/trunk/gui/wxpython/animation/provider.py
grass/trunk/gui/wxpython/animation/utils.py
g.gui.animation: fix small bug with vector input; fix .format() function to be compatible also with python 2.6
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2014-04-01 06:18:18 UTC (rev 59537)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2014-04-01 07:59:23 UTC (rev 59538)
@@ -1389,12 +1389,12 @@
cmd.append('d.rast3d')
if self._name:
if self._mapType in ('rast', 'vect', 'rast3d'):
- cmd.append('map={}'.format(self._name.split(',')[0]))
+ cmd.append('map={name}'.format(name=self._name.split(',')[0]))
else:
try:
maps = getRegisteredMaps(self._name, etype=self._mapType)
if maps:
- cmd.append('map={}'.format(maps[0]))
+ cmd.append('map={name}'.format(name=maps[0]))
except gcore.ScriptError, e:
GError(parent=self, message=str(e), showTraceback=False)
return None
Modified: grass/trunk/gui/wxpython/animation/frame.py
--- grass/trunk/gui/wxpython/animation/frame.py 2014-04-01 06:18:18 UTC (rev 59537)
+++ grass/trunk/gui/wxpython/animation/frame.py 2014-04-01 07:59:23 UTC (rev 59538)
@@ -274,7 +274,8 @@
self._progressDlgMax = count
def _updateProgress(self, current, text):
- text += _(" ({} out of {})").format(current, self._progressDlgMax)
+ text += _(" ({c} out of {p})").format(c=current,
+ p=self._progressDlgMax)
keepGoing, skip = self._progressDlg.Update(current, text)
if not keepGoing:
self.provider.RequestStopRendering()
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-04-01 06:18:18 UTC (rev 59537)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-04-01 07:59:23 UTC (rev 59538)
@@ -101,13 +101,13 @@
layer = AnimLayer()
layer.mapType = 'rast'
layer.name = rast
- layer.cmd = ['d.rast', 'map={}'.format(rast.split(',')[0])]
+ layer.cmd = ['d.rast', 'map={name}'.format(name=rast.split(',')[0])]
layerList.AddLayer(layer)
if vect:
layer = AnimLayer()
layer.mapType = 'vect'
layer.name = vect
- layer.cmd = ['d.vect', 'map={}'.format(rast.split(',')[0])]
+ layer.cmd = ['d.vect', 'map={name=}'.format(name=vect.split(',')[0])]
if strds:
layer = AnimLayer()
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py 2014-04-01 06:18:18 UTC (rev 59537)
+++ grass/trunk/gui/wxpython/animation/provider.py 2014-04-01 07:59:23 UTC (rev 59538)
@@ -90,7 +90,7 @@
@param opacities list of opacity values
@param regions list of regions
- Debug.msg(2, "BitmapProvider.SetCmds: {} lists".format(len(cmdsForComposition)))
+ Debug.msg(2, "BitmapProvider.SetCmds: {n} lists".format(n=len(cmdsForComposition)))
self._cmdsForComposition.extend(cmdsForComposition)
self._opacities.extend(opacities)
self._regions.extend(regions)
@@ -103,7 +103,7 @@
@param cmds list of commands m.nviz.image (cmd as a list)
@param region for 3D rendering
- Debug.msg(2, "BitmapProvider.SetCmds3D: {} commands".format(len(cmds)))
+ Debug.msg(2, "BitmapProvider.SetCmds3D: {c} commands".format(c=len(cmds)))
self._cmds3D = cmds
self._regionFor3D = region
@@ -157,7 +157,7 @@
continue
count += 1
- Debug.msg(3, "BitmapProvider._dryRender: {} files to be rendered".format(count))
+ Debug.msg(3, "BitmapProvider._dryRender: {c} files to be rendered".format(c=count))
return count
@@ -177,7 +177,7 @@
continue
count += 1
- Debug.msg(2, "BitmapProvider._dryCompose: {} files to be composed".format(count))
+ Debug.msg(2, "BitmapProvider._dryCompose: {c} files to be composed".format(c=count))
return count
@@ -190,7 +190,9 @@
@param nprocs number of procs to be used for rendering
Debug.msg(2, "BitmapProvider.Load: "
- "force={}, bgcolor={}, nprocs={}".format(force, bgcolor, nprocs))
+ "force={f}, bgcolor={b}, nprocs={n}".format(f=force,
+ b=bgcolor,
+ n=nprocs))
cmds = []
regions = []
if self._uniqueCmds:
@@ -246,7 +248,7 @@
def WindowSizeChanged(self, width, height):
"""!Sets size when size of related window changes."""
