[GRASS-SVN] r59552 - grass/trunk/raster/r.sunmask
svn_grass at osgeo.org
Wed Apr 2 05:34:43 PDT 2014
Author: neteler
Date: 2014-04-02 05:34:42 -0700 (Wed, 02 Apr 2014)
New Revision: 59552
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.sunmask/r.sunmask.html
r.sunmask manual: minor updates
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2014-04-02 12:09:45 UTC (rev 59551)
+++ grass/trunk/raster/r.sunmask/main.c 2014-04-02 12:34:42 UTC (rev 59552)
@@ -246,7 +246,7 @@
if (!parm.north->answer || !parm.east->answer) {
north = (window.north - window.south) / 2. + window.south;
east = (window.west - window.east) / 2. + window.east;
- G_verbose_message(_("Using map center coordinates: %f %f"), east, north);
+ G_message(_("Using map center coordinates: %f %f"), east, north);
else { /* user defined east, north: */
Modified: grass/trunk/raster/r.sunmask/r.sunmask.html
--- grass/trunk/raster/r.sunmask/r.sunmask.html 2014-04-02 12:09:45 UTC (rev 59551)
+++ grass/trunk/raster/r.sunmask/r.sunmask.html 2014-04-02 12:34:42 UTC (rev 59552)
@@ -7,8 +7,8 @@
location and date/time parameters using the
<a href="http://rredc.nrel.gov/">NREL</a> sun position algorithm. So either
"A:"-parameters to specify the exact known sun position or "B:-parameters"
-to specify date/time for sun position calculation by r.sunmask itself have
-to be used.
+to specify date/time for sun position calculation by <em>r.sunmask</em> itself
+have to be used.
<p>The module performs sunset/sunrise checks and refraction correction for sun
position calculation. Local coordinate systems are internally transformed to
@@ -17,22 +17,25 @@
<h2>NOTES</h2>
-r.sunmask and daylight savings: Rather than convert time to GMT, the solpos
-algorithm uses what is called Local Standard Time, which is generally
-defined politically as an offset from GMT. So the key is the offset from
-GMT, which the solpos Time Zone parameter. If the user specifies clock time
-(different for winter and summer), he/she would have to change the Time Zone
-parameter seasonally in r.sunmask (timezone parameter). See also
+<em>r.sunmask</em> and daylight savings: Rather than converting the
+local time to GMT, the SOLPOS algorithm uses what is called Local
+Standard Time, which is generally politically defined as an offset
+from GMT. So the key is the offset from GMT, which the solpos Time
+Zone parameter. If the user specifies clock time (different for
+winter and summer), s/he would have to change the Time Zone
+parameter seasonally in <em>r.sunmask</em> (timezone parameter). See also
<a href="http://en.wikipedia.org/wiki/Daylight_saving_time_by_country">Daylight saving time by region and country</a>.
<p>
Note: In latitude/longitude locations the position coordinates pair
(east/west) has to be specified in decimal degree (not D:M:S). If
not specified, the map center's coordinates will be used.
-Also <em>g.region -l</em> displays the map center's coordinates.
+Also <em>g.region -l</em> displays the map center's coordinates in
+latitude/longitude (or <em>g.region -c</em> in the actual coordinate
+system).
<p>
-Note for module usage with <em>-g</em> flag and calculations
+Note for module usage with the <em>-g</em> flag, when performing calculations
close to sunset/sunrise:
<pre>
@@ -45,7 +48,7 @@
No map calculation requested. Finished.
</pre>
-In above calculation appears to be a mistake as
+In above calculation it appears to be a mistake as
the program indicates that we are before sunrise while
the <i>sun angle above horizon</i> is already positive.
The reason is that <i>sun angle above horizon</i> is
@@ -63,20 +66,20 @@
# set the region to a place near Raleigh (NC)
g.region rast=elev_lid792_1m -p
-# compute the sun position
-r.sunmask -s --v elev_lid792_1m out=dummy year=2012 month=2 \
- day=22 hour=10 minute=30 sec=0 timezone=-5
+# compute only sun position and no output map
+r.sunmask -s elev_lid792_1m year=2012 month=2 \
+ day=22 hour=10 minute=30 timezone=-5
Using map center coordinates: 638650.000000 220375.000000
Calculating sun position... (using solpos (V. 11 April 2001) from NREL)
2012/02/22, daynum: 53, time: 10:30:00 (decimal time: 10.500000)
long: -78.678856, lat: 35.736160, timezone: -5.000000
-Solar position: sun azimuth: 143.006424, sun angle above horz. (refraction corrected): 36.233883
+Solar position: sun azimuth: 143.006409, sun angle above horz. (refraction corrected): 36.233879
Sunrise time (without refraction): 06:58:11
Sunset time (without refraction): 17:58:47
-# with -g flag
-r.sunmask -s -g --v elev_lid792_1m out=dummy year=2012 month=2 \
+# with -g flag, useful for eval() shell function
+r.sunmask -s -g elev_lid792_1m year=2012 month=2 \
date=2012/02/22
@@ -86,8 +89,8 @@
longitudine=-78.678856
latitude=35.736160
timezone=-5.000000
-sunazimuth=143.006424
-sunangleabovehorizon=36.233883
+sunazimuth=143.006409
+sunangleabovehorizon=36.233879
sunrise=06:58:11
sunset=17:58:47
</pre></div>
