[GRASS-SVN] r59611 - grass/trunk/raster/r.stream.distance
Sun Apr 6 08:18:58 PDT 2014
Author: madi
Date: 2014-04-06 08:18:58 -0700 (Sun, 06 Apr 2014)
New Revision: 59611
   grass/trunk/raster/r.stream.distance/main.c
removing word accumulation in description. The output is a distance map, in meters, not accumulation.
Modified: grass/trunk/raster/r.stream.distance/main.c
--- grass/trunk/raster/r.stream.distance/main.c	2014-04-06 14:48:52 UTC (rev 59610)
+++ grass/trunk/raster/r.stream.distance/main.c	2014-04-06 15:18:58 UTC (rev 59611)
@@ -4,12 +4,12 @@
  * MODULE:       r.stream.distance
  * AUTHOR(S):    Jarek Jasiewicz jarekj amu.edu.pl
- * PURPOSE:      Calculate distance and elevation over the streams and outlets
- *               according user's input data. The elevation and distance is calculated
- *               along watercourses
- *               It uses any stream map  and r.watershed or .stream.extract direction map.
- *               Stream input map shall contains streams or points outlets with or
- *               without unique categories
+ * PURPOSE:      Calculate distance to and elevation above streams and outlet
+ *               according to user's input data. The elevation and distance are calculated
+ *               along watercourses.
+ *               It uses any stream map and r.watershed or r.stream.extract direction map.
+ *               Stream network input map shall contains streams or points outlets with or
+ *               without unique categories.
  * COPYRIGHT:    (C) 2002,2009-2014 by the GRASS Development Team
@@ -78,7 +78,7 @@
     out_dist_opt = G_define_standard_option(G_OPT_R_OUTPUT);
     out_dist_opt->key = "distance";
     out_dist_opt->required = NO;
-    out_dist_opt->description = _("Name for output distance/accumulation raster map");
+    out_dist_opt->description = _("Name for output distance raster map");
     out_dist_opt->guisection = _("Output maps");
     out_diff_opt = G_define_standard_option(G_OPT_R_OUTPUT);