- Debug.msg(5, "BitmapProvider.WindowSizeChanged: w={}, h={}".format(width, height))
+ Debug.msg(5, "BitmapProvider.WindowSizeChanged: w={w}, h={h}".format(w=width, h=height))
self.imageWidth, self.imageHeight = width, height
@@ -260,7 +262,7 @@
@return bitmap with legend
- Debug.msg(5, "BitmapProvider.LoadOverlay: cmd={}".format(cmd))
+ Debug.msg(5, "BitmapProvider.LoadOverlay: cmd={c}".format(c=cmd))
fileHandler, filename = tempfile.mkstemp(suffix=".png")
os.close(fileHandler)
@@ -603,14 +605,14 @@
self.referenceCount[key] = 1
else:
self.referenceCount[key] += 1
- Debug.msg(5, 'DictRefCounter.__setitem__: +1 for key {}'.format(key))
+ Debug.msg(5, 'DictRefCounter.__setitem__: +1 for key {k}'.format(k=key))
def __contains__(self, key):
return key in self.dictionary
def __delitem__(self, key):
self.referenceCount[key] -= 1
- Debug.msg(5, 'DictRefCounter.__delitem__: -1 for key {}'.format(key))
+ Debug.msg(5, 'DictRefCounter.__delitem__: -1 for key {k}'.format(k=key))
def keys(self):
return self.dictionary.keys()
@@ -670,9 +672,9 @@
if os.path.exists(self._tempDir):
try:
shutil.rmtree(self._tempDir)
- Debug.msg(5, 'CleanUp: removed directory {}'.format(self._tempDir))
+ Debug.msg(5, 'CleanUp: removed directory {t}'.format(t=self._tempDir))
except OSError:
- gcore.warning(_("Directory {} not removed.").format(self._tempDir))
+ gcore.warning(_("Directory {t} not removed.").format(t=self._tempDir))
def _setEnvironment(width, height, filename, transparent, bgcolor):
@@ -684,15 +686,20 @@
@param transparent use transparency
@param bgcolor background color as a tuple of 3 values 0 to 255
- Debug.msg(5, "_setEnvironment: width={}, height={}, "
- "filename={}, transparent={}, bgcolor={}".format(width, height, filename,
- transparent, bgcolor))
+ Debug.msg(5, "_setEnvironment: width={w}, height={h}, "
+ "filename={f}, transparent={t}, bgcolor={b}".format(w=width,
+ h=height,
+ f=filename,
+ t=transparent,
+ b=bgcolor))
os.environ['GRASS_WIDTH'] = str(width)
os.environ['GRASS_HEIGHT'] = str(height)
driver = UserSettings.Get(group='display', key='driver', subkey='type')
os.environ['GRASS_RENDER_IMMEDIATE'] = driver
- os.environ['GRASS_BACKGROUNDCOLOR'] = '{:02x}{:02x}{:02x}'.format(*bgcolor)
+ os.environ['GRASS_BACKGROUNDCOLOR'] = '{r}{g}{b}'.format(r=bgcolor[0],
+ g=bgcolor[1],
+ b=bgcolor[2])
os.environ['GRASS_TRUECOLOR'] = "TRUE"
if transparent:
os.environ['GRASS_TRANSPARENT'] = "TRUE"
@@ -710,8 +717,9 @@
@param imageWidth image width
@param imageHeight image height
- Debug.msg(4, "createNoDataBitmap: w={}, h={}, text={}".format(imageWidth,
- imageHeight, text))
+ Debug.msg(4, "createNoDataBitmap: w={w}, h={h}, text={t}".format(w=imageWidth,
+ h=imageHeight,
+ t=text))
bitmap = wx.EmptyBitmap(imageWidth, imageHeight)
dc = wx.MemoryDC()
dc.SelectObject(bitmap)
@@ -772,13 +780,13 @@
prov = BitmapProvider(bPool, mapFilesPool, tempDir,
imageWidth=640, imageHeight=480)
prov.renderingStarted.connect(
- lambda count: sys.stdout.write("Total number of maps: {}\n".format(count)))
+ lambda count: sys.stdout.write("Total number of maps: {c}\n".format(c=count)))
prov.renderingContinues.connect(
- lambda current, text: sys.stdout.write("Current number: {}\n".format(current)))
+ lambda current, text: sys.stdout.write("Current number: {c}\n".format(c=current)))
prov.compositionStarted.connect(
- lambda count: sys.stdout.write("Composition: total number of maps: {}\n".format(count)))
+ lambda count: sys.stdout.write("Composition: total number of maps: {c}\n".format(c=count)))
prov.compositionContinues.connect(
- lambda current, text: sys.stdout.write("Composition: Current number: {}\n".format(current)))
+ lambda current, text: sys.stdout.write("Composition: Current number: {c}\n".format(c=current)))
prov.mapsLoaded.connect(
lambda: sys.stdout.write("Maps loading finished\n"))
cmdMatrix = layerListToCmdsMatrix(layerList)
Modified: grass/trunk/gui/wxpython/animation/utils.py
--- grass/trunk/gui/wxpython/animation/utils.py 2014-04-01 06:18:18 UTC (rev 59537)
+++ grass/trunk/gui/wxpython/animation/utils.py 2014-04-01 07:59:23 UTC (rev 59538)
@@ -290,7 +290,7 @@
cmd = layer.cmd[:]
cmds = []
for map_ in layer.maps:
- cmd[i] = 'map={}'.format(map_)
+ cmd[i] = 'map={name}'.format(name=map_)
cmds.append(cmd[:])
cmdsForComposition.append(cmds)
else:
