[GRASS-SVN] r59582 - grass-addons/grass7/vector/v.neighborhoodmatrix
svn_grass at osgeo.org
Sat Apr 5 09:49:39 PDT 2014
Author: mlennert
Date: 2014-04-05 09:49:39 -0700 (Sat, 05 Apr 2014)
New Revision: 59582
grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
added some comments to make code more understandable
Modified: grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
--- grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2014-04-05 16:43:49 UTC (rev 59581)
+++ grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2014-04-05 16:49:39 UTC (rev 59582)
@@ -58,11 +58,13 @@
type='boundary', option='sides', layer=blayer, qlayer=player, quiet=True)
grass.run_command('g.remove', vect=tempmapname, quiet=True)
+ #put result into a list of integer pairs
temp_neighbors=[]
for line in vtodb_results.splitlines():
if line.split('|')[1]<>'-1' and line.split('|')[2]<>'-1':
temp_neighbors.append([int(line.split('|')[1]), int(line.split('|')[2])])
+ #uniqify the list of integer pairs
n = len(temp_neighbors)
t=list(temp_neighbors)
t.sort()
@@ -76,6 +78,7 @@
i += 1
neighbors=t[:lasti]
+ #if user wants bidirectional matrix, add the inversed pairs to the original
if bidirectional:
neighbors_reversed=[]
for pair in neighbors:
