[GRASS-SVN] r59578 - grass-addons/grass6/vector/v.mkhexgrid
svn_grass at osgeo.org
Sat Apr 5 09:17:55 PDT 2014
Author: neteler
Date: 2014-04-05 09:17:55 -0700 (Sat, 05 Apr 2014)
New Revision: 59578
grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid
v.mkhexgrid Addon: fix v.clean call (trac #2245); fix non-required parameters
Modified: grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid
--- grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid 2014-04-05 09:35:03 UTC (rev 59577)
+++ grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid 2014-04-05 16:17:55 UTC (rev 59578)
@@ -55,7 +55,7 @@
#% answer: area
#% description: Method to calculate size
#% multiple: no
-#% required: yes
+#% required: no
#%end
#%option
#% key: sidelength
@@ -63,7 +63,7 @@
#% label: Side length
#% answer: 100.0
#% description: Size of side length in map units
-#% required: yes
+#% required: no
#%end
#%option
#% key: hexarea
@@ -71,7 +71,7 @@
#% label: Hexagon Area
#% answer: 200.0
#% description: Area of hexagon in map units
-#% required: yes
+#% required: no
#%end
import sys
@@ -275,8 +275,7 @@
return(-1)
grass.message('Cleaning and building topology')
try:
- r = grass.run_command('v.clean', flags='-q', input=tempname, \
- output=tname, type='point,line,boundary,centroid,area', tool='rmdupl')
+ r = grass.run_command('v.clean', input=tempname, output=tname, type='point,line,boundary,centroid,area', tool='rmdupl')
if r <> 0:
raise
except:
