[GRASS-SVN] r59562 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Wed Apr 2 14:23:41 PDT 2014
Author: turek
Date: 2014-04-02 14:23:41 -0700 (Wed, 02 Apr 2014)
New Revision: 59562
Added:
grass/trunk/lib/vector/Vlib/net_analyze.c
grass/trunk/lib/vector/Vlib/net_build.c
Removed:
grass/trunk/lib/vector/Vlib/net.c
grass/trunk/include/defs/vector.h
vector net: implementation of turntable in library
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2014-04-02 20:50:58 UTC (rev 59561)
+++ grass/trunk/include/defs/vector.h 2014-04-02 21:23:41 UTC (rev 59562)
@@ -391,8 +391,12 @@
/* Network (graph) */
int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
const char *, const char *, int, int);
+int Vect_net_ttb_build_graph(struct Map_info *, int, int, int, int, int ,
+ const char *, const char *, const char *, int, int);
int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
double *);
+int Vect_net_ttb_shortest_path(struct Map_info *, int, int, int, int, int,
+ struct ilist *, double *);
dglGraph_s *Vect_net_get_graph(struct Map_info *);
int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
int Vect_net_get_node_cost(const struct Map_info *, int, double *);
@@ -401,12 +405,12 @@
struct line_pnts *, struct line_pnts *, double *);
int Vect_net_shortest_path_coor(struct Map_info *, double, double, double,
double, double, double, double, double,
- double *, struct line_pnts *, struct ilist *,
+ double *, struct line_pnts *, struct ilist *, struct ilist *,
double *, double *);
-int Vect_net_shortest_path_coor2(struct Map_info *, double, double, double,
- double, double, double, double, double,
- double *, struct line_pnts *, struct ilist *, struct ilist *,
+int Vect_net_ttb_shortest_path_coor(struct Map_info *, double, double, double,
+ double, double, double, double, double, int,
Deleted: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2014-04-02 20:50:58 UTC (rev 59561)
+++ grass/trunk/lib/vector/Vlib/net.c 2014-04-02 21:23:41 UTC (rev 59562)
@@ -1,1188 +0,0 @@
- * \file lib/vector/Vlib/net.c
- * \brief Vector library - net releated fns
- * Higher level functions for reading/writing/manipulating vectors.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Radim Blazek
-#include <stdlib.h>
-#include <string.h>
-#include <fcntl.h>
-#include <grass/dbmi.h>
-#include <grass/vector.h>
-#include <grass/glocale.h>
-static int From_node; /* from node set in SP and used by clipper for first arc */
-static int clipper(dglGraph_s * pgraph,
- dglSPClipInput_s * pargIn,
- dglSPClipOutput_s * pargOut, void *pvarg)
-{ /* caller's pointer */
- dglInt32_t cost;
- dglInt32_t from;
- G_debug(3, "Net: clipper()");
- from = dglNodeGet_Id(pgraph, pargIn->pnNodeFrom);
- G_debug(3, " Edge = %d NodeFrom = %d NodeTo = %d edge cost = %d",
- (int)dglEdgeGet_Id(pgraph, pargIn->pnEdge),
- (int)from, (int)dglNodeGet_Id(pgraph, pargIn->pnNodeTo),
- (int)pargOut->nEdgeCost);
- if (from != From_node) { /* do not clip first */
- if (dglGet_NodeAttrSize(pgraph) > 0) {
- memcpy(&cost, dglNodeGet_Attr(pgraph, pargIn->pnNodeFrom),
- sizeof(cost));
- if (cost == -1) { /* closed, cannot go from this node except it is 'from' node */
- G_debug(3, " closed node");
- return 1;
- else {
- G_debug(3, " EdgeCost += %d (node)", (int)cost);
- pargOut->nEdgeCost += cost;
- else {
- G_debug(3, " don't clip first node");
- return 0;
- \brief Build network graph.
- Internal format for edge costs is integer, costs are multiplied
- before conversion to int by 1000 and for lenghts LL without geo flag by 1000000.
- The same multiplication factor is used for nodes.
- Costs in database column may be 'integer' or 'double precision' number >= 0
- or -1 for infinity i.e. arc or node is closed and cannot be traversed
- If record in table is not found for arcs, arc is skip.
- If record in table is not found for node, costs for node are set to 0.
- \param Map vector map
- \param ltype line type for arcs
- \param afield arc costs field (if 0, use length)
- \param nfield node costs field (if 0, do not use node costs)
- \param afcol column with forward costs for arc
- \param abcol column with backward costs for arc (if NULL, back costs = forward costs),
- \param ncol column with costs for nodes (if NULL, do not use node costs),
- \param geo use geodesic calculation for length (LL),
- \param algorithm not used (in future code for algorithm)
- \return 0 on success, 1 on error
-int
-Vect_net_build_graph(struct Map_info *Map,
- int ltype,
- int afield,
- int nfield,
- const char *afcol,
- const char *abcol,
- const char *ncol, int geo, int algorithm)
- int i, j, from, to, line, nlines, nnodes, ret, type, cat, skipped, cfound;
- int dofw, dobw;
- struct line_pnts *Points;
- struct line_cats *Cats;
- double dcost, bdcost, ll;
- int cost, bcost;
- dglGraph_s *gr;
- dglInt32_t dgl_cost;
- dglInt32_t opaqueset[16] =
- { 360000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
- struct field_info *Fi;
- dbDriver *driver = NULL;
- dbHandle handle;
- dbString stmt;
- dbColumn *Column;
- dbCatValArray fvarr, bvarr;
- int fctype = 0, bctype = 0, nrec;
- /* TODO int costs -> double (waiting for dglib) */
- G_debug(1, "Vect_build_graph(): ltype = %d, afield = %d, nfield = %d",
- ltype, afield, nfield);
- G_debug(1, " afcol = %s, abcol = %s, ncol = %s", afcol, abcol, ncol);
- G_message(_("Building graph..."));
- Map->dgraph.line_type = ltype;
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- ll = 0;
- if (G_projection() == 3)
- ll = 1; /* LL */
- if (afcol == NULL && ll && !geo)
- Map->dgraph.cost_multip = 1000000;
- else
- Map->dgraph.cost_multip = 1000;
- nlines = Vect_get_num_lines(Map);
- nnodes = Vect_get_num_nodes(Map);
- gr = &(Map->dgraph.graph_s);
- /* Allocate space for costs, later replace by functions reading costs from graph */
- Map->dgraph.edge_fcosts = (double *)G_malloc((nlines + 1) * sizeof(double));
- Map->dgraph.edge_bcosts = (double *)G_malloc((nlines + 1) * sizeof(double));
- Map->dgraph.node_costs = (double *)G_malloc((nnodes + 1) * sizeof(double));
- /* Set to -1 initially */
- for (i = 1; i <= nlines; i++) {
- Map->dgraph.edge_fcosts[i] = -1; /* forward */
- Map->dgraph.edge_bcosts[i] = -1; /* backward */
- for (i = 1; i <= nnodes; i++) {
- Map->dgraph.node_costs[i] = 0;
- if (ncol != NULL)
- dglInitialize(gr, (dglByte_t) 1, sizeof(dglInt32_t), (dglInt32_t) 0,
- opaqueset);
- else
- dglInitialize(gr, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
- opaqueset);
- if (gr == NULL)
- G_fatal_error(_("Unable to build network graph"));
- db_init_handle(&handle);
- db_init_string(&stmt);
- if (abcol != NULL && afcol == NULL)
- G_fatal_error(_("Forward costs column not specified"));
- /* --- Add arcs --- */
- /* Open db connection */
- if (afcol != NULL) {
- /* Get field info */
- if (afield < 1)
- G_fatal_error(_("Arc field < 1"));
- Fi = Vect_get_field(Map, afield);
- if (Fi == NULL)
- G_fatal_error(_("Database connection not defined for layer %d"),
- afield);
- /* Open database */
- driver = db_start_driver_open_database(Fi->driver, Fi->database);
- if (driver == NULL)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
- /* Load costs to array */
- if (db_get_column(driver, Fi->table, afcol, &Column) != DB_OK)
- G_fatal_error(_("Column <%s> not found in table <%s>"),
- afcol, Fi->table);
- fctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
- if (fctype != DB_C_TYPE_INT && fctype != DB_C_TYPE_DOUBLE)
- G_fatal_error(_("Data type of column <%s> not supported (must be numeric)"),
- afcol);
- db_CatValArray_init(&fvarr);
- nrec =
- db_select_CatValArray(driver, Fi->table, Fi->key, afcol, NULL,
- &fvarr);
- G_debug(1, "forward costs: nrec = %d", nrec);
- if (abcol != NULL) {
- if (db_get_column(driver, Fi->table, abcol, &Column) != DB_OK)
- abcol, Fi->table);
- bctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
- if (bctype != DB_C_TYPE_INT && bctype != DB_C_TYPE_DOUBLE)
- abcol);
- db_CatValArray_init(&bvarr);
- nrec =
- db_select_CatValArray(driver, Fi->table, Fi->key, abcol, NULL,
- &bvarr);
- G_debug(1, "backward costs: nrec = %d", nrec);
- skipped = 0;
- G_message(_("Registering arcs..."));
- G_percent(i, nlines, 1); /* must be before any continue */
- dofw = dobw = 1;
- type = Vect_read_line(Map, Points, Cats, i);
- if (!(type & ltype & (GV_LINE | GV_BOUNDARY)))
- continue;
- Vect_get_line_nodes(Map, i, &from, &to);
- if (!(Vect_cat_get(Cats, afield, &cat))) {
- G_debug(2,
- "Category of field %d not attached to the line %d -> line skipped",
- afield, i);
- skipped += 2; /* Both directions */
- continue;
- else {
- if (fctype == DB_C_TYPE_INT) {
- ret = db_CatValArray_get_value_int(&fvarr, cat, &cost);
- dcost = cost;
- else { /* DB_C_TYPE_DOUBLE */
- ret =
- db_CatValArray_get_value_double(&fvarr, cat, &dcost);
- if (ret != DB_OK) {
- G_warning(_("Database record for line %d (cat = %d, "
- "forward/both direction(s)) not found "
- "(forward/both direction(s) of line skipped)"),
- i, cat);
- dofw = 0;
- if (bctype == DB_C_TYPE_INT) {
- ret =
- db_CatValArray_get_value_int(&bvarr, cat, &bcost);
- bdcost = bcost;
- ret =
- db_CatValArray_get_value_double(&bvarr, cat,
- &bdcost);
- "backword direction) not found"
- "(direction of line skipped)"), i, cat);
- dobw = 0;
- else {
- if (dofw)
- bdcost = dcost;
- else
- dobw = 0;
- else {
- if (ll) {
- if (geo)
- dcost = Vect_line_geodesic_length(Points);
- else
- dcost = Vect_line_length(Points);
- else
- bdcost = dcost;
- if (dofw && dcost != -1) {
- cost = (dglInt32_t) Map->dgraph.cost_multip * dcost;
- G_debug(5, "Add arc %d from %d to %d cost = %d", i, from, to,
- cost);
- ret =
- dglAddEdge(gr, (dglInt32_t) from, (dglInt32_t) to,
- (dglInt32_t) cost, (dglInt32_t) i);
- Map->dgraph.edge_fcosts[i] = dcost;
- if (ret < 0)
- G_fatal_error("Cannot add network arc");
- G_debug(5, "bdcost = %f edge_bcosts = %f", bdcost,
- Map->dgraph.edge_bcosts[i]);
- if (dobw && bdcost != -1) {
- bcost = (dglInt32_t) Map->dgraph.cost_multip * bdcost;
- G_debug(5, "Add arc %d from %d to %d bcost = %d", -i, to, from,
- bcost);
- ret =
- dglAddEdge(gr, (dglInt32_t) to, (dglInt32_t) from,
- (dglInt32_t) bcost, (dglInt32_t) - i);
- Map->dgraph.edge_bcosts[i] = bdcost;
- if (ret < 0)
- G_fatal_error(_("Cannot add network arc"));
- if (afcol != NULL && skipped > 0)
- G_debug(2, "%d lines missing category of field %d skipped", skipped,
- afield);
- db_close_database_shutdown_driver(driver);
- db_CatValArray_free(&fvarr);
- db_CatValArray_free(&bvarr);
- /* Set node attributes */
- G_debug(2, "Register nodes");
- if (ncol != NULL) {
- double x, y, z;
- struct bound_box box;
- struct boxlist *List;
- List = Vect_new_boxlist(0);
- G_debug(2, "Set nodes' costs");
- if (nfield < 1)
- G_fatal_error("Node field < 1");
- G_message(_("Setting node costs..."));
- Fi = Vect_get_field(Map, nfield);
- if (Fi == NULL)
- nfield);
- if (db_get_column(driver, Fi->table, ncol, &Column) != DB_OK)
- ncol, Fi->table);
- ncol);
- nrec =
- db_select_CatValArray(driver, Fi->table, Fi->key, ncol, NULL,
- &fvarr);
- G_debug(1, "node costs: nrec = %d", nrec);
- /* TODO: what happens if we set attributes of not existing node (skipped lines,
- * nodes without lines) */
- /* select points at node */
- Vect_get_node_coor(Map, i, &x, &y, &z);
- box.E = box.W = x;
- box.N = box.S = y;
- box.T = box.B = z;
- Vect_select_lines_by_box(Map, &box, GV_POINT, List);
- G_debug(2, " node = %d nlines = %d", i, List->n_values);
- cfound = 0;
- dcost = 0;
- for (j = 0; j < List->n_values; j++) {
- line = List->id[j];
- G_debug(2, " line (%d) = %d", j, line);
- type = Vect_read_line(Map, NULL, Cats, line);
- if (!(type & GV_POINT))
- continue;
- if (Vect_cat_get(Cats, nfield, &cat)) { /* point with category of field found */
- /* Set costs */
- ret =
- db_CatValArray_get_value_int(&fvarr, cat, &cost);
- dcost = cost;
- ret =
- &dcost);
- G_warning(_("Database record for node %d (cat = %d) not found "
- "(cost set to 0)"), i, cat);
- cfound = 1;
- break;
- if (!cfound) {
- G_debug(2,
- "Category of field %d not attached to any points in node %d"
- "(costs set to 0)", nfield, i);
- if (dcost == -1) { /* closed */
- cost = -1;
- else {
- dgl_cost = cost;
- G_debug(3, "Set node's cost to %d", cost);
- dglNodeSet_Attr(gr, dglGetNode(gr, (dglInt32_t) i), &dgl_cost);
- Map->dgraph.node_costs[i] = dcost;
- Vect_destroy_boxlist(List);
- G_message(_("Flattening the graph..."));
- ret = dglFlatten(gr);
- if (ret < 0)
- G_fatal_error(_("GngFlatten error"));
- /* init SP cache */
- /* disable to debug dglib cache */
- dglInitializeSPCache(gr, &(Map->dgraph.spCache));
- G_message(_("Graph was built"));
- return 0;
- \brief Find shortest path.
- Costs for 'from' and 'to' nodes are not considered (SP found even if
- 'from' or 'to' are 'closed' (costs = -1) and costs of these
- nodes are not added to SP costs result.
- \param from from node
- \param to to node
- \param[out] List list of line ids (path)
- \param[out] cost costs value
- \return number of segments
- \return 0 is correct for from = to, or List == NULL ? sum of costs is better return value,
- \return -1 : destination unreachable
-int
-Vect_net_shortest_path(struct Map_info *Map, int from, int to,
- struct ilist *List, double *cost)
- int i, line, *pclip, cArc, nRet;
- dglSPReport_s *pSPReport;
- dglInt32_t nDistance;
- int use_cache = 1; /* set to 0 to disable dglib cache */
- G_debug(3, "Vect_net_shortest_path(): from = %d, to = %d", from, to);
- /* Note : if from == to dgl goes to nearest node and returns back (dgl feature) =>
- * check here for from == to */
- if (List != NULL)
- Vect_reset_list(List);
- /* Check if from and to are identical, otherwise dglib returns path to neares node and back! */
- if (from == to) {
- if (cost != NULL)
- *cost = 0;
- return 0;
- From_node = from;
- pclip = NULL;
- if (List != NULL) {
- if (use_cache) {
- nRet =
- dglShortestPath(&(Map->dgraph.graph_s), &pSPReport, (dglInt32_t) from,
- (dglInt32_t) to, clipper, pclip, &(Map->dgraph.spCache));
- else {
- nRet =
- (dglInt32_t) to, clipper, pclip, NULL);
- else {
- if (use_cache) {
- nRet =
- dglShortestDistance(&(Map->dgraph.graph_s), &nDistance, (dglInt32_t) from,
- else {
- nRet =
- if (nRet == 0) {
- /* G_warning("Destination node %d is unreachable from node %d\n" , to , from); */
- if (cost != NULL)
- *cost = PORT_DOUBLE_MAX;
- return -1;
- else if (nRet < 0) {
- G_warning(_("dglShortestPath error: %s"), dglStrerror(&(Map->dgraph.graph_s)));
- return -1;
- for (i = 0; i < pSPReport->cArc; i++) {
- line = dglEdgeGet_Id(&(Map->dgraph.graph_s), pSPReport->pArc[i].pnEdge);
- G_debug(2, "From %ld to %ld - cost %ld user %d distance %ld", pSPReport->pArc[i].nFrom, pSPReport->pArc[i].nTo, dglEdgeGet_Cost(&(Map->dgraph.graph_s), pSPReport->pArc[i].pnEdge) / Map->dgraph.cost_multip, /* this is the cost from clip() */
- line, pSPReport->pArc[i].nDistance);
- Vect_list_append(List, line);
- if (cost != NULL) {
- if (List != NULL)
- *cost = (double)pSPReport->nDistance / Map->dgraph.cost_multip;
- else
- *cost = (double)nDistance / Map->dgraph.cost_multip;
- cArc = pSPReport->cArc;
- dglFreeSPReport(&(Map->dgraph.graph_s), pSPReport);
- else
- cArc = 0;
- return (cArc);
- \brief Get graph structure
- Graph is built by Vect_net_build_graph().
- Returns NULL when graph is not built.
- \param Map pointer to Map_info struct
- \return pointer to dglGraph_s struct or NULL
-dglGraph_s *Vect_net_get_graph(struct Map_info *Map)
- return &(Map->dgraph.graph_s);
- \brief Returns in cost for given direction in *cost.
- cost is set to -1 if closed.
- \param line line id
- \param direction direction (GV_FORWARD, GV_BACKWARD)
- \param[out] cost
- \return 1 OK
- \return 0 does not exist (was not inserted)
-int
-Vect_net_get_line_cost(const struct Map_info *Map, int line, int direction,
- double *cost)
- /* dglInt32_t *pEdge; */
- G_debug(5, "Vect_net_get_line_cost(): line = %d, dir = %d", line,
- direction);
- if (direction == GV_FORWARD) {
- /* V1 has no index by line-id -> array used */
- pEdge = dglGetEdge(&(Map->dgraph.graph_s), line);
- if (pEdge == NULL)
- return 0;
- *cost = (double) dglEdgeGet_Cost(&(Map->dgraph.graph_s), pEdge);
- if (Map->dgraph.edge_fcosts[line] == -1) {
- *cost = -1;
- return 0;
- else
- *cost = Map->dgraph.edge_fcosts[line];
- else if (direction == GV_BACKWARD) {
- pEdge = dglGetEdge(&(Map->dgraph.graph_s), -line);
- return 0;
- if (Map->dgraph.edge_bcosts[line] == -1) {
- *cost = -1;
- return 0;
- else
- *cost = Map->dgraph.edge_bcosts[line];
- G_debug(5, "Vect_net_get_line_cost(): edge_bcosts = %f",
- Map->dgraph.edge_bcosts[line]);
- else {
- G_fatal_error(_("Wrong line direction in Vect_net_get_line_cost()"));
- return 1;
- \brief Get cost of node
- \param node node id
- \return 1
-int Vect_net_get_node_cost(const struct Map_info *Map, int node, double *cost)
- G_debug(3, "Vect_net_get_node_cost(): node = %d", node);
- *cost = Map->dgraph.node_costs[node];
- G_debug(3, " -> cost = %f", *cost);
- return 1;
- \brief Find nearest node(s) on network.
- \param Map vetor map
- \param x,y,z point coordinates (z coordinate NOT USED !)
- \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
- \param maxdist maximum distance to the network
- \param[out] node1 pointer where to store the node number (or NULL)
- \param[out] node2 pointer where to store the node number (or NULL)
- \param[out] ln pointer where to store the nearest line number (or NULL)
- \param[out] costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
- \param[out] costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
- \param[out] Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
- \param[out] Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
- \param[out] pointer where to distance to the line (or NULL)
- \param[out] distance
- \return number of nodes found (0,1,2)
-int Vect_net_nearest_nodes(struct Map_info *Map,
- double x, double y, double z,
- int direction, double maxdist,
- int *node1, int *node2, int *ln, double *costs1,
- double *costs2, struct line_pnts *Points1,
- struct line_pnts *Points2, double *distance)
- int line, n1, n2, nnodes;
- int npoints;
- int segment; /* nearest line segment (first is 1) */
- static struct line_pnts *Points = NULL;
- double cx, cy, cz, c1, c2;
- double along; /* distance along the line to nearest point */
- double length;
- G_debug(3, "Vect_net_nearest_nodes() x = %f y = %f", x, y);
- /* Reset */
- if (node1)
- *node1 = 0;
- if (node2)
- *node2 = 0;
- if (ln)
- *ln = 0;
- if (costs1)
- *costs1 = PORT_DOUBLE_MAX;
- if (costs2)
- *costs2 = PORT_DOUBLE_MAX;
- if (Points1)
- Vect_reset_line(Points1);
- if (Points2)
- Vect_reset_line(Points2);
- if (distance)
- *distance = PORT_DOUBLE_MAX;
- if (!Points)
- /* Find nearest line */
- line = Vect_find_line(Map, x, y, z, Map->dgraph.line_type, maxdist, 0, 0);
- if (line < 1)
- return 0;
- Vect_read_line(Map, Points, NULL, line);
- npoints = Points->n_points;
- Vect_get_line_nodes(Map, line, &n1, &n2);
- segment =
- Vect_line_distance(Points, x, y, z, 0, &cx, &cy, &cz, distance, NULL,
- &along);
- G_debug(4, "line = %d n1 = %d n2 = %d segment = %d", line, n1, n2,
- segment);
- /* Check first or last point and return one node in that case */
- G_debug(4, "cx = %f cy = %f first = %f %f last = %f %f", cx, cy,
- Points->x[0], Points->y[0], Points->x[npoints - 1],
- Points->y[npoints - 1]);
- if (Points->x[0] == cx && Points->y[0] == cy) {
- if (node1)
- *node1 = n1;
- if (ln)
- *ln = line;
- if (costs1)
- *costs1 = 0;
- if (Points1) {
- Vect_append_point(Points1, x, y, z);
- Vect_append_point(Points1, cx, cy, cz);
- G_debug(3, "first node nearest");
- return 1;
- if (Points->x[npoints - 1] == cx && Points->y[npoints - 1] == cy) {
- if (node1)
- *node1 = n2;
- if (ln)
- *ln = line;
- if (costs1)
- *costs1 = 0;
- if (Points1) {
- G_debug(3, "last node nearest");
- return 1;
- nnodes = 2;
- /* c1 - costs to get from/to the first vertex */
- /* c2 - costs to get from/to the last vertex */
- if (direction == GV_FORWARD) { /* from point to net */
- Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c1);
- Vect_net_get_line_cost(Map, line, GV_FORWARD, &c2);
- else {
- Vect_net_get_line_cost(Map, line, GV_FORWARD, &c1);
- Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c2);
- if (c1 < 0)
- nnodes--;
- if (c2 < 0)
- nnodes--;
- if (nnodes == 0)
- return 0; /* both directions closed */
- length = Vect_line_length(Points);
- if (ln)
- *ln = line;
- if (nnodes == 1 && c1 < 0) { /* first direction is closed, return node2 as node1 */
- if (node1)
- *node1 = n2;
- if (costs1) { /* to node 2, i.e. forward */
- *costs1 = c2 * (length - along) / length;
- if (Points1) { /* to node 2, i.e. forward */
- int i;
- for (i = segment; i < npoints; i++)
- Vect_append_point(Points1, Points->x[i], Points->y[i],
- Points->z[i]);
- else {
- for (i = npoints - 1; i >= segment; i--)
- Points->z[i]);
- else {
- if (node1)
- *node1 = n1;
- if (node2)
- *node2 = n2;
- if (costs1) { /* to node 1, i.e. backward */
- *costs1 = c1 * along / length;
- if (costs2) { /* to node 2, i.e. forward */
- *costs2 = c2 * (length - along) / length;
- if (Points1) { /* to node 1, i.e. backward */
- int i;
- for (i = segment - 1; i >= 0; i--)
- Points->z[i]);
- else {
- for (i = 0; i < segment; i++)
- Points->z[i]);
- if (Points2) { /* to node 2, i.e. forward */
- int i;
- Vect_append_point(Points2, x, y, z);
- Vect_append_point(Points2, cx, cy, cz);
- Vect_append_point(Points2, Points->x[i], Points->y[i],
- Points->z[i]);
- else {
- Points->z[i]);
- return nnodes;
- \brief Find shortest path on network between 2 points given by coordinates.
- \param fx,fy,fz from point x coordinate (z ignored)
- \param tx,ty,tz to point x coordinate (z ignored)
- \param fmax maximum distance to the network from 'from'
- \param tmax maximum distance to the network from 'to'
- \param[out] costs pointer where to store costs on the network (or NULL)
- \param[out] Points pointer to the structure where to store vertices of shortest path (or NULL)
- \param[out] List pointer to the structure where list of lines on the network is stored (or NULL)
- \param[out] FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
- \param[out] TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
- \param[out] fdist distance from 'from' to the net (or NULL)
- \param[out] tdist distance from 'to' to the net (or NULL)
- \return 1 OK
- \return 0 not reachable
-int
-Vect_net_shortest_path_coor(struct Map_info *Map,
- double fx, double fy, double fz, double tx,
- double ty, double tz, double fmax, double tmax,
- double *costs, struct line_pnts *Points,
- struct ilist *List, struct line_pnts *FPoints,
- struct line_pnts *TPoints, double *fdist,
- double *tdist)
- return Vect_net_shortest_path_coor2(Map, fx, fy, fz, tx, ty, tz, fmax, tmax,
- costs, Points, List, NULL, FPoints, TPoints, fdist, tdist);
- \param costs pointer where to store costs on the network (or NULL)
- \param Points pointer to the structure where to store vertices of shortest path (or NULL)
- \param List pointer to the structure where list of lines on the network is stored (or NULL)
- \param NodesList pointer to the structure where list of nodes on the network is stored (or NULL)
- \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
- \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
- \param fdist distance from 'from' to the net (or NULL)
- \param tdist distance from 'to' to the net (or NULL)
- \return 1 OK, 0 not reachable
-int
-Vect_net_shortest_path_coor2(struct Map_info *Map,
- struct ilist *List, struct ilist *NodesList,
- struct line_pnts *FPoints,
- double *tdist)
- int fnode[2], tnode[2]; /* nearest nodes, *node[1] is 0 if only one was found */
- double fcosts[2], tcosts[2], cur_cst; /* costs to nearest nodes on the network */
- int nfnodes, ntnodes, fline, tline;
- static struct line_pnts *APoints, *SPoints, *fPoints[2], *tPoints[2];
- static struct ilist *LList;
- static int first = 1;
- int reachable, shortcut;
- int i, j, fn = 0, tn = 0;
- /* from/to_point_node is set if from/to point projected to line
- *falls exactly on node (shortcut -> fline == tline) */
- int from_point_node = 0;
- int to_point_node = 0;
- G_debug(3, "Vect_net_shortest_path_coor()");
- if (first) {
- APoints = Vect_new_line_struct();
- SPoints = Vect_new_line_struct();
- fPoints[0] = Vect_new_line_struct();
- fPoints[1] = Vect_new_line_struct();
- tPoints[0] = Vect_new_line_struct();
- tPoints[1] = Vect_new_line_struct();
- LList = Vect_new_list();
- first = 0;
- /* Reset */
- if (costs)
- *costs = PORT_DOUBLE_MAX;
- if (Points)
- Vect_reset_line(Points);
- if (fdist)
- *fdist = 0;
- if (tdist)
- *tdist = 0;
- if (List)
- List->n_values = 0;
- if (FPoints)
- Vect_reset_line(FPoints);
- if (TPoints)
- Vect_reset_line(TPoints);
- if (NodesList != NULL)
- Vect_reset_list(NodesList);
- /* Find nearest nodes */
- fnode[0] = fnode[1] = tnode[0] = tnode[1] = 0;
- nfnodes =
- Vect_net_nearest_nodes(Map, fx, fy, fz, GV_FORWARD, fmax, &(fnode[0]),
- &(fnode[1]), &fline, &(fcosts[0]),
- &(fcosts[1]), fPoints[0], fPoints[1], fdist);
- if (nfnodes == 0)
- return 0;
- if (nfnodes == 1 && fPoints[0]->n_points < 3) {
- from_point_node = fnode[0];
- ntnodes =
- Vect_net_nearest_nodes(Map, tx, ty, tz, GV_BACKWARD, tmax,
- &(tnode[0]), &(tnode[1]), &tline, &(tcosts[0]),
- &(tcosts[1]), tPoints[0], tPoints[1], tdist);
- if (ntnodes == 0)
- return 0;
- if (ntnodes == 1 && tPoints[0]->n_points < 3) {
- to_point_node = tnode[0];
- G_debug(3, "fline = %d tline = %d", fline, tline);
- reachable = shortcut = 0;
- cur_cst = PORT_DOUBLE_MAX;
- /* It may happen, that 2 points are at the same line. */
- /* TODO?: it could also happen that fline != tline but both points are on the same
- * line if they fall on node but a different line was found. This case is correctly
- * handled as normal non shortcut, but it could be added here. In that case
- * NodesList collection must be changed */
- if (fline == tline && (nfnodes > 1 || ntnodes > 1)) {
- double len, flen, tlen, c, fseg, tseg;
- double fcx, fcy, fcz, tcx, tcy, tcz;
- Vect_read_line(Map, APoints, NULL, fline);
- len = Vect_line_length(APoints);
- /* distance along the line */
- fseg =
- Vect_line_distance(APoints, fx, fy, fz, 0, &fcx, &fcy, &fcz, NULL,
- NULL, &flen);
- tseg =
- Vect_line_distance(APoints, tx, ty, tz, 0, &tcx, &tcy, &tcz, NULL,
- NULL, &tlen);
- Vect_reset_line(SPoints);
- if (flen == tlen) {
- cur_cst = 0;
- reachable = shortcut = 1;
- else if (flen < tlen) {
- Vect_net_get_line_cost(Map, fline, GV_FORWARD, &c);
- if (c >= 0) {
- cur_cst = c * (tlen - flen) / len;
- Vect_append_point(SPoints, fx, fy, fz);
- Vect_append_point(SPoints, fcx, fcy, fcz);
- for (i = fseg; i < tseg; i++)
- Vect_append_point(SPoints, APoints->x[i], APoints->y[i],
- APoints->z[i]);
- Vect_append_point(SPoints, tcx, tcy, tcz);
- Vect_append_point(SPoints, tx, ty, tz);
- else { /* flen > tlen */
- Vect_net_get_line_cost(Map, fline, GV_BACKWARD, &c);
- if (c >= 0) {
- cur_cst = c * (flen - tlen) / len;
- for (i = fseg - 1; i >= tseg; i--)
- APoints->z[i]);
- /* Find the shortest variant from maximum 4 */
- for (i = 0; i < nfnodes; i++) {
- for (j = 0; j < ntnodes; j++) {
- double ncst, cst;
- int ret;
- G_debug(3, "i = %d fnode = %d j = %d tnode = %d", i, fnode[i], j,
- tnode[j]);
- ret =
- Vect_net_shortest_path(Map, fnode[i], tnode[j], NULL, &ncst);
- if (ret == -1)
- continue; /* not reachable */
- cst = fcosts[i] + ncst + tcosts[j];
- if (reachable == 0 || cst < cur_cst) {
- cur_cst = cst;
- fn = i;
- tn = j;
- shortcut = 0;
- reachable = 1;
- G_debug(3, "reachable = %d shortcut = %d cur_cst = %f", reachable,
- shortcut, cur_cst);
- if (reachable) {
- if (shortcut) {
- if (Points)
- Vect_append_points(Points, SPoints, GV_FORWARD);
- if (NodesList) {
- /* Check if from/to point projected to line falls on node and
- *add it to the list */
- if (from_point_node > 0)
- Vect_list_append(NodesList, from_point_node);
- if (to_point_node > 0)
- Vect_list_append(NodesList, to_point_node);
- else {
- if (NodesList) {
- /* it can happen that starting point falls on node but SP starts
- * form the other node, add it in that case,
- * similarly for to point below */
- if (from_point_node > 0 && from_point_node != fnode[fn]) {
- /* add starting net SP search node */
- Vect_list_append(NodesList, fnode[fn]);
- Vect_net_shortest_path(Map, fnode[fn], tnode[tn], LList,
- NULL);
- G_debug(3, "Number of lines %d", LList->n_values);
- if (Points)
- Vect_append_points(Points, fPoints[fn], GV_FORWARD);
- if (FPoints)
- Vect_append_points(FPoints, fPoints[fn], GV_FORWARD);
- for (i = 0; i < LList->n_values; i++) {
- int line;
- line = LList->value[i];
- G_debug(3, "i = %d line = %d", i, line);
- if (Points) {
- Vect_read_line(Map, APoints, NULL, abs(line));
- if (line > 0)
- Vect_append_points(Points, APoints, GV_FORWARD);
- else
- Vect_append_points(Points, APoints, GV_BACKWARD);
- if (NodesList) {
- int node, node1, node2;
- Vect_get_line_nodes(Map, abs(line), &node1, &node2);
- /* add the second node, the first of first segmet was alread added */
- if (line > 0)
- node = node2;
- else
- node = node1;
- Vect_list_append(NodesList, node);
- if (List)
- if (Points)
- Vect_append_points(Points, tPoints[tn], GV_FORWARD);
- if (TPoints)
- Vect_append_points(TPoints, tPoints[tn], GV_FORWARD);
- if (NodesList) {
- if (to_point_node > 0 && to_point_node != tnode[tn]) {
- if (costs)
- *costs = cur_cst;
- return reachable;
Copied: grass/trunk/lib/vector/Vlib/net_analyze.c (from rev 57918, grass/trunk/lib/vector/Vlib/net.c)
--- grass/trunk/lib/vector/Vlib/net_analyze.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/net_analyze.c 2014-04-02 21:23:41 UTC (rev 59562)
@@ -0,0 +1,1057 @@
+ * \file lib/vector/Vlib/net.c
+ * \brief Vector library - releated fns for vector network analyses
+ * Higher level functions for reading/writing/manipulating vectors.
+ * (C) 2001-2009, 2014 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Radim Blazek
+ * \author Stepan Turek stepan.turek seznam.cz (turns support)
+#include <grass/dbmi.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+static int From_node; /* from node set in SP and used by clipper for first arc */
+static int clipper(dglGraph_s * pgraph,
+ dglSPClipInput_s * pargIn,
+ dglSPClipOutput_s * pargOut, void *pvarg)
+{ /* caller's pointer */
+ dglInt32_t cost;
+ dglInt32_t from;
+ G_debug(3, "Net: clipper()");
+ from = dglNodeGet_Id(pgraph, pargIn->pnNodeFrom);
+ G_debug(3, " Edge = %d NodeFrom = %d NodeTo = %d edge cost = %d",
+ (int)dglEdgeGet_Id(pgraph, pargIn->pnEdge),
+ (int)from, (int)dglNodeGet_Id(pgraph, pargIn->pnNodeTo),
+ (int)pargOut->nEdgeCost);
+ if (from != From_node) { /* do not clip first */
+ if (dglGet_NodeAttrSize(pgraph) > 0) {
+ memcpy(&cost, dglNodeGet_Attr(pgraph, pargIn->pnNodeFrom),
+ sizeof(cost));
+ if (cost == -1) { /* closed, cannot go from this node except it is 'from' node */
+ G_debug(3, " closed node");
+ return 1;
+ else {
+ G_debug(3, " EdgeCost += %d (node)", (int)cost);
+ pargOut->nEdgeCost += cost;
+ else {
+ G_debug(3, " don't clip first node");
+ return 0;
+ \brief Converts shortest path result, which is calculated by DGLib on newtwork without turntable, into output format.
+static int convert_dgl_shortest_path_result(struct Map_info *Map,
+ dglSPReport_s * pSPReport,
+ struct ilist *List)
+ int i, line;
+ Vect_reset_list(List);
+ for (i = 0; i < pSPReport->cArc; i++) {
+ line =
+ dglEdgeGet_Id(&(Map->dgraph.graph_s), pSPReport->pArc[i].pnEdge);
+ G_debug(2, "From %ld to %ld - cost %ld user %d distance %ld", pSPReport->pArc[i].nFrom, pSPReport->pArc[i].nTo, dglEdgeGet_Cost(&(Map->dgraph.graph_s), pSPReport->pArc[i].pnEdge) / Map->dgraph.cost_multip, /* this is the cost from clip() */
+ line, pSPReport->pArc[i].nDistance);
+ Vect_list_append(List, line);
+ return 0;
+ \brief Converts shortest path result, which is calculated by DGLib on newtwork with turntable, into output format.
+static int ttb_convert_dgl_shortest_path_result(struct Map_info *Map,
+ int tucfield,
+ int i, line_id, type, tucfield_idx;
+ int line_ucat;
+ tucfield_idx = Vect_cidx_get_field_index(Map, tucfield);
+ line_ucat =
+ dglNodeGet_Id(&(Map->dgraph.graph_s),
+ dglEdgeGet_Head(&(Map->dgraph.graph_s),
+ pSPReport->pArc[i].pnEdge));
+ /* get standard ucat numbers (DGLib does not like negative node numbers) */
+ if (line_ucat % 2 == 1)
+ line_ucat = ((line_ucat - 1) / -2);
+ else
+ line_ucat = (line_ucat) / 2;
+ /* skip virtual nodes */
+ if (Vect_cidx_find_next
+ (Map, tucfield_idx, abs(line_ucat), GV_LINE, 0, &type,
+ &line_id) == -1)
+ continue;
+ if (line_ucat < 0)
+ line_id *= -1;
+ line_ucat, pSPReport->pArc[i].nDistance);
+ Vect_list_append(List, line_id);
+ return 0;
+ \brief Finds shortest path on network using DGLib
+ \param Map vector map with build DGLib graph (see Vect_net_ttb_build_graph and Vect_net_build_graph)
+ \param from from node id in build the network
+ \param to to node in build the network
+ \param UseTtb the graph is build with/without turntable
+ \param tucfield layer with unique cats for turntable (relevant only when UseTtb = 1)
+static int find_shortest_path(struct Map_info *Map, int from, int to,
+ struct ilist *List, double *cost, int UseTtb,
+ int tucfield)
+ int *pclip, cArc, nRet;
+ dglSPReport_s *pSPReport;
+ dglInt32_t nDistance;
+ int use_cache = 1; /* set to 0 to disable dglib cache */
+ G_debug(3, "find_shortest_path(): from = %d, to = %d", from, to);
+ /* Note : if from == to dgl goes to nearest node and returns back (dgl feature) =>
+ * check here for from == to */
+ /* Check if from and to are identical, otherwise dglib returns path to neares node and back! */
+ if (from == to) {
+ if (cost != NULL)
+ *cost = 0;
+ return 0;
+ From_node = from;
+ pclip = NULL;
+ if (List != NULL) {
+ if (use_cache) {
+ nRet =
+ dglShortestPath(&(Map->dgraph.graph_s), &pSPReport,
+ (dglInt32_t) from, (dglInt32_t) to, clipper,
+ pclip, &(Map->dgraph.spCache));
+ else {
+ nRet =
+ pclip, NULL);
+ else {
+ if (use_cache) {
+ nRet =
+ dglShortestDistance(&(Map->dgraph.graph_s), &nDistance,
+ clipper, pclip, &(Map->dgraph.spCache));
+ else {
+ nRet =
+ clipper, pclip, NULL);
+ if (nRet == 0) {
+ /* G_warning("Destination node %d is unreachable from node %d\n" , to , from); */
+ if (cost != NULL)
+ *cost = PORT_DOUBLE_MAX;
+ return -1;
+ else if (nRet < 0) {
+ G_warning(_("dglShortestPath error: %s"),
+ dglStrerror(&(Map->dgraph.graph_s)));
+ return -1;
+ if (UseTtb)
+ ttb_convert_dgl_shortest_path_result(Map, pSPReport, tucfield,
+ List);
+ else
+ convert_dgl_shortest_path_result(Map, pSPReport, List);
+ if (cost != NULL) {
+ if (List != NULL)
+ *cost = (double)pSPReport->nDistance / Map->dgraph.cost_multip;
+ else
+ *cost = (double)nDistance / Map->dgraph.cost_multip;
+ cArc = pSPReport->cArc;
+ dglFreeSPReport(&(Map->dgraph.graph_s), pSPReport);
+ else
+ cArc = 0;
+ return cArc;
+ \brief Find shortest path on network.
+ Costs for 'from' and 'to' nodes are not considered (SP found even if
+ 'from' or 'to' are 'closed' (costs = -1) and costs of these
+ nodes are not added to SP costs result.
+ \param Map vector map with build graph (see Vect_net_ttb_build_graph and Vect_net_build_graph)
+ \param from start of the path
+ \param from_type if 0 - node id (intersection), if 1 - line unique cat
+ \param to end of the path
+ \param to_type if 0 - node id (intersection), if 1 - line unique cat
+ \param tucfield field with unique categories used in the turntable
+ \param[out] List list of line ids (path)
+ \param[out] cost costs value
+ \return number of segments
+ \return 0 is correct for from = to, or List == NULL ? sum of costs is better return value,
+ \return -1 : destination unreachable
+int
+Vect_net_ttb_shortest_path(struct Map_info *Map, int from, int from_type,
+ int to, int to_type,
+ int tucfield, struct ilist *List, double *cost)
+ double x, y, z;
+ struct bound_box box;
+ struct boxlist *box_List;
+ struct line_cats *Cats;
+ int f, t;
+ int i_line, line, type, cfound;
+ box_List = Vect_new_boxlist(0);
+ Cats = Vect_new_cats_struct();
+ if (from_type == 0) { /* TODO duplicite code with to_type, move into function */
+ /* select points at node */
+ Vect_get_node_coor(Map, from, &x, &y, &z);
+ box.E = box.W = x;
+ box.N = box.S = y;
+ box.T = box.B = z;
+ Vect_select_lines_by_box(Map, &box, GV_POINT, box_List);
+ cfound = 0;
+ for (i_line = 0; i_line < box_List->n_values; i_line++) {
+ line = box_List->id[i_line];
+ type = Vect_read_line(Map, NULL, Cats, line);
+ if (!(type & GV_POINT))
+ continue;
+ if (Vect_cat_get(Cats, tucfield, &f)) {
+ ++cfound;
+ break;
+ if (!cfound)
+ G_fatal_error(_
+ ("Unable to find point with defined unique category for node <%d>."),
+ from);
+ else if (cfound > 1)
+ G_warning(_
+ ("There exists more than one point on node <%d> with unique category in field <%d>.\n"
+ "The unique category layer may not be valid."),
+ tucfield, from);
+ G_debug(2, "from node = %d, unique cat = %d ", from, f);
+ f = f * 2;
+ else {
+ if (from < 0)
+ f = from * -2 + 1;
+ else
+ f = from * 2;
+ G_debug(2, "from edge unique cat = %d", from);
+ if (to_type == 0) {
+ Vect_get_node_coor(Map, to, &x, &y, &z);
+ cfound = 0;
+ continue;
+ if (Vect_cat_get(Cats, tucfield, &t)) {
+ cfound = 1;
+ break;
+ if (!cfound)
+ G_fatal_error(_
+ to);
+ G_warning(_
+ tucfield, to);
+ G_debug(2, "to node = %d, unique cat = %d ", to, t);
+ t = t * 2 + 1;
+ else {
+ if (to < 0)
+ t = to * -2 + 1;
+ else
+ t = to * 2;
+ G_debug(2, "to edge unique cat = %d", to);
+ Vect_destroy_boxlist(box_List);
+ Vect_destroy_cats_struct(Cats);
+ return find_shortest_path(Map, f, t, List, cost, 1, tucfield);
+ \brief Find shortest path.
+ \param to to node
+int
+Vect_net_shortest_path(struct Map_info *Map, int from, int to,
+ struct ilist *List, double *cost)
+ return find_shortest_path(Map, from, to, List, cost, 0, -1);
+ \brief Get graph structure
+ Graph is built by Vect_net_build_graph().
+ Returns NULL when graph is not built.
+ \param Map pointer to Map_info struct
+ \return pointer to dglGraph_s struct or NULL
+dglGraph_s *Vect_net_get_graph(struct Map_info * Map)
+ return &(Map->dgraph.graph_s);
+ \brief Returns in cost for given direction in *cost.
+ cost is set to -1 if closed.
+ \param line line id
+ \param direction direction (GV_FORWARD, GV_BACKWARD)
+ \param[out] cost
+ \return 1 OK
+ \return 0 does not exist (was not inserted)
+int
+Vect_net_get_line_cost(const struct Map_info *Map, int line, int direction,
+ double *cost)
+ /* dglInt32_t *pEdge; */
+ G_debug(5, "Vect_net_get_line_cost(): line = %d, dir = %d", line,
+ direction);
+ if (direction == GV_FORWARD) {
+ /* V1 has no index by line-id -> array used */
+ pEdge = dglGetEdge(&(Map->dgraph.graph_s), line);
+ if (pEdge == NULL)
+ return 0;
+ *cost = (double) dglEdgeGet_Cost(&(Map->dgraph.graph_s), pEdge);
+ if (Map->dgraph.edge_fcosts[line] == -1) {
+ *cost = -1;
+ return 0;
+ else
+ *cost = Map->dgraph.edge_fcosts[line];
+ else if (direction == GV_BACKWARD) {
+ pEdge = dglGetEdge(&(Map->dgraph.graph_s), -line);
+ return 0;
+ if (Map->dgraph.edge_bcosts[line] == -1) {
+ *cost = -1;
+ return 0;
+ else
+ *cost = Map->dgraph.edge_bcosts[line];
+ G_debug(5, "Vect_net_get_line_cost(): edge_bcosts = %f",
+ Map->dgraph.edge_bcosts[line]);
+ else {
+ G_fatal_error(_("Wrong line direction in Vect_net_get_line_cost()"));
+ return 1;
+ \brief Get cost of node
+ \param node node id
+ \return 1
+int Vect_net_get_node_cost(const struct Map_info *Map, int node, double *cost)
+ G_debug(3, "Vect_net_get_node_cost(): node = %d", node);
+ *cost = Map->dgraph.node_costs[node];
+ G_debug(3, " -> cost = %f", *cost);
+ return 1;
+ \brief Find nearest node(s) on network.
+ \param x,y,z point coordinates (z coordinate NOT USED !)
+ \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
+ \param maxdist maximum distance to the network
+ \param[out] node1 pointer where to store the node number (or NULL)
+ \param[out] node2 pointer where to store the node number (or NULL)
+ \param[out] ln pointer where to store the nearest line number (or NULL)
+ \param[out] costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
+ \param[out] costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
+ \param[out] Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
+ \param[out] Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
+ \param[out] pointer where to distance to the line (or NULL)
+ \param[out] distance
+ \return number of nodes found (0,1,2)
+int Vect_net_nearest_nodes(struct Map_info *Map,
+ double x, double y, double z,
+ int direction, double maxdist,
+ int *node1, int *node2, int *ln, double *costs1,
+ double *costs2, struct line_pnts *Points1,
+ struct line_pnts *Points2, double *distance)
+ int line, n1, n2, nnodes;
+ int npoints;
+ int segment; /* nearest line segment (first is 1) */
+ static struct line_pnts *Points = NULL;
+ double cx, cy, cz, c1, c2;
+ double along; /* distance along the line to nearest point */
+ double length;
+ G_debug(3, "Vect_net_nearest_nodes() x = %f y = %f", x, y);
+ /* Reset */
+ if (node1)
+ *node1 = 0;
+ if (node2)
+ *node2 = 0;
+ if (ln)
+ *ln = 0;
+ if (costs1)
+ *costs1 = PORT_DOUBLE_MAX;
+ if (costs2)
+ *costs2 = PORT_DOUBLE_MAX;
+ if (Points1)
+ Vect_reset_line(Points1);
+ if (Points2)
+ Vect_reset_line(Points2);
+ if (distance)
+ *distance = PORT_DOUBLE_MAX;
+ if (!Points)
+ Points = Vect_new_line_struct();
+ /* Find nearest line */
+ line = Vect_find_line(Map, x, y, z, Map->dgraph.line_type, maxdist, 0, 0);
+ if (line < 1)
+ return 0;
+ Vect_read_line(Map, Points, NULL, line);
+ npoints = Points->n_points;
+ Vect_get_line_nodes(Map, line, &n1, &n2);
+ segment =
+ Vect_line_distance(Points, x, y, z, 0, &cx, &cy, &cz, distance, NULL,
+ &along);
+ G_debug(4, "line = %d n1 = %d n2 = %d segment = %d", line, n1, n2,
+ segment);
+ /* Check first or last point and return one node in that case */
+ G_debug(4, "cx = %f cy = %f first = %f %f last = %f %f", cx, cy,
+ Points->x[0], Points->y[0], Points->x[npoints - 1],
+ Points->y[npoints - 1]);
+ if (Points->x[0] == cx && Points->y[0] == cy) {
+ if (node1)
+ *node1 = n1;
+ if (ln)
+ *ln = line;
+ if (costs1)
+ *costs1 = 0;
+ if (Points1) {
+ Vect_append_point(Points1, x, y, z);
+ Vect_append_point(Points1, cx, cy, cz);
+ G_debug(3, "first node nearest");
+ return 1;
+ if (Points->x[npoints - 1] == cx && Points->y[npoints - 1] == cy) {
+ if (node1)
+ *node1 = n2;
+ if (ln)
+ *ln = line;
+ if (costs1)
+ *costs1 = 0;
+ if (Points1) {
+ G_debug(3, "last node nearest");
+ return 1;
+ nnodes = 2;
+ /* c1 - costs to get from/to the first vertex */
+ /* c2 - costs to get from/to the last vertex */
+ if (direction == GV_FORWARD) { /* from point to net */
+ Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c1);
+ Vect_net_get_line_cost(Map, line, GV_FORWARD, &c2);
+ else {
+ Vect_net_get_line_cost(Map, line, GV_FORWARD, &c1);
+ Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c2);
+ if (c1 < 0)
+ nnodes--;
+ if (c2 < 0)
+ nnodes--;
+ if (nnodes == 0)
+ return 0; /* both directions closed */
+ length = Vect_line_length(Points);
+ if (ln)
+ *ln = line;
+ if (nnodes == 1 && c1 < 0) { /* first direction is closed, return node2 as node1 */
+ if (node1)
+ *node1 = n2;
+ if (costs1) { /* to node 2, i.e. forward */
+ *costs1 = c2 * (length - along) / length;
+ if (Points1) { /* to node 2, i.e. forward */
+ int i;
+ for (i = segment; i < npoints; i++)
+ Vect_append_point(Points1, Points->x[i], Points->y[i],
+ Points->z[i]);
+ else {
+ for (i = npoints - 1; i >= segment; i--)
+ Points->z[i]);
+ else {
+ if (node1)
+ *node1 = n1;
+ if (node2)
+ *node2 = n2;
+ if (costs1) { /* to node 1, i.e. backward */
+ *costs1 = c1 * along / length;
+ if (costs2) { /* to node 2, i.e. forward */
+ *costs2 = c2 * (length - along) / length;
+ if (Points1) { /* to node 1, i.e. backward */
+ int i;
+ for (i = segment - 1; i >= 0; i--)
+ Points->z[i]);
+ else {
+ for (i = 0; i < segment; i++)
+ Points->z[i]);
+ if (Points2) { /* to node 2, i.e. forward */
+ int i;
+ Vect_append_point(Points2, x, y, z);
+ Vect_append_point(Points2, cx, cy, cz);
+ Vect_append_point(Points2, Points->x[i], Points->y[i],
+ Points->z[i]);
+ else {
+ Points->z[i]);
+ return nnodes;
+ \brief Find shortest path on network between 2 points given by coordinates.
+ \param fx,fy,fz from point x coordinate (z ignored)
+ \param tx,ty,tz to point x coordinate (z ignored)
+ \param fmax maximum distance to the network from 'from'
+ \param tmax maximum distance to the network from 'to'
+ \param costs pointer where to store costs on the network (or NULL)
+ \param Points pointer to the structure where to store vertices of shortest path (or NULL)
+ \param List pointer to the structure where list of lines on the network is stored (or NULL)
+ \param NodesList pointer to the structure where list of nodes on the network is stored (or NULL)
+ \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+ \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+ \param fdist distance from 'from' to the net (or NULL)
+ \param tdist distance from 'to' to the net (or NULL)
+ \return 1 OK, 0 not reachable
+static int
+find_shortest_path_coor(struct Map_info *Map,
+ double fx, double fy, double fz, double tx,
+ double ty, double tz, double fmax, double tmax,
+ int UseTtb, int tucfield,
+ double *costs, struct line_pnts *Points,
+ struct ilist *List, struct ilist *NodesList,
+ struct line_pnts *FPoints,
+ struct line_pnts *TPoints, double *fdist,
+ double *tdist)
+ int fnode[2], tnode[2]; /* nearest nodes, *node[1] is 0 if only one was found */
+ double fcosts[2], tcosts[2], cur_cst; /* costs to nearest nodes on the network */
+ int nfnodes, ntnodes, fline, tline;
+ static struct line_pnts *APoints, *SPoints, *fPoints[2], *tPoints[2];
+ static struct ilist *LList;
+ static int first = 1;
+ int reachable, shortcut;
+ int i, j, fn = 0, tn = 0;
+ /* from/to_point_node is set if from/to point projected to line
+ *falls exactly on node (shortcut -> fline == tline) */
+ int from_point_node = 0;
+ int to_point_node = 0;
+ G_debug(3, "Vect_net_shortest_path_coor()");
+ if (first) {
+ APoints = Vect_new_line_struct();
+ SPoints = Vect_new_line_struct();
+ fPoints[0] = Vect_new_line_struct();
+ fPoints[1] = Vect_new_line_struct();
+ tPoints[0] = Vect_new_line_struct();
+ tPoints[1] = Vect_new_line_struct();
+ LList = Vect_new_list();
+ first = 0;
+ /* Reset */
+ if (costs)
+ *costs = PORT_DOUBLE_MAX;
+ if (Points)
+ Vect_reset_line(Points);
+ if (fdist)
+ *fdist = 0;
+ if (tdist)
+ *tdist = 0;
+ if (List)
+ List->n_values = 0;
+ if (FPoints)
+ Vect_reset_line(FPoints);
+ if (TPoints)
+ Vect_reset_line(TPoints);
+ if (NodesList != NULL)
+ Vect_reset_list(NodesList);
+ /* Find nearest nodes */
+ fnode[0] = fnode[1] = tnode[0] = tnode[1] = 0;
+ nfnodes =
+ Vect_net_nearest_nodes(Map, fx, fy, fz, GV_FORWARD, fmax, &(fnode[0]),
+ &(fnode[1]), &fline, &(fcosts[0]),
+ &(fcosts[1]), fPoints[0], fPoints[1], fdist);
+ if (nfnodes == 0)
+ return 0;
+ if (nfnodes == 1 && fPoints[0]->n_points < 3) {
+ from_point_node = fnode[0];
+ ntnodes =
+ Vect_net_nearest_nodes(Map, tx, ty, tz, GV_BACKWARD, tmax,
+ &(tnode[0]), &(tnode[1]), &tline, &(tcosts[0]),
+ &(tcosts[1]), tPoints[0], tPoints[1], tdist);
+ if (ntnodes == 0)
+ return 0;
+ if (ntnodes == 1 && tPoints[0]->n_points < 3) {
+ to_point_node = tnode[0];
+ G_debug(3, "fline = %d tline = %d", fline, tline);
+ reachable = shortcut = 0;
+ cur_cst = PORT_DOUBLE_MAX;
+ /* It may happen, that 2 points are at the same line. */
+ /* TODO?: it could also happen that fline != tline but both points are on the same
+ * line if they fall on node but a different line was found. This case is correctly
+ * handled as normal non shortcut, but it could be added here. In that case
+ * NodesList collection must be changed */
+ if (fline == tline && (nfnodes > 1 || ntnodes > 1)) {
+ double len, flen, tlen, c, fseg, tseg;
+ double fcx, fcy, fcz, tcx, tcy, tcz;
+ Vect_read_line(Map, APoints, NULL, fline);
+ len = Vect_line_length(APoints);
+ /* distance along the line */
+ fseg =
+ Vect_line_distance(APoints, fx, fy, fz, 0, &fcx, &fcy, &fcz, NULL,
+ NULL, &flen);
+ tseg =
+ Vect_line_distance(APoints, tx, ty, tz, 0, &tcx, &tcy, &tcz, NULL,
+ NULL, &tlen);
+ Vect_reset_line(SPoints);
+ if (flen == tlen) {
+ cur_cst = 0;
+ reachable = shortcut = 1;
+ else if (flen < tlen) {
+ Vect_net_get_line_cost(Map, fline, GV_FORWARD, &c);
+ if (c >= 0) {
+ cur_cst = c * (tlen - flen) / len;
+ Vect_append_point(SPoints, fx, fy, fz);
+ Vect_append_point(SPoints, fcx, fcy, fcz);
+ for (i = fseg; i < tseg; i++)
+ Vect_append_point(SPoints, APoints->x[i], APoints->y[i],
+ APoints->z[i]);
+ Vect_append_point(SPoints, tcx, tcy, tcz);
+ Vect_append_point(SPoints, tx, ty, tz);
+ else { /* flen > tlen */
+ Vect_net_get_line_cost(Map, fline, GV_BACKWARD, &c);
+ if (c >= 0) {
+ cur_cst = c * (flen - tlen) / len;
+ for (i = fseg - 1; i >= tseg; i--)
+ APoints->z[i]);
+ /* Find the shortest variant from maximum 4 */
+ for (i = 0; i < nfnodes; i++) {
+ for (j = 0; j < ntnodes; j++) {
+ double ncst, cst;
+ int ret;
+ G_debug(3, "i = %d fnode = %d j = %d tnode = %d", i, fnode[i], j,
+ tnode[j]);
+ if (UseTtb)
+ ret =
+ Vect_net_ttb_shortest_path(Map, fnode[i], 0, tnode[j], 0,
+ tucfield, NULL, &ncst);
+ else
+ ret =
+ Vect_net_shortest_path(Map, fnode[i], tnode[j], NULL,
+ &ncst);
+ if (ret == -1)
+ continue; /* not reachable */
+ cst = fcosts[i] + ncst + tcosts[j];
+ if (reachable == 0 || cst < cur_cst) {
+ cur_cst = cst;
+ fn = i;
+ tn = j;
+ shortcut = 0;
+ reachable = 1;
+ G_debug(3, "reachable = %d shortcut = %d cur_cst = %f", reachable,
+ shortcut, cur_cst);
+ if (reachable) {
+ if (shortcut) {
+ if (Points)
+ Vect_append_points(Points, SPoints, GV_FORWARD);
+ if (NodesList) {
+ /* Check if from/to point projected to line falls on node and
+ *add it to the list */
+ if (from_point_node > 0)
+ Vect_list_append(NodesList, from_point_node);
+ if (to_point_node > 0)
+ Vect_list_append(NodesList, to_point_node);
+ else {
+ if (NodesList) {
+ /* it can happen that starting point falls on node but SP starts
+ * form the other node, add it in that case,
+ * similarly for to point below */
+ if (from_point_node > 0 && from_point_node != fnode[fn]) {
+ /* add starting net SP search node */
+ Vect_list_append(NodesList, fnode[fn]);
+ if (UseTtb)
+ Vect_net_ttb_shortest_path(Map, fnode[fn], 0, tnode[tn], 0,
+ tucfield, LList, NULL);
+ else
+ Vect_net_shortest_path(Map, fnode[fn], tnode[tn], LList,
+ NULL);
+ G_debug(3, "Number of lines %d", LList->n_values);
+ if (Points)
+ Vect_append_points(Points, fPoints[fn], GV_FORWARD);
+ if (FPoints)
+ Vect_append_points(FPoints, fPoints[fn], GV_FORWARD);
+ for (i = 0; i < LList->n_values; i++) {
+ int line;
+ line = LList->value[i];
+ G_debug(3, "i = %d line = %d", i, line);
+ if (Points) {
+ Vect_read_line(Map, APoints, NULL, abs(line));
+ if (line > 0)
+ Vect_append_points(Points, APoints, GV_FORWARD);
+ else
+ Vect_append_points(Points, APoints, GV_BACKWARD);
+ if (NodesList) {
+ int node, node1, node2;
+ Vect_get_line_nodes(Map, abs(line), &node1, &node2);
+ /* add the second node, the first of first segmet was alread added */
+ if (line > 0)
+ node = node2;
+ else
+ node = node1;
+ Vect_list_append(NodesList, node);
+ if (List)
+ if (Points)
+ Vect_append_points(Points, tPoints[tn], GV_FORWARD);
+ if (TPoints)
+ Vect_append_points(TPoints, tPoints[tn], GV_FORWARD);
+ if (NodesList) {
+ if (to_point_node > 0 && to_point_node != tnode[tn]) {
+ if (costs)
+ *costs = cur_cst;
+ return reachable;
+int
+Vect_net_shortest_path_coor(struct Map_info *Map,
+ double *tdist)
+ return find_shortest_path_coor(Map, fx, fy, fz, tx, ty, tz, fmax, tmax, 0,
+ 0, costs, Points, List, NodesList,
+ FPoints, TPoints, fdist, tdist);
+ \brief Find shortest path on network with turntable between 2 points given by coordinates.
+int
+Vect_net_ttb_shortest_path_coor(struct Map_info *Map,
+ double tmax, int tucfield,
+ double *tdist)
+ 1, tucfield, costs, Points, List,
+ NodesList, FPoints, TPoints, fdist, tdist);
Copied: grass/trunk/lib/vector/Vlib/net_build.c (from rev 57918, grass/trunk/lib/vector/Vlib/net.c)
--- grass/trunk/lib/vector/Vlib/net_build.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/net_build.c 2014-04-02 21:23:41 UTC (rev 59562)
@@ -0,0 +1,1073 @@
+ * \brief Vector library - releated fns for vector network building
+ \brief Build network graph with turntable.
+ Internal format for edge costs is integer, costs are multiplied
+ before conversion to int by 1000 and for lenghts LL without geo flag by 1000000.
+ The same multiplication factor is used for nodes.
+ Costs in database column may be 'integer' or 'double precision' number >= 0
+ or -1 for infinity i.e. arc or node is closed and cannot be traversed
+ If record in table is not found for arcs, costs for arc are set to 0.
+ If record in table is not found for node, costs for node are set to 0.
+ \param ltype line type for arcs
+ \param afield arc costs field (if 0, use length)
+ \param nfield node costs field (if 0, do not use node costs)
+ \param tfield field where turntable is attached
+ \param afcol column with forward costs for arc
+ \param abcol column with backward costs for arc (if NULL, back costs = forward costs),
+ \param ncol column with costs for nodes (if NULL, do not use node costs),
+ \param geo use geodesic calculation for length (LL),
+ \param algorithm not used (in future code for algorithm)
+ \return 0 on success, 1 on error
+int
+Vect_net_ttb_build_graph(struct Map_info *Map,
+ int ltype,
+ int afield,
+ int nfield,
+ int tfield,
+ int tucfield,
+ const char *afcol,
+ const char *abcol,
+ const char *ncol, int geo, int algorithm)
+ /* TODO very long function, split into smaller ones */
+ int i, j, from, to, line, nlines, nnodes, ret, type, cat, skipped, cfound;
+ struct line_pnts *Points;
+ double dcost, bdcost, ll;
+ int cost, bcost;
+ dglGraph_s *gr;
+ dglInt32_t opaqueset[16] =
+ { 360000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+ struct field_info *Fi;
+ dbDriver *driver = NULL;
+ dbDriver *ttbdriver = NULL;
+ dbHandle handle;
+ dbString stmt;
+ dbColumn *Column;
+ dbCatValArray fvarr, bvarr;
+ int fctype = 0, bctype = 0, nrec, nturns;
+ int ln_cat, nnode_lns, i_line, line_id, i_virt_edge;
+ struct line_cats *ln_Cats;
+ double x, y, z;
+ struct boxlist *List;
+ dglInt32_t dgl_cost = cost;
+ /*TODO attributes of turntable shoud be stored in one place */
+ const char *tcols[] = { "cat", "ln_from", "ln_to", "cost", "isec", NULL
+ dbCatValArray tvarrs[5] = { };
+ int tctype[5] = { 0 };
+ int tucfield_idx;
+ int t, f;
+ int node_pt_id, turn_cat, tucfound;
+ int isec;
+ /* TODO int costs -> double (waiting for dglib) */
+ G_debug(1, "Vect_net_ttb_build_graph(): "
+ "ltype = %d, afield = %d, nfield = %d, tfield = %d, tucfield = %d ",
+ ltype, afield, nfield, tfield, tucfield);
+ G_debug(1, " afcol = %s, abcol = %s, ncol = %s", afcol, abcol, ncol);
+ G_message(_("Building graph..."));
+ Map->dgraph.line_type = ltype;
+ ll = 0;
+ if (G_projection() == 3)
+ ll = 1; /* LL */
+ if (afcol == NULL && ll && !geo)
+ Map->dgraph.cost_multip = 1000000;
+ else
+ Map->dgraph.cost_multip = 1000;
+ nlines = Vect_get_num_lines(Map);
+ nnodes = Vect_get_num_nodes(Map);
+ gr = &(Map->dgraph.graph_s);
+ /* Allocate space for costs, later replace by functions reading costs from graph */
+ Map->dgraph.edge_fcosts =
+ (double *)G_malloc((nlines + 1) * sizeof(double));
+ Map->dgraph.edge_bcosts =
+ Map->dgraph.node_costs =
+ (double *)G_malloc((nnodes + 1) * sizeof(double));
+ /* Set to -1 initially */
+ for (i = 1; i <= nlines; i++) {
+ Map->dgraph.edge_fcosts[i] = -1; /* forward */
+ Map->dgraph.edge_bcosts[i] = -1; /* backward */
+ for (i = 1; i <= nnodes; i++) {
+ Map->dgraph.node_costs[i] = 0;
+ dglInitialize(gr, (dglByte_t) 1, sizeof(dglInt32_t), (dglInt32_t) 0,
+ opaqueset);
+ if (gr == NULL)
+ G_fatal_error(_("Unable to build network graph"));
+ db_init_handle(&handle);
+ db_init_string(&stmt);
+ if (abcol != NULL && afcol == NULL)
+ G_fatal_error(_("Forward costs column not specified"));
+ /* --- Add arcs --- */
+ /* Open db connection */
+ /* Get field info */
+ if (tfield < 1)
+ G_fatal_error(_("Turntable field < 1"));
+ Fi = Vect_get_field(Map, tfield);
+ if (Fi == NULL)
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ tfield);
+ /* Open database */
+ ttbdriver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (ttbdriver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ i = 0;
+ while (tcols[i]) {
+ /* Load costs to array */
+ if (db_get_column(ttbdriver, Fi->table, tcols[i], &Column) != DB_OK)
+ G_fatal_error(_("Turntable column <%s> not found in table <%s>"),
+ tcols[i], Fi->table);
+ tctype[i] = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if ((tctype[i] == DB_C_TYPE_INT || tctype[i] == DB_C_TYPE_DOUBLE) &&
+ !strcmp(tcols[i], "cost")) ;
+ else if (tctype[i] == DB_C_TYPE_INT) ;
+ else
+ G_fatal_error(_
+ ("Data type of column <%s> not supported (must be numeric)"),
+ tcols[i]);
+ db_CatValArray_init(&tvarrs[i]);
+ nturns =
+ db_select_CatValArray(ttbdriver, Fi->table, Fi->key, tcols[i],
+ NULL, &tvarrs[i]);
+ ++i;
+ G_debug(1, "forward costs: nrec = %d", nturns);
+ /* Set node attributes */
+ G_message("Register nodes");
+ if (ncol != NULL) {
+ G_debug(2, "Set nodes' costs");
+ if (nfield < 1)
+ G_fatal_error("Node field < 1");
+ G_message(_("Setting node costs..."));
+ Fi = Vect_get_field(Map, nfield);
+ if (Fi == NULL)
+ nfield);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (driver == NULL)
+ if (db_get_column(driver, Fi->table, ncol, &Column) != DB_OK)
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ ncol, Fi->table);
+ fctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if (fctype != DB_C_TYPE_INT && fctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_
+ ncol);
+ db_CatValArray_init(&fvarr);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, ncol, NULL,
+ &fvarr);
+ G_debug(1, "node costs: nrec = %d", nrec);
+ List = Vect_new_boxlist(0);
+ ln_Cats = Vect_new_cats_struct();
+ G_message("Building turns graph...");
+ i_virt_edge = -1;
+ /* TODO: what happens if we set attributes of non existing node (skipped lines,
+ * nodes without lines) */
+ Vect_get_node_coor(Map, i, &x, &y, &z);
+ Vect_select_lines_by_box(Map, &box, GV_POINT, List);
+ G_debug(2, " node = %d nlines = %d", i, List->n_values);
+ cfound = 0;
+ dcost = 0;
+ tucfound = 0;
+ for (j = 0; j < List->n_values; j++) {
+ line = List->id[j];
+ G_debug(2, " line (%d) = %d", j, line);
+ continue;
+ /* get node column costs */
+ if (ncol != NULL && !cfound && Vect_cat_get(Cats, nfield, &cat)) { /* point with category of field found */
+ /* Set costs */
+ if (fctype == DB_C_TYPE_INT) {
+ ret = db_CatValArray_get_value_int(&fvarr, cat, &cost);
+ dcost = cost;
+ else { /* DB_C_TYPE_DOUBLE */
+ ret =
+ db_CatValArray_get_value_double(&fvarr, cat, &dcost);
+ if (ret != DB_OK) {
+ G_warning(_
+ ("Database record for node %d (cat = %d) not found "
+ "(cost set to 0)"), i, cat);
+ cfound = 1;
+ Map->dgraph.node_costs[i] = dcost;
+ /* add virtual nodes and lines, which represents the intersections
+ there are added two nodes for every intersection, which are linked
+ with the nodes (edges in primal graph).
+ the positive node - when we are going from the intersection
+ the negative node - when we are going to the intersection
+ TODO There are more possible approaches in virtual nodes management.
+ We can also add and remove them dynamically as they are needed
+ for analysis when Vect_net_ttb_shortest_path is called
+ (problem of flattening graph).
+ Currently this static solution was chosen, because it cost
+ time only when graph is build. However it costs more memory space.
+ For Dijkstra algorithm this expansion should not be serious problem
+ because we can only get into positive node or go from the negative
+ node.
+ ret = Vect_cat_get(Cats, tucfield, &cat);
+ if (!tucfound && ret) { /* point with category of field found */
+ /* find lines which belongs to the intersection */
+ nnode_lns = Vect_get_node_n_lines(Map, i);
+ for (i_line = 0; i_line < nnode_lns; i_line++) {
+ line_id = Vect_get_node_line(Map, i, i_line);
+ Vect_read_line(Map, NULL, ln_Cats, abs(line_id));
+ Vect_cat_get(ln_Cats, tucfield, &ln_cat);
+ if (line_id < 0)
+ ln_cat *= -1;
+ f = cat * 2;
+ if (ln_cat < 0)
+ t = ln_cat * -2 + 1;
+ else
+ t = ln_cat * 2;
+ G_debug(5,
+ "Add arc %d for virtual node from %d to %d cost = %d",
+ i_virt_edge, f, t, 0);
+ /* positive, start virtual node */
+ ret = dglAddEdge(gr, (dglInt32_t) f, (dglInt32_t) t,
+ (dglInt32_t) 0,
+ (dglInt32_t) (i_virt_edge));
+ if (ret < 0)
+ G_fatal_error(_
+ ("Cannot add network arc for virtual node connection."));
+ t = cat * 2 + 1;
+ i_virt_edge--;
+ if (-ln_cat < 0)
+ f = ln_cat * 2 + 1;
+ else
+ f = ln_cat * -2;
+ G_debug(5,
+ /* negative, destination virtual node */
+ (dglInt32_t) 0,
+ if (ret < 0)
+ G_fatal_error(_
+ i_virt_edge--;
+ tucfound++;
+ else if (ret)
+ tucfound++;
+ if (tucfound > 1)
+ G_warning(_
+ ("There exists more than one point of node <%d> with unique category field <%d>.\n"
+ "The unique categories layer is not valid therefore you will probably get incorrect results."),
+ tucfield, i);
+ if (ncol != NULL && !cfound)
+ G_debug(2,
+ "Category of field %d is not attached to any points in node %d"
+ "(costs set to 0)", nfield, i);
+ Vect_destroy_cats_struct(ln_Cats);
+ for (i = 1; i <= nturns; i++) {
+ /* TODO use cursors */
+ db_CatValArray_get_value_int(&tvarrs[0], i, &turn_cat);
+ db_CatValArray_get_value_int(&tvarrs[1], i, &from);
+ db_CatValArray_get_value_int(&tvarrs[2], i, &to);
+ db_CatValArray_get_value_int(&tvarrs[4], i, &isec);
+ dcost = 0.0;
+ /* TODO optimization do not do it for every turn in intersection again */
+ (Map, tucfield_idx, isec, GV_POINT, 0, &type,
+ &node_pt_id) == -1) {
+ G_warning(_
+ ("Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
+ "Cost for the intersection was set to 0.\n"
+ isec, tucfield);
+ else {
+ Vect_read_line(Map, Points, Cats, node_pt_id);
+ node_pt_id =
+ Vect_find_node(Map, *Points->x, *Points->y, *Points->z,
+ 0.0, WITHOUT_Z);
+ if (node_pt_id == 0) {
+ G_warning(_
+ ("Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
+ isec, tucfield);
+ else {
+ G_debug(2, " node = %d", node_pt_id);
+ dcost = Map->dgraph.node_costs[node_pt_id];
+ G_debug(2, "Set node's cost to %f", dcost);
+ if (dcost >= 0) {
+ /* Set costs from turntable */
+ if (tctype[3] == DB_C_TYPE_INT) {
+ ret = db_CatValArray_get_value_int(&tvarrs[3], i, &cost);
+ dcost = cost;
+ else /* DB_C_TYPE_DOUBLE */
+ ret = db_CatValArray_get_value_double(&tvarrs[3], i, &dcost);
+ G_warning(_
+ ("Database record for turn with cat = %d in not found. "
+ "(The turn was skipped."), i);
+ continue;
+ if (dcost >= 0) {
+ if (ncol != NULL)
+ cost =
+ (Map->dgraph.node_costs[node_pt_id] +
+ dcost) * (dglInt32_t) Map->dgraph.cost_multip;
+ else
+ cost = dcost * (dglInt32_t) Map->dgraph.cost_multip;
+ /* dglib does not like negative id's of nodes */
+ if (from < 0)
+ else
+ f = from * 2;
+ if (to < 0)
+ t = to * -2 + 1;
+ else
+ t = to * 2;
+ G_debug(5, "Add arc/turn %d for turn from %d to %d cost = %d",
+ turn_cat, f, t, cost);
+ (dglInt32_t) cost, (dglInt32_t) (turn_cat));
+ if (ret < 0)
+ G_fatal_error(_
+ ("Cannot add network arc representing turn."));
+ Vect_destroy_boxlist(List);
+ i = 0;
+ db_CatValArray_free(&tvarrs[i]);
+ ++i;
+ db_close_database_shutdown_driver(driver);
+ db_CatValArray_free(&fvarr);
+ if (afcol != NULL) {
+ if (afield < 1)
+ G_fatal_error(_("Arc field < 1"));
+ Fi = Vect_get_field(Map, afield);
+ if (Fi == NULL)
+ afield);
+ if (db_get_column(driver, Fi->table, afcol, &Column) != DB_OK)
+ afcol, Fi->table);
+ G_fatal_error(_
+ afcol);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, afcol, NULL,
+ &fvarr);
+ G_debug(1, "forward costs: nrec = %d", nrec);
+ if (abcol != NULL) {
+ if (db_get_column(driver, Fi->table, abcol, &Column) != DB_OK)
+ abcol, Fi->table);
+ bctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if (bctype != DB_C_TYPE_INT && bctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_
+ abcol);
+ db_CatValArray_init(&bvarr);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, abcol, NULL,
+ &bvarr);
+ G_debug(1, "backward costs: nrec = %d", nrec);
+ skipped = 0;
+ G_message(_("Registering arcs..."));
+ G_percent(i, nlines, 1); /* must be before any continue */
+ type = Vect_read_line(Map, Points, Cats, i);
+ if (!(type & ltype & (GV_LINE | GV_BOUNDARY)))
+ continue;
+ Vect_get_line_nodes(Map, i, &from, &to);
+ dcost = bdcost = 0;
+ cfound = Vect_cat_get(Cats, tucfield, &cat);
+ if (!cfound)
+ continue;
+ if (cfound > 1)
+ G_warning(_
+ ("Line with id <%d> has more unique categories defined in field <%d>.\n"
+ i, tucfield);
+ if (!(Vect_cat_get(Cats, afield, &cat))) {
+ G_debug(2,
+ "Category of field %d not attached to the line %d -> cost was set to 0",
+ afield, i);
+ skipped += 2; /* Both directions */
+ else {
+ dcost = cost;
+ ret =
+ G_warning(_("Database record for line %d (cat = %d, "
+ "forward/both direction(s)) not found "
+ "(cost was set to 0)"), i, cat);
+ if (bctype == DB_C_TYPE_INT) {
+ ret =
+ db_CatValArray_get_value_int(&bvarr, cat, &bcost);
+ bdcost = bcost;
+ ret =
+ db_CatValArray_get_value_double(&bvarr, cat,
+ &bdcost);
+ "backword direction) not found"
+ else
+ bdcost = dcost;
+ Vect_cat_get(Cats, tucfield, &cat);
+ else {
+ if (ll) {
+ if (geo)
+ dcost = Vect_line_geodesic_length(Points);
+ else
+ dcost = Vect_line_length(Points);
+ else
+ bdcost = dcost;
+ cost = (dglInt32_t) Map->dgraph.cost_multip * dcost;
+ dgl_cost = cost;
+ cat = cat * 2;
+ G_debug(5, "Setinng node %d cost: %d", cat, cost);
+ dglNodeSet_Attr(gr, dglGetNode(gr, (dglInt32_t) cat), &dgl_cost);
+ Map->dgraph.edge_fcosts[i] = dcost;
+ cost = (dglInt32_t) Map->dgraph.cost_multip * bdcost;
+ dgl_cost = cost;
+ ++cat;
+ Map->dgraph.edge_bcosts[i] = bdcost;
+ if (afcol != NULL && skipped > 0)
+ G_debug(2, "%d lines missing category of field %d skipped", skipped,
+ afield);
+ db_CatValArray_free(&bvarr);
+ db_close_database_shutdown_driver(ttbdriver);
+ Vect_destroy_line_struct(Points);
+ G_message(_("Flattening the graph..."));
+ ret = dglFlatten(gr);
+ if (ret < 0)
+ G_fatal_error(_("GngFlatten error"));
+ /* init SP cache */
+ /* disable to debug dglib cache */
+ dglInitializeSPCache(gr, &(Map->dgraph.spCache));
+ G_message(_("Graph was built"));
+ return 0;
+ \brief Build network graph.
+ If record in table is not found for arcs, arc is skip.
+int
+Vect_net_build_graph(struct Map_info *Map,
+ int ltype,
+ int afield,
+ int nfield,
+ /* TODO long function, split into smaller ones */
+ int dofw, dobw;
+ int cost, bcost;
+ dglGraph_s *gr;
+ dglInt32_t dgl_cost;
+ dbHandle handle;
+ dbString stmt;
+ dbColumn *Column;
+ int fctype = 0, bctype = 0, nrec;
+ G_debug(1, "Vect_net_build_graph(): ltype = %d, afield = %d, nfield = %d",
+ ltype, afield, nfield);
+ ll = 0;
+ ll = 1; /* LL */
+ else
+ if (ncol != NULL)
+ opaqueset);
+ else
+ dglInitialize(gr, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
+ opaqueset);
+ if (gr == NULL)
+ if (afield < 1)
+ if (Fi == NULL)
+ afield);
+ G_fatal_error(_
+ afcol);
+ nrec =
+ &fvarr);
+ G_fatal_error(_
+ abcol);
+ nrec =
+ &bvarr);
+ skipped = 0;
+ dofw = dobw = 1;
+ continue;
+ G_debug(2,
+ "Category of field %d not attached to the line %d -> line skipped",
+ afield, i);
+ continue;
+ else {
+ dcost = cost;
+ ret =
+ "(forward/both direction(s) of line skipped)"),
+ i, cat);
+ dofw = 0;
+ ret =
+ bdcost = bcost;
+ ret =
+ &bdcost);
+ "(direction of line skipped)"), i, cat);
+ dobw = 0;
+ else {
+ if (dofw)
+ bdcost = dcost;
+ else
+ dobw = 0;
+ else {
+ if (ll) {
+ if (geo)
+ else
+ else
+ bdcost = dcost;
+ if (dofw && dcost != -1) {
+ G_debug(5, "Add arc %d from %d to %d cost = %d", i, from, to,
+ cost);
+ ret =
+ dglAddEdge(gr, (dglInt32_t) from, (dglInt32_t) to,
+ (dglInt32_t) cost, (dglInt32_t) i);
+ if (ret < 0)
+ G_fatal_error("Cannot add network arc");
+ G_debug(5, "bdcost = %f edge_bcosts = %f", bdcost,
+ Map->dgraph.edge_bcosts[i]);
+ if (dobw && bdcost != -1) {
+ bcost = (dglInt32_t) Map->dgraph.cost_multip * bdcost;
+ G_debug(5, "Add arc %d from %d to %d bcost = %d", -i, to, from,
+ bcost);
+ ret =
+ dglAddEdge(gr, (dglInt32_t) to, (dglInt32_t) from,
+ (dglInt32_t) bcost, (dglInt32_t) - i);
+ if (ret < 0)
+ G_fatal_error(_("Cannot add network arc"));
+ afield);
+ G_debug(2, "Register nodes");
+ double x, y, z;
+ if (nfield < 1)
+ if (Fi == NULL)
+ nfield);
+ ncol, Fi->table);
+ G_fatal_error(_
+ ncol);
+ nrec =
+ &fvarr);
+ /* TODO: what happens if we set attributes of not existing node (skipped lines,
+ cfound = 0;
+ dcost = 0;
+ continue;
+ if (Vect_cat_get(Cats, nfield, &cat)) { /* point with category of field found */
+ /* Set costs */
+ ret =
+ db_CatValArray_get_value_int(&fvarr, cat, &cost);
+ dcost = cost;
+ ret =
+ &dcost);
+ G_warning(_
+ cfound = 1;
+ break;
+ if (!cfound) {
+ G_debug(2,
+ "Category of field %d not attached to any points in node %d"
+ if (dcost == -1) { /* closed */
+ cost = -1;
+ else {
+ dgl_cost = cost;
+ G_debug(3, "Set node's cost to %d", cost);
+ dglNodeSet_Attr(gr, dglGetNode(gr, (dglInt32_t) i), &dgl_cost);
+ if (ret < 0)
+ return 0;
